jdm B16a(2), map sensor????
Old Aug 20, 2006 | 04:32 AM
NathanielH's Avatar
Default jdm B16a(2), map sensor????
Hey, whats up guys,
I am in the process of finishing up my swap (b16a sir2 into my hatch). I was tryin to find the map sensor on the intake manifold, and I cant find it, anywhere. Its not on the throttle body, its not on the top or the bottom of it, i just dont see it. I dont see any bolt holes for it or anything either. Dose anyone know where it should be? what i did for now was just run a vaccum line off of the throttle body and zip tied my old map sensor off of my d15b8 to a fuel line. can someone help me? please ignore anyt typos, as i didnt get to bed till 3am this morning
Old Aug 21, 2006 | 05:14 AM
NathanielH's Avatar
Default Re: jdm B16a(2), map sensor???? (NathanielH)
has anyone else run into this before?
Old Aug 21, 2006 | 03:52 PM
NathanielH's Avatar
oh come on, i know somone else has a jdm b16a sir II swap with the same set up.
Old Aug 21, 2006 | 04:18 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NathanielH &raquo;</TD></TR><TR><TD CLASS="quote">Hey, whats up guys,
I am in the process of finishing up my swap (b16a sir2 into my hatch). I was tryin to find the map sensor on the intake manifold, and I cant find it, anywhere. Its not on the throttle body, its not on the top or the bottom of it, i just dont see it. I dont see any bolt holes for it or anything either. Dose anyone know where it should be? what i did for now was just run a vaccum line off of the throttle body and zip tied my old map sensor off of my d15b8 to a fuel line. can someone help me? please ignore anyt typos, as i didnt get to bed till 3am this morning </TD></TR></TABLE>
You did the right thing.
The picture below shows the throttle body front. The top sensor is the MAP sensor. That's how all honda throttle bodies that have MAP sensors are located there.
If your TB didnt have one or dosen't have a hole for it, then you could have gotten the b16a1 throttle body.
How you hooked it up is the proper way. Civics that don't have the MAP sensor mounted on the TB have it hooked up the same way you did
Old Aug 21, 2006 | 06:49 PM
NathanielH's Avatar
Default Re: jdm B16a(2), map sensor???? (Mr.RHTuner)
alright, thanks alot for the info bro
Old Aug 23, 2006 | 01:07 PM
1fastVX's Avatar
Some of the earlier b16a sir II motors have the MAP sensor on the firewall.
John
JDM_EK4_Coupe
Apr 20, 2007 06:40 AM
wcknockoutk86
Jul 6, 2005 05:18 PM
zer0.
Jun 4, 2004 10:39 AM
mongoliandonuts
Feb 29, 2004 07:26 AM
zerofighter777
May 27, 2002 01:43 PM
