View Full Version : Suspension & Brakes
- fastbrakes 11" rotor pics?
- anyone running Bilstein HD's???
- Suspension Options
- 98 GSR integra ABS delete ???'s
- What rod seal for my itr master cylinder ?
- Tokico illumina(white) dampening adjusters
- Tie rod/steering problem
- Question about coilover set-up for an EK hatch
- hawk hps break in come to stop or?
- help eibach & GC, what spring rate is this in lbs?
- what else do i need to get to run cheap ebay coilovers ?
- what sway bar to go with 2000 civic ex
- Is there a drop axle for integra's?
- Integra and civic brakes interchangable?
- What is camber?
- name this rear sway bar!
- what springs do you run on your 06-08 (FA5) sedan?
- Steering Rack makes Horrible squeeks!
- Just lowered my CG accord coupe
- Is it just me or is older Honda suspension poorly designed?
- Rear OEM Strut removal.
- Brake problem on my DA need help
- Jdm Itr 5 lug Question
- on the market for coilovers.
- Integra DC and DA fitment and questions..
- 95 Civic jerks sometimes on lifting of gas pedal....
- Integra tokico blue shock dilemma!!
- Bad booster check valve?
- Spring rate question
- I am in the market for suspension...
- Help with suspension
- Function7 rear subframe brace + Beaks kit?
- Drove on/off curb :facepalm:
- alignment question?
- Any idea what the spring rates are on CRX/EF Intrax springs?
- Need help with alignment, camber kits and adjustable ball joint
- Tire Squeel during Low Speed cornering..
- speedbump domination
- Front end LOOSE
- heim joints on a 94 civic
- Looking to take the slop out of my DC2, opinions?
- ctr/em1 front lca's on eg?
- swaybar fitment question?
- Slight steering wheel shake >70mph
- WHAT SETUP SHOULD I GET????
- omnipower sport coilovers for ef, spring rates?
- civic hit a curb
- What shocks to go with?
- ground control spring rate?
- Anyone running PIC Apex coilovers?
- which camber kit?
- Can anyone tell me...
- ball joints
- Help Please: Problem after big brake kit install
- About to order Skunk 2 Pro S Coilovers for my 95 LS Integra. Opinions
- Looking to get top hats
- rotor sizes for GSR vs stock EG DX rotors
- EK9 strut bar fit EJ6???
- Lowering my Civic: No clue what I'm talking about
- Chassis stability question
- which banjo fittins for master cylinder?
- Alignment Q's
- Semi metallic hawk brake pads
- ASR subframe/w Beaks tie bar. Question
- pullin hard to the left
- Gsr Calipers on Stock civic vx brakes
- 5 Bolt conversion for 2000 civic
- cheap coilover help
- Cheap Sleeves Good Springs
- brake tuck 20' enough
- Alignment + Blown Axle
- 94 integra rear koni yellow sport .. on ef?
- TEIN SS with or without pillowball upper mount?
- 96 gsr abs troubles
- 96 EJ6 Hatch Rear sway bar possibilities? SI or GSR
- Koni GC problem...
- struts ruining alignment??
- Quick Question
- skunk2 struts w/tein s. tech springs
- which suspension bushing will lead to wheel hop?
- Should I upgrade my suspension?
- tokico illumina question
- which pads do i need
- Opinions wanted. full race traction bar vs hardrace bushings
- Skunk2 drag launch kit: Did it used to come with all four sleeves?
- need help buying tonight!!!
- Car sits uneven
- Car pulls to the right when I take off.
- custom extended top hats
- new suspension opinion
- tokico shock identiication
- 114.3 JDM Disc Brake Conversion on my 1993 Civic Coupe EX-Wrong rotors?
- Upper Control Arm Torque?
- Trailing arm bushing
- trying to figure sway bars out, need some help please.....
- Daily Driven
- traction bar..
- Strut bars. Push or pull?
- alignment with aftermarket suspension
- Raceland Coils?
- Anyone have any experience with "Blackworks" suspension
- honda civic/integra rear lca bolts
- quaife steering rack EF
- 95 Civic coilover, spring questions
- addco sway bar subframe questions
- do i need a camber kit with this tein setup
- q
- Need help finding a suspension set up on my race car????????
- rack end bushing
- Tein spring and Skunk2 shocks compatible?
- 99 ek front swaybatr
- Coilover Height Relative to Fender Arch Height in some way?
- Mugen EG6 Lowdown 5-way questions..
- Alignment results, how bad before/after?
- buddy club camber kit " how to align"
- How To Press In Control Arm Bushings...
- Tein H-tech + Koni SP3 = Smoothe dropped ride?
- Need help with eg6 rear disk coversion?
- Are the mugen active gate brakes the same as s2000 brakes???
- swaybar with traction bars
- suspension set up question
- car is jerking when i brake
- I got an alignment and here are the results...
