View Full Version : Suspension & Brakes
- I need help to Choose
- backspacing?
- da rear lca on an EG?
- installed ksports today, got a question?
- Loose Ball Joint?
- trying to install suspension techniques front sway bar on a 1996 cx
- Does this bar do anything?
- need some help deciding on some struts
- Help: what oem parts used in Koni/GC?
- TEIN replacement springs on stock struts.
- Tight turn chatter
- need shop in sO*caL to install my lowering springs and camber kit!
- Ball joint separator tool that actually works!
- Progress group spherical bearings on aftermarket arms?
- Suspension questions for H22a Integra - 94 LS
- da suspension onto a eg/dc need to know asap!!!!!
- KYB AGX clicking after install
- How Low Are You / How Low Can you go on Bilstein Sport Shocks
- hub problem
- Quick question on assembly of Tokico and Ground Control.
- grund control limited edition vs. regular ground controls
- how to change tie rods?
- lost with what setup to go
- are camber kits necessary?
- Shocks/Struts queston
- honda EF or DA adjustable tension rods?
- Top hats
- CHEAP Ebay coilover, spring rate= 400
- Koni Yellow owners.
- subframe reinforcement: removing tack welded bolts
- 89 civic suspension question what should i use
- Need some info. on shock/spring combo or full coilover that's good for a turbo car.
- Tokico Illumina R (RAK-502)... Anyone know about these?
- scientific question
- help with tein flex
- Ground Control Extended top hats
- SUPER TRICK FRONT LOWERING SPINDLE
- Eibach Sport-system kit or Tokico Illumina suspension kit?
- Omni street coilover adjustment help!!!!
- NRG Seats?
- Ohlins
- Alignment issues...?
- dc integra/ek civic front sway bar question
- KONI / GC QUESTION
- lowering springs for integra
- Lowering a Car put extra stress on Upper Ball Joints???????????
- EK Civic Konis on a DC Integra - EK LCAs?
- right shock or spring being noisy
- REAR TRAILING ARM BUSHING X-TRACTOR?????
- Suspension Collars question
- camber kits question
- How do set everything using Ksport?
- FS or FT: 94-01 skunk2 coilovers 0700.2.50.010
- H&R Springs Question
- FS: Trailing Arm Extraction Tool
- how do you like you s2 dampers?
- Brembo brakes
- conversion?
- Installing ITR Sway bar with ASR brace?
- tokico blues with skunk 2 springs????
- need help
- worth getting LCA's??? Skunk2 preferrably
- What should i do? need help with rear break and suspension!!!
- eibach sportlines on the front and ground controls rear ?
- Mugen 26mm Rear Sway bar
- Sleeve Coilovers Vs. Full Coilovers
- eg/dc front shocks on a da?
- EDFC help.
- what to do if stripped screw??
- Ball Joint
- front and rear conversion?
- KONI "Lifetime Warranty"
- Change suspension settings for Drag Racing...
- adjustment rod for tokico illumina where do i get it
- bad ride!
- Replacing LCA
- Car Feels Dipped to the Left on 97 Civic DX
- torque specs for suspension?
- Edelbrock Coilovers
- any companies that make all suspension pieces?
- ebay coilover review?
- lower control arm Q
- need some info
- Anyone hear about Koni Reds coming out for Gen7 Accord?
- 2" drop daily driver.. HELP ME on a spring rate/struts!
- Koni/GC Squeak Problems
- ITR 4X114 Suspension Question
- Alignment After A Drop?? Again??
- stock shock and GC coilovers
- TEIN SS for 99 civic anyone put the EBC on them
- beaks kit...anyone have it?
- Are EG and DC suspension parts compatible?
- WHO HAS APEXI ExV COILOVER?
- Replacing bushings with billet inserts
- skunk2 coilovers drag kit
- Stiff Suspension (EK related)
- Traction Bars?
- Will EM2 Rear Swaybar fit in an EG?
- is this all i need to install ITR swaybar?
- koni/gc assembly
- Cheapest price on Omni Street Coilovers?
- H-Brace = Lower Tie Bar???
- adjuster stripped
- SUSPENSION SUGGESTIONS FOR 92 DA
- Man my Apexi WS won't clear the rear sway on my EG? WTF!?
- Suspension is a little off
- full coilovers
- 94 Integra Suspension on an EG? Why?
- ITR Front Sway Bar -- good enough for an EG?
- Eibach sportlines with Tokico Illuminas?
- anyone runing spoon fixed dampers with progressive springs
- Type- suspension question
- rear suspension suddenly bouncy?
- How to adjust ride height on my omni's
- what LCA do you use and WHY?
- energy suspension motor mount inserts Do they really eliminate wheel hop??
- SI rear sway endlinks...can it be removed? Will Blox aftermarkets fit?
- front camber setting on dc2
- which shocks
- 5 lug crx possible and how to?
- squeaking when going slow/turning
- Axle nut will not come off
- suspension math?
- ITR wheel bearings
- K-SPORT shock just BLEW!
- NPG Suspension..! Help
- street spring rates, some light shed
- i already have all the parts, but did i make the right choice?
