View Full Version : Suspension & Brakes
- TEIn or Skunk2
- tokico HPs? what struts to mate with neuspeed sports
- Powder coated suspension
- SRR Coilovers ?
- Caster is way off!!
- Traction bar tuning
- better than koni/GC
- Can't go lower in the rear?
- tein basics?
- debating on suspension tech. front sway install
- KYB GR2 warenty ???
- Busted Shock Effects Ride Height?
- Should i buy?
- Eibach lowering springs
- switch springs from coilovers now front is higher??? any suggestionts???
- people whoe have Password front or rear STB's
- Spindle, Rotor And Hub experts help me out
- H&R Sports Difference (Ek vs Eg)
- slipon coilovers....
- Front forks fact or fiction!
- Best set up for my situation?
- Power Steering Rack leak. Searched
- installed new suspension, weird noises?
- Ebay Slide over Coilovers
- **4x100 to 4x114.3**
- 90-93 integra.. koni yellows with nuespeed race or UGR full coilovers
- ::::::The Next Phase in Fully Adjustable Coilovers::::::
- Anyone riding on Koni yellows with stock springs?
- Quick DA/DC question.
- does anyone use D2 RACING RS COILOVERS
- Accord 95 camber kits
- 97 civic sedon on tein s-techs
- can anyone verify this?
- noob: why do you want aftermarket LCA?
- what coilovers for dc?
- OBX Gravitation Control System
- Does anyone know the spring rate limits of koni Reds?
- Which Coil over set?(dragracing)
- Question to Koni Yellow users about Top Hat Bushings
- Type-R coilovers on an LS?
- Noob alignment questions
- budget suspension
- neuspeed & next camber kits for eg6
- off the shelf spring rates?!?!
- Function7 Lca's + Comptech swaybar/tiebar anyone running this in an EG???
- (Spring+Shock) Combined dyno vs Bump Amplitude & Frequency
- cant put castle nut on?
- comfortable ride
- type r lca or aftermarket?
- Need alignment on going down on wheel size? 16" to 15"?
- tokico blues with ground controls
- need type r lca
- Koni Yellows / Ground Control Coils Do I need camber kit?
- how long
- Can I go any lower with F2's?
- just how bad would this be?
- k sport really stiff
- Suspension needs cleaning up
- Anyone install Quaife Steering Rack grears?
- EK neuspeed race springs fit DC?
- Omni power drag coilovers vs the pic apex coilovers
- 96 Civic Rear Disc Conversion
- SS brake line question: how to mount?
- EG brake master cylinder upgrade, worth it?
- GC spring rates with koni yellows on 98 lude
- what did I do wrong? Got GC/Koni yellows and its really bouncy =(
- Koni Yellow/GC Combo vs Coilovers??
- Strut Bars: Square tube vs. Round tube (theory and discussion)
- Why is Tein despised by so many people?
- spring ID and length for koni yellows
- blown koni yellow?
- looking for a new setup.
- Caliper/Wheel Setup Question...
- Installing anti-roll bars....
- subframe tear?
- will my subframe rip?
- what setup would be best for daily driving..GC's or D2?
- ETD racing
- Tokico blues?
- Tokico blues?
- tein s-techs on 96 civic?
- Question on trailing arm
- How Low Should I Go?
- car too low??
- Best suspension set ups for 92-95 EG//EJ?? Pics?
- what should be my new suspension?
- Rear brake pads rubbing after new rebuild
- Who makes an affordable coil over for a 4g prelude?
- Installing Ksport coilovers and maybe LCA's on a stock 92 Civic Si...what to watch out for?
- I have been to embarrassed to ask this question for a long time.
- Omni Power sleeve coilover ride quality??
- technicasport anybody?
- Noob question about coilover adjustment
- i dont know what kind of springs i should get
- kyb/tein stech combo questions
- advice on camber!!!
- LETS SEE PICTURES OF YOUR SUSPENSION!!!!!
- best susp. street da
- help!
- Squeals when turning!
- Spring Suggestion?
- Problems with omni coilovers? strange knocking sound...
- who has removed there front sway bar for track use? driving feel?
- any one have a d2 racing rs coilover setup
- K sport or UGR Full suspension packages
- camber kit?? few questions
- Is Changing a Front LCA Hard?(94 Integra)
- recomended front camber kit
- When do you need ITR lca's?
- Replacing all my bushings
- EG SI and TEG/GSR differences
- which suspecion would be better???
- Eibach Sportline for Civic FS
- how do i get my steering wheel straight?
- popping, knocking noise?? lsd diff or tie rods?
- Looking for Albany, NY Shops that do Suspension Corner Balancing
- which suspension setup feels like stock?
- aftermarket springs on G/C perches? Can you do that?
- Need advice!! Which setup should i go with?!?!
- Suspension or sway bar? sigh..
- raise up on springs
- SNAP!!!!!! oversteer
- is 8k/6k too much???
- Should I get full coilovers? (as opposed to springs and struts)
- Certain spring rates according to shock valving
- wanting to leave coilovers
- price of (GC + Illumina) almost = Function + Form....