- Gr-2's and GC's? what do you think?
- GSR/Type R rear lower arm question.
- D2 racing lowering spring rate
- Tokico blues on CRX leaking oil?
- Is the front and rear track width the same on EG
- EG6 Tein EDFC and strut bar
- Uneven ride height with stock shocks and fixed height shocks
- INTEGRA (DC2) & CIVIC (EK) LCA??
- Need some help with brakes.
- mushy brakes new steel lines ???
- Is there now a resolution to axle failures while being slammed?
- Anyone ever use these
- rear upper control arms? Aftermarket OE style or camber kit?
- Grade 5 bolt strong enough for suspension
- Caliper / Bracket interchangability
- Need a shallower brake booster
- Upgrading brakes on dc2 with 15" wheels
- Finding my full suspension set up
- What's the purpose of aftermarket LCA's?
- Will DC2 shocks fit on a EK?
- swaping lowering springs on stock suspension?
- Spoon Twin Block Caliper.. Clicks
- need help stoping my sh!ty ghey wheel hop :/
- Problem with Ksports
- what is this item
- GC/Koni questsions.... Hear me out...
- Tein Seper Street Setup Help!!
- DC Integra w/ S2K front brakes...prop valve?
- jdm itr shocks
- DA shocks fit an EK?
- 5lug question
- What springs for a 1998 GSR?
- teggy brakes
- 88 ef suspension problem
- Tokico blue Question
- 2000 gsr suspension/hub set
- Need help with installing shocks/struts and springs.
- will rsx 5 lug work on eg?????
- Integra brake setup...need input
- Popping noise?
- wilwood 4 pod caliper
- How would i get this bolt out? what do i do now?
- A little disappointed with hard race quality
- spoon caliper clearance
- Ef rear disk conver?
- PIC REQUEST: H&R Cup Kit on 96-00 civic
- How is it that with negative camber your tires can still wear fine.
- All four Brakes locking up, and its driving me CRAZY!
- eg air cylinders
- same wheel bearing keeps going out
- Which springs to use? ej h23v
- Does anybody know?
- caster and camber adjustment arms
- EG shock install help!!!!>??? PROBLEMS!!
- need help identifying LCAs
- Will BWR Upper Ball Joint fits Skunk2 A-arm?
- Integra bushings overhaul
- Suspension mystery
- 93 cx drum conversion help
- Help with alignment setup
- Just Got an Alignment
- lowering 60 foot times...
- Acura El... suspension ?
- new suspension setup
- sway bar from an eg fit an ek?HELP PLS
- differance between eg and ek front forks
- i need a suspension set-ups for a crx...
- spring rate question ef sedan slammed
- Suspension Headache
- Is a lower tie bar worth it?
- converting rear drums
- installing lowering springs?
- Apex PIC vs Koni Yellow & Ground Control
- Tell me what the rating is on these springs
- Koni yellows and groundcontrol sleeves?
- fixing false steer
- How To: 99 Si 26mm Sway Bar with EX LCA!!
- Size of fittings master cylinder 1" Integra 90 93 with ABS
- q8 + 205/50/15 drop. how low?
- how do u know if shocks are blown and no good
- Rear Caliper Bracket
- calipercover.net
- how low can i go?
- Omni power coil adjusting wrenches.
- DA Integra trailing arms onto 99 Civic
- Getting annoyed with spring install
- rear disc conversion q's
- Brake booster question
- Prelude 5 lug on a civic?
- Good Drag suspension?
- anyone using the addco sway bars
- Subframe question.
- ek rear swaybar endlinks
- EM1 master cylinder swap options
- who rides with progress technology?
- drag racing setup
- Skunk 2 Pro C
- GC/GR2 combo worth
- blues
- Koni Yellow/Ground Control Spring Rate
- suspension for street/strip
- 92-95 5 Lug conversion
- help with 96 shock mount bushing replacement
- Brake Flush
- Question!??
- 03 Civic: Hawk HPS, Hawk Performance, EBC green pads vs OEM
- best street pads?
- **HELP!! did i get swindled?!**
- brake upgrades for an ls
- GSR brakes meet DX
- 1999 Civic Si Suspension Setups?
- EG OBX SUBFRAME W/ 24MM SWAY BAR REVIEW
- Integra/Civic front sway bar compatibility
- KYB AGX V.S. Tokico Illumina -HELP.
- Spring Rates
- Will 4dr DC Integra front knuckles fit on my EG
- Will rear ITR LCA'S fit EK/EJ8 ??
- EK AMR coilover install
- alignment q's
- Neutral handling
- E-Motor Full coilovers
- power steering to manual converision. steering feels really LIGHT turning right??
- HELP ON BRAKES LINES PLEASE!!!!
- Looking for Best ride for DD EK
- Reachin out
- Top Nut Hex Problem
