PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99
  1. Tokico RAK vs Omnipower full coilover
  2. Eibach Sportlines or H&R Race?
  3. Suspension installation for Accord 96 help?
  4. questions about alignment specs
  5. Eibach Pro-Kits or Sportlines???
  6. Do Springs Wear Out?
  7. need swaybar options for EJ6
  8. suspension setup - please help
  9. Nuespeed front strut bar
  10. ot: Eibach Factory Tour by Tunerzine
  11. EF "sway" bars
  12. suspension gurus, need your help??
  13. 93 Accord shocks?
  14. Rear toe on 4th gen Prelude?
  15. ITR springs on a civic
  16. DC2: Tanabe Sustec Pro S-S Type II vs. H&R Cup Kit
  17. DA: Shock Body Lengths?
  18. tockico gas shocks
  19. car shaking under heavy acceleration???
  20. Omni Sport spring rates
  21. tires rubbing, please HELP
  22. Password 4 point rear tower bar
  23. front bearings working their way out from hubs
  24. 3 broken studs switch to extend or replace with stock?
  25. a good combo for civic hatch w/ h22
  26. Is this a good price for eibach pro-kits.
  27. EG suspension problem. need help pinpointing the problem
  28. Tein S. Tech Springs with what struts?
  29. Suspension, where do I start?
  30. power streering pump
  31. Help, i need suspension components
  32. Which LCA's to use for Comptech sway combo
  33. rimsvs. alignment *searched
  34. Eibach Pro Kit
  35. Suggestions, bushing setup
  36. 92- 95 Civic shock and springs
  37. Recommended drop for 19" rims. 2002 accord coupe.
  38. inner fender braces
  39. Suspension pics
  40. Is this a good package?
  41. do i HAVE to have a camber kit with 2 inch drop??
  42. ????DOUBLE SPRING COILOVERS....????? EVER SEEN THIS ISH
  43. Suspension Problem with KYB's!!!!
  44. just an idea about coilover sleeves.
  45. CAMBER WEAR HELP !!!
  46. Tokico vs Eibach struts with sportline springs
  47. Beaks vs. BSQ reinforcement kit
  48. were can i get 3 way strut bar for my 92-95 civic coupe
  49. Ingals or Adjustable Arms ????
  50. TIRES RUBBING A BIT
  51. need help with front strut tower bar... ;\
  52. Please Help!!
  53. UNinstall shoot out WHOOOOEEEE!
  54. Fitment question....
  55. wilwood brakes
  56. replaced wheel bearing, still has play..
  57. front is higher than the rear..
  58. Full Race Traction bar setup: Caster Adjustment?
  59. H&R Sports with stock shocks... noisy?
  60. Neuspeed, H&R, or Sprint on KYB AGX's?
  61. will front and rear sway bars from a ek fit on a 95 civic coupe (ej1)?
  62. koni yellows or tokico illuminas for DA teg?
  63. Great handling for not to much money
  64. braking: I got questions
  65. Suspension set up for drag race?
  66. Shocks actually lower your car bit???
  67. If you have sway bars in the back and front...
  68. H&R sports and eibach sportlines
  69. Did I get lost again?
  70. 2 inch drop
  71. camber?
  72. Installed, omnipower sport full coilovers on 91 civic si
  73. Do Koni Yellows have any advantage over Illuminas besides ride height?
  74. Koni Reds for Integra... What Settings??
  75. should i get my car corner balanced?
  76. JIC FLT-A2 coil-overs for sale...crackhead price in NJ
  77. REAR TOE ALIGNMENT HELP!!!!
  78. somebody recommend me a reputable/good place to get alingment done.
  79. invida rear sway 19mm install, endlink bushing broke already
  80. Using a Camber Kit, how do I know it is correct?
  81. integra sofsports on a civic
  82. tokico illumins and tein springs
  83. Opinions please
  84. what is the difference
  85. 92 civic strut tower bar??
  86. alignment...hmm
  87. How long can the stock shocks last with lowering springs...?
  88. Buddy Club pillowball comparo
  89. Adjustable strut question
  90. what kind of kamber kit should i get?
  91. Who's running what rates?
  92. Omni coilovers...you MUST preload?
  93. Bilstein Sports with Stock Springs??
  94. Kyb AGX or Koni Yellows?
  95. Would this setup rub??
  96. D2 sport suspension
  97. Limits of dampening for "stock" Koni Yellows
  98. rear upper strut tower brace
  99. Dropzone...first hand experience only!
  100. Blown brand new suspension... need advice
  101. A list of problems, any insight will be great
  102. omnipower camber kits..good or bad???
  103. quick question about H&R Springs...which is which?
  104. H&R Sport springs and what shocks ?
  105. basic or super streets?
  106. Bouncy suspension
  107. Installed H&R Coilovers, did I do this correctly? w/pic
  108. OEM 99 civic springs
  109. Tokico Blues, KYB AGX or Koni Yellows?
  110. skunk 2 bouncy ride?
  111. ep3 suspension
  112. Koni with H&R Race or Eibach Sportline
  113. Apexi N1 Coilovers
  114. Eibach numbers...
  115. Sway bar setup- good combo?
  116. which camber kit?
  117. Mounting cups for coilovers??? Do they exists?
  118. D2 info request. Comparisons? Pro/Con?
  119. Full Race traction bar lubrication/protection
  120. kart problem???
  121. dc2 stock shocks/struts on a ek???
  122. Progress "H-Series Swap" for Civic Springs, are they good?
  123. custom endlinks
  124. Sagging with S-Techs?
  125. Best suspension upgrades in order for traction
  126. The dreaded DropZone..
  127. ot: Job opening at Eibach (r&D)
  128. Straighgt Axel Conversion
  129. Omnipower VS. Neuspeed Race/Neuspeed Koni Sp3
  130. should i buy UGR?
