PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. What suspension setup to go with?
  2. H&R race or sport
  3. kyb gr2 with some skunk 2 coilovers questions
  4. will i need a camber kit on a 1.5" drop?
  5. adjusting coilovers without messing up the preload
  6. rebuilding koni yellows
  7. coil over question
  8. Skunk2 Shocks and springs for CRX 88-91?
  9. Swift Springs...
  10. calling all H&R owners..
  11. do shocks squeak when they are blown...? need big help!!!
  12. My SKunk2 Suspension is on Ebay
  13. springs rust
  14. Camber help!
  15. Will 90-93 H&R race springs fit into 1994 integra gsr..?
  16. spring rate
  17. Gr2's with 1.5" lowering springs?
  18. fix this? or leave it be?
  19. GSR Suspension or 96 spec ITR suspension
  20. Suspension Theory Literature
  21. H&R Neuspeed race Header clearance
  22. civic Si suspension questions
  23. Dust cover orientation???
  24. is this a good deal ?
  25. REAR DISC HELP!
  26. suspension tie rods, etc . . . .
  27. SUSPENSION FOR A DA6 integra
  28. dc2 with h&r race
  29. slight vibrations....
  30. Skunk2 Full coilover setup
  31. JIC FLT A2
  32. ?.. putting integra suspension on EK...will the sway bar bolt up
  33. Dropzone coilovers. How are they rated? 450RR/350RR?
  34. suspension on eg
  35. goldline springs: which ones in the front? which in the rear?
  36. ASR brace/ITR bar with tanabe hyper?
  37. Cut bump stops?
  38. front and rear camber kits.
  39. whats the purpose of o rings???
  40. tein s-tech springs
  41. Drag suspension?
  42. gsr brakes swap upper ball joint
  43. TANABE PRO S S reviews...
  44. 1988 CRX which shock combo?
  45. what the heck... koni has to different set of koni yellows?
  46. tein 92 civic
  47. J's or ALEX racing a frame braces
  48. Civic Lower Rear Arm Bushings..
  49. AGX install on a crx ( any precaution i should take?)
  50. specific spring selection help
  51. how is the KYB shocks?
  52. simple question? does 4x114 suspension use 32mm or 36mm axles?
  53. will RSX springs fit Si?
  54. coilover ques
  55. Ej8 - Suspension question
  56. Shocks are blown again!!!
  57. Ingall's Accord camber kits...
  58. Rear sway bar?
  59. installation
  60. worth it?
  61. got skunk2 springs need advice on shocks.
  62. Tokico illumnia VS KYB AGX
  63. coilover installation intructions on a 90 si hatch
  64. ksport coilover spring rates please help.
  65. OHH, Why thank you very much Mr. Brown. A-Spec Racing pics inside>>
  66. what would you buy?
  67. progressive wound spring vs linear pros and cons
  68. Got an alignment. Am I okay? Tips for a seized rear toe adjustment bolt?? Results inside.
  69. Spring installation - Socal Orange county.
  70. tenzo r springs
  71. tein basic vs. omni power
  72. monroe shocks... anyone ?
  73. ever been done befor?
  74. HELP with brake lines n such
  75. omni power or megan lca's
  76. do i need a subframe reinforcement kit for my crx
  77. Cracked Rear Subframe Help!!! (::PICS::)
  78. which bushings crack or break?
  79. sway bars
  80. eg suspension question?
  81. Yay or Nay?
  82. can i still get an alignment with LCA and lower tie bar on
  83. Integra camber specs???
  84. coilover rookie
  85. Best Springs??
  86. any ef pics with D2 full coilovers, or tein SS
  87. Lower control arm
  88. good or bad suspension coice?
  89. torque specs for camber upper control arms
  90. Camber Kit question
  91. skunk 2 upper control arms
  92. Alignment shop issues...
  93. 02 Acura RSX Type-S Suspension
  94. Dirt Protecion on Shocks
  95. Chopping springs?
  96. 01 civic+ rsx s rear sway
  97. Yay or nay? 94 honda civic ex suspension question...
  98. DropZone racing struts/shocks+ springs
  99. Traction bars, Does any body have them?
  100. Skunk2 pro-series full coilovers
  101. help me out!!
  102. Air ride 96-00 civic hatch
  103. Trailing arm bushing replacement
  104. Civics: Struts or Shocks
  105. what would happen if...
  106. Tein S Tech/KYB Gr-2 -or- H&R Sport/KYB AGX
  107. Found a great tool to help with bushing installs, 1 ton Arbor Press for $23
  108. QUESTION FOR TEIN, USA!!
  109. EK H&R Race Springs on EG?
  110. rear suspension noise
  111. good idea?... 24mm sways
  112. Proper balance of sway bar sizes
  113. will 94-01 work with 90-93 teg?
  114. buddy club n+ or d2 coilovers
  115. 1999 Ex suspension
  116. NEED CHEAP DRAG SPRINGS
  117. shock absorbers for lowering springs
  118. teggy brakes on civic?
  119. dampening levels
  120. need to know what years these coilovers fit
  121. EK w/ gsr suspension LCA please help
  122. strut bars and gc top hats
  123. where can I buy 21mm front sway brackets?
