PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Advanced Brake Bias Calculator - Free online tool.
  2. '94 Accord Suspension Question
  3. Nice firm brake pedal ....sometimes?
  4. brakes squeaking, question
  5. Bump Stops?
  6. PITA LCA BOLTS!
  7. Sensible suspension?
  8. 1993 ex coupe non ABS calipers vs 1992 VX calipers
  9. Ground Control Spring Rates EJ6 Sedan 1996
  10. ek sedan suspension issues help!
  11. ef sedan springs and shocks
  12. Clutch pedal stiff after front coilover sleeve instal?
  13. 91 DA9 Bent Subframe or crossmember??????? 1 wheel hellaflush.
  14. coilovers
  15. camber is uneven...what would that effect?
  16. Progress coilovers
  17. brake bleeding
  18. DB8 Tein Flex full coilover
  19. heavy brakes problem
  20. Popping suspension
  21. 92-95 Front UCAs on 5th gen. Why not?
  22. help finding bsq mounting kit???
  23. Does Axxis Ultimates still exist?
  24. Honda noob, needs help with brake caliper bracket. overseas
  25. Ground Controls/ Tokico HTS fitment on EM2?
  26. Spoon calipers?
  27. Coilover sleeves
  28. wheel bearing?
  29. Help me figure wtf is wrong.
  30. alignment reading!
  31. Attn: Function7
  32. do we have a lowering spring thread??
  33. Front Camber-Kit Question
  34. 99-00 Si front sway on non-Si
  35. LCR's?
  36. alighnment
  37. Suspension promblem please HELP!!
  38. madfablab big brake kits
  39. Tein SS P ride height adjustment.
  40. suspension q's
  41. Trailing arm issue
  42. ok..think it's finally time for a suspension setup
  43. Would an Acura 3.0CL bearing fit the CB7?
  44. Coilover Life Expectancy?
  45. progress coilovers for rsx problem
  46. ED6 with FunctionForm Type1 Ride Height Question
  47. Help! Suspension set up !
  48. which brake booster do I need?
  49. ITR Springs & GC specific Konis
  50. Outer Tie Rod Lock Nut too small?!?!
  51. Blue Eibach Springs?
  52. NEED AN IN-EXPENSIVE CAMBER KIT
  53. integra/ civic si calipers
  54. 94 SI Hatchy squealing in reverse!!!
  55. Humming noise coming from front end. Please help!
  56. What trailing arm bushings to buy?
  57. Flexible Brake Lines?
  58. Suspension question
  59. bad brake booster?
  60. suspension problem need help
  61. megan ez streets or function and form type 1's?
  62. Question about rear alignment after lowering the car!
  63. 95 Civic Hatch Rear Disc Conversion
  64. violent intermittent wobble
  65. Knuckles
  66. EG Suspension Bushings, Help
  67. Recommendations for all new bushing set for the front 00 ex
  68. 96 civic rear camber kit help!!
  69. function and form type 1....ball joint question
  70. Which prop valve?
  71. extended ball joints civic
  72. replaced spindle now it sits lower?
  73. dc coilovers on da?
  74. Stiff front and OEM rear
  75. ITR Shocks Fit What Civic?
  76. Skunk2 pro-s ll coilovers
  77. 97 accord front end
  78. SKUNK2 Pro-S V2 PROBLEMS!
  79. How to assemble and install Ground Controls with Koni Yellow
  80. Help on usdm itr bushing replacement
  81. dc2 tein flex coilover issue.
  82. BUDDY CLUB CAMBER KIT???
  83. Control arm bushings replacement vs frequent tire rotation
  84. Rear trailing arm removal and alignment
  85. 96 civic coupe ex leaning
  86. Rear disk conversion on sedan
  87. 97 Ek sedan rear subframe damage.
  88. Need suspension to maintain car stability
  89. Steering Rack Leaks after sitting - then stops?
  90. plan on raising the car, new tires going on as well
  91. 91 CRX to 93 Civic sedan coilovers.
  92. Stainless brake lines questions
  93. 97 sedan raceland coilovers
  94. Stop Lamp Failure Sensor Help
  95. Another coilover question
  96. suspension help
  97. what can i do??
  98. 93 si rear discs vs integra rear discs
  99. Loud POP! Noise from passenger side
  100. Loud POP! Noise from passenger side
  101. Best and lowest coilovers for 92-95 civic
  102. Proportioning Valve Question
  103. Need Help!! Lost/Confused - Trying to decide on suspension for 00 Coupe
  104. I dont know shit about brakes! Help!
  105. Double Wishbone suspension
  106. Rear sway bar endlink mount points?
  107. 2005 honda civic em2 coilovers !!
  108. Rear camber kits? Factory bushings are shot
  109. Tire fender rub, fender roll?
  110. Suspension Refresh (95 RS Integra)
  111. Function and form 2 Coilovers
  112. 94 Honda Civic ABS light...
  113. 98 Civic EX Scarebird Conversion
  114. Took my diy alignment setup to the next level...
  115. GC purchase..need advice
  116. GC spring length
  117. Suspension Noob- Educate me!
  118. Buddy club n+
  119. Buddy Club N+ Coilover Review - DC
  120. Exhaust question for those riding low
  121. DA Integra Inner Tire Wear
  122. Spring & Damper Recommendations for a Worn-Out '95 EX Coupe
  123. spring rates leading to over/under steer question
  124. GC sleeves, Koni version. Whats the difference?
  125. Which coilovers (Full) or sleeve combo will do?
  126. new springs
  127. Yet another spring rate question and a unique coilover idea
  128. how to tell if aftermarket?
