Problems wiring dissy and coil on ek obd1 h22 swap
ok, im down to the last part of my swap before I can fire it up, and im stumped on how to wire the obd1 h22 dissy and external coil to my obd2a car. I know its something that will click in my head once someone tells me how. I followed this chart and everything from the plugs wired up perfect.
Now the problem is I dont know how to wire the external up. Im using an msd external coil. Then also thiers an extra wire on the h22 dissy thats blue and orange that I have no idea what up with it. The chart says nothing about an orange/blue wire and I have no more wires on the civic dissy plug even for it. Please help with any info. Im stumped and car less
Re: Problems wiring dissy and coil on ek obd1 h22 swap (94fourdoor)
why post "hey search". Thats ****** retarded. If you don't have an answer to my question, I don't need a smart *** response.
Re: Problems wiring dissy and coil on ek obd1 h22 swap (deucedeuceEK)
the extra wire u have... is it blue/orange or orange/blue?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">
some have asked about how to wire an obd 2 ext coil dizzy to use with a obd1 p13 in an EK
so here ya go. ----------------
for a 99 civic ex, putting in a h22a4 w/ the factory disitributor (obd2 ext. coil), using a obd2-->1 conversion harness and obd1 p13, USE the civic engine harness and modify it to fit the H22.
99 civic ex distributor wires (labels & colors):
<FONT COLOR="red">TDC (top dead center) - ORN/BLU(dizzy color) or GRN(egnine harness color)</FONT>
TDCM (ground) - WHT/BLU(dizzy color) or RED(egnine harness color)
CKP (crankshaft position) - LT BLUE or BLUE/GRN(dizzy colors) or BLU(engine harness color)
CKPM (ground) - LT BLUE/YEL or WHT(dizzy colors) or WHT(engine harness color)
CYP (cylinder position) - ORN(dizzy color) or YEL(engine harness color)
CYPM (ground) - WHT or BLK(dizzy colors) or BLK(engine harness color)
ICM (ignition control module) - YEL/GRN
Power wire - BLK/YEL
Tachometer - BLU
2000 prelude distributor, ext coil, and CKP/TDC sensor wires (labels & colors)
here is also the ecu locations for obd2 for each of these wires.
4 wires go to CKP/TDC sensor ontop of the crankshaft:
<FONT COLOR="red">C3 - TDC - GRN</FONT>
C13 - TDCM - RED
C2 - CKP - BLU
C12 - CKPM - WHT
distributor:
C4 - CYP - YEL
C14 - CYPM - BLK
A20 - ICM - YEL/GRN
tachometer - BLU(should be on 2 prong plug)
EXTERNAL IGNITION COIL will have 3 wires coming out of it. 2 connect to the distributor and 1 goes to a power source.:
GRN@coil, GRN@dizzy - connects coil to dizzy
YEL@coil, BLK/YEL@dizzy- connects coil to dizzy (should be a LARGE wire)
BLK/YEL - connects coil to power source.
the orange/blue wire is the TDC wire.
as for your msd external coil, does it have any diagrams or instructions that came with it?
here are a few pix i have of what the dizzy wires should look like:
close up top view: (sorry bad pic)
close up bottom view:
do you see the orange/blue wire? 2nd from the right on the big clip. it matches up to the green wire on the bottom.
hope that helps some...
Modified by hondaZvic at 4:17 PM 9/16/2006
Tachometer - BLU
C13 - TDCM - RED
C2 - CKP - BLU
C12 - CKPM - WHT
distributor:
C4 - CYP - YEL
C14 - CYPM - BLK
A20 - ICM - YEL/GRN
nickwilmot
01-06-2004 05:43 AM
