PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. EM1 LCA ?
  2. odd steering alignment symptom
  3. Springs and struts for eg/dc fit eks right?
  4. megan racing lca
  5. Help! Which springs?
  6. selling ksports for something else
  7. Shocked crazy
  8. The effects of negative toe in practice
  9. Koni yellows question
  10. shock/ coilover opinion
  11. Weird sound from rear suspension
  12. omni power front lower control arm bushing replacement
  13. Tired of getting beat up the road...
  14. Have a 1991 integra, will camber adjusters for 88-91 civics fit?
  15. WHATS THE BEST???
  16. Will They Fit???
  17. Camber kit
  18. need help with suspension
  19. Looking for front & rear camber kits
  20. Desperate! switching from AMR to Koni/GC due to ride harshness....can i re-use the AMR top mounts,
  21. Enough is Enough with Camber!
  22. Traction Issues. Help?
  23. tein ss coilover question
  24. Springs on an EG
  25. Just got my S2K with Tein Green Coilevers.
  26. wat better
  27. suspension 101
  28. Is there a rear sway bar that will work with CX lower control arms?
  29. suspension question
  30. 91 civic suspension setup
  31. Will 99 civic Si springs fit a 97 civic DX?
  32. Blox Adjustable Endlinks owners: I need your input???
  33. Can you buy replacement BUSHINGs for BLOX LCA's?
  34. Tein coilovers for crv
  35. itr lca's on eg (del sol)
  36. function/form type 1
  37. Putting coilover sleeves on.
  38. coilovers
  39. alignment issue.
  40. miracle x bar and c pillar bar?
  41. Brake problems help!
  42. RaceRunner Springs?
  43. Got a quick question about a suspension brace/bar???
  44. Help me with my EG project!
  45. Top hat nut/shock rod problem
  46. Koni Yellows with stock springs on lowest pirch???
  47. Need Some Advice on Suspension
  48. Kyb Agx With What Springs?
  49. New Shock and Springs now Bouncy
  50. Koni Yellow's into a '00 Sir
  51. Ground Control COILOVERS not low in rear
  52. Koni Yellow + OEM ITR Springs Height Clarification ????
  53. Koni SP3s vs. Sports
  54. NEED HELP. INSTALLING COILOVER SPRINGS
  55. need suspension setup for ek h22 type sh
  56. Front suspension Binding up
  57. Is this normal for camber issues?????
  58. *****Help finding rotor size for sir eg6 ...******
  59. godspeed adjustable vs skunk2 pro S coilovers
  60. Ground Control sleeves for a 92-00 Civic on 94-01 Integra?
  61. 1st time, installing my new suspension.HELP
  62. DC to EK LCA question
  63. Bushings on rear sway bar?
  64. Did 1992 civic CX's come with a front sway bar?
  65. drop springs?? spring rate??
  66. keeping smooth ride with skunk2 lowering springs
  67. Suspension For My Civic
  68. Will Koni's Allow my car to sit lower?
  69. Fundamental question regarding progressive-rate springs and their relationship to dampers
  70. Will 92-00 Civic suspension work in a DB Integra?
  71. Lower Down
  72. lost tokico illuminas red adjustment piece
  73. Good powder coating shop in the south bay area?
  74. Best Set Up to Lower My 08' Accord Coupe
  75. Front Swaybar/LCA on EK
  76. stuck LCA bolt heres MY solution
  77. Question on my Setup
  78. 96-00 Civic Suspension (EK) on 1992 Integra (DA)
  79. Tein vs. skunk 2
  80. Anyone running GC/Illumina Setup on a 00 si????? I NEED HELP FROM A SUSPENSION GURU!!!!!!
  81. progress camber kit?
  82. EM1 suspension set up.
  83. Suspension set-up and question
  84. ITR springs on GSR Koni Yellows?
  85. Whats the difference b/w mugen & OEM rear trailing arm bushings?
  86. lift throttle oversteer
  87. Fixed spring perches vs Coaxial spring perches
  88. Squeaking Sound When Braking...
  89. CAR TOO LOW+FLAT TIRE=HELP!!!
  90. KONI Yellow strut concern
  91. Koni 1150 coilovers?
  92. R-Crew Subframe brace
  93. extended studs installation question
  94. Drop Spindles
  95. Looked but didnt find....
  96. what dampering system should i get in my eg?
  97. KEI OFFICE Coilover Suspension?? on EK hatch
  98. Skunk 2 Sport Shocks
  99. rear disc in ek question
  100. ek suspension on dc2
  101. Anti seize where the ball joint goes in the knuckle? answers ASAP!!!
  102. Coil Bind/Bump Stop
  103. Help Dumping my car!
  104. skunk2 struts
  105. Shock mount fitment
  106. im not that low but why am i on the bump stop koni/GC setup
  107. Help with a DIY please.....
  108. Ek Pro Series Plus front camber kit:
  109. Tanabe TEAS vs. Tein EDFC
  110. twin bloc calipers
  111. How tight to make nuts on shock piston shaft? (Koni Yellow)
  112. [B]ASR Brace, F7 LCA's, ST sway bars F/R!! anyone have this on an EG? [/B]
  113. OEM Endlinks
  114. Skunk shocks w/ skunk coilovers
  115. My suspension plans
  116. Question on rear sway bar end links??
  117. Eibach sportline question
  118. 94-97 Accord H&R Sport Spring
  119. toe is really bad after front LCA install
  120. Progress Coilovers
  121. Anything to keep the balljoint from spinning?
  122. Quick Question about my ZEAL b6 coilovers on my R!
  123. need assistance on this...ksport??
  124. rear bolt and washer camber kit?
  125. Most suitable set up for DD
  126. can you still adjust koni yellow without the white knob?
  127. h&r race....
