front LSD for a AWD CRV 5spd?
Is theare a front LSD avalable for the 1999 CRV AWD 5sp, or could a different (aftermarket LSD) honda differential fit?
Go Tigers!
Re: front LSD for a AWD CRV 5spd? (89ED8)
good luck, the bearings are prob the same size, if that helps. check to see how many LHT bolts the ring gear requires. what final drive is in the awd crv 5speed trans?
Re: (iBkickinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBkickinit »</TD></TR><TR><TD CLASS="quote">Check on Honda AUtomotive parts, and verify that the bearings are the same size.</TD></TR></TABLE>
couldn't find any info
Call Quaife 949-240-4000
http://www.quaifeamerica.com
They will know. I bought my diff and some other stuff there. There good guys.
Re: front LSD for a AWD CRV 5spd? (88ED8)
91005-PG2-004 BEARING, TAPER (40X75X21) (KOYO) MT DIFFERENTIAL
91006-PX5-008 BEARING, TAPER (40X68X22) (NTN) MT DIFFERENTIAL
29011-P1C-000 GEAR, TRANSFER DRIVE MT DIFFERENTIAL
41100-PBX-000 DIFFERENTIAL
1999, 41100pbx000, 5spd, 91006px5004, addfrontlsdawd, awd, crv, diff, front, limited, lsd, quaife, series, slip, tranny
