PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. 95 coupe rear sway bar
  2. Ground Control/Koni suspension install problems 93 civic EG
  3. suspension techniques
  4. Negative camber on front after swapping knuckles.
  5. I cut ITR spring, whats my spring rate now?
  6. 97 Civic Ex
  7. Will i have rubbing issues with 16's on H&R Sport Springs?
  8. Springs and shocks vs coilover steups...questions
  9. Coilover Ride Height From Inside?
  10. Tein Vs. Tanabe Vs. Omni Power
  11. Ground Control Question
  12. Sway bar
  13. Tein Ra
  14. BACK SEAT STRUT BARS ???
  15. Suspension part numbers
  16. tubular front lower control arms
  17. 2000 Mustang Problems... can't push back the rear pistons
  18. Which coilovers should I pick for mainly street driving and moderate track visits?
  19. Where do you guys buy your Koni/Neuspeed SP3?
  20. - Big Brake Kit = 5 Lug conversion? ?? -
  21. aftermarket front lca's
  22. tanabe springs any good?
  23. Help tuning suspension. GC/Koni/ST setup >>
  24. Top shock mount bushings - S2000
  25. ever heard of
  26. Damaging fenders from to much travel?
  27. Skunk2 Rear Camber KIT!!
  28. Steering pulls right, left on small bumps
  29. ohlins shocks?
  30. Camber kit necessary?
  31. Stripped one lug on 3 of my axles. 3 wheels have only 3 lugs on them...
  32. -----need help with springs-------
  33. question to Omni SPORTS owners
  34. Need suspension help in Columbia, SC. INSTALL help
  35. POLL /// should I go 5 LUG or stay 4 LUG & upgrade on my 95 k20a hatchback
  36. I know I just posted a topic like this....
  37. Rear upper control arm hard to get on...Twisted?
  38. What other parts are need to completely assemble a strut?
  39. FR traction bars and i still have wheel hop, Please help
  40. Koni Yellow, any down sides?
  41. Opinions/experiences with Sprint lowering springs & lowering options
  42. EF shocks on an EK?
  43. good spring rates for an eg
  44. question for people who has Cusco coilovers on their EK
  45. Going from Coilovers to GC/Koni Setup PLEASE HELP! long and PICS
  46. can i use civic forks on my teg??
  47. GSR front sway bar install in eg hatch
  48. Omnipower LCAs
  49. **90-93 Integras: Which Companys Make Traction Bars For Them????**
  50. vibration issue
  51. integra and civic ex knuckle ?...
  52. Pt.2-95 cx-Blown shocks OUT-New koni/gc setup IN-Still harsh ride?PT.2!HELP!PICS!
  53. 00 Civic Sits Uneven??
  54. please help, when shock goes wild
  55. Expected alternator life?
  56. Do you need an alignment after changing tires and/or rims?
  57. lower drop
  58. what is yalls opinion on cutting springs
  59. ////////////best rear lower control arm!!!!\\\\\\\\\\\
  60. ingals or skunk2 camber kit for acura integra?
  61. drag/street/auto-x??? help i'm new
  62. How low is to low, from a performance aspect
  63. What are the spring rates for the standard D2 coilover kits for 96-00 Civic?
  64. tein ha coilovers for dc, can i make them work on my da integra?
  65. Best Handling Upgrade?
  66. Traction Bar hitting my oil pan b18c in eh2 HELP!!
  67. Where can I get a Straight Rear Axle?
  68. infinite-auto coilovers system???????
  69. jdm itr rear sway bar vs srr rear bar
  70. adjustable damping whats the deal with it
  71. dc2 front camber.
  72. 92 civic frnt. sway bar problem.
  73. Rolling fenders?
  74. Noob to suspension... help me out.
  75. Did an alignment today without camber kit I have pics?
  76. Brake line mounts
  77. Advanced Steering Gear...
  78. skunk2 wheelstuds diy
  79. trade: My b16 a swap for ITR Five Lug Setup with Wheels?
