wheel bearings
wheel bearings
I recently hit a curb with my front passenger tire. it slightly bent the rim. the front passenger tire is shaky and progressively getting worse. Is this just the rim or will i need to replace the bearing as well?
Re: wheel bearings
Lower control arm and ball joint may need to be replaced as well. You may need to get camber adjustable upper control arm, to ensure tire has proper contact with the road.
90H22
01-28-2003 09:47 AM