  129. what shocks are these??
  130. proper brake mc sizing for boosterless setup + more questions
  131. Suspensions
  132. 2000 civic si rear strut question....
  133. Rs 40/40 leaking!!!
  134. ABS light question!
  135. A few question about rear disc brake conversion
  136. Rear disc brake hose, Integra Civic Si?
  137. RL OR TOKICO help??
  138. Replaced Master Cylinder - Poor Stopping Power
  139. del sol VTEC - spring rates / sway bars
  140. Front brake line help
  141. drag rear suspension
  142. Suspension Setup
  143. Aftermarket or OEM LCAs
  144. EG2 vtec Del Sol brake uprade using the ITR/ MINI setup possible?
  145. 1992 Hatchback CX help
  146. Suspension Over Kill
  147. Need GC Spring rate expert advice!
  148. quick lca question
  149. What type of spring rates? Higher/lower or lower/ higher? Gc Koni
  150. Ground Control Perches
  151. m2 performance springs?
  152. Clicking
  153. Skunk 2:2.00'' drop springs with KYB AGX safe to run ?
  154. Any ill-effects of using 3/16" OD brake line for fuel line?
  155. rear disc conversion on 99 civic ex
  156. Rear disc brake conversion... Proportioning valve??
  157. EBC Sport Rotor Conversion 2009 Accord Coupe
  158. HFP Sport Suspension - 8th Gen Accord
  159. Special edition integra sway bar size
  160. What calipers from other honda and acura can i use in my 99 crv
  161. Megan Racing coilovers
  162. 92 Integra MC
  163. 22mm or 24mm front sway - help Gagnar decide!
  164. car pulling to left
  165. wilwood booster delete
  166. Car is low and bounces up and down
  167. Low brake at Low RPMs - 2007 CRV
  168. PIC or Omni drag coilovers?
  169. Gsr/Type R front end link question
  170. Spring Rate - Stiffer F or R?
  171. HEL S/s brake lines flare seat problem
  172. ABS light comes on
  173. brake response!
  174. Non abs disc to drum help
  175. Caliper help
  176. brake problems after tuck?
  177. skunk2 or junk?
  178. how to convert spring rates?
  179. Camber or alignment
  180. Hydraulic parts from Discount Auto ?
  181. New suspension set up
  182. ek civic full bushing kit hardrace or energy suspension
  183. Toe settings question
  184. Coilover Sleeve install??
  185. 95 civic lx front brake upgrade?
  186. Waiting time on AMR Engineering Coilovers?
  187. Washington Alignment/Corner Balancing Shops?
  188. 2003 Accord Poly bushing kits?
  189. 99 LS BRAKE TUCKING
  190. 95 civic rear drums
  191. H&R sport spring question
  192. Brake Help Needed!! 05 EP3 3Dr.40K HFP Northern NJ!!
  193. Megan=Hardrace
  194. Offset confirmation!
  195. Need upper ball joints and a inner tie rod
  196. When adjusting coilovers....?
  197. Rebuilding the rear suspension... suggestions?
  198. My Impression- Rear Strut Bar Removed
  199. ******5 Lug/Type R Calipers on GSR/LS HUB??*****
  200. spring rates for slamming
  201. Caliper sticking
  202. Anyone else almost crash after suspension adjustments?
  203. Assault wheel hop... it kills!
  204. My Impression- Front Upper Strut Bar
  205. new ek h22 help
  206. Best Spring Setup for Del Sol with KONI STR.T
  207. Blackworks Suspension Any comments?
  208. 1996 lowered, how to return it to factory spec?
  209. Ksport Kontrol vs BC BR coilovers?
  210. HELP! Camber issue
  211. Suggestions on suspension and brakes for del slo boosted.
  212. DA suspension rebuild
  213. Lowering springs = no drop URGENT HELP!!!!!!!
  214. front lower control arm bushing replacement problem
  215. Koni/GC spring rates?
  216. Spring Diameters?
  217. Civic/Integra Sway bars
  218. WEIRD STEERING PROBLEM
  219. PLEASE HELP!!!!!!!
  220. ABS Scarebird Acura 1.6 EL/Civic EX
  221. Over Steer/ unstable
  222. Spring rate question
  223. Brakes lines and caliper issues
  224. ETD traction bars..
  225. Lowering Springs for an EG sedan?
  226. Proportioning valve discontinued, so now what?
  227. Steering pulls - no solution in sight!
  228. Del Sol knuckles
  229. What lowering springs for standard Civic EK3 shocks ? 20-25mm drop wanted
  230. Brake pedal goes to floor - at a loss here
  231. can you tell which brakes these are?
  232. Super Low for Good Price?
  233. 94ex brake swap on eg
  234. Looking for a good front brake setup for my track car. Ideas?
  235. whee bearings.. 2005 civic lx
  236. Different types of caliper slide pins - '08 Civic Si
  237. Upgrade Brake Lines
  238. Skunk2 pro s2 vs megan ez street cloilovers?????
  239. Front end vibration 91 RT4WD wagon
  240. Del sol coilover's
  241. suspension squeaking?
  242. Top Hat Q?
  243. my ride height is off by 4mm??
  244. EG Sedan Suspension Idea Help DMV Area
  245. Skunk 2 Lowering Springs???
  246. Function and form type 1 on efs
  247. brake upgrade- leave rear drums
  248. Not sure whats going on with my rotors...
  249. so idk what to do. can youu help?
  250. Rotors warp after changing them repeatedly
