PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. function and form type 1
  2. Warp Brakes Help
  3. I need brake help!!!
  4. what do I need for rear disk brake conversion on a 92 hatch?
  5. Safety of Redrilled brake rotors
  6. Brake Upgrades for 96-00 Civics, applicable to some older Civics and Integras
  7. Suspension Decision
  8. Camber kit needed? 06+ Si
  9. question
  10. Any DIY write ups out there for installing coilovers/shocks on my 4th gen lude?
  11. cheap coilovers, whats the skinny
  12. CRX Stock Suspension
  13. CAR SHACKING... need input.......
  14. Question on front sway bar install - ek
  15. anyone have numbers for honda motion ratios?
  16. can super blue brake fluid be used for?.....
  17. installing a itr swaybar on an ek?!
  18. What Color?
  19. how to maintain trailing arm spherical bearing kit?
  20. Skunk2 Pro-C Installed....Need help figuring out unusual noise!
  21. tokico illumas question
  22. Looking to air bag my car!
  23. adjusting coilovers
  24. I need some abvice from people with really low cars
  25. OEM SUSP!!! BIG SPRINGS FRONT OR BACK???
  26. Alignment advice
  27. H&R springs with .....?
  28. Traction bar question?
  29. KONI coilovers
  30. tokico illumina adjustable shocks
  31. just curious about something...
  32. uneven susp.
  33. Any problems with beaks subframe brace?
  34. My ideal adjustable end link design
  35. b pillar bar safey
  36. wilwood 11'' brake disc repacment
  37. EH give me your opinions for AUTO-X
  38. Dumb slammed question
  39. Popping from front end during braking / turning
  40. installing bushing help.
  41. EF strut fork on EK
  42. Spring rate question???? (Searched)
  43. help balancing sway bars
  44. Camber
  45. Koni 8212 vs 8611 vs Race (8041)
  46. sway bar on 92-95 honda civic cx??
  47. k sports good to auto x?
  48. how to tell if omnipower are fake?
  49. Mugen rear trailing arm bushing VS. OEM
  50. shock travel problem on itr with gc/koni
  51. Need spring/shock suggestion
  52. Passwordjdm Spherical Rear Lower Control Arms
  53. Front end of my car shakes like crazy under acceleration after 40mph
  54. Help on Steering Rack
  55. Function 7 HELP ME FIND ! ! !
  56. gc question
  57. GS-R vs ITR LCA's
  58. driving
  59. Suspension questions 97 civic
  60. Help! Camber kit noob question!
  61. Possible theory: Rsx rear tophat could be used as an extended tophat for a civic/integra
  62. camber wear...?
  63. The New Koni Orange STR.T shocks
  64. How to set Camber kits right
  65. Why do people spend so much money on lowering/suspension but...?
  66. interchangeable suspension
  67. Need Help.. Lowering Suspension, incorrect Height on 96 Civic Hatchback.
  68. Are these good coilovers?
  69. Camber kits?
  70. 08 SI and lowering?
  71. 225/45 R17's 97 Accord
  72. spring rate help
  73. ITR rear trailing arm
  74. bump stop acura integra
  75. quenstion about my struts
  76. Illumina or Koni YELLOW? CIVIC
  77. Using Koni Yellows with Ebay Coilovers
  78. 1983 Civic suspension?
  79. eg to ek compatability
  80. Optimum camber/toe settings DD street sol
  81. REAR TRAILING ARM BUSHING?
  82. Lowering my honda fit gonna cause camber issues?
  83. Susp. Insight please!
  84. Can I use a 98 GSR Brake booster and master cylinder in a 95 hatch?
  85. Eibach bumpstop question
  86. Bigger wheels up front?
  87. best out there
  88. 99 civic struts on a 96 integra
  89. drop spindles
  90. rear wheels brake issue
  91. Tokico Illuminas Question
  92. maximum spring rate on illumina
  93. help please top hat extending
  94. WHEEL HOP!
  95. Which LCA's to avoid?
  96. Need Help On new Springs for My GC's
  97. Can anyone recommend cheapest place to get H&R Sport springs?
  98. is camber my problem??
  99. IB/blueprint mfg lowering springs
  100. Tie Rod adjustment question
  101. oem ef suspension
  102. anyone have these?
  103. someone help im rubbing bad
  104. suspension on 99 civic ek.
  105. Crx Bushing Help
  106. Tein SSP owners...
  107. Camber Kit
  108. How to convert to 5 lugs
  109. help what do i need
  110. Mild drop recommendation?
  111. mystery noise coming from rear suspension
  112. Balljoints and Alignment
  113. Best Struts
  114. Measuring CG or finding "level" ?
  115. Koni STR.T Street Strut?? anyone rocking them yet?
  116. DC2 camber kit on DA.. will it fit?
  117. Some quick questions about the Tokico Illuminas.
  118. Neuspeed Race Spring Length for EG Civic?
  119. d2 lower sleeve stuck.. what to do?
  120. Koni Red Setting
  121. Air Bag suspension...
  122. Tires bottoming out to the frame (front)
  123. Quick + - Tokiko Illumina Discussion
  124. Ground Control coilover install info
  125. axle problem??
  126. Help with my Integra Gsr Dampening setting
  127. knocking cusco coilovers
  128. first gen s2000
  129. Noisy springs? tapping sound (skunk2)
  130. OBX Camber Kit
  131. koni yellow with ground control vs tein basic coilover dampers
  132. need to lower.
