View Full Version : Suspension & Brakes
- 98 civic ex trailing arm bushing
- looking for best suspension for 92 eg hatch
- Coilover questions and need suggestions
- give me ur thoughts.
- EG progress II coilovers on an EF?
- hypercoils?
- Best Suspension Setup for 89 DX Sedan?
- HELP! LoTek lowering springs?? (ive searched!)
- suspension for a cb7
- itr 4x114.3 question.
- delsol brakes
- koni yellow bolt size
- Steering issues
- TEIN SUPER STREET WHICH SETTING.
- rear type-r sway bar into EG
- 97-01 CRV FRONT 5 LUG HUBS ON EK SEDAN
- DC2 Camber kit question...
- oem swaybar with f7 lca problem
- Coils on the EP
- How hard is re-bending brake lines?
- "Rear Camber Washer Trick" Question
- Installing 1" MC/booster/prop-valve on CRX
- Coilover Spring Replacment
- BEWARE BLACKWORKS LLC
- best lca's for a 95 civic sedan ex/si
- help what to use on poly bushing to stop squeaking
- I need a how to on inner tie rods
- looking to buy full body coilovers need advice
- Deleting the booster, KKC
- 90-91 civic megan racing springs experience?
- Integra G2 lowered axle question
- Adjustable Roll Center Adjusters.
- Adjustable coilovers/what do I need?
- Koni Yellow G/C Assembly/Hardware Question
- Bear big brake kit
- Blown Strut what are my options
- mild suspension setup with GC extended top hats. overkill?
- Tein S-Tech Lowering Springs Installing Questions
- Eibach factory tour vid
- Tokico shocks/Riding LOW.?
- What sort of suspension setup for '95 CX Hatch?
- Letting the car down 1/2" change the toe enough for tire wear?
- Acura Brake fluid DOT3
- Suspension opinion. plzzz
- Best shocks w/ Ground Control coilovers - Near stock height
- Spoon sports Cailpers On a EG9?
- 93 hatch w/b18c swap suspension question. Koni?
- KYB GR-2 + Skunk2 Lowering Springs for EG
- Upper arm pivot bolt torque spec
- Diameter of honda springs & ground control sleeves
- Progress CsII struts and rear swaybar HOW TO and review
- brake help
- Accord struts are shorter?
- ground control insulator replacement
- Lots of parts+tuning, still feels weird
- Dc2 Coilovers
- Shock fork alignment collar
- Front suspension knocking/vibrating
- Opinion on CUSCO ZERO 1 Damper
- what would be a good coilover setup for a daily driven vehicle?
- dropping the rear hubs?
- EF suspension on EG, disadvantage?
- del sol rear disc conversion ?
- Need Help! What type of suspension are these
- eBay rear LCA's
- Anyone have experience with Rokkor coilovers?
- What causes rear suspension perch to bend?
- What coilovers do you recommend and why
- Suspension Opinions and Finalization HELP Wanted
- LF: Good Alignment Shop
- nex full suspension
- DC2 Suspension Upgrades - Need Experienced Opinons
- Weird ground control spring rates
- Weird steering wheel pull ?????
- Help with shaking steering wheel.
- tokico illumina shocks with oem springs review?
- coilovers for 95 del sol what rates? support brace for the cabin?
- what goes into slamming a 91 hatch?
- tie rods question
- Skunk 2 lowering kit with cambers.
- Sway Bar Question
- bottom shock mount size
- EBC Ultimax Rotors
- Bilstein coilovers- Using non-coilover springs?
- need help? Cant decide on suspension :(
- del sol coilovers ?
- EF/DA Front LCA question/idea.
- Why is the back of my civic higher than the front?
- cant find the problem after accident.
- Nice shock/spring or Cheap coilovers?
- Another BWR Thread, Anyone own a pair of their lower control arms? *PIC INSIDE*
- why does my skunk2 camber kit keep loosening while driving
- Which bushings are affecting alignment?
- Need Coilovers civic ek!!!!!
- yonaka motorsports full coilovers spec 1 NEED HELP!!!
- Need some pointers on what to get .
- Skunk 2 Sleeve Overs
- SUSPENSION difference between DC2 AND DB8?
- Extended ball joint necessary?
- Integra drop, what shocks to buy?
- ground control rubbers
- Tockico Illumina warranty.
- Looking for good Struts and spring that dont bounce
- new wheels, now i have problems. wheel balance issue?
- Progress coilovers -- dust boots?
- Are no name lowering springs okay to use?
- best rear sway bar for weekend autocross EK hatch
- which setup? need your opinions
- Ball joint reamer for outer tie rod
- Beak's Quick Swap RSB for DC
- EK rear sway bar to EG??
- Down sizing rotors on aftermarket calipers question
- Looking for stiffer stock height rear suspension 2010 honda civic
- tokico blues with coil sleeves on ef
- Alignment out of spec
- Big + for Function 7
- Wondering if i need a Camber kit?
- What Top Hats to get for Progress CS-II Coilovers?
- Rsx civic Si fit strut
- Squeaky Suspension in the front
- h&r spring rates
- Good shocks under $200
- 95 hatch dx brakes sticking
- Ball Joint Rubbing!
