H22 EF CRX sway bar fitment issues?
As the title says, I am wondering if anyone knows of any sway bar fitment issues with this swap. I was thinking of goign with a suspension techniques front and rear sway bar package.
Banned.
Re: H22 EF CRX sway bar fitment issues? (djnikko)
Aftermarket sway bars, are thicker and with that are a bit stronger also believe they use a polyurethane insert bushing as well...The weak point I think is the bracket that holds the bushing into place it's thin and is known to break...I don't for see any problems running the aftermarket sway bars...I have a h22 crx...
Re: H22 EF CRX sway bar fitment issues? (ExplicitSpeed360)
Thanks for the reply
I was going to go with the suspension techniques set below. Is it more for cornering? What difference did it make to your CRX?
http://cgi.ebay.com/ebaymotors...ZWDVW
Banned.
I haven't purchased a set yet...I will tho and make my own bracket make it thicker so it wont break...only suspension mods I run are my own 3 pt Front Upper Strut Bar, 4 pt Rear Upper and Rear Lower 2pt... AGX adjustable shocks on Skunk2 coilovers...
And your car handles good im guessing?
I hear of h22 CRX owners just runnng a front sway bar, is it not worth me forking out for both?
Please give me some pros/cons
Banned.
Re: H22 EF CRX sway bar fitment issues? (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">I just run the stock sway bars.. fitment of the h22 wont be an issue with the sway bars.</TD></TR></TABLE>
I also have run the stock sway bars...
Im fitting an energy suspension bush kit to my CRX it has the sway bar bushings to go on the stock sway bars so that should suffice for now. Have any of you done the same? If so have you run with stock bushings and P/U?
fireant
14
04-12-2006 11:43 AM
ShagginJet
08-27-2003 10:00 AM
