View Full Version : Suspension & Brakes
- Looking for help on front and rear calipers
- TIE ROD END REPLACEMENTS
- Max operating angle for axles / CV shafts
- Type-R Eyelet Style vs Fork Style
- Skunk 2 Kit and Caster
- Suspension problems?
- Having a caster problem. 91 Civic
- creaking/popping from front end
- re-building cliper?
- Camber issues on a 200k + Civic EX
- abs delete?
- OE F/R spring seats interchangable?
- Ground Control Koni yellow adjustables? help!!
- Not my night. Snapped head...
- WTF Tein H-tech? Super wierd right height...not right.
- Two questions, master cylinder and frozen caliper?
- would 89-91 civic/crx suspension fit on 95 del sol
- help with kyb agx shock and eibach springs!!!
- Definition Of Stance
- ride height
- 97 civic hb rear disc conv help!
- No front sway bar = sloppy front end?
- koni yellow question
- brake help!
- Your opinion from a mechanics price quote
- spring rate help!
- 98-02 Accord UCA bushings
- Help! GC and konis yellow set up trouble.
- energy suspension control arm bushings
- Sqeak When Break Pedal Released
- 09 Accord Sedan Suspension
- Front end popping
- Front Lower Tie Bar Necessary?
- Do I need front end alignment? 91 DA
- Spherical vs. polyurethane
- 4th and 5th gen prelude rear lower tie bar
- Brake noise while stopping
- EK4 Front Camber and Caster adjustment
- Lower Ball Joint help
- Ek rear disk brake conv.
- Skunk 2 Ball Joint
- brake line is cut!! HELP
- eg front sway bar, whats availible?
- Sway bar question for the guys for drive on the "track" 96 hatch
- Swapped new 4040 prop valve with issues...
- Complaints to Koni, who to contact?
- who here has use skunk 2 pro C
- Poly RTA Bushings Made Back End VERY Vague/Washed Out?!
- tokiko or kyb OR skunk 2??????
- Springs or coilovers on 93 eg????
- Shock/spring is popping after replacement
- Ebay coilver question
- ? for you suspension Guru's
- Rear EF shocks on an EK?
- EJ1 tein springs on blown shocks
- Ek coupe Eibach Sportline & Proline...
- Skunk2 Lowering Springs - Shocks?
- need help: how to lower car.
- help changing front camber kit on my ef
- WHAT IS "ON THE BRAKE"
- broke my control arm bolt.. need advice
- Rattling noise on left wheel
- Looking Forward to buy Coilovers.. F&F Type ONE or BC N+
- help with alignment and camber problem
- Integra shocks that were on a Civic without washers won't fit Integra anymore
- TEIN SHOCKS!!!!
- looking to do a s2k brake upgrade for a 93 si hb
- How bleeding an old master cylinder can increase failure rate
- help asap!!!! drum to disk conversion help
- spring rate/shock question
- Energy Suspension Torq Mount Inserts
- Brake pedal
- God Speed Full Coilovers
- How good are H&R coilovers
- h22, ek, d2 suspension... sway bar questions...
- brakes keep going out
- 91 STD Hatch Lowering
- Springs VS. Coilovers
- Form and Function Type 1 vs. Progress CSII
- Shop said outer tie rod is bad, how to tell if inner is okay?
- Question about my Tokico shocks...
- 92 eg hatch no brakes
- Time to go low?
- (RSX-S) Front SPC camber bolts de-aligned within a day! Need help
- Need help w/ Raceland EP3 Coilovers!! Stranded.
- Anyone heard of this??
- Suspension is too stiff
- Daily Driving alignment specs?
- where do i find rotors and brake pads for 4x114 suspension
- Need help picking out suspension setup
- Coilover selection
- Need to tweak my suspension
- 92-95 EG question about drop coils
- What's a good price for Tokico Blues for EK????????
- kyb agx shocks anygood?????
- 5zigen 15x7 +33 ?!?!?
- Eeeek!!! Suspension help!
- just recieved an asr swaybar for da ?????
- Best Camber Kit: for 96-00 EK Civic
- Brake Threads?
- spring choice for DD on illumnas
- Front upper control arm stuck
- best sway bars
- springs to accord 5gen from oddyssey
- Please help with new brake set up
- Crossbeam/steering gearbox removal
- what 22mm sway bar is this comptech ?
- coilovers??????????
- Problems contacting KONI...
- BWR Rear Subframe and OEM rear sway.
- crazy front tend shake
- ball joint question
- strongest rebound ?skunk2 or koni yellow
- Daily Driver, Opinion on parts store shocks vs. perf. shocks
- Whats the proper way to set preload?
- Where to get ds2500?
- eg front
- KW Suspension??
- eg raer breaks
- lower control arms?
- Please Help with Civic Ek Springs
- Got an aligment, steering wheel is still crooked
- DROPZONE SUSPENSION
- New Koni Yellow, squeak and low compression resistance
- Need help on lowering my car...
