View Full Version : Suspension & Brakes
- swaybar Q?
- having prob with camber and tires!!!
- Summit Racing Performance Cross Drilled/Slotted Rotors - Anyone Have Experience With These?
- whats your opinion??
- ENERGY SUSPENSION BUSHINGS FOR CIVIC EK VTI JDM???
- Rack and pinion overhaul.
- Progress Sport Lowering Springs?????????
- D2 RACING COILOVER MUST SUCK IF NO ONE USES THEM
- help on 00 civic suspension setup
- 1989 CRX Si: ETD Racing Traction Control/Front Crossmember
- 1989 CRX Si: New Suspension Setup
- whats the best type of suspension?
- Please advise..DRIVER ART COILOVERS
- Recommend me a spring
- dc2 front and rear sways
- For $500 can you beat the Eibach Pro kit System? (EG)
- Need Help - Installing Carbing 3pt Strut [ lots of pics ]
- Is it really important to get a alignment after lowering.
- Steering upgrade?
- lowering springs ?
- 91 civic struts on a 95, caused the struts to wear out faster?
- Subframe problem...
- What spring rates are you guys running for "slammed" cars?
- H brace?
- HElp!!!!
- Stance, Function-7, Topsetup CTR/TIE bar!!!!!!!!!
- Tein, or Ground Controls?
- spring rates for H&R sports for EF CRX???
- tokico blues and springs? any good? tein help too.
- suspension setup need help
- EM Racing C Pillar question..
- ------> you think i'll rub with my setup?
- What should I do? Buy softer replacement springs for F2 coilover or buy Tein SS
- Anyone know of a strap type spring compressor tool?
- RATE YOUR KONI YELLOW/GC SHOCK COMBO COMFORT LEVEL
- new to suspension!!!!
- Need civic shock pictures
- what suspension should i get?
- Troubleshooting suspension problem
- Crunch or knock at full steering lock
- H-T groundcontrol code? (have searched, even called..)
- Ej1 front lower control arm question?
- for those wanting a rear sway bar... read this...
- Anyone riding dirty on an Eibach Pro-System Plus?
- Has Anyone Tried The Eibach Pro Street S ??
- TEIN S-techVS Tanabe GF210'S
- Would like to get an old set of springs tested to find their actual rate
- front fork question
- bump stops look like a worn out eraser
- How firm/soft on Koni Yellows?
- Front full omni power coilovers won't lower anymore?
- Question on springs & struts...
- installing coilovers
- I searched and searched No luck so my question. RSR springs on Tokiko Illuminas?
- Koni shocks still good?
- Eibach Spring Stats
- ASR Brace
- energy suspension bushings
- Quality difference in Integra H&R sport,Neuspeed Sport,Eibach Sportline w/ Tokico HP Shocks!
- what are these coilovers? baffled
- Question about the ball joint replacement
- Install cost for Coilovers? socal
- s-tech teins
- Brake like bracket when installing ASR bar?
- help please
- are grade 5 bolts strong enough
- Wheres your camber?
- skunk2 camber kit?
- Rear tire wear
- What car jack would you recommend?
- skunk 2 lowering springs....
- Front upper ball joints, options?
- GC top hats with stock struts..
- -~-~-~- Anyone ever use ITR H&R sports on a LS/GSR -~-~-~-~-
- Rookie mistake! kinda funny[ksport full coilovers/skunk2 camber kit]
- Soft Quiet Ride Wanted - Prelude
- CTR rear sway+ASR brace on my lowered civic
- Settings for Koni yellows
- How to improve my current suspension setup
- stumble away or file for refund/credit ::: Zeal B2 Suspension
- Sway Bars That Work With ASR
- JIC Magic coilover?
- what do i mount my trackson bars on my CRX?
- ? about GC coilovers
- camber kits
- camber, etc
- Best suspension for being dumped
- Suspension advice from autox'rs
- GC Top Hats on Tokico Shocks
- Front L-shaped Sway Bar Endlink
- Koni Yellow Adjustables and NYC roads question...
- What are the Pro's and Con's about the SI VSA traction control system..?
- itr sway bar usdm
- Buddy Club Racing Spec Coilovers - 1 adjuster stuck
- Bump stop hitting the spring insulator, what to do? Need pix of GC spring insulators
- A little OT...adjusting height in rear when you have a big sway bar
- front sway bar questions??
- Messed up steering rack? help please...
- 97 civic ex coupe suspension upgrade?
- Polished Koni Yellows
- What is a good coilover set?
- 475f/400r spring rates?
- 92 honda accord shock advise
- 92 accord ex shock advise
- driving vibration, what could it be?
- Poly Urethane Bushing kit vs oem
- auto to manual motor mount
- EG installed GSR w/Kaaz and now handles like crap...
- will LCA help out w/ rubbing issues.
- Camber Kit
- 99 Si Suspension parts on 88 civic dx
- Is this a good deal?
- Messed up suspension?
- 95 Accord
- Best coilovers to dump a 1998-02 Accord?
- Omni Power knocking issue....post here if you have this problem.
- GSR rear sway on EG - need subframe brace?
