PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. spring/strut setup?
  2. WHICH COILOVERS TO BUY.?
  3. Parking brake stopped working
  4. Lowering F2's lower perch
  5. Lower Control arm HELp....
  6. Which way do the oem EK rear LCAs curve?
  7. steering spindle/knuckles
  8. Ground control collar -not impressed
  9. wilwoods making clicking noise
  10. accord coupe brake trouble
  11. tophats?
  12. Tein Flex vs BuddyClub Racing vs Cusco Zero-2, help on Japan
  13. Suspension
  14. Ground Control Allen Head Size??
  15. question about lowering with k sport coilovers
  16. 99 Prelude lowering without camber kit?
  17. want to replace front adjustable ball joint
  18. 89 Accord DX Suspension
  19. Will the Ride be bouncy ?
  20. ebay brake rotors: different claims, which is better?
  21. Adjusting Tein flex coilovers
  22. GSR swaybar/endlink ?
  23. Why do cars 3 wheel?
  24. Suspension help w/ End links? (ASR/ITR)
  25. no pressure to 1 brake.
  26. DIY BEAKS rear lower tie bar.
  27. Hard brake peddle
  28. Install tanabe front sway bar on ef!
  29. Squeaking Noise Front Right Wheel
  30. two questions about the mugen activegate kit
  31. Traction bar / 5 lug suspention on civic EX
  32. good idea to read this if you use energy ES suspension front arm bushings civic/teg
  33. brake issues.. searched. didn't find what i was looking for.
  34. EJ rear brake conversion
  35. will 94 integra struts work on a 93
  36. Extended Lug Stud Install - Wheel Bearing Question
  37. Upgrading master cylinder and brake booster and keeping stock brakes.
  38. Fastbrakes 4 pots with 11" rotors
  39. Quick question about my Omni power Front UCA's
  40. How low can i go?!?!??! HELPPP!!!
  41. EX supention tie rod are they the same as integra DC2????????
  42. Maxed Megan Racing Coilovers. QUESTION
  43. Eibach ProKit Springs - How Much Gap?
  44. questions about trailing arm bushings
  45. 94+ integra rear disc brakes on CRX?
  46. ef coilovers into ek?
  47. Coilovers? What brand should i go with?
  48. civic springs
  49. delete
  50. PIC coils.. your thoughts
  51. strut and shock removal problem in my DA
  52. how do i tell what brand coil overs are on my TEG.
  53. Rear sway bar end link bushing, how to put in
  54. GC/Koni combo vs. Coilover set up Performance
  55. suspension problem in delsol
  56. Tein superstreet springs?
  57. need help on determining what size sway bar to run
  58. ASR subframe and abs lines???
  59. Password JDM strut bars
  60. delete
  61. eBay strut bars?
  62. anyone know the standard rates for D2 coilovers?
  63. BLOX coils vs. Function Forms 1....which??
  64. '98 Honda Civic Ex front subframe work on '94-01 Integra?
  65. Tires Still wearing?
  66. Cutting springs - what do you say to this?
  67. rear right suspension making noise
  68. help adjusting skunk2 camber adj (very tight)
  69. GC's with Skunk2 struts. Question.
  70. Tires HALP!!
  71. 94-01 teg coilover on civic
  72. DA Skunk2 suspention Question
  73. my failed attempt to slam my em1
  74. JDM EG H22 suspension
  75. eg shock install on ek
  76. SPRING QUESTION [NOOB ALERT]
  77. Wheel Bent a little back help?!
  78. Decent spring rate for daily?
  79. non height adjustable race suspension
  80. cheap brake ducting material
  81. ground control coilovers
  82. How Maintain the Performance of Breakes?
  83. A couple quick questions
  84. binding
  85. still cambered out with a camber kit...
  86. EG civic Suspension & Wheel question
  87. How to Adjust Car Wheel Alignment?
  88. Need part number for Tein SS helper spring
  89. Rear caliper e-brake locking up (DA Integra)
  90. Trailing arm bushing?
  91. Wheel hop going up hill I suspect ...
  92. where to order megan lca bushings?
  93. i need coilover wrenches
  94. GC Koni Slam Help
  95. Proper swaybar sizing.
  96. identify this APEXI coilovers
  97. Energy suspension bushings.
  98. GC riding slammed.
  99. Handling potential of the Del Sol?
  100. GC top hats, need opinions
  101. Question about replacement shock/strut
  102. Civic with ITR 5 lug suspension
  103. 5 lug civic track width?
  104. need help DC2 5 lug conv which one do i have !!
  105. can pic coilovers slam a car??
  106. HELP IDENTIFY THESE COILOVERS!
  107. Questions about Ground Controls
  108. How to repair My Brakes?
  109. How to repair My Brakes?
  110. Ksport GT's on EJ8
  111. 36mm 5 lug conversion
  112. Is this a good alignment? Doesnt feel right..
  113. coilover/spring height problem
  114. Best way to unfreeze coilovers
  115. so i need some help
  116. The Best Rear Camber Kit to road use
  117. coilover spring loose at full droop
  118. GC Coilover
  119. Type R 4x114.3
  120. GC/KONI 550F 350R adjustments
  121. sprint lowering springs
  122. Installed Skunk2 Rear camber kit, but creaks like hell
  123. coilover blown
  124. Buddy Club N+ Spec Coilovers
  125. TEIN Super Street problem
  126. Suspension Package Opinions
  127. D2 V's buddy club camber adjusters,
  128. Progress Track day giveaway...
  129. NEED PERSONAL INSIGHT ON SUSPENSION
  130. Pros and Cons of Wheel spacers
  131. Skunk2 pro c series
  132. OEM shock replacements
  133. Sprint springs
  134. Koni yellow and gc trouble????
  135. 00 civic si brake Q:
  136. camber and lots of it!!!!!!
