PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. ES motor mount inserts...
  2. spring preload
  3. need help?
  4. zeal coilovers question searched. specific ef8/dc2
  5. 90-93 Integra Suspension VS 94-01 Integra Suspension
  6. 90-93 Acura Integra Air Ride
  7. Front lower control arms
  8. 93 civic rear subframe help
  9. EK coupe or hatch? Or same thing?
  10. quick question on assembly!!
  11. 01 civic lx coupe
  12. EG LCA's in a DC
  13. wtf jhpusa.com
  14. Searched and still need one questions answered for Neuspeed Race Springs
  15. shopping around: omni
  16. Best Sway Bar Combo For 98 Civic Cx
  17. Drop Zone Springs
  18. ksport spring rate on dc2
  19. Is the ST speedtech swaybar good or is there better?
  20. integra struts
  21. Bought used susp. Did I get screwed? Koni / Bilstein
  22. Ground Control / Illumina Install help and ????
  23. Coilovers
  24. air ride for $300 rear, or agx 8ways for my sol to get traction??
  25. 90-93 Integra and 92-00 civic/94-01 integra Spring interchangability (word?) question
  26. ITR Sway Bar installation....ran into a problem
  27. AVO coilovers? Anyone?
  28. Uneven pad to rotor contact
  29. What Sway Bar is this?
  30. coilovers/car parts and ebay (^_^)
  31. illumina/H&R sports srings install questions..
  32. Tokico Illumina Adj or KYB AGX Adj?
  33. Need help with swaybars with the specs I want for my car....
  34. d16z6 vs d16y8 vs Single cam ZCvtec
  35. Apexi World Sport Coilovers!!
  36. Which koni's?
  37. proportional valve??
  38. question about Eibach springs
  39. NRG springs
  40. Traction Bar Setup Info Needed
  41. Thud Noise coming from front passenger...searched...
  42. Eibach 92-95 Anti-Roll/Swaybar kit
  43. Formula for calculating clocking with the rear trailing arm bushings?
  44. Which Camber kit?
  45. lower control arms?
  46. 1mm larger sway bar, noticeable difference in reducing body roll?
  47. Koni strut problems
  48. swapping to P/U sway bar bushings on stock sway bars...big difference or not?
  49. Suspension Setup for 00 Si
  50. What lowering springs for EP3 do you have and how do you like them?
  51. Installed my ground controls and lowered 1/2"
  52. Which is most beneficial?
  53. k sport coilovers.....quality?
  54. what kinda mounts??
  55. Suspension 101 HELP!!
  56. i need opinoins for shocks/struts
  57. Suspension for dc2 teg?
  58. Rear ITR sway on a LS integra
  59. Dumped
  60. where to order bushing kit
  61. What to do?!?
  62. will 95 integ gsr shocks fit a 99 civic si ?
  63. wheel shake!!!helpppp
  64. H&R coilovers
  65. are 95 eg coupe LCA's the same as 94 DC2's?
  66. Looking for Koni parts/equipment........
  67. should i use this camber kit or go all the way?
  68. EM1 IMPROVED HANDLING?
  69. S-tech + GR-2
  70. TC SPORTLINE
  71. Do you need need shocks if you get lowering springs?
  72. dc5 strut tower braces on em2
  73. Koni Threaded Spring Perch Sleeves
  74. Lowering Car but concerned that springs are loose ...
  75. why is spring height important, please tell me.
  76. little confusion on H brace
  77. Need new suspension on my 98 GSR
  78. South Jersey Shops WANTED
  79. where to buy gc tophats? i need ASAP!
  80. MEGAN RACING
  81. Aftermarket LCA's use which bushings?
  82. Eibach Sportline spring rates?
  83. air suspension
  84. Which coilover...
  85. best drag suspension
  86. front spring noise & the cause possibly effecting the steering?
  87. ground control spring rates???
  88. Truechoice Koni Racing
  89. EM Racing c-pillar tie bar?
  90. Ground Control/Koni Yellow Settings
  91. Benefits of Lower Control Arms?
  92. 2 things i want to fix
  93. i have a rear sway bar - whats missing / who makes this?
  94. ITR Rear Upper Control Arms?
  95. Where to get koni's revalved ?
  96. Upper Control Arms out of place. Hard to put back ?
  97. need some advise.
  98. tottaly confused
  99. function form type 2
  100. FFF@%#**!!! UCA PROBLEM -any ideas?
  101. eibach sportline
  102. OBX Sway/Tie Combo.....
  103. camber problem???
  104. WTB LSD for gsr tranny So Cal
  105. Neuspeed Race/Tokico Illumina setup
  106. Help> sprint spring?
  107. Help me choose the ideal spring rate
  108. How can i raise the ride height just a bit, without changing the springs?
  109. New Suspension Tuning
  110. Installation Question...
  111. Suspension choice for G3 LS Teg
  112. Stripped the allen bolt on my one of my GC's...
  113. ground controls?
  114. i hate suspension arguements with idiots
  115. alignment specs let me know what y'all think
  116. teins on my si
  117. Tanabe Lowering Springs?
  118. Tanabe SS - Del Sol
  119. just installed springs
  120. Traction bars for integra
  121. cant get off spring...
  122. Tokico Illuminas vs. Koni Yellow Sport for Skunk2 coilovers.
  123. need help--->> Suspension...
  124. Circuitworx 32mm to 36mm 4X100 hub adapter good quality??
  125. koni yellows
  126. D2 (purple) Coilovers or H&R Sport/Koni
  127. Interchanging upper control arm
  128. 19mm ST rear sway bar or 23mm ITR rear sway bar on a 400f/450r street car
  129. which camber kit is better progress tech or revo technica?
