View Full Version : Suspension & Brakes
- ground control spring rate
- Ctr Red strut Bar
- Will installing new struts/shocks raise my car a bit?
- 1" extended shocks top hats
- Can you put an ITR rear sway bar on '93 Civic VX?
- Dampening limit of OTS Koni Yellows?
- Im F*****.Bent strut
- trailing arm Question
- crx front lca's???
- function7 front lca
- SPC Rear Camber Kit Question
- JDM Front LCAs?
- ACCORD COILOVERS
- NOT bottoming out on Koni/H&R Race, how to?
- Top Mount Bushings ITR vs POLY?
- I wanna get better shocks, help needed !!!
- Tein Super racing damper and Tein N1 damper Opinions
- suspesion setup on my ek
- ***Questions about installing KYB GR2 Struts and H&R OE Sport Springs***
- Omni Power 1 Piece Coilovers, can I go any lower? (PICS)
- cheap suspension?
- finally going to do it yay!!! 5 luggin ?
- function and form decal
- Loud thuds?
- Advice please on suspension components
- shocks
- 380/380 Ground Controls 5th Gen Prelude Just Ordered! Opinions wanted please!
- Suggestions on NEW Suspension set up
- alignment in MD
- Possible Wheel Bearing - No Idea
- what coilovers will to slam 5th gen prelude
- Where are you getting GC/koni's from?
- Ground Control which springs belongs in the front ?????
- Are Illuminas really adjustable?
- Car handles bad now after installing tires!!!
- having problems with tien's
- complete suspension rebuild?
- help with my accord
- Front end set back on passenger side - need help.
- How Do I Install Coilovers???
- Rebuilding shocks?
- Koni Yellow/GC: Where's my suspension travel?
- CRV 5 lugs conversion
- integra hub same as civic si hub?
- Can't find function 7 lca's anywhere help!!
- Opinions on TEIN Coilovers
- pic or koni/gc
- Help me set up my camber angles! :)
- Revo Technica camber kit?
- Dropzone / Springtech struts?
- Front end alignment and lowering - camber and tire wear, etc.
- ***Ground Control question***
- Something Fishy About Super Racing Tein Suspension I Won From Ebay . link inside
- ground control, which one??
- ITR springs on an LS/RS/GS and OEM shocks
- Help: Rear sway bar hitting exhaust
- Getting a creaking sound from the front passenger side suspension???
- ksport questions
- Is the Tokico Illumina Suspension Kit any good?
- CUSTOM koni road race suspesnion????
- Function Form Coilovers
- Bigger brakes for a prelude
- Squeak,help me figure out if i blew anything please
- endlink and sway bar position
- ~~~~~WHICH COILOVER!?!?!?!?!?~~~~~
- quick question on gsr rear disc swap
- how to install camber kit front and rear
- Omni coilover help-collar recall-replacement
- will EG rear lca's work with a ek
- energy suspension
- anyway possible?
- 91 accord, did rear disc swap, should i get Master Brake Cylinder from all disc accord?
- ebrake wont engage?
- ***Trailing Arm Help***
- shocks with skunk2 springs
- Shock Design?
- H&R OE sport springs...
- Alignment shop south nj...
- lower arm
- tein s & koni?
- suspension help! weight transfer sucks!! (pic)
- It's going down... couple questions
- 4 lug conversion???
- need instruction how to install agx shockstruts pls
- An issue with my Koni Yellows
- Questions on EG lca's. and coilovers
- f2 install
- integra H-tech springs with kyb gr-2 in civic ?
- nose dive
- Brake Lines With Koni Install
- 6th gen sedan on neuspeed race springs
- -Spoon strut- Price Please HELP
- HELP im a noob to suspention
- NH! Alternative Rear Shock Absorber Bolts
- Suggestions for better ride?
- Can I reuse stock LCA's with new suspension setup?
- toe in/out adjusting seized
- 16x7/8 +35 Fit an Integra?
- diy extended top hat
- Best double-wishbone Civic
- tenzo r springs?
- EBAY COILOVERS
- STOCK SHOCKS
- original suspension
- adjustable endlink install
- I got skunk 2 springs.
- EK Front/Rear Swaybar Setup
- EG and EK
- integra type r lcs
- Eibach Pro-kit or G.C. coilovers?
- suspension setup questions.....
- just lowerd my integra and weird noise now
- Function/Func Type II
- srs light after alignment mechanic screwing me
- who makes this strut bar? help!
- function 7 lca w/ beaks kit?
- SPRINGS
- ksport customer service
- Omni power?
- Pic of ITR sway bar on EG??
- I need help choosing suspension.
- Which H&R springs for my tokico illuminas?
- aftermarket / adjustable length front knuckle for ef or dc2?
- Ball Joint or Tie rod?