  137. coilover sleeves
  138. Broke a bolt in control arm.
  139. F2 Type I Question
  140. ground control coilovers
  141. Coil over options
  142. koni bump stops???
  143. tight wheels affect braking? myth or fact
  144. D2 Racing Coilovers-Reviews, thoughts, experiences, etc
  145. 4x100 DC2R brake upgrade for EK
  146. What Struts are best to put with skunk2 springs???
  147. Rear Swaybar question
  148. top hat bushings
  149. ground control sleeve????
  150. Clunks over dips
  151. clicking from recently installed koni/gc
  152. Parts identification?
  153. V-Maxx - 96-01 Civic - Spring fitment / Part #
  154. koni/gc question on civic
  155. spoon calipers on 4x114
  156. Suspension for em2 lx 03
  157. OEM dust boot
  158. Corner balance question?
  159. what are your opinions
  160. skunk2 suspention question?
  161. Gc/koni problem
  162. noise when driving slowly
  163. will a ctr anti-roll-bar work as well as a aftermarket one?
  164. compensator arm installation question
  165. PIC performance still in business???
  166. Squeaking from rear while driving
  167. What Springs Would Be Best For Drag Racing?
  168. Whats should i use to lower My EJ8
  169. need coilover rebuilt
  170. Civic-Teg rear brake conversion questions
  171. slammed suspensions question
  172. 99 GSR brembro slotted or drilled?
  173. bilsteins rear shock question
  174. Front sway bar 95 civic dx< swaybar ?
  175. Loid bang coming from coilover. Aragosta
  176. Toe adjustment
  177. Prothane Bushing.
  178. tein basics with oem dust covers
  179. coilover problem
  180. jdm 23mm itr rear sway bar bushing parts numbers the same as us 22mm
  181. ST rear swaybar install help on my '98 DX...
  182. gc/konis
  183. were to get 4x100 to 5x114 spacer
  184. ef drop springs
  185. Hybrid Street/Race Alignment Setup DC Chassis
  186. Used gc/konis
  187. ohlins dc2 itr coilovers how can i adjust ride height?
  188. Spring Rates - Please Educate
  189. ksport camber kit?
  190. integra suspension help
  191. Integra Suspension question?
  192. rear compensator arm question
  193. front lower control arm part question
  194. H&R OEM Sport on DC, do I need a camber kit?
  195. Quick question: Allignment
  196. 01 gsr rear brake spindle question
  197. 92 EG6 LCA?
  198. Top hats?
  199. OEM endlinks and sway bar hardware?
  200. are JDM EK front lca's the same as US EK Si?
  201. is it possible to weld to shocks?
  202. Steering pulls hard right!!!HEEELLLPPP
  203. Mugen suspension
  204. Integra 4x114 rear bearing
  205. Pad Retaining Clips & Rubber Cylinder Seals
  206. koni vs kyb agx
  207. coilover lower mounts crossthreaded help
  208. Alignment help! 1999 prelude SH---specs inside
  209. Wilwood 12.19" BBK on 7th gen EM/ES Chassis
  210. Rear disk Conversion
  211. Cracked open bleeder screw...yet the pedal is still super stiff..
  212. NEED HELPPPP!!!!
  213. blox lca & gsr sway bar
  214. installed camber kit tire squeels when turn to the left
  215. I just cant put my finger on it and need some Help
  216. 4x114.3 itr on del sol
  217. rear lower control arm
  218. 90-93 teg coilovers on 96-00 civic
  219. Help - DC2 Suspension Aftermarket items
  220. Getting Stiff...Suspension.
  221. jdm sport control arms or..
  222. what spring to use with koni yellows
  223. alignment quick question
  224. alignment quick question
  225. Suggestions for good suspension set up
  226. Need suggestions for Suspension
  227. Koni Yellow GC set up
  228. Dumb(?) question, camber kit spec meanings
  229. Are these Coilover set Legit?
  230. Are EG and DC2 Suspension arms/LCA's/Knuckles/forks/hubs 100% identical?
  231. I am ordering coil overs tomorrow need advice
  232. help... Please..
  233. skunk2 coilover sleeve spring rates.
  234. rebuilding 4x114.3 ITR conversion
  235. No, you DO NOT need camber kits!!!!!!!!
  236. ABS delete on 92 GS-R. Looking for a brake upgrade. Suggestions?
  237. Function and Form Type One height adjustment
  238. My Shocks keep blowing...wtf..what gives
  239. RSX EP3 PRELUDE REAR CALIPER
  240. What shocks with Eibach Sportlines (05 RSX-S)
  241. Camber Kit Confusion
  242. E break help
  243. ??? on replacing my Civic brake master cylinder.
  244. Clock springs?
  245. what end links do I need?
  246. New ground control suspension....
  247. Right brake pads are totally worn but left pads are new?
  248. GC's on stock shock?
  249. Replacing Beaks SRK with ASR brace
  250. coilovers or just lowering springs???
