View Full Version : Suspension & Brakes
- EP3 koni/GC rates
- Break pads and rotor suggestions? Also q's for fellow gc Koni!
- duralast brake pads
- Function & Form Type 1 Coilovers
- Anyone ever bought ground control cool overs new? Quick question
- tein full coilover setups
- Sway Bars
- HSD Coilovers
- Skunk2 springs question.
- 00 civic sedan 5 lug conversion
- So I found these new 02 civic ex ground control sleeves
- Tanabe PRO S-OC Coilovers
- vibration i cant seem to get rid of
- gsr rear disc conversion
- how do dampering shocks work?
- Bumpstop???
- Thoughts on this rotor/pad bundle?
- Skunk2 Setup for EH2
- Wheel fitment help
- ef forks on integra to go lower??
- Brake Problems
- Bumpstop Length Increase
- DC Integra steering rack and subframe into EK civic and vise versa
- (Another) Koni Sport Question
- 95 civic ex ST sway bars
- Bilstein shock
- 5-6 year old brake fluid ok to use?
- 96 ACCORD - Rear Suspension/Alignment Issues
- Spoon rare jdmonly gold springs specs
- brake light on after replacing rear calipers
- Brakes locking up!.....HELP
- Can you use rear bumpstops for front shocks?
- Best Suspension and Springs Combo for Road and Track 96 Civic CX NB
- rotor redrill place in SD Ca?
- Lowering Springs???
- couple questions reguarding bumpstops
- Toe variance in realation to suspension travel
- ***How Do Option Racing Coilovers Ride???***
- Spherical Bearing for front LCA
- Civic Dx rear end up upgrade. Need clarification on ITR swaybar and LCA's
- What rotors for EG front??
- Brake bleeder kit
- Best ep3 coilover
- Suspension
- how to adjust buddy club n+ 06 civic si
- no preload shock travel
- why does rear caliper guide pin seize?
- 2000 Civic Hatch asr rear sway/s2 lca install question..
- eibach pro system plus is not fitting properly! Please help!
- Brake dont work and the e-brake light stays on
- can anyone tell me which model and year cars these calipers came from?
- 94 civic sedan rear disc brake conversion questions
- Another godspeed post
- ABS Integra Brakes on non-ABS Civic - Work?
- lower contol arms
- suspension problem
- Cut stock Springs on Koni Yellow, anyone else done this before?
- whats a good oem replacement shock?
- 4gen suspension question
- cutting on a slammed EH6
- EF Front Forks on EK9?
- suspension?
- Brake master cylinder Identification help!
- looking to lower 06 accord
- brake fluid wond get to one caliper??
- 2000 hatch sway bars
- Slammed em1 need help with Axle PLEASE!!!
- feedback xs-power coilovers
- Hyperco Carbon Composite Bellows Spring Technology
- HELP: WAS LOWER BALL JOINT EVER REPLACED BY MECHANIC OR WRONG INS ADJUSTER ASSMNT?
- KSport and Blackworks - Spring Rates
- EG civic integra brake swap Brake booster and Master cylinder issues
- Good Coilover sleeve Combo?
- OEM Sway bar options?
- Ej 9 rear disk conversion
- Bolt keeps spinning PIC
- Suspension Setup 00 Civic EX Questions
- Coilover squeak :x *HELP*
- Is anybody running Koni RACE shocks?
- notice hiss from brake booster area when car turned off
- Is my ASR newer or older model? HELP PLEASE?
- Lower ball joint/Bushing
- 3'' lowering springs on stock struts
- Introduction
- steering wanders/shoots in one direction or the other???
- lowering/camber question
- OEM vs. aftermarket brake parts
- Questions on coil overs and springs.
- Dupli Colour Brake Caliper Kit
- Brake Bleeding Sequence 96-00 Civic
- suspension/brake questions
- want to use wilwood prop valve, what do i need to do?
- Question on ITR Shocks on Eg
- Where to buy Goodridge crush washers?
- Civic EP1 2002 1.4 90HP ABS light stays on
- Pls. help diagnosing F/L creaking....
- Suspension Parts
- Noob question of the day.
- 93 hatch Caster way off
- Suspension question - stock suspension & Extended Lower ball Joints?
- 93 del sol s Brake Swap
- Help me to Buy Coilovers (from New Zealand)
- 4x114 to 4x100 adapters
- 95 Civic Ex, Brake pedal goes to the floor
- ebay coilovers
- Another Koni/Ground Control thread...yes I searched!
- Fullbody coils on ek sedan
- Need answers for my Accord build
- What suspension should i use?
- 92 civic vx with 5 lug, brake line questions
- Excessive brake wear '09 Civic
- Different Suspension Parts
- Springs that will let my EG6 sit the lowest.
- Brake fluid change question
- Lowered 1999 Accord V6 Coupe Ride Quality (Seriously)
- 96 prelude, problems on right turns!?!?
- Integra sedan struts on EG sedan with EG springs
- Sway bar questions
- blue tokico shocks
- Brake master cylinder ?
- Rear disc conversion question...
- 2002 Civic Blown Ksport Coilovers
- EF w/H&R Race springs..illumina or koni shocks?
- Toe maxed out, bent trailing arm?
- Will 16x8 20+ wheels with 195/50/16 tires recquire a camber kit for an EM1?
