View Full Version : Suspension & Brakes
- D2 Coilover v.s. Function& Form coilver vs K-Sport
- suspension help&!^@^*(
- taking apart TEIN suspension super street model?
- 99 Ex (need new struts)... Recomendations?
- rack & pinion problem....replacements?
- Suspension Help
- Which brake pads to go with?
- hey will this also fit del sols and ek's
- Busted Stock Front Sway Bar End Link. !!HOW!!? (searched)
- BC review...
- does this effect handling at all?
- 1993 civic sedan is sitting crooked
- Should I get these? why or why not?
- Neuspeed race w/ kyb agx
- If caster can be adjusted?
- Cheap, but effective shocks for stiffer springs; Tokico HP vs. Bilstein HD
- Help with the right name for the product!
- Weird Steering Noise--Please Help
- Tein spring change
- sway bars? Next step?
- another springs question...
- super cheap coilovers?
- Buddy Club Racing Spec Dampers: Review
- crv hub, 5lug conversion (itr conversion)
- installing strut bar on eg hatch.
- Omni Sleeve over kit, and Koni Yellows?
- need help with which springs i have
- How are G-Force sport tires?
- Tein coilovers
- Disk Brake swap info
- EK swaybar help
- Interchangeable front upper control arms for the 97+ Prelude..
- Adjusting coilovers
- sway bars and harshness???
- Will integra front knuckles work on 96-00 civics?
- Comptech worth it over ASR?
- koni yellows + omnipower springs
- Drag suspension set up help
- Shim Kit
- does anyone know if tokico illuminas come with the bump stop on all 4 struts??
- suspension help
- what's the difference between camber kits?
- Quick question regarding to Skunk2 full coilover set.
- did the impossible 85 h22
- LOWERED CIVIC !!!!
- omnipower sport full coilovers 92-95 civic
- Apexi N1 coilovers....... Does anyone have any experience with these??????????????
- Skunk2 springs with Kyb shocks! Good Match?
- Black/Red K-Sport's?
- EF CRX axle removal....
- Brake line situation
- Strut is blown need help
- question about heim endlinks
- H&R race springs
- Uncaptive Springs?
- apexi n1 99 spec problems
- EG lowering springs on an ef, yes?
- AMR Coilovers
- tokico suspension package vs rsr & koni yellows
- Engine torque damper? Pre-Load or not??????
- si suspension question
- 4x114.3 on a DA help
- K sport full coilover 92-95eg
- Please comment on this price for suspension work
- anyone know the lowering law for nys
- Does Traction Bars affect a car handling.....????
- looking into getting a new setup...
- Annoying Squeeks when turning and slowing down
- Full Review: PIC Performance Select Coilovers *Pics inside*
- EK Suspension into EG...How can I make this work?
- Bump stops, Trash or cut in half?
- Extended Wheel Studs
- dropped LCAs?
- Need Pic of eibach sportline for 94-01 Integra!
- wheel bearing removal tool...
- Pillowball Mount Question
- Weird TEIN Basic Damper problem on a civic hatch
- kyb agx and spring matched, and bump tops
- Skunk2 or ground control coilovers?
- What suspension will lower my dc5 the lowest
- everyone says KYB AGXis junk, are they really that bad?
- integra knuckle hub
- lowering my EK
- DC integra coilovers on my eg hatch?
- EF upper control arms
- Comptech and Koni Yellows, incite???
- Steering rack issues
- acura TL wheel studs on EG civic as exteded wheelstuds?
- What do I need to put sleeves on my Koni Yellows?
- which shocks struts should i use 93 integra or 00 civic si ( i plan on getting tein springs )
- Converting from 4 x 114 to 4 x 100 ?
- New or used springs?
- k-sport one piece
- Skunk2 pro full coilover VS Tein SS full coilover
- buying used springs
- Strange alignment problem
- lowering help
- MUGEN!!!!!!!!! coilovers
- Good struts for my EG coupe, KYB AGX, whatcha think, help a noob out!
- omni power spring question
- itr 5 lug conversion question
- What's the Best suspension set up for 91 crx?!!!
- D2 suspension products?
- traction bar?
- Confussed?
- would the jdm itr front sway bar fit in my ls
- Suspension Technique sway bars
- Tokico Dspec vs Koni Yellow
- TEIN Super Streets
- Help ID a B+C pillar bar
- NEED HELP ASAP!!!
- Tokico Illumina RAK Full coilovers for Ej2 (1995 Honda Civic Coupe DX)
- Matching springs to shock
- what lowering springs?
- alignment denied at les schwab!!
- When is it a good idea to replace Front Lower Control Arms?
- Tokico Illuminas, and HP's and bumpsstops?
- Need new bushings for UCA, OEM?
- **Too Much Go - Not Enough Turn - DC suspension build*HELP**
- Summit bar!! Where to buy????
- wheel hop with new clutch and tranny
- 23mm sway questions
- Aftermarket Lower Control Arms
- 13k/7k too much for an eg sedan?
- Noob Question on Coil-overs
- 4x114 Conversion on DA
- REAR DISC BRAKE CONVERSION QUESTION ???
