View Full Version : Suspension & Brakes
- HELP!!! Tein Ra
- Integra pulls to the right under acceleration?
- Spring question for swapped civics
- spring rates for tanabe sustec pro ss coils + b18c5 + ek hatch
- Koni Sport Vs. Koni/Neuspeed version Sport?
- KTELLER.com Adjustable springs aka "coilovers", what are your thoughts/experiences.
- Stock Shocks + Coil Overs?
- full urathane suspension bushings
- tokico shocks
- What is wrong with my Eibach spring??
- Tein SS 16 way adjustable, which way do i turn to make it stiffer?
- who makes the best traction bar? (poll)
- Shock went through hood...still good to use?
- zeal coilovers
- Need to know if 92-95 Civic Shock will fit 88 Civic SI
- Omni Power Coil-overs for the 94-97 Accord...Tein Basic Dampers...need help
- Traction bars
- Si shocks on Teg
- Sprigs without struts....
- Why are RSX rates higher in the rear?
- KONI + Eibach Installation Article on DA (FREE) 39 Photos (800x600)
- Anyone with experience or similarity...KONI/GC With 450F and 400R
- Safe to drive my DB8 without a rear sway bar??
- s2000 rub?
- offset UCA anchors: install them backwards and get more - camber?
- anyone heard of hardrace?
- omnipower camber kit
- is it the alignment?
- Street CRX setup
- Are shocks really necessary after suspension mod?
- front lower arm from ITR
- Fixing a cross threaded coil over perch?
- Longer LCAs?
- kyb shocks
- will my arospeed coilovers mount right up to kyb agx strust?
- Broke Rear Shock bolt! need some advise, thanks
- A spec re inforcement subframe kit
- springs upside down?
- GC plus struts...
- Rear LCA bolt problem
- do skunk 2 come withe new bolts?
- Brake Rotors and Pads
- EG civic / DC integra type r suspension question
- K Speed Coilovers..
- Omni Power Or TEIN Type BASIC
- Whats a good price for JIC FLT-A2 complete coilovers?
- Omnipower specials
- Thoughts on Skunk 2 Coil Overs?
- Question about putting sleeve coilovers onto aftermarket struts.
- integra rear lca question
- DA springs into an EJ8 damper
- Spring compressor : TOOLS simple question
- Better than stock ride quality? caddilac style
- 16" Rims - Tyre / Suspension Setup Suggestions Required ...
- How to set
- Do i need to disconnect my Rear swaybar when cornerweighting and height adjusting my car?
- anyone know a good alignment shop in Westchester county NY?
- RSR down spring
- omni suspension being too stiff.?
- Anybody familiar with buddy club suspension?
- GC Spring rate *searched
- EP3 vs. DC5 rear calipers
- Steering Wheel Play
- integra rear swaybar?
- Skunk2 lowering springs....
- Just installed Koni Yellows and GC need help?!?!?
- diy for top hat
- how do you know?
- disc brake coversion on eg6..
- front shocks slip out of forks
- EDFC problem?
- Questions about Tein SS-P and NEX GT coilovers
- race design coilover
- This is my last Koni/GC question, I swear. Simple question....
- looking for a good alignment shop in PA(lancaster county)...........
- Fully threaded shock vs. coilovers w/ drag springs
- Zeal or Ground Control Koni Set-up
- LCA's
- What do you guys think about Koni Rsk suspension Kit?
- possible koni issue...lee@koni???
- spring rates!
- Apexi N1 99 spec revalve?
- anyone run Omni race coilovers....
- lowering springs for '99 accord question
- 2000 Civic EX Suspension Problem . . .
- lowering spring compatability
- I NEED HELP PICKING A LOWERING SPRING...
- What's the difference? (Tire Size Question)
- Dialing out wheelspin with shock valving....
- eibach pro kit w/ stock shocks
- TEIN or SKUNK 2 ?
- uneven suspension
- camper kit???
- Tokiko HP vs KYB GR2 for DA
- drag suspension w/street driveability?????
- Coilovers Best for Handling and is not harsh when im with my gf.
- Retarded Springs... Calling out for help!
- 90 civic si rear disc into civic 00 dx?
- What springs to get? (95 civic)
- [HELP] Removing rear strut and spring.
- dropzone JUNK?
- H&R Sport or Tanabe GF210
- problem with tenzo-R coilovers :(
- Type r 5 lug suspension
- is the suspension & brakes interchangable to a 91 4 dr civic hx
- my coilover alignment specs. ok or bad?
- Bushings/Bearing press
- Tokico Illumina/Tokico springs combo - $450 shipped, worth it? anyone got these? know the spring r
- how is it that my ingall camber kit is stopped from moving once bolted in?
- what kind of Shocks w/ H&R race springs
- Very loud noise coming from passenger side wheel
- GAB REVO coilovers
- i know its dumb but......................how do traction bars actually stop movement
- Ground Control Coilovers with.......
- Places to get alignment/cornerweighed near Portland, OR?
- sus help on my 92 teg
- sprint or h&r or eibach
- Type-R suspension questions
- EK rear struts into an EG
- tires rubbing well - help!