  128. subframe kit and reinforcement kit?
  129. Traction bars and front sway question?
  130. Do ef front forks work as a "drop fork" on a 96-00 civic?
  131. Will They Fit???
  132. Tein RA DC2
  133. GC top hats W/ Camber kit
  134. QQUESTION? I HAD SOME COILOVER put on my ek4 ferio. and i had drop all arould evenly and my rear is
  135. Koni specific GC coupled with a AGX/Lumina's/Blistens?
  136. Looking for info on JDM Ohlins
  137. Skunk 2 Coilovers with KYB AGX's good setup??
  138. going to try to install my coil sleeves on my da9
  139. 96 Integra LS: Why not just set the camber at 0 degrees in front and rear?
  140. spring rate megan sleeve coilover
  141. Energy Suspension inserts or Avid motor mounts?
  142. Caliper Operating Temperatures
  143. Maximum drop
  144. Camber Kits...
  145. good suspension
  146. Who has FUNCTION & FORM FULL COILOVER
  147. rubber spring protectors
  148. GC thread body removal off Koni shock help!
  149. KONI + GC??
  150. GAB sports
  151. KONI 2812 for ITR DC2-HELP!
  152. Who sells Ohlins coilovers
  153. help with teggy with 17''
  154. EG and EK GC coilovers
  155. please help! rear strut mount bushing 92 civic, how do I get it out?
  156. Does anybody here really know about suspension?
  157. front end wheel bearing replacement
  158. where can i get splined lug nuts in south OC ?
  159. how low can i go with omni full coilovers
  160. how do i take these springs?
  161. will ef tokico blues fit on my DA teg
  162. cutting a hole in the shock tower:
  163. eg struts in ef what i need (JIC)??
  164. D2 Coilover question for you!
  165. my car shakes.
  166. Ground Control/Koni H-T Discount??
  167. gc/koni problem
  168. itr suspension vs gsr suspension
  169. TEINS from a 92-95 civic on a Del Sol
  170. skunk2 camber kit OR oem uca?????
  171. Most worthwhile suspension mods for an EH?
  172. Koni Yellows. Mounting Perch? which is the right way?
  173. da springs on ef??
  174. Coilover problems
  175. H&R race springs on my 98 EK
  176. GROUND CONTROL ????
  177. Skunk2 Proseries S How to...?
  178. EG drop springs on a EF.
  179. tein bump rubber
  180. Softer Ride Quality
  181. Ef Front Forks on DC
  182. ? Is OMNI still replacing their breaking front shock collars?
  183. Why is my car pulling to the left??
  184. Is this nut stripped? Can I still drive the car?
  185. compliance bushing not complying (help, advice?)
  186. ef6 crx gc/ eibach spring rates
  187. Best place to get good ball joints / tie rod ends?
  188. Please Help
  189. ~>~>~>~> I NEED ASR END-LINK HELP!!! <~<~<~<~
  190. Adj. Sway Bar Endlinks needed with SK2 Rear LCA's?
  191. DropZone shocks info..........
  192. EK suspension on DA?
  193. PIC vs F2 Autolife Type II?
  194. i have a problem w/ my rotar i think
  195. Recommendations for Budget Set up
  196. H&R Sport Springs on Accord
  197. Allignment always goes off uurghhhhh help
  198. will 00' gsr sleeves work on a 97' civic?
  199. ASR 24mm swaybar?? Bushing??
  200. Tokico RAK coilovers anygood?
  201. gc extended tophats
  202. Coilover help!!!
  203. Ebay coil over question
  204. Suspension Brag thread (just a fun thread for ppl to post what they got)
  205. question with installing poly bushings in front lcas
  206. Advice on 200-230whp DD/Drag
  207. Which spring rate for Ground Control
  208. Function & Form vs Ground Control/ Koni Yellows Opinions
  209. type r swap
  210. help slammed people!
  211. tried many suspension setups HELP
  212. Skunk2 Pro Series-S, ways to soften ride? ...different springs?
  213. car not sat level?
  214. Question about front sway bar on del sol
  215. type-r swaybar 23mm for civics 92-95
  216. Tokico RAK vs Skunk 2 adjustable coilovers?
  217. shock/spring vs swaybar $$$ is an issue
  218. skunk2 camber kit on ef
  219. Tokiko and GC combination question
  220. cheap upgrades
  221. Mugen Shocks?
  222. Skunk2 poll
  223. accord disc conversion on an eg? possible?
  224. tein coilovers
  225. Daily driver EG... need advice..
  226. How to install Blox adjustable endlinks on LCA??
  227. camber kit on my ef
  228. D2 LCA's, endlink question
  229. Question about H&R Race Springs on Illuminas...
  230. putting in a full Tein Coilover kit and Skunk2 front camber kit 2morrow and just wanted to know.....
  231. Rear lower tie bar 98-02 Accord 4-door
  232. Picture of a 84-87 crx/civic spindle.
  233. Install help on Tein Basic Coilover
  234. Too stiff??
  235. skunk 2 shocks/coilover combo....any good?
  236. alignment problem: toe in
  237. How would H&R sport springs ride on an EF chassis?
  238. Shocks/Struts Installation Questions
  239. What do you track guys set CO height at?
  240. shock comatibility
  241. 99ek coilover question
  242. Shocks & Struts
  243. HOW???
  244. Neuspeed Front Upper Strut Bar Fitment
  245. Are the spindles the same for a 92 dx and a 98 dx?
  246. Suspension install/alignment shop?? - TAMPA
  247. i want it dumped but...
  248. Neuspeed Rear Lower Tie Bar wont fit?!?!?!?!?!?
  249. How many of you use spring compressors to install lowering springs?
  250. 99-00 Civic Si Front Lower Control Arms on 92-95 Civic Cx?
