View Full Version : Suspension & Brakes
- Redrill ITR 96 wheel hub from 4x114.3 to 4x100?
- Help me get my civic back out on the track, rear disc swap spacing prblem, 1/4" more track on RHS.
- RTA questions
- Omni coil-over spring rate question
- Need better handling
- Has anybody heard of Specs suspension?
- omni coilover with koni yellows
- crx illuminas with stock eg springs on eg
- car sags to one side
- dc5 rear tophat
- itr sway bar with bsq kit - to comptech rear sway bar
- Worn suspension bushings = bad ride quality ?
- What brake set up for your DA?
- Pictures of a rear koni yellow
- Converting toe from degrees to inches?
- 95 civic b16 suspension help
- advantages of progressive vs. linear spring rate
- camber kit n00b = me
- Riding on little shock travel bad?
- skunk 2 coilovers and koni yellows?
- Carbing
- Suspension question
- crx camber
- B+G LOCK RING JAMMED!!!!
- Do I need a spring compressor?
- Koni with Progress Springs
- best coilover/spring-shock-combo under 650 dollars?
- Where to put brakeline when installing Koni Yellow?
- Where did everyone buy their ground controls at (im buying them for koni's, and it looks like no spo
- in need of springs
- coilover ?
- 5 Lug on a D-Series
- h-brace
- What camber kit had worked best for you?
- got stuck while trying to change the shocks
- Omni Dyno Graphs
- 2.5 front drop
- Just ordered Koni Yellows For 97-01 Integra Type r for my 95 gsr Need help with Ground control setup
- Sqeaky Suspension
- TANABE SUSTEC PRO S0-C VS. OMNICOILOVER KIT
- Adjustable Upper Ball Joint
- gc/ tokico illuninas
- putting in new axle, and this THING appeared????
- Rear driver side higher than passanger side after installed Tein Coil-over
- dropped accord acting funny on high speed curves and other issues..
- KSport suspension owners or people who just may be able to help... What is this wrench?
- Need some opinions on suspension setup. (95 GSR)
- Ride Height on 17" Rims
- question about capadible suspensions
- Omni power front camber kit
- DC Integra H&R Sports Interchangeability with EG and EK Civic
- energysuspension
- official street/strip suspension thread
- How are Weapon R Coilovers compared to others?
- what spring rate should i go for h22a in ej
- need help fast!!!
- 2nd gen CRX suspension model
- ASR subrame brace+EG+ ASR 32mm hollow swaybar.....doable?Done?
- rear sway bar
- A few suggestions, please.
- what do i need
- Anyone got pics of H & R Sports on their cars?
- Bilstein HD
- What type needs rebuild (shocks)
- Arospeed coilovers = RS Racing coilovers ???
- strange engineering coilovers honda
- Skunk2 Lowering Springs with what shocks?
- Newb suspension question
- EG to EK suspension
- coilovers
- Installing wheel studs: How hard?
- 5 lug conversion
- question about crx suspension
- SPC Camber Kit - Difference btw Ball Joint nd Anchor Adj?
- No name tie bars?
- usdm integra 90-93 rear disc brake swap.
- question about putting springs on my car...
- Is Undergroundracing.com a reputable site or do they bS?
- Has anyone ever heard of RG suspension of Germany??
- installing lowering springs
- eibach pro system (springs and shocks)
- crx tien RA? to do or not to do.
- Alrighty guys... need your help, camber kit ?'s
- Need advice on suspension for eg
- what susp. to go 4 i.e H22inej
- where is th spring rate list
- low and what suspension to use?
- alternative to stiffer drag springs
- Suspension Bushings on 95 GSR
- X Bar
- Question will 5th gen accord brake assembly work with 1990 civic lx need answers QUICK
- Just installed GC Coilovers with Eibach ERS springs
- quick question about illuminas
- 2" drop will i need camber kit
- Quick question regarding EK lca's
- need help deciding wat camber kit to go with
- suspension help
- anyone know anything about aem brake pads?
- How did you guys install and integra rear sway on a 92-95 civic.
- Anyone using Tanabe springs?
- Uninstalling stock struts and springs
- Carbing
- Suspension Recommendations - 97 Accord ex
- Question about lowering a prelude
- Eibach pro-system
- EG civic trailing arms and upper arms
- On Going Wobble
- Looking for a street setup.
- Big brakes upgrade
- lower ball joint civic and teg the same?
- help on installing springs.
- clunking when turning
- Dust cover?
- omni power help
- Skunk 2 Camber kit differences
- Solution without using wheel spacers?
- Problems removing front LCA
- Si oem swaybar nuts and bolts questions.
- my DA got into a wreck today!!help
- Coilovers for my EG
- Would softer ride affect proformance?!
- Is my 4G Prelude's suspension stock?
- Megan Racing C-Pillar bar??
- Integra is rubbing, help!
- R1 motor sport camber kit
- Suspension Technique install for 99-00 civic si.
- used lowering springs?
