View Full Version : Suspension & Brakes
- Drivers side rear drum not bleeding.....why not???
- AMR still worth buying from?
- No washer on axle?
- Looking to find the right rotors and pads
- creak when coming to a slow stop or starting
- Front Caster Angle Different Left and Right
- dragging rear brake 1991 honda prelude
- Eg hatch stiffer same eight springs
- sound in suspension
- 96 Honda Accord inner tie rod end
- Spoon twinblocks with mg rotors
- honda civic 77
- 700$-1000$ budget coilover?
- Stiffer rear springs or bigger swaybar?
- Ebay coilovers?
- 2016 Civic EX Salvage car: Caster ~1 Degree Off
- Rear drums to disc
- Long-Lasting Fix for Squeaking Polyurethane Suspension Bushings
- Moog upper control arm with ball joint or just replace ball joint?
- Has anyone used ASR rear lca's
- Changing rear geometry
- 1997 Honda Odyssey pulling hard right
- Brake pedal pulsating - ABS bleed needed?
- Identifying rear wheel hub/bearing sizes
- Honda accord 2009 sticky rear brake
- Rotor keeps getting ruined. Replaced rotor+pads already?
- One front brake running much hotter than the other?
- DC5 Steering Arm Replacement
- LOOSE BALL JOINTS
- Need help!
- Loose Wheel bearing
- what matches with 17cl front brakes for thr rear?
- Any experience with these coilovers?
- BBK - front vs rear bias
- 2012 Honda Accord wants going forward before brake stop
- Still have Clunking noise after replacing front suspension!
- Sol brakes on integra trailing arms
- Coil overs or air suspension
- 1990 Civic Brakes randomly go to the floor
- 9th gen accord rear brake upgrade
- Zero camber, good or bad?
- upside down RTA bushing okay? HELP!
- Will most suspension parts work on either LHD or RHD?
- Good coilovers for Del Sol
- Front brakes locking up
- Broken trailing arm weld nut
- KW Variant 3 Questions (Ek Civic)
- Coil Over Question
- ABS Gurus, Can I pick your brain on an ABS Light problem after upgrades?
- 2008 Honda Civic Suspension replacement
- Stripped rear Camber hole... what to do?
- Brakes rock hard in -20c and below
- Ball joint stud too narrow for FLCA?
- The right way to Clock RTA bushings?
- rear brakes upgrade options for 9gen accord coupe
- Rear Spring Rates vs. Rear Sway Bar Calculation?
- Better choice than Tein Street Flex?
- 9CLP14S on Ek4. Direct fit?
- Civic springs on a accord?
- Where are all the good deals on Ground Control?
- Are these skunk2 lca fake?
- Vibrating sound coming from front right near top suspension mounts
- Suspension parts question?
- Both right wheels have positive camber - 2007 Civic Si Sedan
- Inner tie rod torque spec 95 accord
- Same ABS error after replacing sensor. Confused
- Can you identify this part??? Rear Suspension Component Damaged, hit curb
- 07 Odyssey
- Creak / Pop from Front Suspension
- What progressive springs work with ground controls?
- Dumb question - 8" vs 9" springs, same spring rate...
- Uncontrollable Torque Steer. HELP!!!
- BBK theoretical problems
- Need advise on lowering springs/coilovers-'01 Prelude-BB6
- eg chassis/suspension setup
- What struts should I buy?
- Entire Car (96 Integra) Vibrates & shakes violently at idle rpm speed
- 1996 accord dx... Weird suspension wobble
- Which coilovers for under $600?
- Toe rod hack job
- 94 Integra ABS DTC-1 - pump motor over-run
- Coilvers
- brakes for a 2011 civic sedan
- coilover ?
- Skunk 2 LCA bushings EG
- Anyone tried Moog GSR end links?
- Upgrading brake pads Civic ES8 2003
- Sk2 Pro-C discontinued?
- Same Spring Rate on Both Axles?
- 1999 honda civic ex sedan manual
- 03 RSX seized rear toe
- wheel bearing for 2005 Honda pilot
- 2007 Coupe Suspension
- Foam on coilovers
- Foam on top hats of coilovers?
- EK Rear disc conversion w/soft peddle
- Vibration After Tire Rotation
- Koni/GC Ride Height
- Break issue
- Are strut bars worth it?
- Few coilover questions for EM2
- Steering column rattle after alignment
- Parking brake
- 2017 Accord Sedan Sports, need advice on Coilovers or drop springs
- 99 Civic LX Sedan Rear Swaybar
- Koni RACE shocks on CRX
- Wheels too wide which causes my car to go right?
- Caster left 2.2, right 1.6.. Nothing to worry about?
- 98-02 stock Accord struts/ 97-01 CRv
- 96-00 civic suspension system
- Recommended changes to suspension after air supsension
- ITR 4x114.3 Conversion to Prelude Brakes
- A little help?
- Got An Alignment - Still Pulls Right
- brake line
- Brake Line Burst While Driving
- Cam bolt kit
- Tokico Shock Adjuster Screw - where can I find them?
- hardrace vs energy suspension
- rear sway bar 99ek
- 99-00 SI Strut Forks clarification
- Isolated Suspension Noise
- What are good brake upgrades?
- Buddy Club vs. Brian Crower Coilover suspension systems
- Koni red's with H&r race??