  80. EM Racing Products, thoughts? reviews?
  81. Cusco Zero2's - Rebuildable?
  82. EF9 noob...
  83. Ground controls H22 Integra
  84. Easier to turn left... ??? w/ perfect aliagnment
  85. Right wheel hop when turning left...
  86. Alignment help
  87. i dont understand F1 type suspension.
  88. Are these worth checking out?
  89. Any regrets buying omni power coilover?
  90. TOV Civic Si Project Car Video: Progress Suspension Install
  91. Looking for adjustable struts and springs.....
  92. 96-00 civic omni power coilovers fit 94+ integras?
  93. what are the spring ratings for H&R sports for a DC?
  94. where to buy ground control coilover replacement parts?
  95. Spriong rates
  96. ITR Sway Bar on EJ8 With Omni LCA's
  97. My proposed suspension setup, good or no?
  98. Omni Power or Skunk2 full coilovers?
  99. Real Cusco Strut Bar?
  100. Hondatech ground control password
  101. lowered car = more suspension strain?
  102. .::Can it be done? Question: EG suspension onto a EK?::.
  103. S-techs from a DA to an EJ6
  104. Are my springs adjustable?
  105. camber kit necessary?
  106. Just bought ground control springs...
  107. coilovers
  108. Ground control coilovers
  109. Kyb or Koni
  110. Looking for a trust-worthy alignment shop in NoVA
  111. for all you ground control and kyb agx people..
  112. Tein Type HR coilover suspension for 96-00 civic EKs
  113. i want to turn ... i mean really turn. help
  114. 95 civic p.s. steering rack removal/install
  115. Cracked Axle?
  116. eibach sport-system vs pro-system kit reveiws???????
  117. changing rear camber affect toe?
  118. omni power coilovers????
  119. quick question about kyb agx
  120. good set of springs for swapped ef
  121. Omnipower height adjustment question
  122. Setup for 02 civic lx
  123. Koni yellow height adjustable?!?!?
  124. CRX TRACTION BARS........EBAY
  125. Question on orientation of H@R race springs
  126. Suspension Choices; GC w/ Koni Yellows, K-Sport, D2, or H&R Coilovers???...
  127. EG b16
  128. f2 coilovers
  129. 96-00 civic rear struts/shocks
  130. abs stopped working
  131. Any Eibach Sport-System Plus Kit Users / Comments?
  132. Replacement adjuster.
  133. TEIN RA OWNERS , CHIME IN
  134. Need advise on suspension!
  135. how much psi in hks coilover??
  136. My official Tokico Blues suck rant
  137. Need help with Tokico blues!
  138. which car model to pick springs from
  139. do aftermarket struts change ride height?
  140. Looking For Stiff Sunspenion
  141. need suspesnsion advise on an h22 sol.
  142. What Omni spring rate for a h22 EG
  143. not low enuff!!!!!!
  144. Sqeaky shock.
  145. gc/koni yellow combo -- 92 civic
  146. Compatability??? EM1 TEIN SS on a DC2 chasis???
  147. Traction bars need help...
  148. lower ball joint on eg hatch
  149. suspension setup. need suggestions!!
  150. 5lug Conversion......
  151. EF front adjustible camber mount opinions
  152. eg spindles messed up alignment
  153. Searched - DA9 w/ Eibach Prokit / Illuminas.
  154. attn: COMPTECH tie bar question
  155. Coilover Questions
  156. ABS Help on 94 ls
  157. ...95 cx...blown shocks replaced w/ new koni/gc setup..Still harsh ride?Feels almost like before?but
  158. integra to civic suspension swap
  159. got suspension?