  133. Ground Control Help
  134. I would really like some advice on lowering my 2002 Accord
  135. Ground control spring rate help needed..
  136. Alignment question
  137. Sportline Springs
  138. Not your typical "what lowering springs should i get?"
  139. remove shock from coilover?
  140. really need help (stuck allen bolt)
  141. Looking for a DIY Strut replacement...Urgent help needed!
  142. Best drop springs
  143. Suspension Set-up for Canyon or Touge
  144. suspensions on dc chassis help please
  145. 90 si ef civic suspension
  146. ground control coilover question
  147. Quick question on full suspension swap with coilovers
  148. H&R Race Springs w/ Kyb setup rubbing tire
  149. need advice on suspension!!!!
  150. Koni and Bilstein with lower perch setting + stock springs?
  151. Help identify Eibach Springs?
  152. Camber kit, or no camber kit?
  153. EP3 Suspension Tuning
  154. Swift Springs Questions - What is my Springs Rate?
  155. New Suspension.
  156. Extended Top Hats Question.....SEARCHED
  157. EK shocks on EJ Question, Help
  158. eibach prokit springs w/ kyb agx -or- koni yellows?
  159. just lowered car, questions..
  160. Alignment Settings for first track day?
  161. godspeed crossbar/x bar (miracle cross bar replica)
  162. spax coilover kit will it
  163. OEM rubber bushings -or- Energy full poly bushing kit
  164. need help with my suspension
  165. 1.75 >< 2.5 in.
  166. 1.75 >< 2.5 in.
  167. itr shocks vs eibach pro kit
  168. counteracting oversteer ?
  169. Blox end links on stock swaybar?
  170. Tein S Techs w/ Skunk2 Shocks - Have some ?'s
  171. Koni Yellow/Eibach Sportline
  172. This month's issue of Project Car Mag.
  173. stock 91 HB - jerks to one side or the other
  174. Skunk2 Pro Series Coilovers Stem diameter
  175. Skunk2 Pro-C's & BC Racing BR Series: Need your expertise!
  176. New bushings?
  177. Lowered car Aligment good?
  178. How much camber for a change in ride height
  179. anyone knows how it looks or has pictures?
  180. Brakelines/PIC
  181. Planning to upgrade suspension! Got a couple of questions.
  182. Recommend me a suspension set up - been searching a while....
  183. Damper Fork fitment..
  184. Brake Question??
  185. skunk2, people who have used or have on there integra.
  186. 86-89 accord shock
  187. ES bushings in BLOX lca
  188. Any input on Function Form or KSPORT coilovers?
  189. YONAKA COILS
  190. My Konis/Ground Controls are seized when I try to take them apart, halp
  191. tourqe mount ??
  192. i have a question
  193. Bilstein perch help
  194. Shock dust covers
  195. rear end alignment necessary after car is lowered??????????????
  196. Coil spring position on plate:
  197. Going Back to Stock Springs :P
  198. del Sol front sway bar clearance issue
  199. omnipower slip over
  200. cusco comp-s
  201. Review: PIC Apex coil-overs
  202. Noob Suspension question
  203. Autox suspension?
  204. Neuspeed Race Springs ?? yes ive searched
  205. Function and Form > Great Customer Service!
  206. Some good coilovers for 94 accord
  207. I need some help on Spring Rates (searched)
  208. DA lowering springs on EG
  209. integra suspension to itr
  210. calling all lowered FA5's,help.
  211. Stipped Axle Nut??
  212. squeak?
  213. spring compatability
  214. Is there a non-subjective way to tell if a ball joint should pass inspection or not?
  215. Suspension Compatibility
  216. $500 Suspension Research, eibach, kyb, tien, tokico, neuspeed
  217. Best suspension for all round use. (Street Racing, Track use and Everyday use)
  218. H-R Springs
  219. ITR mugen struts... Can they be put on ek civic ?
  220. Koni Dampening Controller
  221. question . ( simple answer )
  222. Ksport EF coilovers into EG?
  223. rear 19mm Suspension Techniques with asr brace?
  224. Springtech Springs, anyone have experience? I SEARCHED and found nothing
  225. Clunking front suspension again *argh*!
  226. CUTTING SPRINGS WHILE ON CAR!!! HELPP
  227. kayaba excel-g
  228. 92-95 Civic Eibach Pro kit springs quick question
  229. Koni shock / spring combo question...ride quality
  230. GC with stock struts anyone????
  231. Dont laugh...2nd Gen CR-V share parts with anything?
  232. Suspension set up
  233. suspension problem..need help asap
  234. what kills struts? big drop or stiff spring rates?
  235. Where to buy 7th gen civic OEM parts?
  236. ITR Sway Bar Question
  237. 00 Integra LS with susp. problems.. engine shutting off after bad bumps..
  238. sqeaking shock
  239. question about lowering and bushings
  240. 00 Integra GSR w/ Koni Yellows and ITR Springs. ----> Passenger side sits higher than Driver side
  241. Rear swaybar bushing question.
  242. EIBACH PRO-DAMPER SHOCKS/STRUTS
  243. ek rear camber kit 12mm bolts
  244. does it really matter
  245. torque industries coilovers
  246. Rebuilding front end... where to buy
  247. Have Tein SS coilovers, but can I change out the springs??
  248. 04 EM2 Slammed into curb, bent tire.
  249. Instability whilst breaking / Higher Speed
  250. Best Place to Order OEM Suspension Parts?
