EK Rear disc conversion w/soft peddle
I recently installed a rear disc conversion off a 94-98 integra on my 1996 DX hatchback and also installed s/s brake lines from the proportioning valve back all the way around. Ive bleed the system several times and still have to put the peddle pretty far down and doesn't feel stiff. I've also replaced the master cylinder to another new OEM re-manufactured one and still the same thing. Should I replace the master cylinder to an ITR or S2000 to fix this problem? Any and all recommendations are greatly appreciated, thanks!!
Re: EK Rear disc conversion w/soft peddle
If the fronts are stock it shouldn’t be as drastic, but you are going to have more pedal travel with the rears converted. Is it spongy, or is it just more travel? Did you really replace all of your hard lines with braided? Why? A 98+ Integra (any trim) is 1” and will bolt on to your booster and lines, but is not recommendable with the 9.5” front brakes.
I would expect a little. Not as much as if you swapped in larger fronts. Fastbrakes does offer a kit that will let you upgrade to 11" fronts with Civic or Integra calipers on your current knuckles. That could be an option if you don't want to find knuckles.
But here's the deal, you've put an atypical combination of parts on your car and you are concerned about the atypical function. You can't really expect to fix it without changing out some more parts.That's how this whole thing works!
You may explore what size master cylinder the 92-95 Civic or Del Sol Si had. Both of those cars had 9.5" front brakes with rear discs. Check into whether or not you can source the same prop valve to your car also.
delsizzle1
15
02-15-2012 09:37 PM
Ek9andyroo
09-09-2009 12:42 AM
STN_Pat
13
08-12-2004 05:20 PM
Ya@inlinePRO
03-14-2002 11:41 AM
