NEED HELP WITH IDLE PROBLEM!!!
Old Aug 24, 2006 | 12:06 PM
EvstarH22's Avatar
Default NEED HELP WITH IDLE PROBLEM!!!
Ok, I am about to go absolutly nuts. I am having an idle problem with my civic. I have an h22 in a 99-00. I just put on pullies, cam gears, and a flywheel. The car fluxuates its idle from around 500 or 600 rpms to 1000 to 1200 rpms and it just pulses as if i was pressing the gas on and off. Ive checked my vacuum and cant find a leak. Anyone that has any ideas would be greatly appreciated for I am close to dropping a 10 ton weight on my head as I would never do it to my car.
thanks
Old Aug 24, 2006 | 12:48 PM
ek_chris's Avatar
unplug the iacv see what happens. Is it an obd1 or obd2 motor?
Old Aug 24, 2006 | 06:31 PM
poison's Avatar
Default Re: NEED HELP WITH IDLE PROBLEM!!! (EvstarH22)
Any check engine light? Check the codes if so..
Other than that, with the engine running, but your hand over the throttle body, and it should stall. If it keeps running, you have a vacuum leak. I would grab some soapy water and spray midly around the area to see where the leak is coming from.
Edwin909
17
Apr 21, 2011 07:46 PM
EvstarH22
Aug 24, 2006 09:41 PM
jboogiebrown
Feb 18, 2006 02:35 AM
wolf3007
Mar 26, 2004 05:06 AM
0 0 0
30
Dec 18, 2002 06:25 PM