- How to tuck 20's?
- tokico illuminas going out?
- Good strut bar?
- Sporlines or Stech? Coilover or not?
- Suspension Prob.
- Front vs Rear springs??? Colors
- 92-95 Si/Ex front sway on 99 lx (searched)
- Camber angle...
- will a del soltraction bars fit a ek ?
- rear disc swap. ebrake problem
- first time shock install question/problem CRX
- Install a Radius Rod
- what front strut bar will fit 96 ek hb with b series
- Who makes the biggest front sway bar for 96-98 civic?
- question on lca
- skunk 2 coilovers
- Just installed GC tophats. Can I do this?
- strut bars for eg hatch
- KYB AGX's And Groundcontrol Coilovers
- Quantum suspension?
- Looking at buying Skunk2 lowering springs (non adjustable) anyone have them on there EK?
- GC slip on's, have a question.
- suspension setups on high hp wheelie bar cars??
- Binding bearings? - GR2 and Eibach springs install
- Tein Super Streets or KYB AGX w/ Skunk2 coil overs ?
- "sloppy" steering. possible to fix?
- some questions about tokico illuminas and ground control coilvers
- excessive leaning & rubbing
- ^^^^^ Need help with Function & Form Coilovers ^^^^^
- OEM shocks...
- which stabalizer bar should i buy
- supspension problem
- Need EK Rear LCA torque specs please!
- omni help
- Apexi N1 Coilovers
- No picture thread of your car and your drop???
- upper control arm removal
- best for the money
- Rear Disk Swap PROBLEM pleas help!
- Rear suspension bolt seized
- lowering question!
- Ground Control options
- 96 Civic - KYB AGX & H&R Race - Possible blown strut.
- How do i keep the coilover rings from coming loose?
- Endlinks for st sway bar for 93 Integra
- beaks!
- new omni lca vs fuction 7
- Lowered car, driver side sids a bit higher??
- 96-00 Civic 5 Lug conversion question
- EF Camber ADVICE!!! Please read and comment
- Blox UCA question
- Bay Area Suspension Gurus
- tein nr
- upgrading suspension.. help!
- Speaker tray squeak.
- The Squeak
- sway bar Q?
- suspension kits and such
- T1R coilovers DC2
- best shock for skunk springs
- HELP - spring rates for gc/koni setup
- omni front lcas
- compressed TEINS...?
- 5 lug conversion using 4 lug spindles front and rear
- whats the main difference between skunk2 pro-c and pro-s coilovers?
- Need advice
- Toe Measurement/ Setting Tool
- ///-Problem installing GC sleeves/kyb AGX - 97 Civic-URGENT
- sway bar question
- anyone cut their tein springs
- Suspension problems/questions
- CTR suspension.
- efdsed
- want to lower my car
- Help. My car clicks and knocks.
- im kinda confused and annoyed. CAMBER PROBLEMS
- omni old lca?
- Just Say No to polyurethane bushings
- Lower control or upper control??
- Where can I order custom spring rates for Teins?
- Strut?
- LCA's Question
- MUGEN N1 Coilvers STUCK!
- SH- Longer than normal springs
- how to stop car squatting?
- really bad shaking??
- Toe or camber?
- em rear sway bar sway bar problem
- Help for 1.6 EL
- wierd sound please help
- Bushing Question
- need new shocks. agx or TOKICO ILLUMINA
- Ground Controls for agx shocks, what other shocks can i get?
- Bilstein Sport shocks
- HELP!!! brake calipers hitting the front shock forks when turning all the way/
- Eibach spring's installed incorrectly..???
- omni drags
- about 1.7" max drop, wich shock and camber needed?
- crossmember installation
- rear toe out / toe adjuster
- what are the best coil over springs for a 05 civic ex
- short ratio steering rack
- underspringing mugen nz's?
- 94 LX, how low and best way?
- anybody ever heard of these?
- Which gives the smoothest ride?
- Camber Kit needed for alignment?
- 97 lude coilovers 2 94 accord? help plz
- 96 rear lca hep
- Koni Race/GC or PIC Select for CRX
- ~~~~????TORN SKUNK 2 CAMBER KIT ????! ~~~~~~
- Lower Tie Bar? Worth it?
- k-sport color question
- Lower control arm bushing
- Check your own alignment AT HOME. Longacre Toe Plates
- rubbing tires....need suspension advice
- Quick Question on Lowing on Tein Basics
- question about apexi ws sport coilovers
- What should my next suspension upgrade be?
- Spring rates and dampers
- EG rear suspension ?
- Tokico illuminas addjusment?
- How do you lower the lower control arm for an 05 civic
- Lower ball joint...
- koni adjustable setting for my car
- Choose spring rates for me please. (necessary info inside)
