- eibach sponsors??
- 1984-1988 Civic Suspension Setup
- H brace VS traction bars
- mugen replica front strut bar any good as real one?
- ek hatch with five lug and toe problem
- lowerin 99 tegg
- Ksport and D2
- Stress Calculations:
- Toe & ride height relation
- EG Chassis: best rear subframe reinforcement kit
- Will a 3 point front strut tower bar fit with a k series swap
- Where can i get the best deals on suspension, and other structural parts?
- lower tie bars...i searched no luck
- what steering racks are bolt in? 92 cx
- getting some koni+gc's -- need some help
- just installed springs/struts; really bouncy ride
- will adjusting koni+GC affect spring rates?
- NEED HELP??!
- hey does anyone know the torque settings on ls struts.
- 5 lug conversion question
- Mugen Trailing arm bushing
- RSX REAR UPPER SHOCK MOUNT
- Koni/H&R change what else do i need?
- Anyone know whats up with ground control.com?
- whats a good drop for a 96 teg on 205 40 17s?
- Beaks Sucks
- omni suspension are horrible?
- omnipower camber kit, squeeks
- Tein RE coilovers installed = night/day
- D2 RS.....DC or EG spring rates?
- problem after installing skunk2 adjustable spring w/kybgr2
- Noob here.. but got a question.....
- Dropped my car...front passenger side is squeaking...annoying...
- GSR very loose
- What car are these springs for?
- Suspension Techniques Sway Bar.......
- 5-lug conversion question
- Hitting alot harder now with GC tophats installed ::help::
- Air ride Question
- Adjustible Shocks vs. Non-Adjustible
- Newb needing help raising car
- curious bout this.........
- how often do you guys check your rear endlinks and sway bar
- ++--POLL--++ what coilover do you like?
- Front wheel bearing directional?
- EK 2 DC..
- Review of Buddy Club N+ coilovers ???
- KYB AGX/NEUSPEED SPORTS
- plz help...
- Are my Koni's used?
- suspension swap/ help
- anyone on tein ss?
- tire rub elimination
- 640whp Turbo Integra .. Stablizer Bar Questions ...HELP ..????
- 91 Integra Autox Recs?
- Mugen Shocks on a Prelude?
- will 16x7 slipstreams with 45 offset fit spoon calipers?
- Noob suspension questions
- FWD Tuning
- Omni Sports or D2 coilovers?
- H&R Ultra Low coilovers
- Koni install problem/question
- Sway bar issues
- sway bar issues
- omnipower coilovers help...
- Looking for some knowledge...
- quick suspension question?
- d2 coil overs? omni? are they to same in quality?
- 91 civic radius bushings...help
- front lower control arms
- Dropzone Suspension ??
- Solid bushing and Spherical bearings kit
- FS:FRONT SHOCKS AND SPRINGS FS
- lowering an ls
- How much damage have i done?
- NEUSPEED SPORT SPRINGS?? any good..yes/no?
- Brake clearance question
- Rear upper control arms, what happens if they are shot?
- Eg=integra?
- Solid vs. hollow swaybars
- Are these any good?
- Mods for Sk2/ Omni UCA camber kits?
- how low can you go on 16x7 rims???
- lca/stripped bolt problems
- what the heck is up with the rubbing?
- skunk2 or omni camber kit?
- Will poor shocks cause the trailing arm bushings to break?
- hard shaking while braking...
- weird coil over height
- Can you Rebuild Tein Basics to not suck?
- best place to buy koni yellows?
- is this going to be too much offset for my integra?
- Adjustable shock question (spring or sleeve)
- Wandering and Pulling While Accelerating
- need a new brake master cylinder for my 90 teg...wat fits???
- Suspension took a dump time to shop suggestions?
- type r lca's fit on em1
- trailing arm bolts
- question/for my DA suspension
- is this okay?
- Best suspension for dd crx/hatch « » 3:20 PM 9/6/2005 Reply Edit
- people who ordered either d2s or ksport
- Front Forks
- cant get front springs off.....
- Confused about spring rates
- Integra struts on civic????
- progress springs?
- new d2s for me
- progress springs?
- Sway bar question
- ITR rear sway bar differences?
- New suspension setup?
- rear lower shock bolt seized on my EG
- KYB GR2 any stiffer than OEM?
- Adjust front camber
- Suspension squeaks
- D2 Racing Rs Coilovers problems?
- my rear end suspension is extremely stiff....
- Im new to suspension.......will this work???
- Can anyone name this rear anti-sway bar setup for an EK?
- removal of the siffness adjuster on Zeal B2
- b16 build up
- 95 del sol si rear disks into 94 civic cx
- HELP: Getting Koni yellows for a great price- DO THEY MATCH WITH SKUNK2 sleeves?
- Skunk2 Replacent ball joints?
- D2 install pics and Review..
- My 93 hatch handles like shit...why?
- uneven Car
- Rear Swaybar thickness question
- Need help deciding what suspension to order
- please help!!! 91 integra gs w/ axle-steering problem
- Is it possible to get better traction w/o lowering?
