View Full Version : Suspension & Brakes
- Apexi N1 99spec ITR coilovers
- Need your all's help....
- Best LCA out???
- 05' GS-R Tein S-Techs on a 02' TL Type S
- skunk 2 lowering springs
- k sport lowering springs
- Eibach Sway Bar Kit for 2006+ Civic??
- Too soft to be this low?
- Where to buy coilovers. (price wise)
- worst experience at alignment shop ever
- Will grade 8.8 bolt work for LCA's?
- Best suspension setup for street/strip.
- Drag race set-up??
- Rear LCA Bolts Discontinued?
- bushings
- suspension skunk2 pro s
- Question for people who know their Teins/EDFC...HELP PLEASE!!!!
- Apex N1 Damper Type EVX??
- Need Help Asap!
- KSport vs. Tokico Illumina/GC
- air ride suspension/air bags
- Accord Type-R brake upgrade
- HELP, car is too low on drivers side!
- Anyone experience with Tein HR
- tein basics on a car
- Help with ITR swaybar (pics included)
- budget brake upgrade
- lower control arms EM1
- Just bought some Eibach Sportline Springs for my 95 DC2 GSR
- WTF? H&R springs raised instead of lowered?
- Changing the spring rates on Omnipower coilovers?
- how to lower "adjustable shocks"
- gc part # for illuminas
- Apexi N1 99Spec Coilovers
- Camber Kits.......
- HELP! itr sway bar install
- Koni disassembly question
- Password spherical trailing arm bushing?
- spc adjustable balljoint help
- Need some opinions please.
- D2 Racing shock dyno results
- civic ek sway bar help..!!!!!
- Opinions Please- Rear Lower Tie Bar Clearance with ST Sway bars
- Rear Swaybar Help
- inner tire wear
- Will Accord/Prelude ARP wheel studs fit civic???
- Best way to lower an eg sedan??
- Problem with a set of KYB shocks
- I've always wondered (...regarding top hats)
- Need Help...DC Sports Lower Tie Bar
- Will this setup fit a 1999-2000 Honda Civic EX coupe?
- Anyone have a pic of the bottom of a Tein tophat
- 92-95 lowering springs
- 94 accord wagon- 1.5" drop- recommended spring/struts for stock ride?
- 96 civic drop?
- best LCA for being slammed
- Comptech Sway Exhaust Fitment Question
- Extended Top Hats of Koni Yellow Sp3's?
- help please just put skunk2 springs in
- Front LCA Bushings
- Preloading radius rods on a CRX with FullRace traction bars??
- GROUND CONTROL ADJUSTMENT??
- Still that damn noise!
- Do I need anything else/ am I forgetting something?
- Tein SS's or BuddyCub N+'s
- eg coilovers to ek?
- eg trailing arms on teg
- es bushing kit
- suspension tips
- Best suspension set up for ef hatch (three choices) on a $500 budget.
- H&R race springs for Tokico Illuminas???
- Extended top hats.........
- At what point does too much drop = Bad handling?
- Koni help >>
- gc with agx or tein basic
- i need some help. noob to suspension.
- koni/gc question
- help choosing shocks...
- Gc top hat/koni yellow install problem
- ksports hurting my tender tush
- TEIN BASIC THOUGHTS/OPINIONS???
- tokico illumina bumpstops
- Koni, removal of the circlip .. any tips ?
- quick question
- Ek comptech install help
- will this damage a shock?
- coilover springs on stock shocks
- Ksport springs, Whats wrong?
- trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
- Civic Suspension??
- Looking for Tanabe coil over.
- Skunk2 Suspension Q
- Progress Sway Bars on RSX-S... Good choice?
- Knocking rear swaybar
- How do you replace LCAs?
- Wobble and lack of performance - CRX
- Tein SS w/ Pillow Ball Mounts for $350-400??
- double check my koni set up
- Alignment needed
- Eg Si Suspension.
- problem installing prothane front endlink bushings on 95 integra ls
- real quick stupid question
- 96 itr rear hub and bearing same size as gsr?
- ES front endlink bushing nipple to large for DC2 LCA? end link bushing size?
- asr subframe brace kit & front suspension upgrade
- wheel bearing
- how to adjust coilover height
- tokico blues + skunk2 coilovers = won't go that low?
- who uses shock boots for their shocks?
- JDM ITR VS USDM GSR Calipers.
- coil over question
- Drivers side rear toe PERMANENTLY shot?
- rubbing issue
- Cusco Type OS Front Strut Bar for EK
- function & form type 2's
- looking for a spring/shock setup
- Swift spring dimensions for Skunk2 adjustable coilovers
- GSR strut bar or ebay strut bar?
- Need help with choosing correct suspension
- REAL QUICK: H&R warranty Question!?
- a few questions...
- which springs offer the most drop?
- best way to go wit springs some opions..
- 22mm rear confust on front size.
- replacing upper ball joints?
- will 96 coupe supsension fit on a del sol....