- help with springs for EG with b16
- Need some hints for springs on my EG with b16!!!!!!!!
- sage lca's
- CTR strut w/ Function Form
- What exactly does an alignment consist of? EG Civic specific....
- Labor cost to install ES "Master" bushing set
- i was wondering
- GC looks like the best option to me. but my friend disagrees.
- spring question
- where to buy??
- H&R Sport Limited Edition?
- k sport suspension??...pix?
- Ksport coilover spring rates
- used koni yellow questions!!!! please help/reply
- 94-01 Integra/EG Rear shocks on 99-00 Civic???
- skunk2 vs ground control coils
- DA Z10 traction bar
- Blox extended wheel stud issue
- Cutting Coils on my '83 Civic to lower it. Advise needed!
- is this the right spring rates for me?
- Custom endlinks issue
- how to know u got the custom spring rates you ordered
- Does traction bars affect handling?
- gc standard spring rates for EF chasis
- Need help !!!!!! GC/KONI?????
- Koni yellow shock stuck. Help!
- koni yellows and ground control(non koni sleeves)
- suspension questions.
- need some help with my new suspension.. koni yellows and coils.
- Custom spring rate
- rear lower control arm
- Labor cost for installation of energy suspension bushings. (Phoenix Arizona)
- NRG Coilovers
- D2 coilovers......help!!!!!!!
- Rsr - race springs - how are they?
- EK Hatch rear sway-bar install
- DA suspension on a DC?
- Springs and Struts
- Using a harborfreight ball joint press correctly
- Rear disk conversion 98 civic ex
- best suspension for my eg hatch?
- Poll: Want To Roll Slammed w/ Full Suspension (DC2)
- how can i fix my drop!!!
- D2 or K-Sport????
- What do you do in winter????
- 93 Del Sol eibach pro-kit or sportline?
- tein luxury master (h-tech) -- any experience?
- This noise is beginning to kill me.. why does nobody KNOW? what is this Noise coming from?! HELP!
- Best Dampening for Tein HAs on a EG
- Springs and struts are rubbing and knocking issue....
- LOWER my Accord.
- Progress full coilover setup wondering which one to get?
- ANYBODY HAVE PROBLEMS WITH COILOVERS SEIZING UP
- rollcage yes or no??
- One lug wheel change like F1's on a Teg????
- 95 honda civic dx with 2 1/2 inch drop all the way around
- Ksport taking track records!
- Differences between Ground Control setups: 1021.04 and 1021.05?
- Are these springs Eibachs?
- Help, design and rebuild new susension for my 96 accord v6
- Help me with New Setup for EM1....Tein S-Techs got me bottoming out!
- Proper assembly order of shocks/springs........Help please
- Need help.......Acura Integra 96 Lowered need an Alignment
- Equal spring rate F and R on DC2?
- Need suspension for Daily Driver/Open Track Day Car
- spring and shock combo for a 1990 crx
- i think i need help mayeb you guys could help me
- Rack and Pinion
- Fender braces
- Custom mounted swaybar with pics - in need of a techies advice
- pic request for eg sway bars
- Best suspension setup for 99-00 Civic Si for under $1000
- 8kf 6kr UGR coil sleeves on AGXs?
- spring/strut combo for ek hb
- tein flex question
- soft springs like a bmw/lexus
- wheel offset question!!!
- NEED HELP WITH WISHBONES(LCA)
- 96-00 HB Suspension Upgrades
- suspension
- Ok, ASR 22mm DC2 complete kit instructions?
- Koni Yellow sleeve adapters?
- Ksport?
- Clunking in right rear.
- Function Form Suspension?
- rear breaks on a gsr Help!
- good setup?
- eg civic with a h22 handling?
- Stuck between a rock and a hard place
- Had a few brake realted questions!
- QUESTION ABOUT GROUND CONTROL
- Camber Kits???
- Suspension 4 EK Civic
- HELP! Does DA Brake Caliper and Rotor fit EG (non ex) knuckle?
- best bang for buck coil overs?
- koni reds - paired with rsr race or eibach springs?
- GSR front ITR Rear Sways on EG? impressions?
- suspension, im confused.
- Strut installation question
- Measuring Ride Height - Coilover Question
- Skunk2 Coilover sleeves Vs. H&R Race Springs
- camber kit
- suspension/ spring rate issues
- Rates to run on GC and koni yellows
- Clunking on deceleration at front left wheel
- Are all EG Front spindles the same?
- coilover question
- tokico illuminas / skunk2 coils?
- Lowering your car=more wheel hop?
- question about adjusting koni yellows
- rear brake question
- spring question
- camber adjustment needed with a 1.7in. drop, 1 rear?
- What Apexi Coilover is this?
- Ingalls adjustable ball joint help
- rear Camber Kit on 94 DC2???
- drill EG rear LCAs for swaybar attachment?
- question about wilwood big brake kit
- can't find motor mounts and bracket for 90 teg
- Lower Spring, don't know which goes up front and which ones goes in rear?
- just installed asr sway kit and, have a question though
- coilovers vs. spring/strut
- 94 Civic passenger rear suspension?
