PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99
  1. torquing suspension bolts at ride height q
  2. Eibach rear sway bar question for 92 Civic SI thats has no oem rear sway bar???
  3. Koni Yellows and H&R Sport springs- A bad combination?
  4. CAMBERS **Omni vs. Skunk2**
  5. What type of shocks/struts to use with Omni?
  6. ek cusco bar or not?
  7. where can I find rubber spring covers? like the ones on ITR springs.
  8. What is most to blame...
  9. sitting uneven??
  10. skunk2 spings w/kyb 4 way's ????
  11. ohlins discontinued?
  12. What to get for under 600$?
  13. Omnipower street or track for dumping?
  14. Civic/Teg ball joint.. interchangable???
  15. GC with Koni or GC with Bilsteins???
  16. traction bars
  17. Avid Mounts
  18. bumpstop direction .. prelude 4th gen
  19. -- Spring Rates archive --
  20. subframe+floorjack
  21. Progress Coilovers ?
  22. Assorted suspensions....
  23. ANY SUGGESTIONS ON TOKICO SUSPENSIONS?????
  24. Neuspeed Race Springs / KYB GR-2 Shock Combo?
  25. tein s-tech on stock shocks?
  26. New Suspenion Help.
  27. Tein Electronic Dampers
  28. Noisey Omni coilovers and a leak in the rear...need some help
  29. springs compatibility
  30. Sway Bar Selection Help..
  31. what springs should i get with gsr swap?????
  32. Neuspeed Sport Cup Kit for EF's..
  33. Tein SS or GC's and Koni?
  34. noob to suspension set ups
  35. Need help, messed up top 19mm nut on Omni's
  36. what camber kit on jef
  37. Anyone know anything about the B+G S# Coilovers?
  38. suspension question
  39. For Those of You With Tein EDFC.
  40. 10kg/mm & 6kg/mm too much for koni's yellow on street?
  41. Nut Size on the strut?
  42. What shocks to go with
  43. will srr tie brace fit my type r sway bar for my 94 teg?
  44. KONI vs TEIN SS vs OMNI
  45. Omnipower "old version." Why the new collar?
  46. ground control help
  47. 90-97 accord rear illuminas on eg/dc/ek?
  48. Dampening Equation ?
  49. AEM Big BRakes for 98 GSR.
  50. 94 accord kyb gr-2?
  51. H&R Ultra Low Coilovers...
  52. Coilover Swap
  53. NEW Skunk2 Coilovers Reviews???
  54. TEIN SS Blown?
  55. Need Real Advice On This Potential Setup(Tokico Illuminas/GC Top Mounts/What Springs?)
  56. Right front sits higher than left front
  57. Neuspeed Race or H&R Race?
  58. stock Shocks and spring setup from an EG fitting on a 97 4DR lx??
  59. GR2 blown!! Whats a good shock?
  60. itr strut bar on ej
  61. Are VIS coilovers any good????????
  62. H&R or Neuspeed?
  63. upper and lower control arm question
  64. Anyone got info (neuspeed/bilstein)?
  65. suspension ? please read and bumb
  66. 2005 4dr civic suspension
  67. Sway bar and Rear Lower Tie Bar for EG6
  68. Who's rocking D2 full racing coilovers??? I'm looking for impressions and pricing info....
  69. Pros - Please critique my CRX auto-x setup
  70. suspension tech rear sway on EK
  71. Caliper Squeal? *SEARCHED*
  72. sway bar mounting - how does this mount affect the rate?
  73. stock EG spring rate
  74. what are these parts?
  75. Need alignment after changing wheels (from 14" to 15")?
  76. Suspension for 2005 Civic 2door, a few questions
  77. NEX RACING SUCKS!!!!!! (here's why...)
  78. compatible parts?
  79. help wrong ball joint
  80. Help. My lower adjusting sleeve on omni coilovers is frozen. I cant budge it.
  81. Bilstein BTS Civic kits- WTW?
  82. where to get JUST the rear sleeve for ground control coilovers?
  83. PBR Brake pads
  84. EG Si suspension/brakes on EK DX
  85. n00b-ish Ground Control install and info questions
  86. OmniPower Street (EK) short rear collar problem fixed!
  87. Koni yellow pieces missing
  88. ferio rear end issues
  89. rear tie bar help
  90. quick question
  91. TEIN SS
  92. Still banging harder then before
  93. Hayame Coilovers.....
  94. Which Strut Bar I Should Get For My Ferio???
  95. RSX DC5/Civic EM2 Hybrid Strut Bars
  96. What are the best tractions bars??
  97. how do you take the 2 nuts on the the cap of a koni shock apart?
  98. KYB AGX with Ground Control Installation
  99. skunk2 top perch won't move
  100. lowering my car???
  101. rear ground control install question...
  102. control arm bushings question
  103. Is this used control arm OK to use?
  104. agx dampening question...
  105. ek rear suspension on eg does it work?
  106. Problem with big brake setup-no brakes
  107. What Should I Use to Drop my Car?
  108. Tein SS or Omni street.
  109. dc sport product help pls..
  110. Competition Engineering Tubular Lower Control Arm Kits
  111. H&R springs
  112. not your typical shock settings question...
  113. EMRacing C-Pillar bar... ???
  114. coilovers?
  115. eg - type r setup
  116. squeeking?
  117. What COULD the problem BE? alignment, suspension, etc????
  118. Need a Good Alignment Shop in Philadelphia or nearby...
  119. Cobra suspension?
  120. Problem with omni coilovers !!!
  121. Lower tie bars?
  122. Might be a stupid question...
  123. Going to get alignment soon. Is Walmart a bad idea?
  124. people who've done rear disc brake conversions ... or knowledge of
  125. best suspension for a bumpy road?