- lopsided suspension?help please
- where can i purchase srr LCA?
- ebay stut bars info... or comments from u guys
- HOW TO I LOWER MY NEX GT FULL COILVERS MORE?
- Beaks EK Rear Anti-Roll Bar Mount kit - Instructions needed
- Will Omni coil over fit
- Ground Control
- will 94-01 integra skunk2 coilovers fit my 91 civic SI?
- Upper Control Arm Hitting Strut Tower
- wheel bearing?
- Anti-roll bar material?
- Brake Cleaning Question
- best daily driver suspension?
- What size allen key/wrench for GC?
- Redrilling (prelude vtec) rotors
- Suspension quick question
- Anybody know how to make poly bushings? Looking for some help.
- removed p/s help!
- !!!HELP!!! - Rusted rear suspension bolts
- Need pics and setup for EG Coupe
- suspension tuning by scc
- any one have any issues with GCs
- KYB AGX w/ Eibach prokit
- Adjustable Dampers
- REQUEST!ek rear suspension rear body panel cut
- skunk2 coilovers
- replacing busted shock question.
- Koni Yellows w/o Spring Seat?
- EG Suspension Setup
- will these endlinks work ?
- For those of you with the comptech tie/sway bar combo
- Annoying suspension problem
- School me on this.....
- installing camber kit on crx....NEED TO SHAVE FENDER WELLS???????
- will dc2 coilovers fit eg civic
- Best Coilover setup for a TSX
- Skunk2 Coilovers
- 91 sedan question about height?
- Rotors for 4x114 suspension
- Top Hat!
- Measurement Request: GC's for Konis (ITR)
- Please Help Identify These Coilovers
- 89 Civic Hatch. Suspension setup questions (reviews would be great)
- dropzone shocks??????????(any good)
- ST Sway bar set on my EF hatch. Couple questions first...
- Squeaky steering....
- performance shop in philadelphia, pa
- What Should I Get Next For $350 or Less!?
- question about my set-up
- USDM 24mm Front ITR Sway on EK chassi
- lowering springs?
- Koni vs Spring Height vs 15" question please.....
- Which motor mount route should I go with?
- Going from Koni Yellow/Neuspeed to Coilovers...questions...
- Bolts wont come out
- Going from Beaks to ASR.
- h & r/koni or ksport coilovers
- GC rate vs Shunk2 coilover(spring over sleeve slip ons) accord
- Need to know the stock spring rates
- rear trailing arms
- beaks vs. asr rear sway kit?
- Car on jack for awhile... Is this bad for the shock?
- Maximizing negative camber on wishbone suspension BB6
- best suspension combo for lowered look but smoothest ride.
- Powersteering Idea
- reviews on 94-97 accord suspension setups.
- Best all around suspension setup?
- Got a question (tucking rear tires)
- Tien Basics or Ground control + Koni Yellow
- Da suspenion on a CRX direct bolt on right?
- Integra suspension fit on Civic?
- wanting to change spring rates on omnifullcoilover 8kf 6kr anyone ?
- mugen lowering springs???? legit or not
- EK Rear Trailing Arm Bushings interchangeable with EG/DC?
- Skunk 2 Ball Joint Thread Pitch/Size needed! Castle Nut Size?
- Supension height trouble
- help with kyb axgs on my ek..
- Camber with H&R Race Springs on EG
- DropZone Vs. Maxspeed Coilovers
- what BRAKE PADS do I use? JDM ITR 4x114.3 conversion
- AXLES???
- Rough sound when under normal driving, half shaft?
- Which Shock???
- hit a curb, alignment no help, what's next?
- Steering Knuckle help
- Tien Basic Coilover vs GC/Koni
- Suspension Drop Problem
- HELP- Stock spring perch with Koni install.
- TODA Racing FIGHTEX Type FS?
- just installed skunk2/blox camber kit (opinions please)
- Does this looked Fu**ed???
- omni power ?
- Suspension Woes
- Lowering car...
- spring/shock vs coilovers
- remove rack and pinion
- Bushing suggestions for an EG6
- Touge setup suggestions??
- GC spring rates for a 95 eg6
- Setup for an EG
- correcting camber with a sledgehammer
- 4-wheel disk conversion questions
- need a product review!!!
- springs on stock shocks
- Rear Sway bar questions
- suspension on a 94 4dr
- Problems with ETD Crossmembers?
- ASR 32mm swaybar HELP!!!
- coilover rings HELP
- 00 civic Question
- Caster and Camber, Independent?
- Suspension Problem: 1995 Honda Civic DX Coupe (166,xxx miles on chassis)
- Tokico Illumina (whites) Thinking about buying. Please give me your opinions on them
- Del Sol/Type R sway bar
- GC coilovers
- Installing lowering springs
- No more grease needed!!!
- ATTN Koni users, rear Reds acting strange. Very slow rebound
- Clicking noise after new install
- Camber Kits???
- New to Spring Rates. Whats good for what?
- Knocking while driving and greese wheel? HELP!
- 96 civic coil over