- ot: No "dorifto" championship, but we....
- Axle problem: Integra. Do I need new ones?
- clocking RTA bushings and lowering
- Setup on Koni/GC
- Skunk2 or Omnipower Coilover sleeves?
- Installing lowering springs on civic.
- Tein Flex + ITR LCA + Exhaust Clearance Issues (NEED SOME HELP)
- Wrech to adjust height on coilovers, don't have it ....
- Coilover sleeve ride height adjustments ???????
- Adjustable Coils and Struts for 4th gen. prelude
- Coilovers vs. Matched shocks/springs
- some opinions on the blue konis?
- eg/ek susp/help
- Question on MFactory Rear Sway bar and ASR Brace..
- Camber kit advice
- Back to basics ground control and koni yellows
- Eibach Or Suspension Technique sway bar?
- is it necessary to grease bushings on honda's?
- Anyone know the link to the WRITE-UP of "How to install lowering springs"?
- rtas for rear disc
- srr lcas
- Bump stop question - installing Neuspeed Sports on a 97 Integra LS
- CB7 Feature on High-Performance Handling Handbook
- Good deal on KYB Struts & H/R Springs?
- Prelude with GC coilovers custom spring rates?
- KYB AGX Shocks W/ Progress Springs on 93 Hatch... questions
- Replacing all wheel studs with new extended APR hardware
- Del Sol-Energy Bushings responsiveness+torque specs
- TEIN FLEX on del sol what RLCA's to use?
- little help??????
- Suspension Techniques Front sway bar Pics
- agx purches...
- Eibach pro-dampers with Road Race springs
- Suspension Q please help.
- superstreets w/ pillow mounts`
- need help: good rear LCA for 93 civic with ITR rear sway bar
- pre loading the suspension??
- Upper control arm bushing bolts squeaking
- please help with rumbling front end
- suspension help
- (maryland)where can i get my omnipower camber kit installed at?
- 2" or 1.5" drop on 17" rims. ???
- endlink bushing broke??
- GSR Half Shaft used in H22A ?
- Ksport Coilovers for Ek 96-00 civic used for about 4 months
- ksport shock blown
- Where to get Tein parts (helper springs)?
- K-Sport Settings
- Acura 1.6 EL '97
- I Need Help On Extending My Top Hats...
- tein basics, how low?
- Best way to get my '07 V6 to handle more like a G35?
- Suspension Help for Camber Kit/Rear Sway Bar/ LCA !
- Need help with a 2000 GS-R suspension set up
- eibach pro kit with tokico illuminas?
- looking for major suspension upgrade
- tein superstreeets
- KYB AGX's
- SRR LCAs
- suspension setup question.
- willwood bleeder valves help???
- shocks making noise
- KYB AGX Shocks on Progress Springs Question... 93 hatch
- GC Coilover Spring Rate
- got my skunk2 struts/coilovers on
- Eibach sportlines
- Neuspeed lowering springs or Ground Control coilovers?
- DC 5 lug conversion
- DC lower tie bar install Questions.
- agx's front gr2's rears?
- 2 inches
- coilovers help
- jdm disc conversion!
- shock noises ?
- CAMBER WEAR!!!!
- help am new
- Omni Street vs Omni Sports?
- Cannot get nut off top of shock!!
- tokiko struts and H&R springs problem!
- koni question
- hit a curb.. will it be safe?
- Alignment shops in Columbus OH
- Did I destroy my hub?
- what springs did a search
- Tein super streets vs. Buddy club N+ dampers
- ABS sensor troubles, 4x114 Convers
- does anyone remove the rubber piece in the top hat to get lower?
- what you guys think is better?
- i need to know where the springs go....
- whats a good camber kit for a 90 civic
- GC question Really stupid im sorry please just help
- upper nut on the shock (cant take it apart) help! 14mm
- Sleeve Coil-Overs On 95 Accord
- will tein ss fit on civic
- who has used omni power full coil-overs on there integra
- Spring rates too high on GC/Koni ?
- Good upgrade shocks to use with stock springs?
- Need help on GC/Koni assemblie!!!
- ground control problem
- EK front strut forks vs. dc shock forks
- koni+gc "bouncy" ride problem
- Whats the best suspension for a 94 EX?
- nex full coilovers?
- omni power full coilovers (street)
- Suspension upgrades help
- question with rear swaybar
- 00' EM1/ TYPE R Suspension question.
- DIY rollbar for CRx
- CAN DC SPINDLES BE USED FOR CRX?
- Quick question about the koni yellows
- strut rod mpves when driving
- Tokico Non-Adjustable Shocks & Spring Combo (As Seen on EBay)
- coilover decision: megan, form and function, omnipower
- Aftermarket Honda Fit shocks/struts?
- Tein Suspension for FG3
- Bilstein Touring class???
- i need a complete supsension overhaul....opinions/suggestions...?
- Ball Joint ?'n
- KYB GR-2 shocks any good w/ Tein S.Techs?
- Endless Zeal pads CC-X cant find and need help
- westend alignment
- First Time Ever - My Car's Aligned To Spec