  126. 91 Civic DX lca question
  127. eibach sprtline kit
  128. How to tell if my omni coilovers are the the "old" version...
  129. Camber adjustment - Control arm hitting wheel well - I WANT LOWER!!!
  130. Skunk2 on stock shocks?
  131. BUDDY CLUB COILOVER:Clunk Sound
  132. will my shocks be affected in any way?
  133. bumpy/bouncy ride?
  134. educated/experienced opinion needed...
  135. lowering springs
  136. torsion bars
  137. Questions about my set up...
  138. Rear Disc Brake Conversion Question
  139. Megan Racing coilovers = Apex'i N1 coilovers?
  140. which is better eg control arms or dc control arms for sway bar set up?
  141. spc balljoint help
  142. EF suspension troubles
  143. How much for a complete brand new Type R rear sway bar ???
  144. changing brake pads.
  145. GC custom rates questions + Good combos?
  146. which alignment
  147. Whats the best set of suspension for a DC?
  148. omni coiovers vs. shock and sleeve setup?
  149. squishy air sound from new Tokico Illuminas
  150. Koni Ground Control install
  151. can i install a sway bar?
  152. how do oyu tell if an axle is bad
  153. Ground Controls?
  154. Where to get custom bushings?
  155. Getting Omni's with camber kit or not
  156. Anyone know what kind of camber kit this is?
  157. Handling like an EVO
  158. dumb question
  159. Q:How to properly tune suspension.
  160. Da camber kits
  161. Issue with Omni Rear LCA's... ITR sway bar doesnt work
  162. need how on how to correct my toe-in problem.
  163. ahh help how do i fix this?
  164. camber kit problem
  165. tuner nuts
  166. kyb agx blown?
  167. 96 Rear struts on EG
  168. Ground Control Coilovers with Skunk2 Drag launch springs
  169. sterring problems
  170. tokico bumpstops?
  171. Anyone heard of Silkroad/Section SPEC-RM coilovers ?
  172. Cutting front springs for the rear of a del sol
  173. Helms Manual / Subframe alignment question...
  174. wats a Good Suspension package
  175. Rear lower tie bar for Integra with ST Sway Bar
  176. Getting rid of sway bar noises
  177. looking for new springs need some help please
  178. Camber suggestions
  179. Will 99-00 civic SI shocks/springs fit a 00 teg?
  180. easy question...im not that good with suspension so.....
  181. Coilovers for 97 civic dx and 00 dx hb
  182. GC Question
  183. Sway bar end link
  184. Where did you get your Shocks/coilovers installed?
  185. Anyone had problems with their Omni Sports?
  186. Del Sol sway bar install question
  187. 99-00 Si Traction Bars??
  188. Any more worthwhile suspension mods???
  189. Searched but cant find anything need tire help
  190. KONI+H&R and perch settings
  191. stripped rear end changing caster angle
  192. Need suggestion, jumpy ride...
  193. JIC MAGIC COILOVERS
  194. Coilslap... I think... Help me out
  195. agx
  196. How do i make my EG hatch NOT handle like shit?
  197. Koni yellows / ground control
  198. OmniPower Question...This one's new
  199. need help koni yellow+skunk2
  200. What are you Big HP guys running for suspention? 500+hp
  201. My opinion on tokico blues and H&R spring combo
  202. ground control o-ring??
  203. Can anyone identify this part?
  204. Suspension Techniques Sway Bar
  205. CARBING real lower tie bar
  206. KYB GR2 shocks with 2 inch drop on a focus??
  207. Benen 3 point strut brace or Neuspeed 4 point strut bar?
  208. KYB AGX question...
  209. dropzone coilover kit, yay or nay?
  210. EM2 Civic w/ TEIN SS-P with some tire rub...please assist!
  211. would i need to reinforce if...
  212. Replacing the "Backing plate" of Trailing Arms and Rear Axle
  213. Recommendations on shocks... or screw it and move on to coilovers
  214. Question about Spax Sport springs
  215. Suspension install Problem, please help!
  216. HELP!!! lca and sway bar/tie bar
  217. 88 Crx Glides...how can i improve my handling?
  218. WHats the best shocks for drag racing?
  219. do i need itr LCAs for the comptech sway/tie combo?
  220. question on Tein S-Tech
  221. Traction bars for em1?
  222. Good shocks for ITR spring
  223. CRX suspension set up
  224. Looking for a somewhat aggressive pad....
  225. Bad coilovers? (newbie)
  226. Question About Tokico Illumina?
  227. shock disassembly (help!!!!)
  228. Steering Problem: Any suggestions?
  229. Suspension bolt Length (DC2)
  230. Need opinions or feedback
  231. supension set ups
  232. Megan Racing Suspension System Questions
  233. Anyone have experience with the NEX coilovers for the accords? (90-97)
  234. is this what i need?
  235. rear tires rubbing on trailing arm.
  236. HELP WITH SWAYBAR
  237. ride height
  238. integra-R LCA now i need shocks also?
  239. Bushing Removal Press Requirements
  240. Odd question/theory......but could my lower ball joints affect height?
  241. Omni-Power Spring Rate Question
  242. anchor bolt or ball joint
  243. Changing spring rates on Tein Super Street?
  244. progress camber kit
  245. Eibach Sway Bar Question...help!
  246. 17s and Omnipower Sport, unbearable?
  247. Camber Kit Question
  248. car swerving at higher speeds?
  249. Alignment in Toronto for lowered car?
  250. Ground Control Coilovers is that a good choice?