- 1987 Civic Si
- car pulls to the left??????
- 205/55-16's Major Rubbing
- Suspension HELP! Blown Struts? Or... ?
- b pillar bar
- Need feedback for Subframe Problem.
- suspension
- Ride Profile/Pic, Q's ride height & rust prevention
- QUESTION FOR THE SLAMMED CARS! axle cv boots always ripping?
- quivalent brake pads to hp plus
- Del Sol suspension how to adjust
- 96 civic hb - Eibach Pro Street S Coilover Review
- traction bar question
- sway question
- 11in Rotor on an EX
- suspension suggestions...
- Slammed car axle problems
- dc brakes on ej
- How to fix busted Integra front sway bar link kit ??
- TOP MOUNT/TOP HAT
- Looking for Infromation
- Brake problem
- What do I need besides lowering springs and shocks
- Looking for experience: H&R Ultra Low VS. GC/Koni
- Alignment on my new suspension setup.
- Upgrading pads, rotors, and swapping to stainless lines, suggestions wanted!
- Help Picking Suspension
- peformance in control coil overs
- Would this Set-up be everything I need? Please help.
- Spring Rates
- Suspension replacement parts?
- energy suspension bushings
- any better coilovers out there?
- collar wont lower on GC coilovers. HELP!
- for ground control do i turn collar up or down to lower
- Need help with supspension 99 civic si
- Rear Disc Swap ABS question
- Brake cleaning question
- 89 Accord - Front Sway Bar Mount
- size of brake boosters?
- Suggestion on replacement brake rotors / pads
- Rear LCA's
- Coil over set up?
- Learn me the honda odyssey knuckle: cut, shorten, and reweld? For dc2 and EF
- What do H&R racing spring look like?
- lower ball joint hitting rotor
- Could someone identify this part for me?
- Is this EM1 sway bar mounted correctly?
- 650 to spend educated advise wanted
- Help Please.
- What part is this? Noob Help
- Type r five lug question????
- LCA's EG/DC Chassis
- replacing shocks need help 95 teg
- Semi or posi-quiet loaded calipers ?
- which calipers?
- Rebarreled Steelies wearing out front tires
- short shifter
- Opinions On Rolling Fenders.
- HowTF Can I Get A Hold of Koni Customer Service?
- Hard when off falls to floor when running
- will good struts solve my problem?
- 1996 DX brake upgrade
- whats the idea camber/toe setting for dd
- finally learned i need an alignment/ but is it bad to get with different tires ?
- BuddyClub n+ squeak in rear..but....
- bad whine while braking
- Ground control/ koni yellow assembly
- Caster problem.
- DIY: 92-00 Civic Wheel bearing Replacement
- alignment shop recommendation santa monica
- RSX TYPE S MASTER CYLINDER
- 92 Civic CX Front Sway Bar?
- tokico illumina kit?
- My ride quality
- New rotors and pads
- raceland on 01 civic?
- braking going to the floor
- Does the asr 24mm sway bar with brackets bolt onto function7's 96-00 subframe brace?
- Rebuilding Apexi Coilovers
- 5 lug conversion-which master cylinder booster?
- cheap ways to lower car???
- SPC Rear Toe Kits - Help Deciding Between 2 Designs
- looking for RL advics RL 4 piston calipers
- Fake Skunk2 Lowering Springs
- Importance of Proper Torque Specs?
- keep tein ss or get omni?
- going to make my first sway bar/reinforcement purchase, but which?
- Please help identify front strut bar
- Coilovers not sitting at same height/bumpstop problem
- LCA bolt! Any way to take it out without breaking it?
- 97 ITR BB/MC more pedal travel problem...
- Are shock boots necessary on stock shocks/springs?
- Skunk2 lower tie bar no hardware
- Budget Drag suspension setup?
- Where to buy es rear lca bushings for blox lcas?
- tokico illuminas, what springs?
- what is the real advantage of a 40/40 prop valve?
- OEM Rear Trailing Arm Bushings vs. Sliding Aftermarket Type???
- Replace wheel bearing on EG9 VTI
- Rubbing noise after changing Brake Pads
- Which spring is front, Which is rear?
- Slammed Suspension Recomendation
- Rear camber question
- NEED HELP FAST!!! Ek/Eg coilovers
- camber adjustment
- Best options for struts?
- JIC Dyno sheets
- Need help
- do i need a spring compressor for....
- 90 crx si suspension
- Spherical bearings for EK front lower control arms?
- blown coilover
- mars suspension for dc2
- Chopped my springs
- Beaks Lower tie bar
- Help diagnosing a problem
- Caliper pin orientation
- Difference between Civic & Integra Brake lines??
- Installed ITR suspension in my EG, rear is bouncy
- Camber ????
- breake cables for a civic 96 conv
- traction bar and clunking= ???
- How do I fix this? Caster on EF + itr knuckle
