b20vtec into a del sol
Old Sep 9, 2006 | 05:50 AM
SOLvtec's Avatar
Default b20vtec into a del sol
like the title says, i am putting a b20 into a del sol
i was just wondering if i would run into any problems (ie - mounts)
i was told that it will just go right in and match up pretty well
i was also wondering about the wiring and if that would all match up
thanks for the help in advance
Old Sep 10, 2006 | 03:56 PM
SOLvtec's Avatar
Default Re: b20vtec into a del sol (SOLvtec)
anyone????????
Old Sep 11, 2006 | 12:53 PM
unknown0001's Avatar
what year del sol? did it come with the b16 swap factory?
if it's a b-series in the del sol then the mounts will work on your b20
but if the del sol came with the d-series engine then you will need all the proper b-series mounts.
Wiring will not be a problem
Old Sep 11, 2006 | 02:14 PM
splashystrwbery's Avatar
hi i have a sol, and was thinking about doing a b20 block with my b16 head... um
as your know the CRV wasnt exactly built for power.. or speed..
it is not very strong, so taking the precautions and makin git stronger to withstand future mods.. turbo.ect.. would be my advice.. and although this sounds cool..
with the money you will spend DOING IT RIGHT you might be better off with a gsr, or H they were built to handle stress.. just some thoughts from a fellower soler
Old Sep 11, 2006 | 02:50 PM
Default Re: b20vtec into a del sol (splashystrwbery)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splashystrwbery &raquo;</TD></TR><TR><TD CLASS="quote">hi i have a sol, and was thinking about doing a b20 block with my b16 head... um
with the money you will spend DOING IT RIGHT you might be better off with a gsr, or H they were built to handle stress.. just some thoughts from a fellower soler</TD></TR></TABLE>
FYI..B20 engines have weak sleeves but when going turbo. Staying with a 180-240whp setup the stock sleeves will do just fine
yea but for the price of the GSR/ITR swap, he can take the B20, buy the vtec head, golden eagle conversion kit, new high compression pistons, lumpy cams, valve springs/retainers, transmission and a method of tunning.
Once he has all that, he will be making more HP and definetly much more TQ then a GSR/ITR engine so it would be money's worth.
Old Sep 12, 2006 | 07:41 AM
SOLvtec's Avatar
Default Re: b20vtec into a del sol (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">what year del sol? did it come with the b16 swap factory?
Wiring will not be a problem </TD></TR></TABLE>
94si
came with d16z6
and i believe that you only have to buy one of the mounts
i think it is one of the trans mounts..
thanks for the help
Old Sep 12, 2006 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOLvtec &raquo;</TD></TR><TR><TD CLASS="quote">
94si
came with d16z6
thanks for the help </TD></TR></TABLE>
one of the mounts? your wrong
you will need to buy the following from a 94+ teg:
-driver side engine bracket
-rear subframe bracked
the factory D-series ones will not work
94delsol6428
20
Oct 2, 2012 07:10 PM
s2kds
14
Jan 23, 2004 02:58 PM
mongrill
Nov 27, 2003 11:41 AM
Soon_2b_evil
19
Jun 29, 2003 01:52 PM
Honda_Fanatic
Jun 29, 2002 07:06 PM
