ls to b18c
Old Sep 6, 2006 | 11:17 PM
SOHC_me's Avatar
Default ls to b18c
i have a ls integra, with the ls motor in it, i have a b18c block and head with all the internals in it, and the intake manifold, basicly i want to put it in my ls integra, i know i cant use the dizzy, but can i use the altonator and starter and such parts? What will i need to buy to be able to put it in?
Old Sep 8, 2006 | 11:09 AM
unknown0001's Avatar
Default Re: ls to b18c (SOHC_me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_me &raquo;</TD></TR><TR><TD CLASS="quote">i have a ls integra, with the ls motor in it, i have a b18c block and head with all the internals in it, and the intake manifold, basicly i want to put it in my ls integra, i know i cant use the dizzy, but can i use the altonator and starter and such parts? What will i need to buy to be able to put it in?</TD></TR></TABLE>
You can't use the LS dizzy, you will need to use the b18c distributor for it to run properly.
The alternator just needs to be the same OBD version as the car...so if your car is OBD 1, get an OBD1 alternator. If your putting in the same year b18c that your integra is, then the alternator should have the same clips.
1990-1991 integras were OBD 0
1992-1995 integras were OBD 1
1996-2000+ integras were OBD 2
so you need to get an alternator that matches your car year.
About the starter...the starter is only a positive and negative connection so you can use a starter from a 1990 integra in your 1999 gsr and vice versa. Starters are all the same...except for automatic and standard starters, which they are different
killa4lyfe
24
Jun 1, 2006 10:44 AM
meric0786
Sep 26, 2005 04:43 PM
RiceInjectedCivic
Nov 20, 2002 03:14 PM
g's integ
Jun 26, 2002 12:19 PM