  130. New on suspension
  131. is a Pieced together suspension a bad idea?
  132. Camber parts
  133. after 3yrs of blown shock finally got 2out4 of my kybs in 2day
  134. best daily driver/ good cornering
  135. 45 series tired with Illuminas?
  136. STRUT BARS QUESTION????
  137. parts missing? What all do i need?
  138. TOKICOS ON GROUND CONTROL COILOVERS????
  139. Rear drum to disc swap knuckle questions.
  140. Skunk 2 number stamp/part no. on spring
  141. Ek owners with ground controls!! Chime In!!
  142. strut bar/GC tophat fitment issues (dc2)
  143. Tokico 5-way+tein s tech
  144. 91 si crx brake upgrades?
  145. Road race or SCCA spring set up
  146. 1986 Full body coilovers (with pics)
  147. question concerning my springs
  148. Springs compatability
  149. help noob questions
  150. tokico illumina install help
  151. What do think of Koni shocks?
  152. 2dr & 4dr integra same suspension?
  153. Skunk2 Pro-s Coilovers Application difference, EF, DA
  154. ITR 22mm Sway with Beaks Kit on EJ1, some fitment issues.
  155. NO Brakes!!! PLZ HELP
  156. 90-93 integra susp. on 92 civic??
  157. OMNI POWER VS AGX W/ H&R
  158. installed tein flex and edfc on my s2000. questions...
  159. CRX w/ b18a1 swap axle issue.
  160. Quick ratio steering
  161. Apexi World Sport Suspension
  162. Just installed my GC/Koni combo...need some advice
  163. GC Tophats on Omnipowers!!!!
  164. need help on decision (keeping my double adj konis)
  165. coilover kit
  166. rear trailing arm bushing rta part number
  167. Help with suspension!!
  168. AXEL HELP
  169. Honda Sway Bar Sizes and Interchange
  170. Are Omni Slip on coilovers compatible w/ Skunk2 sport shocks?
  171. tail happy integra
  172. D2 Racing Coilovers???
  173. brake line bracket with ksports / 96 civic - no use?
  174. are Cusco Comp S coilovers a good choice and will DC2 ones fit an EG RLCA?
  175. Noobish request for opinions/advice
  176. Stumped...Humming noise from front end.
  177. 4x114 Conversion for the DA
  178. Is there an OEM Spring Rate master list somewhere?
  179. Changing springs on Koni coilovers
  180. Advantages of full coilover setup
  181. universal top mount?
  182. Loose axle sounds
  183. time to change rear lca's? or time to change suspensions?
  184. How does slower rebound on koni yellows help with handling?
  185. Ek Civic Front camber solutions?
  186. lac bushing price ? help info
  187. Needs pics and info.... (Sway Bar)
  188. tein type flex vs. buddyclub n1 plus
  189. Ohlins Suspension ...
  190. 95 civic strut bar
  191. which coil over should i pick?
  192. will an 8" spring be stiffer than a 7" spring if both rates are the same?
  193. ksport coilovers?
  194. Possible Blown Shock?
  195. EF Camber Kits (ingall vs revo)
  196. brake conversions
  197. Alignment cost?
  198. TEIN SS or Function & Form?
  199. Opinions wanted on beginner setup
  200. Has anyone tried brembo brake pads?
  201. 88 crx suspension
  202. Weird rubbing sound
  203. gas milage going to shit!!! help
  204. Adjustable omni coilovers
  205. Toe Adjuster
  206. TEIN S. Tech vs. Eibach Pro-Kit (Owners Only)
  207. New guy with issues..help
  208. safety center???
  209. Cround Control coilovers and a broken cup....
  210. rebuild Koni shocks or buy new?
  211. MONROE SHOCKS with tein or eibach springs?
  212. camber kits
  213. Do 92-00b civic springs fit 90-93 integra?
  214. accord coilover choices
  215. front camber help 93 integra.
  216. Ground controls: 96-00 Civic = 94-01 Integra?????????
  217. lower control arm question
  218. rubbing
  219. Skunk2 Coilover w/ shocks
  220. Ground control on stock struts
  221. H&R Race Springs Any Good?
  222. 91 integra rear disc into 92 hatch
  223. Need your Opinion
  224. Skunk2 coilover spring rates ????????
  225. Suspension Advice
  226. Omni Power Fitment
  227. Max speed full coilovers
  228. Koni Yellows
  229. Custom engine swap.....how perfectly lined up do the axles have to be...can they be off?
  230. integra front suspension in a eg
  231. Coilover Setup
  232. full coilover kits vs air ride/ air suspension whatever its called...
  233. variable camber suspension.
  234. who's rocking ksport coilover?
  235. Any cheap ways to add negative camber up front??? pls help.
  236. will 2 door da springs fit on a 4door eg
  237. Stay with Koni or go with Showa ?
  238. Suspension Setup for Road Racers only!!!
  239. Looking for a motor mount insert
  240. Suspension Techniques
  241. let me hear your ways to pop the ball joint.
  242. coilover question: which are the front and which are the rear?
  243. about tein springs
  244. GC / H&R / TIENS ????? Need your personal to professional opinon!!!!!!
  245. What coilover should i choose?
  246. Ground Control Sleeve Question Regarding Length
  247. will gsr springs and struts fit in a eg hatch
  248. Koni Yellows
  249. NSX Brake Upgrade on My Integra
  250. Problems Installing Eibach Swaybar