- Driveshaft: Outboard Joint + Knuckle
- KONI YELLOW ARE BLOWN. D2 RACING ANY GOOD
- hybrid sus... buddy club RSD typer sus into 90-93 integra..front wont go lower than .5 fingers?
- LCAs for CD7s
- ITR rear sway help
- Tein HA Coilovers
- skunk works coil overs
- KONI YELLOW KEEPS TURNING
- Omni rear upper contral arm install question...
- Best ride coilover - Edelbrock vs Illumina R vs Koni/GC
- which shocks give the smoothest ride?
- COTTER PINS
- how 2 adjust function form coilover type 1 (DC5)
- What other suspension parts should I replace in my 14 year old car?
- Going to Strip, shock settings question...
- Pic Select or Koni/GC with 400f/450r
- Coilovers with progressive custom spring rates?
- si rear swaybar to DX EK
- 02 si skunk2 coilover fit a 02 RSX
- cambe kit worthy?
- Installing ASR sway bar/Tie bar combo?
- help please
- question about KYB AGX shocks/struts
- GC Koni or Flex Tein
- Brake caliper location
- My car in the makin
- Difference between Ground controls for Integra and Civic?
- ? about TEIN STECHS!
- Stock forks?
- suspected bent frame
- Function/form fully adjustable coilovers
- Auto-X Setup
- can i put 92-95 stech on 96-00 civic?
- Is this a Bad Strut??
- if i run 225/45/17...
- FWD Drag Suspension Tuning
- Camber kit question
- need help.. have b18 eg6 and need to know what kind of suspensions is good..
- 2.5 -2.0 drop
- Installed my Koni Yellows, need advice on settings
- brake caliper location
- Really squeaky suspension...
- Optimal Height
- function7 LCAs, Can i use my stock end links with these???
- 93 civic Ex drums to Discs fomr a 91 si hatch
- Is my Buddy Right?
- Needed some input on alignment questions
- Megan Racing Sleeve-overs
- K sport kontrol coilover???
- endlinks
- What's your suspension?
- Such a big lie!!
- 01 Civic Roaring Front End
- new to suspension, tokico blues
- omni uca camber kit
- EG GSR Booster/MC swap... Which brake lines?
- clunking when hitting uneven road.. or like railroads
- Best Suspension setup
- suspension problem
- Rear disk brake swap
- bushing condition, what do u guys think?
- Koni/GC ride quality???
- Has anybody used Omnipower coilovers on the track?
- KYB GR2 Shock help
- lowering spindles, anyone use these or have experience with them?
- Safe lowering on Tokico blues?
- ummm...whats this all about?
- kyb agx 4 way question
- h&r coilovers feedback?
- Recomended GC spring Rate on Ek..?
- buying new suspension, looking for in-put
- best set up for my EF
- Lowering
- koni bumpstop isntall
- Can I use the stock endlinks on rear ITR sway w/ ASR subframe brace?
- do i need spacers?
- Endlink Question
- Is it noraml. (searched)
- H&R race and what shock?
- Tophats for a 2002 Civic EX Sedan
- function form coilovers
- question about function form coilovers..
- helper springs?
- new suspension any suggestions...
- need some help asap koni install
- Adjustable UCA/LCA's for DA?
- which coilovers for stripped out 95 coupe?
- damage from riding on blown shocks?
- best CRX Suspension?
- Should I expect a drastic toe change on an integra with a .25-.5" ride height increase??
- Accord 5 Lug Conversion
- F2 & BC coilovers
- Upper a arm noise???
- Negative Camber?
- Springs?? or blown shocks?
- 1996 ACura 3.2 TL Struts/Shocks
- What are Good Axels to Use
- which shock is the best
- is this suspension setup any good for the money??
- noob: D2 Coiloves, Do i need EG6/ITR LCA's??
- AEM Big Rotor brake kit with 15"
- pics of mugen rear strut bar
- D2 racing
- Omni adjustable daping coilovers
- Two questions
- How do you kow if you shock are ok?
- I have tein springs, could i still get the coil overs, if i want ,
- Switched to type r suspension
- Koni Service
- New or Used?
- Diagnosing a blown damper......how do I go about it (this is a long one).....?????
- ek rear lca's on my DA?
- Still need help on sway-bars
- tien ss
- car accident - right rear suspension damage, fix or move on?
- Which bushings are most important to replace on a 200k chassis?
- Can you switch out the sleeves?
- Installing ARP wheelstuds? What's the best way??
- Rear Camber kit (Band)?
- Koni snap ring question
- help with suspension problem
- increased caster angle with no powersteering
- springs or coilovers?
- where can I buy h&r springs / koni yellows? (one vendor)
- Shocks for my 06 Accord
- how much can they take, spring rate that is
- lowering springs for em1 w/ front integra shocks, stock rears?
- Function 7 Endlinks... which swaybar bushing?
- Winter Storing Car - Suspension preservation
- warranty issues (koni yellow + gc top hat)
- So I snapped an endlink, found some that are beefier to replace them with.
- custom spring rates..???
- will 96-00 shocks and springs fit a 92-95 civic