- Tokico Illumina or KYB AGX for 99 Civic EX
- bilsteins and what?
- coil over sleeves fit on my EK?
- Simple upgrades... Noticeable difference?
- Body rool is a killer
- DC2 vs. DB8.. which handles better?
- GC Extended Tophats fit Skunk2 coilovers?
- mugen 5 way
- which is better?
- Need help on LCA's ASAP!!!!!
- Suspension price, what should i do?
- Need advise/comparison between d2 and tein SS
- Zeal suspension users, need some feedback on springrates for ITR
- Advice Lowering EJ1 [Cost and Safety Important]
- EG CX Omnipower Coilover
- Omni camber kit
- Which Bilstein are these?
- Steering not right after accident, need input please.
- eibach drag launch springs
- kyb agx w/ H&R race. knocking sound?
- Will Zeal b6 for eg/dc fit ek's???if not what is needed???
- Best way to adjust ground control Coilovers?
- Can you get koni shocks with clicks?
- where to get drag springs?
- itr rear sway bar
- Tein STECH or Skunk2 Coilover system
- Need to know the best spring rate for my application
- replacing studs on civic
- Inverted coilovers vs reg. coilovers
- H22 Civic suspension questions
- Just ordered KYB AGX...
- urethane bushings with a zerk fitting?
- Koni Sport Shocks + Ground control sleave question
- Roll bar safety for rear seat passengers.....
- Will 2000 si springs fit 93 ex coupe?
- 2 inch drop on ej1 whats the best camber kit (arm replacement)
- Spring rate; Converting kg/mm to lbs/in
- Red SRR LCA's
- help with rear sway bar install...
- should i stick with ITR springs?
- Steering Wheel "Wobbles" @ Low Speed, What Causes?
- anyone have any opinions about nex coilovers
- what are good bushings?
- ITR springs/shocks/LCA on a 99 civic EX sedan?
- CRX suspension swap---Converting stock crx suspension with Integra suspension
- ground control upper mounts and axles
- Unit Conversion
- OEM springs + not enough sleep = 4x4...
- skunk2 coilover spring rate?
- suspension question
- new axle cause pull?
- trailing arm bushing part number
- When Omni's new coilover will come out??
- KYB AGX's
- "full" coilover differences....
- Any benefit to using ITR rear lower control arms?
- for all who have installed Omniman coilovers LOOK!!
- After Market LCS Issues
- CAMBER KIT???
- will ek susp. fit on eg??
- HELP bolts broke (rear suspension 97 integra ls)
- annoying squeeking noise
- stock spring drop
- Welding balljoint camber kit.
- Questions on Sway bar's.
- Need springs
- Comptech Rear Sway/Tie Bar + Apexi N1 catback Question
- Where are omnipower coilovers made?
- Ball joints and white lithium grease
- Traction Bars
- 97 H22 on a 96 civic 2dr best suspension
- Reading on Gyrosopic Effect to Stabilize the Car on Uneven Surfaces
- didnt c wut i needed
- spring install trouble **Free Laugh**
- Suspension / Chassis Books - Reading List - Reviews
- looking for a shop to buy springs (menlo park SF)
- KYB GR-2 SHOCKS/STRUTS For a 89 CRX
- Eg6 H22 suapension question.
- energy bush for integra question
- OMNI owners... install question- EK
- skunk2 or ground control...?
- Tie Rod help
- :::G-C&koni yellow, What rest of parts do i need?:::
- Monroe's??
- gsr or itr sway bars
- tein basic vs. omni power vs etc
- The idea of Preloading
- Anyone installed air ride.
- Traction bars for 88-91 civics
- traction bar install / setup question
- anti roll bar compatability on EG w/ITR LCA?
- out of these springs/tein H tech *searched
- integra civic suspention... interchangable?
- H BRACE??????
- Omni power slip- on coilovers
- Cup Kits
- Omnipower Coil-sleeves w/ Tokico Illuminas
- Do these shocks work? 92-95 coupe? Help
- heated stock springs
- 88-91 civic camber kits? help
- camber specs
- ITR sway bar install parts
- tire contact patch vs. ride height
- koni yellows/GC adjustment question
- Question about Prelude Suspension?
- Suggestions on new springs and shocks...PLEASE HELP!!
- Spring Rate Question
- Can't decide on Spring rates...
- Tein SS Fitting...
- lower controll arms
- Tein Flex Too stiff up front; want some 8kg/mm springs
- URGENT Spring Help
- Illumina's and Tein S Tech ?
- disc brakes
- control arms
- shakeing when I let off the gas????
- Theory, Construction, Tuning books?
- Tein Springs ??
- 88-91 honda civic shocks?
- Nuformz Rear Suspension
- OEM Suspension Bushing Part Numbers?
- type r strut braces
- Please suggest Rear Lower Sway Bar for EG6
- dc2 omni power coilovers
- Anyone got problems with spring/sleeve contact with GC's??
- Hypercoil springs
- Couple questions for a new auto x'er Suspension pro's needed!
- How the hell do you get your ride height even?
- Buddy Club Damper Question
- 88-91 honda civic si rear lower control arm?