- Coilovers problem!
- cracked shock tower?
- Brake Rotors
- 2.5 drop springs for civic
- top hats
- KVR 7573 pad
- EK suspension swap
- Axis brake pads ?
- Integra Type R front/rear disc brakes
- Coilover comfort at ~1.5" lower than stock
- AGX/GC vs KONI/GC comfort?
- Do I need to remove swaybar to install shocks?
- Suggestions for suspension setup on del sol?
- Front brake caliper comparison
- 450F/550R
- Any word from MFG on 2013 accord springs >>
- Squeaking noise when turning steering wheel
- 5 lug swap for EM1 MC|BOOSTER|HAND BRAKE LINES question
- tokico blues or agx with Ground Controls
- Set of ebay strut brace bars
- 98 ex coupe lowering springs
- Another Rotor Question
- 99 Honda Accord EX Sedan cyl
- Rear disc question for rear wheel speed abs
- simulating eg/ek suspension
- skunk2 shocks&springs on ek9
- drop engineering extended Wheel studs?
- Beaks tie end bar question
- function form type 1 or neuspeed race springs for 99 si?
- energy suspension
- Will rsx coilovers fit my 04 civic sedan
- Beaks Reinforcement Kit?
- suspension for 99 honda accord
- 1995 honda civic si with ls/vtec swap vibrateing problom
- 04 Civic just out of storage - brakes making a "swish" sound
- shock/coilover assembly help?
- Eg civic - front lower camber adjustment?
- squeaking from front passenger side
- lots of neg. camber double tire life??
- Driver side is lower then passsenger side. How do i fix it?
- Hard Race Radius Rod Bushings... orientation?
- Need help with brake diagnostic 1995 H23A
- Hard line broke, all brake fluid leaked, can't bleed brakes
- Wilwood noise
- sand blaster plus free time and ASR framebrace
- Hit a curb at about 30 mph, front wheel isn't sitting right
- 95 civic sway bars oem or aftermarket?
- What could be causing my camber problem?
- DA koni help
- H&R OE Sport springs??
- Pics of H&R OE Sports on integras
- AP Racing Fake?
- i want my EF lower
- rwd rear or mid engine help??
- Rear Trailing arms/ Spindle bolts
- help identify these coilovers
- skunk2 pro s coilover lifespan?
- general coilover adjustment question?
- Sway bar lca q
- civic EG sedan camber kit
- Koni/GC question
- Parking brake only locks one wheel
- civic 96 swaying very slightly at high way speeds
- Purchased JDM ITR suspension - need advice
- Will these front end links fit my 97 Civic LX?
- What's needed for ITR f&r sway bars on EG?
- Drag Coils
- What suspension setup should i run?(94 DC2)
- Coilovers
- Function and Form Coilovers - Made in ?
- LCA bushing replacement
- Coilover fitment question EM2/EP3/DC5, Can anyone help?
- '04 Accord EX-L V6 Motor Mounts
- Looking for a set of springs/struts for 99 Si, Suggestions?
- Progress CS-II a step-up from AGX/GC?
- options: CR-X
- Will Civic Si Brake Calipers Fit RSX TypeS?
- shocks to lower my car. Enthusiast needs help!!!
- Loading the suspension when torqing lower front knuckle bushing on rear of car
- top hats...
- Lost for answers... Wheel bearings or Rack and Pinion next?
- is it normal for skunk 2 bushings to be this jacked up?
- Anyone know how to replace the bushings on the older type LCAs?
- ed7 with F&F problem
- How to disassemble Function & form type 1 coilovers
- What are these sway bars from?
- Ebrake sticking slightly, Possible warped rotors and ebrake not releasing 100%?
- What suspension/steering tear-down tools do I need?
- how much should i sell a front set of prelude vtec calipers for?
- Master cylinder help
- Squirrelly ride in 92 hatch
- coilover question with pics?
- Wilwood Caliper for 2006 Si
- 97 civic suspension noise
- ej2 suspension upgrade
- 97+ prelude coilovers fit 98+accord?
- extended ball joints with stock ride height?
- GC w/ Koni Yellow w/ Tophats????
- [HOW-TO]Spoon Twin Block Caliper Install on 4x100 with 10" Stock Brakes
- Tire cupping and tire shreading !
- How much are si rims?
- Newbie needs help w/2000 Civic CX(hatch) suspension
- Looking for help
- Wilwood brake master to stiff???
- EG front brake components making noise ?
- EG EK LCA bolt spacing for rear tiebar..
- Front camber kit selection help...
- function & form type1's max height
- Washers in Rear UCA to Help Cambering Problems?
- NEO MOTORSPORTS FULL COILOVER REVIEW
- Buying coilovers from US seller to Australia
- Function And Form Type 2 coilovers?
- DEL SOL DRUM TO DISK HELP.
- bent integra shock fork
- problem with lowering springs. please help
- Spring size modus agile
- life span of a koni yellow ? estimate
- corrado rotor for itr brake setup?
- Rear Brake Caliper Bracket for Upgrade
- Brake lights want come on...2001 Civix
- ITR rear swaybar on EG
- EG alignment question.TOE..
- Installed springs, Rear still sits high
- eibach 2.5" diam. vs GC spec springs
- Prop valve