- REAR BRAKES, torx screws stripped?
- are my springs, shocks bad. How can i tell >>
- My suspension, anyone else got these?
- SiR rear brake question
- Hybrid civic suspension
- coilover bushing popped up @ shock tower??
- Handling characteristics
- quick gc questions
- Swaying DC2
- rear sway for a crx
- eg/ek suspension
- installed shock and it lowered my car after test drive?
- 99-00 Civ Si rear brakes same as 94-01 integra?
- ABS code help?
- Omnipower LCAs...
- tokico hp w. skunk 2 springs?
- ground control with koni yellow sp3s ??????????????????????????????/
- Pulling off front hubs: HELP!!
- Help w/suspension
- LCA question
- What are these?
- Question????
- tokicko illumina 5 ways how do i adjust them
- Height issues civic/integra
- Problem: GC Sleeve will not fit over Koni Yellow Shock Body
- Help.. Is my hub or wheel bearing over with?
- sway bar question
- tokico hp problems??
- Will ek coilovers fit a eg?
- diff. drop front and rear on a 92-96 prelude
- slammed civic w/ to much shaking?
- bump stop
- new lowering springs are on and driver side is tilting upward?????why???
- loud clunk when going over small bumps? how to check ball joints? teg upper arms on a civic??
- Question about D2's
- Problems getting GC's?
- About to buy Koni Yellows, but first what is Perches? what does it do?
- Problems with my HS type coilovers
- suspension specialist... need a little help
- gc tophat and camber plates
- tein s-tech
- Preferred Camber Kit?
- 00 em1 civic rear trailer arm bushing question?
- Actually have a suspension problem and need help with it. No recommendations of aftermarket parts ne
- removing lower fork arm nut - need help
- tokico illumina r's for circuit? let me know please!
- suspension set ups for FF cars
- Smooth suspension for 2000 Si...ideas?
- DSS axles ABS ring removal
- D brackets for swaybar bushings-rear
- how do you tell which springs go on the front and which go on the rear??????
- Spring Rates and Lengths
- GC HondaMounts......I Thought You Could Only Use Them On GC Coilovers??
- Any shops with DMS coilover experience?
- Stock supension Hardware?
- Suspension installation
- how low to go?
- Reseting bushings?
- 4-Door DC2 GS-R what's a good setup with S.Tech Springs
- Best budget EG coilovers?
- How does a camber kit work?
- new shocks \ springs - stock ride height
- Blown JIC damper
- lowering - the smart way?
- Will JDM TYPE R suspension fit 89crx si?
- Goldline spring rates anyone have any clue?
- Rear Struts on a 94 TEG( What a pain)
- car geometry and lowering car?
- Type R rear sway bar
- best rear and front sway bar for dc2 gsr
- can anyone ID these Apex'i springs??
- eg shocks in a ek??
- type r question?? what parts do i need to get a 5lug r brakes to stop right on a eg???
- I Hate LCA bolts [Rant]
- can anybody identify this spring?
- Odd dents on my rear quarter panels... suspension related?
- Which set of springs would you go with?
- Anyone using the A Spec Racing 32mm rear sway bar??
- has anyone raised this question ?
- warranty@koni-na.com
- integra type r brakes into 97 civic coupe
- Wondering what types of shocks I have....
- 90 Accord: Adjustable coilovers
- K Sport Coil overs.
- Firewall brace: Anyone seen/heard/used them?
- wheel alignment in nyc??
- Help on some springs....... CHOices CHOices CHOices???
- how do you install air ride?
- Help with Ground Control Order
- Basic "True" Info On Air Suspension
- Tie bar needs longer bolt? shit!
- Alignment question
- What suspension setup do you swear by?
- need some feed back ( suspension,lowering )
- skunk 2 springs on kyb gr-2 shocks
- LCA install tips...needed!
- Car vibrates like crazy cause of Suspension????
- NRG Innovations
- 10.2" brake upgrades
- Which Setup would you prefer?
- Can adjusting camber throw off alignment?
- GSR brakes on my Civic DX intelligent questions
- So it begins...
- Horrible Squeeksss and clanks. 1995 Prelude KYB AGX
- Replacing Wheel stud: can someone explain these instructions?
- camber kits for 2nd gen integras
- quick question...... benen
- My D2 dyno charts.
- Ground Control pics
- interchangable??
- KYB AGX Durability Question????
- Omnipower suspension+brakelines?
- Ksport reveiws
- susp fix advice?
- Koni Shocks and Eibach Pro kit or Kyb AGX shocks with Eibach pro kit?
- Chicagoland brake vacuuming shop???
- 17x7 rubbing ??
- drag racing what do u guys set ur camber,toe,caster at?
- Buddy club Racing Spec Damper vs Koni / Gc
- ARE THESE ANY GOOD.....
- How to set shocks on my 3G TL?
- Need help with GC Top-hats install w/Illuminas
- CRX EF8 WITH 93 GSR FRONT BRAKE SWAP???