- Lowered car, keep blowing axles / ripping cv boots.
- Rear camber adjustment
- Brake Clearance/Fitment with Wilwood 6 Pot
- What suspension setup recommended for Chumpcar - 1999 Honda Accord 4 DR
- 97 crv rear bushings
- 97 Accord SE brake upgrade
- Pulsating Brakes 2007 Honda Fit Sport
- Which coilover spring with KYB GR-2 on CRX
- wheel bearing or something else?
- 93 Civic Hb with Koni/GC issue running 235/50/15
- Camber Kit v.s. Control Arms
- I want change bigr rotors on my 2016 accod sport with 19in wheels
- Swapped Civic...which axles do I need?
- Advics problem?
- Brake issue
- subframe question
- Need help identifying suspension
- Civic 6th Gen... Lower Control Arms
- Jumped / Slipped Off Curb - Where to Look?
- OEM quality caliper repair kits for Accord
- coilovers-need tips on pushing sleeve into top hat!
- Best rear brakes for 99 ex 1.6
- Steering Feel on Lowered Car?
- database for bushing specs?
- Suspension build for EK hatch
- how do you find loose suspension parts?
- Probably dumb question about the brake booster
- Schley Lower Ball Joint Air Hammer Tool
- Wilwood adjustable brake bias on honda
- air bags with skunk2
- NSX calipers on ITR
- Swapping Shocks
- rear sway bar questions
- K1 Street Vs. Sk2 Pro-C ?
- coilover struts fro progressive springs
- Wheel alignment
- Why are the UCA bushings joined with that strap?
- Rear Toe mount issue! Any suggestions?
- Question regarding rear trailing arm bushing installation.
- rubber bushing brands which ones are good?
- 89 Civic Si, Loose front spring seat fitting for Koni STR.T and H&R Sport springs
- First time drag racing
- Suspension Suggestions Needed
- Bad Lower Ball Joint - Need Opinions Fast!
- New rotor & break pad change causing left side wheels noisy and heating
- 2003 Honda Civic Wheel Bearing issue
- Ideal ride height for street/ track ?
- Honda Civic EP2
- spring rates for 200 mph+
- EE8 Front Suspension vs ED9
- Custom control arms, how much should I plan to pay?
- K-Tuned K1 Coils on my Civic EM1
- Suspension Setup Help
- Can Someone Identify these Coilovers?
- Swap 82 Honda Prelude drums for disc
- honda civic brakes
- BC or Megan Racing coilovers - 2000 odyssey
- New Slotted Rotors, labelled L and R - installed on the wrong side. Worth switching?
- Need help rear end sways
- 2012 Acura MDX left rear camber
- ska18-aub00 on an eg?
- Shocks for a 2012 Honda FIT RS (Japanese)
- Reliable camber ball joints?
- Honda Accord Front Brake Sound
- Integra DC2 Honda Access Suspension
- Civic ek hatch 97
- springs
- how to know front disk need to replace?
- Skunk2 springs/struts on '98 LX Sedan = harsh ride?
- Rattling Noise
- Poor Brake Feedback
- Ground Control Sleeve Removal
- Sticking Calipers
- Beat brake upgrades
- Do I have a bad Proportioning Valve?
- 350Z brembo rotors question
- Camber vs Toe Alignment/Adjustment
- rsx problems
- Alignment Specs - Help!
- Where to permanently weld toe nut for 3 degree or 4 degree adjustable toe kit?
- heim joints: to lube or not to lube
- Rebuilding EK coilovers
- Locked Brakes
- 2007 Honda Odyssey rear suspension
- spring rates
- Wilwood brakes dont line up!!
- Wilwood 4 piston brakes not aligned right
- ground control vs ktuned coils
- Daily driver del sol
- Subframe brace quality and testing
- 5th Gen Prelude Adjustable Camber Kits
- Suggestions Needed: 2017 Civic HB Sport Coilover Spring Rate for Daily Use
- Adjustable Control Arms
- EF rear trailing arms
- rear noise
- RSX strut to CV clearance question.
- 93 EG complete Suspension & wheel set up help
- Sway Bar Help.
- Reclocking bushings question.
- Wilwood 5/8 master cylinder braking power sucks
- Acura front sway bar
- Centered rack n pinon but tie rods are funky
- 500hp eg6 suspension recommendations!?
- 98 civic rear trailing arm rubs body
- Strange noise when hitting a bump...
- Camber Maxed Out
- 5 Suspension Mods That Can Ruin Your Car
- sway bar compatibilty
- wheel bearings
- wheel bearings
- Replacing rusty front hard brake lines
- Wilwood 7/8 single port soft pedal
- Civic Tein H-tech recommendation Struts?
- Springs or coilovers for my Acura rsx 2005
- Best EG coilovers for daily/grip
- Honda Accord 2007 alignment warning light
- Problam with my Eibach ProKit(?)
- 30/30 Brake prop valve leak question
- Rear Drum Brakes?
- OEM or Moog Front Lower Control Arms?
- What fits with 15” 949 wheels and 91 EX knuckles
- GC coilovers came with 4 o-rings, what are they for?
- 94 Accord R-O-H Conversion... Fail.
- PROGRESS COILOVERS - Is it still in the market?