  124. OMNI new thicker bottom mount... no more height adjustement for me ?? (92-95)
  125. Brake line help
  126. QUICK SUSPENSION QUESTION
  127. EG Carbing bar w/ MCS fit a DC2 integra?
  128. Tein RA on EK...help
  129. installed tein s tech on Tokico illuminas pas. side 2in higher than dr. side
  130. outer tie rod end
  131. Accord 1992 Lx REAR BRAKE CONVERSION
  132. Tokico illuminas and tokico springs
  133. koni's tein stech, gc, or eibach sports and question on brakes
  134. OMNI POWER SUSPENSION
  135. Wich is better Eibach Proline or Sportline springs??
  136. TEIN FLEX vs. KONI/GC set up.
  137. Which one's to use ?
  138. breaking upper control arm ball joints?
  139. ebay coilovers
  140. Suspension mod. names?
  141. EG EK spring rates
  142. Will toe damaged tires ruin a good alignment ?
  143. spring rates
  144. What size tire on ls mesh?
  145. tokico Illumina firm adjustment direction
  146. 1991 CRX suspension project.
  147. do type r five lug lca's fit 99-00 hatch?
  148. rear ek civic shocks on integra?
  149. ground control password?
  150. suspension
  151. rides real bad.. Ground Controls
  152. For those with 15" wheels on eg civics!
  153. Viberation at high speeds after getting stuck...
  154. worth it?
  155. Rear Suspension Help!! (56k no no)
  156. Car has more weight on the left side
  157. Spend My Money
  158. EK control arms?
  159. What strut bar works with GC top hats?
  160. setup
  161. front end problems
  162. can i lower my car a little more after springs have been installed?
  163. What kind of suspension for extra weight in the back?
  164. rear suspension problem
  165. question... is this normal?
  166. need input on suspension upgrades...mainly bars
  167. which set up do you suggest
  168. is it possible???
  169. leaving the spring assy. on car to decompress?
  170. anyone using KSPORT coilovers?
  171. neuspeed suspension dealers?
  172. Endlink Questions
  173. Getting an Alignment
  174. First suspension upgrades?
  175. ITR vs GSRs suspension set up?
  176. sway bar confusion
  177. silencer tubing needed for goldline springs?
  178. LCA from itr to ek?
  179. Ex vs. Si Springs
  180. ground control top hats
  181. Buddy Club N+ Damper
  182. I HAVE FIVE LUG ?????????????????????'S
  183. Skunk2 Coilovers on Kyb Agx's
  184. getting an alignment after drop...
  185. D2 on an Eg civic
  186. Skunk2 pro series Rates
  187. good Daily driver coiover over shock combo
  188. Stock Spring rates
  189. 25mm JDM ITR front sway bar, what does it fit
  190. Type Flex
  191. KYB AGX and Tein
  192. good coilovers?
  193. tenzo springs r
  194. Difference in height .. stock oem vs koni
  195. differences between GC for koni and GC for stock.tokico/etc.?
  196. Skunk 2 coil over help!
  197. omni coilovers good for daily driver
  198. car sitting on no suspension. need help ASAP. PLEASE HELP
  199. which is better..Tockico Illuminas or KYB's
  200. raised front dropped rear
  201. Beaks on an EK with H&R OE's
  202. Koni/GC setup...Helper Spring ?'s
  203. Rear Lower Control Arms
  204. dissatisfaction
  205. is it good to lower more from the front than from the back?
  206. broken upper control arm bolt.. suggestions?
  207. who makes this
  208. Front and rear sway bar sizes
  209. Which Suspension??????
  210. megan racing strut bars?
  211. 05 civic 2dr, cant decide on springs
  212. coilover springs????? how low can i go without camber kit for right now?
  213. 2001-2005 civic rearshock mounts, alternative to GC tophats for ef/eg/ek's????
  214. traction bars for daily driver
  215. front lower h brace for eg?
  216. TEINS!getting the facts straight
  217. Tokico Coilovers
  218. Inner Diameter of H&R sport springs for ITR?
  219. h&r race spring rates
  220. bilstein with h&r
  221. crx rear suspension
  222. subframe reinforcement required?
  223. best coil overs money can buy?
  224. are koni yellow hard to adjust? springs for decent drop and will 16" fit
  225. Tanabe Pro S-S Type I and S Type II
  226. occasional KNOCK when leaving first gear/down shifting/dips/reversing...?!
  227. NEED ANSWER ASAP PLEASE!! EX rotors and calipers on CX knuckle.....
  228. Anyone familiar with the NEX coilover system?
  229. Adjustable Damping..... What the Flip????
  230. coilovers or springs
  231. Skunk2 Full Coilover spring swap
  232. Has anyone used this mugen style upper strut bar?
  233. WILL OMNI SUSPENION OFF AN EK COUPE FIT MY 89 EF CIVIC HATCH?
  234. Anybody using negative A-arms????
  235. spring is way soft ,can i change that by using koni
  236. quick qeustion?
  237. i have 16 in my eg can i drop it two inches?
  238. Axxis Brake Pads
  239. what springs should i get for my car
  240. h&r with what struts/shocks?
  241. civic/teg lca's
  242. New Suspension Plans
  243. installing stock suspension please help!
  244. Best Sway bars for 5th gen prelude
  245. Koni yellows
  246. Omni Power coilovers for an em1
  247. any body runs dropzone coils and shocks!!! r they good
  248. my 93 civic cx pulls to the side in highways, or in uneven streets.
  249. Seized Upper Arm Bolt
  250. NRG Coilovers
