PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. AMR Engineering coilovers
  2. Eg camber kit on Ek?
  3. Inner Tire Wear
  4. Ooops... brake pad change
  5. Wilwood Dynalite brake kit 15" wheels?
  6. miracle x bar size?
  7. considering changing out GC for something..
  8. 98 civic ES rack bushing install.
  9. Rear spindle mount fabrication pics and info
  10. Rear end creaking
  11. Need help identifying this Brake Master Cylinder
  12. Will DA brakes fit an EJ6?
  13. loose steering wheel??
  14. Ek hatch suspension help
  15. Koni Yellow`s vs Eibach Sport Line
  16. Any input on Koni sport struts with skunk2 springs, Whos got this setup?
  17. Anyone know of 11inch 4x100 rotors??
  18. 12.19 wilwoods with 15x8 +35 pf01's?
  19. camber kit help!!!!!please
  20. Drag suspension setup??
  21. Rotors and pads
  22. Article on cracking of drilled rotors, awesome.
  23. Brake Conversion help.
  24. Front suspension creaks when going over speed bumps
  25. suspension upgrades???
  26. Skunk2 LCA and OEM sway bar Endlinks?
  27. Brake Bleed sequence for RHD eg
  28. Lowering springs for my 98 prelude, need help.
  29. Max front Camber on integra
  30. 1994 Civic Hatch CX Suspension need help**
  31. Need new brakes... Any recommdations?
  32. Creaking when turning
  33. CX vs. SiR front Disc Brakes
  34. Skunk2 516-05-5685 Pro Plus Camber Review
  35. opinions and comments on ek suspension...
  36. Blox Full Coilovers
  37. 96 gsr 4dr abs booster and master replace or upgrade?
  38. ITR 5lug conversion on crx?
  39. How to figure out what Disc brake conversion is on my car?
  40. Koni/Gc help?
  41. honda red springs info
  42. KYB AGX shock with "_________" is the best suspension setup!!!
  43. caster adj. eg chassis
  44. squishy brake pedal?
  45. is my suspension bottoming out?
  46. Progress Technology CS2 Problem
  47. How to adjust Tokico Illuminas without Red Adjusters?
  48. How to remove a stripped front camber screw??
  49. Rear Toe adjustment maxed out and still .59 off?
  50. ground control discount password?
  51. Skunk Coilovers max height = slammed?
  52. MC and Brake Booster Compatability Question
  53. Drop forks 96-2000 civic
  54. EF civic, Function Form coilover ride height FIX
  55. radius rod modification
  56. 2000 civic si brake booster help!!!
  57. good shocks to pair with tein h techs.
  58. NSX Caliper Clearance w/ SSR Mk-III
  59. EM1 H&R Sport Springs Issue
  60. Need help, cant decide.
  61. shocks for dd with lowering springs
  62. Rims and suspension aren't getting along
  63. Energy suspension bushing question. 96-00 civic
  64. Brake booster push rod adjustment
  65. Camber kit suggestions
  66. what are the spring rates for these eibachs?
  67. G/C Koni Setup EF9, Rear sitting uneven, what to do.
  68. What e-brake cables for 95 civic rear disc conversion?
  69. da springs/struts on an ek
  70. HELP!!! GEM struts, has anyone heard of them
  71. AMR's INC!
  72. Bringing the civic ride height back to stock which springs where
  73. Alignment questions...
  74. Cleaning coilovers (basic question)
  75. coilover help!!!!!!!!!!!
  76. Adjustable coilover problem...
  77. Mas Industries Upper Control Arm??
  78. What is the best combo Lowering springs/shocks for street driving
  79. Finalizing my suspension. AutoX EH2
  80. Clunking noise driving me nuts!
  81. Slammed EK. Question about caster and handling.
  82. RSX wilwoods on DC2 type r?
  83. WILL A 92 INTEGRA LS REAR BRAKE SETUP BOLT ON MY 95 EG??
  84. quick question about brakes
  85. What mods to fit a function 7 subframe brace to a civic/crx chassie?
  86. ITR compliance
  87. Is it possible to over preload your progress cs2 springs
  88. 01 ITR suspension over haul- input please.
  89. Best coilovers to slamm your car?
  90. ITR Caliper + Rotor + Soft Line Question for my Civic
  91. F&F or F7 LCA's With ITR Endlinks
  92. problem that nearly kille me.....
  93. skunk2 pro S-II damper leaking :(
  94. Need help for deciding shocks and springs
  95. need the knowledge
  96. i have some question about my civic type-Rx suspension
  97. what happens when you BOIL your brake fluids?
  98. Spring Insulator for Civic and Integra interchangeable?
  99. ABS with legend dual piston calipers 95 del sol
  100. New into AUTOX.. Coilover suggestions?
  101. Need help with front and rear disk brake conversion
  102. front lower control arm
  103. ITR (5 lug) rear caliper question
  104. 1995 honda accord tire wear HELP!
  105. coilover help
  106. -1% caster
  107. Need Help on A good Quility Coilover System for my '94 EG6
  108. Coilover System HELP!!
  109. Need help advice and opinion on suspension set up
  110. Looking for Rear Lower Tie Bar lengths
  111. 96 integra front hub wobble is it hub or bearing??? need help please
  112. Another stupid question: ITR endlinks with 22 or 24mm ASR bar?
  113. REVO Front Camber Kit
  114. Where to service coilovers?
  115. Ej1 needs struts
  116. spc camber kits
  117. Spring Rates - kg/mm to pounds
  118. Ebay Coilovers????
  119. Function Form Type 1 Coilovers?
  120. 96 civic bolts
  121. do prelude and accords share the same type of shocks?
  122. gsr vs dx
  123. sway bar question.