- Suggeestions for kid friendly lowered setup.
- Extended TOPhat mod, what kind of piping?
- KYB AGX Problem
- tein edfc crx
- 400+ whp street cars help me out!
- what kinda lower tie bars you using with ITR rear sway bar ?
- swift lowering springs?
- 01 Koni and GC setup on my 90 integra rs - Searched
- Suspension Question Need Help Guys????????????
- fitment issue on tein coilovers
- suspension suggestoins
- Best way to raise 90 Hatch
- the best overall suspension set up for a honda?
- anyone running dropzone coilvers on a 92-95 civic?
- need wheel stud
- Sprint Springs on a EG
- anyone runing only with rear lower strut bar?
- Huge problem during 5-Lug Conversion...Unable to remove this bolt.
- EF front omni coilovers correction ?
- R1 Racing Sports Coilover
- Need H&R sports spring on integra pix
- stock spring son lowering my car(HELP)!!
- What kind of aftermarket tubular upper control arms are these?
- Suspension is grabbie after installs
- 114.3x4 accord/prelude on 96-00 civic?
- Spoon Calipers on EM1 4x100 searched and confused PLEASE HELP
- safe suspension height
- New style Omni LCA's & ITR sway bar
- which springs to get!!
- People with the JDM 5 lug conversion on their GS-R
- Koni specific Ground Controls, the same for all years of civic?
- ot: any SoCal'ers have an EG manual steering rack for sale?
- Drum to Disc onversion on '98 civic ex
- Intake Air Box
- Is this price reasonable
- 97 Civic Wheelbase off after collision
- tien springs
- My Apex-i N1 99spec Coilovers need rebuilding!
- which bushings to buy for ITR rear sway on EK?
- kyb agx question about settings
- car shutters under accel.
- **Review: Skunk2 Coilovers on 92-95 Civic EG/EH**
- too low to align camber?
- need to know which ground control coilover goes where.help?
- Megan Products
- Not sure between Tein or GC/Yellow
- Suggestions for a 97 Prelude SH
- cutting bushings bad?
- Suspension Tuner
- What else do i need to put on my si rear sway bar
- 2006 Civic Suspension
- EK Coupe with ITR 5-lug or Si Suspension
- Brake fuild ATE vs. Motul
- werid noise in the back of my hatch
- Suspension suggestions for DC2R
- MEGAN RACING LCAS?
- Koni Hardware
- My 2000 CRV is having a problem on the left front. . . but mechanics can't find the problem?
- Spring rates with GC and Koni Yellows
- Tein RA with EDFC
- ot: Ground Control is now an H-T sponsor
- hey guys i got a quick suspension question
- H&R OEsports vs. sports on sp3 koni yellows review -eg hatch
- Steering Wheel Shakes VIOLENTLY Going Over 50 mph, HELP!
- Air Ride
- can gc springs be used with stock shocks?
- eg hatchback with h22
- ek with k24a2 swap
- quick highway question
- I always wondered
- buddy club racing spec damper adjustment
- Help me with a new suspension set up (crx)
- Whos got a 02 civic Si dropped on springs with a good ride
- Help: Custom Spring Rates for a 4dr Integra
- what LCA's to go with
- omni-power rear lca's and toe
- camber adjustments
- Tein or cusco ???? for EK civic
- Anybody Running A Rear Sway Bar With No Front Sway Bar?
- Where can i get Ground controls to use with koni yellows?
- Help: Ingalls camber kit 35730 Questions
- Is ground control the way to go?
- Question on steering rack for DC2
- popping noise from right rear when turning right
- D2 Coilover Review Request
- Tein Circuit master system
- EG Rear disc brake conversion question.
- Too much info on here. Illumina's with what springs plz???
- equal size sway bars?
- would new shocks raise my ride?
- Ground Control noise
- Camber is different on each wheel... weird.. HELP!!!
- ZEAL B2 helper springs???
- Radius rod noise with z10 crossmember
- tein+koni=?
- helppe w/ tien type flex on an ITR
- spring rates?
- Rayne Motorsports Big Brakes?
- Omni Lca On GSR and Omni Rear Camber Kit Problems
- OEM CORSS MEMVER 90 civic hatch
- all handling **searched**
- Quick help for lowering spring install
- tokico blues and what shocks?
- getting rid of my omni streets... what suspension should i go with now?
- Question about wheel size and drop???
- '94 Teg coilovers in '91 CRX
- Zeal Coilovers
- h&r coil-over spring rates
- GC custom spring rate question
- One coil sitting higher than the other?
- Sagging ass of Ep3 and random noises
- GSR rear sway on EG hatch
- kyb or koni?
- Help...front driver side sqeaking after dropping it...
- On-Car Ball Joint Press, Special tool that allows ball joint swap
- Brakeline to Caliper bolts/washers
- civic lca work on itr?
- If I want to change my sway bar, what's everything I need?