- Sway bar effects on ek chassis
- what is lightest stock rotor?
- Front Brakes Locks up
- tanabe coilovers maxed out
- What shocks do my Ground Controls fit?
- Shocks Advice for 90-93 Integra
- 17mm sway bar to brace or not to brace!
- front spindle headache!
- Does anyone make CNC aluminum strut tophats for DC2/EG?
- Bolts bolts and more bolts! -- 99 Civic SI
- REbuild or replace?
- Bilstein HD with H&R OE Sport Springs
- drum to disc conversion
- Questions about Hardrace super tie rod end.
- Opinion on Eibach Sportlines (or entire System) on EK *hatch
- rear suspension Noise .Help
- Importance of booster in Honda brake system?
- Suspension Guru's, What Miscellaneous Parts Are Needed ?
- Debating: Koni Yellow/GC Vs. Tokico Illumina/Skunk2
- 95 DX Question
- Alignment Questions
- steering rack???
- Aftermarket EG RLCAs with EK bushings
- Attn H-Ters
- Energy Suspension bushings on rear LCA's - no outer shells?
- Good but inexpensive coilovers
- Suspension question
- the start of my 95 dx civic suspension build *parts list* suggestions?pointers?
- will the 96-00 civic front lca's fit onto the 92-95 civics?
- Koni Yellow/GC combo
- Anybody have experience with ksport air ride?
- a "help me choose which suspension" thread :/
- 36mm 5 lug swap help. compatible oem axles
- Suspension overhaul
- need a new steering rack what kind?
- 92' eg Brake Bleeding
- opinion on spring drops
- Need Urgent Help
- ed hatch help
- help. base ring.
- weight transfer help understanding plz
- ksports pro coilover vs skunk2 pro series2 coilover
- Current setup or NEW Coils?
- skunk 2 struts gc sleeves?
- lcas wroth it? or are sturt bars better?
- skunk 2 full coilovers
- 94 EG4 Coilover Choice ! please Not SKUNK2
- String Alignment & EG vs DC Rear Track Width
- Removing 96-00 Dx caliper- Quick How to anyone?
- Rear suspension creak
- EJ2 GSR brakes and sway bars.
- OEM vs AUTOZONE Wheel Bearings
- Symptoms of bad trailing arm bushings?
- Swapping Swift springs for Ground Controls
- need help with brakes,, pedal dropping to the floor
- Factory ek9 ctr dc2r ITR camber and toe settings?
- Suspension/Steering noise??
- horrible steering issues
- Stock Suspension Help
- Wheels stick out more on one side after lowering?
- Caliper code meaning
- REAL HORRIBLE NOISE COMING FROM REAR.
- Suspension for Comfort/Performance?
- Looking for full coilovers
- Custom Coilover rate Ground Control Help!
- Wilwood big brakes vs 15" wheels
- progress coils?
- Help with track rod end outer
- ***Car jerks to the right once decel***
- sway setup-
- HELP problem doing a 96'' spec itr 4 lug conversion on 98'' gsr/ ABS?
- front sway bar- price check
- in need of some suspension help
- Full Race traction bar help!
- rear sway bar help pls
- 1994 Civic Ex Brakes Disc Brakes???
- quick question
- where to buy upper ball joints best prices?
- "JDM" Front Camber kit: Im not tracking the car, will it work? *car picture inside*
- pull to the right, worse under braking?
- pic or gc coilovers??
- Bad wheel hop from Bad shock?
- installing lowering springs NEED HELP
- Full Coils vs ground control sleeves vs Springs
- Suspension help? Not sure whats wrong
- Help, will they fit?
- First Gen CR-V suspension differences
- drag crx suspension
- Torsion bar worth it?
- endlinks- help
- ctr rear sway bar onto ek dx civic-help!
- asr brace- opinion
- Help, tires wear quick, suspension problems???
- how to change 98 TL rotors
- Ground Control + Koni Yellow Review
- Any way to fix handling problem after accident?
- springs for ground controll coilover
- Blox Front Camber Kit
- Ground Control Tophats Help
- Tein Basis ??
- EG Civic front suspension/brakes re-build questions
- are PIC shocks re-buildable?
- GC/Koni Spring Rate Advice
- Custom Suspension
- Why do my tein S techs look un balanced?
- Shock question
- true coilovers VS coilover sleeves + shocks VS lowering springs + shocks
- 94 accord brakes suck
- 92 integra gsr, tires lasted 4 months. camber kit?
- Tein Basics and megan racing
- gsr brake upgrade
- Tein basics or Function forms for slammed?
- Looking for trailing arms
- Squeaking from right rear after installation of Eibach Pro Dampers.
- Wheel bearing help
- Troubleshooting road/tire noise (details and vid inside)
- coilovers
- Will 99 Civic Si front strut brace fit 94 Civic?
- Ebay camber kits???
- symtomps of bad/worn/ripped front LCA(Lower Control Arm) bushings??
- Next suspension upgrade, totally hybrid
- tein super street
- what is a good camber kit for eg
- Front sway for 00 ex coupe