- will a 92-95 EG hatch suspension fit on a 94-01 integra 2 dr chassis?
- Is it camber?
- Was my alignment done right? (nooB)
- ep3r vs. dc5 base
- H-t suspension setups
- KW SUSPENSION Variant 1,2,3.......What are the opinions???!!!
- should strut bars be fitted with the car jacked up?
- ride height vs. wet roads
- tein basic / tein ss
- Gc Upper Mount, Koni Shock Body
- front sway bar = understeer?
- Cold weather effect suspension?
- Beaks on Benen Lower Tie Bar ?WORK?
- tire alignment?????
- hemi joints
- Which bushings do I load on Rear suspension?
- What spring rates are you guys running on your GC/Konis? MUST INCLUDE VEHICLE!
- 450f/ 350-400r on gc/konis?
- urethane nushing install tips
- springs from integra to Del sol
- Stock del sol shocks and springs
- Need some advice
- 00 SI, Need suggestions on spring rates!!
- Overdamped System?
- Goldline Lowering Springs
- What to expect: Same shocks, Lower Rates
- Form & Function full coilover feedback
- What are your Ground control spring rates with Koni's?
- car to slamed
- can some1 give me their camber/caster/toe settings please?
- Dust Boots and.... rain?
- What is the point of preloading?
- What kind of grease/anti seize for suspension bolts/metal bushings?
- Skunk2 Pro C coilover review (56K)
- ok so my coilovers are on...
- Koni yellow + Ground Control
- Neuspeed Race -or- Skunk2 springs?
- help with front steering knuckels
- Seized rear disc calipers
- LCA to TA bolt broke, need help!
- which bolts should i worry about breaking
- GC extended Top Hat for gc/koni
- Anyone using this spindle & rear link combo
- EF owner needs new strut forks
- squeaking noise when steering
- quick question on camber kits
- How much travel does the shock need?
- megan lca's on 91 civic help?????
- i want higher spring rates
- Bump stop
- spring rate question! Why?
- Skunk2 Coilovers????
- gc+koni installing right now. Few questions
- Between these two coilover set ups........which would you choose?????
- Question on spring rates
- Rear Brake problem
- spring rates
- ef civic toe adjustment?
- Can't turn my shock body.......frustrated !!
- J's Racing SPL Roll Center Adjuster { 00000h J's Racing !!! }
- can si shocks swap into my ek
- Suspension Guru's put your .02
- camber question
- tein or koni
- Press Release; the long awaited Pro-Series Traction Bars for 88-00 and 90-01 Integra
- ek/ del sol fit???
- Tein Flex or Skunk2 Pro-C
- Aftermarket Steering Knuckles
- Koni/GC or Keep Eibach Sportline
- Function & Form help
- 325/250 on gc+konis
- Not stabile at high speed HELP!?
- itr whiteline 22-24mm adjustable sway bar install pics!
- Del Sol handling
- What should I do?
- omni street full coilovers what sways?
- omni full coilovers on ef
- I'm At Wits End w/ My Car....
- Sk2s or Tokico shocks?
- what Ground Control spring rates? Koni yellow shocks. whats best for my setup?
- tein ha coilovers
- GR-2s bouncy after 45k on stock springs, what next? (DA)
- S2 spring rate question
- aftermarket shock forks ?
- drag race suspension?
- Places to get OEM brake lines for 1992 civic besides at the Honda dealer
- Suspension Question??
- Just got some gc+konis. Some problems...
- one of my koni shocks wont adjust! has this happend to anybody? how to fix?
- Annoying light knock... what could it be (see my diagnosis)
- LCA's ?? SKUNK2???
- 96-00 dx/cx knuckles vs ex/si knuckles
- Quick DC2 Sway Bar Question
- Weird noises from rear suspension after lowering car?
- Daily driving...
- Suspension review threads
- omin power coilovers? searched
- H or S tech teins
- Tokico vs KYB AGX
- suspension help!!!!!!!!!!!!!!
- need help with lowering EK
- bad shocks/springs.. what to buy new?
- Del Sol Suspension?
- Skunk 2 LCA question on EM1????
- Bad Roads, Stiffer or Softer Springs?
- nissan sentra SE-R brembo brakes on a crx
- koni yellows vs function form vs pic vs d2
- Help Broke adjustable nob off tein SS coilovers
- Lower control arm install HELP! 2002 civic
- Where to buy replacement rear LCA bolts?
- Will an axle change/repair mess up a wheel alignment?
- Tanabe Sustec Super H springs
- skunk 2 full coilovers VS. tokiko blues and neuspeed springs.
- am i going to need to do a camber kit?
- non-adjustable suspension suggestions for daily driver
- Tanabe Helper Springs...School Me H-T !
- need suspension suggestions
- Type R suspension ?
- koni ground control setup
- tein h tech owners...
- 92 - 95 Civic - Sway Bars / ASR Brace Advice?
- which is the best CAMBER KIT????
- REAR CAMBER KIT, WASHERS???
- Progress Group Drag Coilovers, any good?