  160. wheres the best place to get tokico blues? (shocks)
  161. what would be the best springs/shock setup for a 99 civic
  162. eg suspentions
  163. help with rotor
  164. FK Coilovers, Anyone know anything about them?
  165. Too many suspension noise
  166. Buddy Club N+
  167. Can I assemble these before I take the suspension off my car
  168. Anyone using the ebay suspension max camber kit??
  169. H&R SEMA PICS UP!!!!!!!
  170. DA Koni Yellow Rear Shocks on Ef?
  171. first post in suspension.....
  172. neeed help indentifying GC
  173. Tein Flex height adjustment???!!!
  174. Crossed drilled rotors worth it?
  175. EK suspension on EG?
  176. what Ground-Control spring rates for my set-up
  177. BUddy Club Suspention
  178. ST rear sway bar fitment
  179. Buddy club N-Spec or Racing Spec coil-overs
  180. question of similarities of teg/civic brake master cylinder
  181. Just bought a car that had z10 radius bars installed. what do they do
  182. Coilovers or Shocks/Springs..? What will suit me more?
  183. Koni yellows with Eibach ERS - what length
  184. Threaded setscrew
  185. Shock/Spring Question
  186. rsx 5 lugs conversion into 96-00 civic
  187. clunking/Knocking noise.....??
  188. struts gonna go out?
  189. broken studs
  190. Suspension help
  191. Koni/GC rear spring length question
  192. Will Aftermarket Rear LCA's correct camber issues?
  193. drag setup
  194. steering wheel hub
  195. Eg - Uneven Suspension - Eibach Pro Kit & KYB AGX's - Just installed - yes I "searched"
  196. Which DC2/EG came with the 15mm rear sway bar?
  197. Which rear swaybar endlinks?
  198. axle problem?
  199. crx rack end bushing
  200. C pillar and b pillar bars for civic (Ej1)
  201. DC2 roll-bar setup pics...
  202. lowering springs
  203. energy suspension or prothane ???
  204. Rally for ek civic
  205. anyone know the spring rate on these tokico springs (show 5046-r on springs)
  206. tein super strret
  207. 15' Slips-205/50 hankooks-Blown shocks-Back tires squeak/rub/hit on bumps-Replaced shock-tires still
  208. adjusting(leveling) ride height without coilovers?
  209. lower suspension
  210. Car Shakes
  211. Where can I get metric heim joints?
  212. Worn inner tires = camber or alignment?
  213. full race traction bars?
  214. ITR shocks and springs
  215. Sorry, but search has been down all day
  216. shock manufacturer?
  217. Ek front sway bar and lower control arms.
  218. No dust boot on shocks bad
  219. Will it lower???
  220. Squeaky rear :( :(
  221. does the type R steering rack have quicker ratios?
  222. Eibach Help
  223. quick shock question
  224. tokico illumina for crx
  225. i need help with this jdm itr bar.
  226. Air ride Yes or No
  227. need help, i lost my nuts and bolts for aem big brake kit
  228. spc uca for integra?
  229. Need to find quality CV shafts/halfshafts
  230. CRX Clunking noise, could it be these bushing tears? Pics...
  231. rear knocking noise?
  232. D2 Racing RS coilovers or tein super street
  233. Air Suspension Kits, Parts, & Accessories!!!
  234. KONI/GC ? to tune or not to tune
  235. 2000 civic tein ss fit on 1992 eg hatch?
  236. So is it needed??
  237. Motorsport Tuning
  238. HELP: Undecided as to which setup i want to go with...
  239. H&R OE sport springs
  240. DC swaybars on a DA chassis
  241. Eibach pro-kit/konis or tockicos?
  242. eg hatch with gsr suspension, which bushing kit do i buy?
  243. 4 cyl 2004 ex heavily loaded bad camber, need device to lift & level rear end
  244. what would cause this to happen twice?
  245. Eibach Pro-Street-S Coilover Install (00 Civic EX) *long with lots of pics*
  246. OEM Sway Bar Endlinks 94 Accord Ex
  247. Winter and my GCs
  248. Adjusting Camber
  249. Coilover suggestions?
  250. urethane suspension bushings shake?