  124. ITR Sway Bar End Bushings
  125. skunk 2 pro s v2
  126. EF2 Civic Suspension Question
  127. Whats the length of the Ground Control Spring?
  128. To much Play in Brake Pedal
  129. FD2 Brembo Calipers
  130. Weird vibration on clutch pedal
  131. **SLAMM EP3**
  132. Sway bar compatibility
  133. Best Spring Rates for Ground Control Coilovers? Slammed?
  134. DC2/ITR brake pads replacement
  135. Ride height changing on Tein coilovers
  136. help deciding!
  137. M12 to AN Brake fittings
  138. Del Sol traction bar
  139. Rear Camber/Control Arm suggestion/help
  140. Proportioning Valve ABS Non-ABS
  141. KONI SRT.T shocks
  142. Which BB and MC with non ABS civic dx (eg)?
  143. Coilovers for DD
  144. Adjusting Coilovers And Messing Up Alignment
  145. rsx buddyclub n+ suspenson prob
  146. Koni/GC help (1991 civic si)
  147. Stock suspension
  148. weird braking after brake replacement
  149. eBay Sway bar end links
  150. Del Sol - Raceland Coilovers
  151. quick question about coilovers for type r integra
  152. rhd eg6 brake hose help
  153. 92-95 Honda Civic Tokico Shocks Struts + M2 Lowering Springs Combo Kit
  154. Advice on Suspension
  155. Megan Racing Coilover
  156. Noob Questions About Suspension Setup
  157. Need advise on a good suspension pls...
  158. The only reason to hump a man's leg
  159. Extended top hats for Full body coilovers?
  160. Damping or springs?
  161. Ej1 shock and coilover overhaul.
  162. Skunk2 sleeve install help
  163. blackworks sub frame brace
  164. KYB GR2s vs Tokico Blues as stock replacement shocks
  165. pillowball type coilovers
  166. Is this how honda-techians are height adjusting their Tein Flex's?
  167. Accurate way to measure ride height
  168. Down-sides to Lowering?
  169. Anyone Use the NNR 1 peace Coilovers?
  170. Eibach pro shocks + lower springs?
  171. Worth it to get coilover sleeves for exsisting new skunk2 shocks?
  172. Progress CSII on 99 Civic...ride question
  173. Function Form Coilover, no preload
  174. omni struts with eibach springs?
  175. rear strut bar question
  176. how to keep coilovers clean?
  177. What lowering spring to go with?
  178. Ground Controls at stock height vs stock springs?
  179. Lower control arm options....
  180. 96 itr hub and spindles in a crx bend or hub swap
  181. lowering springs
  182. Build ideas for 91 Hatchback
  183. Has anyone used the SPC adjustable UCAs?
  184. Rear Aftermarket LCA's Don't Fit Right
  185. What do yall think about buddy club n+ damper coilovrs
  186. Looking for a good strut/spring combo for my DC2
  187. Best bang for your buck suspension?
  188. funtion and form type 2 or k sports
  189. Alignment Results on my lowered Fit
  190. Alignment shops near Philadelphia / Philly Area...
  191. Function form vs. blox?
  192. rear disc conversion
  193. Unknown Coilovers?
  194. Suspension upgrades that make a difference. (long post)
  195. Are SRR Lower Strut/Tie Bars Any Good?
  196. 96-00 civic alignment issues. (Skunk 2 camber plates)
  197. Coilover Sleeves
  198. Bad booster or what?
  199. PIC Select vs. Buddy Club N+ vs. Koni/Ground Control
  200. Flaring brake lines
  201. Alignment specs... Need opinions
  202. Oversteer after suspension upgrade?
  203. cv axle came out!?!
  204. brakes getting stuck
  205. Skunk2 Pro S II or Function & Form Type 1's
  206. Shopping for new suspension for my DC2....any suggestions on what I should go with?
  207. Sway Bar
  208. Trailing Arm Bushing Replacement Pins
  209. Skunk2 Pro S coilover...sleeves and springs on EK? HELP
  210. has anybody try cutting their tein s-tech?
  211. Front control arm torque
  212. AMR vs Modus
  213. why do everyone suggest Ground Control over other brands?
  214. suspension choice
  215. need help/coilovers/99 civic dx
  216. power steering conversion
  217. Problem Assembling Pro Springs and Pro Dampers for EK
  218. help on lowering eg
  219. help on lowering eg
  220. Camber kit question.
  221. creaking/screatching coming from coil over - cold weather related
  222. Another satisfied Progess eg owner!
  223. Skunk2 Coilover Installation
  224. skunk2 pro-s coilovers, front really bouncy,thump noise, 1999 civic dx
  225. Booster delete while using stock MC?
  226. Heating up springs??
  227. Help your fellow Civic EG owner with his Suspension Choices?
  228. 01 dc2 gsr How do i remove the front lower control arm connected to the rotors?
  229. Skunk2 Rear Lower Control Arm Review
  230. Need a Camber Kit for my 1999 Honda Civic Hatch
  231. rotors after caliper install fail
  232. anyone that has tein monoflex please chime in
  233. Anyone ever buy from this site?
  234. Best suspension for EG8
  235. blox drag pro series coilovers.. just installed
  236. Changing Springs?
  237. what wheel bearing's do u use?
  238. brakes sparking when i brake
  239. would ES bush's fit Skunk2 lca's?
  240. EK/DC rack & pinion swap, parts needed?
  241. lifting ef2!
  242. koni gc vs tein flex
  243. what kind of suspensions are these?? anyone know??
  244. Hawk Brake Pad Buying Guide - BrakesPros.com
  245. Searching for rear rotor info
  246. 2004 accord disc conversion???
  247. RSR springs help
  248. Braking issue, help needed.
  249. ek/eg/ef pic coilover body
  250. Changing coilovers from Skunk2 to Ground Control