  131. can someone please help!
  132. ITR vs. GSR suspension geometry: really that different?
  133. CHEAP FULL COILOVER SHOWDOWN!!!
  134. kyb agx adjustables...question
  135. Buddy Club Racing Spec Damper......damper adjustment..how do you do it??
  136. THE BEST LOWERING SPRINGS
  137. Tender/ Helper springs???
  138. Trying to understand wheel travel...
  139. tokico illumina shock/spring kit.....HELP!!!
  140. skunk 2's with stock itr or gsr shocks?
  141. YO neuspeed race how to compress it... help!
  142. bushings on the omnipower lcas?
  143. TEIN SS coil overs 16way adjustable question
  144. is it the alignment?
  145. lowering springs on stock EP3 struts?
  146. koni yellow's from delsol 97 fit 90 EF hatch?
  147. Sway bar question
  148. How can i tell if i have 94 up integra knuckles?
  149. TEIN S-TECH SPRINGS on my GS-R
  150. Ksport Full Coilover System in progress
  151. i blew my kyb/agx's...
  152. Omnipower installer error (most likely)
  153. How to???
  154. susp. techniques Front sway on ek???
  155. Rear Disc Conversion Questions
  156. Omnipower rates backwards?
  157. Flaring factory brake lines?
  158. Did search, what's good a a 4 inch drop
  159. need help installing polyurethane Motor Mounts
  160. EBAY Strut Bar Kits. Do they work?
  161. Bought new wheels, need new parts for alignment. Suggestions?
  162. dropzone?
  163. frame damage?!!!
  164. problem with omnipowerusa coilovers and RUST
  165. Where to get my modded honda cornerweighed/aligned?? Near SW WA/Portland, OR
  166. suspension fabrication questions.
  167. Matrix Springs
  168. What went wrong? (Koni Reds / Eibach Prokit install)
  169. Sway bars on a CX? There aren't any from the factory...
  170. are these real or just knock offs?
  171. b,c pillar bars
  172. Will these bars fit my car???
  173. illuminas, KYB AGX's, tein?????
  174. Need to replace a broken strut on a 2001 Civic EX
  175. skunk2 or omni power
  176. Brake upgrade idea...
  177. kyb struts??
  178. Weird steering after spring install
  179. Car is sitting at an angle
  180. teinsprings,16's, anything else?
  181. Suspension set-up for stock ride quality for 94 Legend 2dr
  182. can somebody help me
  183. Anybody heard of JDM RM coilovers?
  184. Help! Steering wheel vibrates badly after 60MPH
  185. HELP WITH INTEGRA FRONT LCA's
  186. Tire pressure question.
  187. Spring Perch Lowering Question?
  188. stuck on poly front bushing install
  189. eibach prokits problem
  190. 6th gen w/ full front & rear GS-R brake swap
  191. Skunk 2 Camber Kit.. Ive searched
  192. wheel stud cost
  193. re: anyone heard of EIBACH road course springs
  194. lca bolts don't fit in Function7 rear lcas
  195. passenger side axel popped out of transmission@380whp..
  196. alignment after changing ride height
  197. Which H&R springs to buy for a 95 ex coupe?
  198. front end conversion suspension troubles?
  199. question!
  200. GC spring rates
  201. Koni Reds appropriate with Eibach Prokit springs?
  202. Camber and toe and coilovers; oh my...
  203. ITR springs/shocks on a GSR?
  204. My review of the Korback frame locks
  205. Energy Bushings
  206. 99/00 civic si rear sway bar on hatch?
  207. understeer
  208. Partner for my Eibachs
  209. Non-technical Review of Ksport Coilovers and LCA (EK)
  210. alignment ques.
  211. dc2 and da suspension
  212. KYB AGX Struts w/ Neuspeed Race Springs
  213. BuddyClub RSD question
  214. popping noise when car jerks
  215. Problem with Tein Flex anyone else?
  216. Correct way to adjust ride height
  217. i did the top hat extention mod....super results
  218. Tein Springs w/ Tokico Illuminas
  219. Suspension Technique Speedtech Rear Sway Bar?
  220. invida sway/tie bar combo
  221. nuespeed used springs???
  222. Accord Lowering
  223. Spoon Struts
  224. HELP!!! Tenzo R coilovers bouncey. And wont lower all the way in the front. Spring Rates?
  225. will civic coilovers be good for integra....are they the same?
  226. loss of power
  227. KYB suspension question
  228. Crack/Tear in rubber seal
  229. Getting an alignment soon, DIY rear washer trick?
  230. real suspension people... help
  231. Coilover perch height spacers?
  232. 94' Integra Rear LCA bolt question
  233. Are Omni Full Coilovers better than Koni and Ground Control?
  234. What is the spring rate on my GC's? -> GC200.64.58
  235. Megan LCAs w/ ITR Sway bar, ENDLINK WOES!!
  236. Spring / Shock vs Coilovers
  237. I need to SIZE up my ENDS!!
  238. KYB AGX problem
  239. dropping rear suspension
  240. Cusco 6 point cage
  241. need help converting from 4x100 to 4x114.3
  242. Energy Suspension Bushings
  243. 98 crv front right clunking
  244. PICS Needed !!! Reverse Ground Control Coilovers for More LOWERED Stance!
  245. Correct rear tie-bar + LCA combo
  246. Acura 01'-04' TL, RL, CL 5 Lug into a Civic can it be done?
  247. which tie bar will work with integra using itr swaybar?s
  248. suspension technique rear sway bar ?
  249. which brand has the best lowering springs?
  250. tie bars...
