PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. ITR Swaybar Endlink to ITR LCA-Bolt missing. Anyone know what bolt i should use?
  2. Koni Problem
  3. Help with front wheel hub...
  4. bump stops
  5. Torque specs on Front camber kit
  6. em1 swaybar info
  7. Omni coilover Preload. Is it necessary?
  8. Just got poly rear swaybar bushings, wtf?
  9. my suspension set up need opinions wondering if tokico illuminas with gc coilovers good setup
  10. F2, Omni, KSport, UGR LCAs...?Which is the best cheap LCA?
  11. Megan Racing Coil Overs.. HOW DO U Lower iT??
  12. Ball joint compatibility
  13. help I.D. suspension noise!!!
  14. an FYI on the beaks 22mm ITR sway kit
  15. Whats your view on old school lowering springs and shocks Vs Full adjustable coilovers...
  16. motor mount? insert?
  17. Help, dont have any idea how to adjust my shocks, Apex-I World Sports
  18. Will i need camber kit?
  19. Help with KSport Adjustment on EK Civic
  20. Complete integra gsr subrame, lower contol arms, hubs, on 96 ek hatch, quick question.
  21. jumping rex
  22. new gsr buildup, first step: suspension setup
  23. installed coilovers, adjust the height from lowest/highest- barely changes
  24. exhaust rubbing on rear sway bar - bad?
  25. Spring Suggestions
  26. what coilovers???
  27. Calling all Suspension Techniques Sway Bar Owners!!
  28. Question - ASR + Tie Bar
  29. are megan LCAs reliable?
  30. tenzo r springs
  31. Getting shocks revalved
  32. what are these black o-rings for?
  33. need a springs compressor?
  34. AP Brakes on ITR
  35. swapped Tein Basic damper kit for EK
  36. Koni Yellows over TOKICO Illumina? Or AGX?
  37. Shock/Springs
  38. What is the best adjustment for traction bars?
  39. pics of front LCA anyone?
  40. What to do for a suspension setup?
  41. ITR rear sway or rear ite bar?? =/
  42. Ball joint compatibility
  43. **How do i adjust 1 Piece Coilover**never done it
  44. tein or GC
  45. are drop zone shocks any good?
  46. corner balancing
  47. shaking in the front suspension since i put in new clutch?
  48. omni coilover sleeves
  49. Squeek when turning right only
  50. camber kits info............
  51. EK Bushing in GSR LCAs...?
  52. Koni and H&R Setup noise
  53. cheapest place for a full bushing kit for a crx
  54. best struts
  55. 88-91 crx rotors fit on 93 civic si's?
  56. What do you think of Skunk2s front & rear camber kit and Test Pipe?
  57. function form & d2 suspension?
  58. Fitting lowering springs
  59. Shortening Koni's
  60. camber kit help me?
  61. Kuruma Motoring
  62. Hatches lower in the back ? Why ?
  63. quick question
  64. k sport coilover install help?
  65. My Omnipower Full Coilvers Broke yesterday
  66. UCA balljoint boot?
  67. I truly need help
  68. EG rear swabar install questions
  69. KYB GR2 anyone have trouble with them?
  70. GSR brake torque specs
  71. will tein basics off a dc2 fit 96-00 civic
  72. Going Low..... Again. What if Alignment is good
  73. best struts/shocks for GC Coilovers
  74. EM1 Tracion Bars
  75. tokico blues question...
  76. help 95 eg civic/Skunk 2 camber kit not fitting do I need something else?
  77. ASR Spacer
  78. camber wear :(
  79. eg suspension upgrade on 88si?
  80. Bushing problem??
  81. 94 gsr brake upgrade on 94 dx
  82. what would be nice suspension setup for my 1998 Ek?
  83. Ride height for best center of gravity???
  84. What suspension for my DA? KYB?
  85. Suspension question
  86. Tein SS Install on 97 prelude base
  87. cv axles driving me nuts!
  88. Guys I have a big problem-
  89. Tokico 5-way adjustable help!
  90. rebuilding cusco coilovers?
  91. Thread pitch on KYB AGX's.......? S.O.S.
  92. tsudo/skunk camber arms
  93. Lower Control Arms
  94. Tokico Springs
  95. Omnipower suspension on 1990 crx
  96. eg lca's on ek?
  97. Custom Spring rates. I need help. D2 Coilovers
  98. Rear LCA to trailing arm bolt issues
  99. ZEAL FUNCTION S6 - Damper Setting question
  100. Inspecting Used Suspension
  101. Best tuner in TEXAS?????????? your opinion.......
  102. Pros and Cons....Information needed on Control Arms
  103. Help, Koni install for a 97 civic
  104. Springs on stock car?
  105. Small diameter steering wheel = faster turning?
  106. noob at this suspension scene- your advice needed please!
  107. Body roll vs driver movment
  108. OEM Upper control arm
  109. Need help deciding/opinions
  110. Where is ASR
  111. Drop Spindles / Trailing Arms. Anyone run these things?
  112. Will ASR brace from integra work on EG civic?
  113. Difference between LS Discs and EX Drums
  114. trailing arm replacement??
  115. So who has Omni's?
  116. Omni power full coilovers question
  117. Axle ?
  118. asr?? help
  119. suspension bushing replacements
  120. Lower Ball Joint and Tie Rod: Do they wear out together and should you replace both?
  121. Will static negative camber affect stopping distances?
  122. Spring Rates- Front/Rear
  123. Blowing shocks left and right...
  124. C/V joint help?!?!?
  125. SILK ROAD SUSPENSION QUESTION
  126. What are ways to tell if your shocks are blown? (KYB AGX's)
  127. Check out my alignment specs
  128. ITR rear sway bar question
  129. adding a suspension setup few ?'s
  130. suspension noise from the front coilovers
  131. Which bolts do I need to get?
  132. ASR subframe kit with CTR sway? Price help
  133. rear disk brake help!!!
  134. need help with skunk2 lowering springs!!!
  135. Suspension for a DB7?
  136. omni coilover slevees
  137. ::please help:: Spring noise/clicking (searched)
  138. EF, b16, cable ls tranny, what axles? Tried searching
  139. Suspension set up question
  140. CTR Sway Bar on a 2000 Si (US) / SiR (Canada)
  141. How Could I get this bolt off the LCA
  142. Found my problem...another question...
  143. Eibach ProKit, which shocks?
  144. Big Brake Kit That Fits Under 16" Rims
  145. Front camber kit problems
  146. Crazy vibration noise coming from the rear
  147. LCA Bolts broke can I??
  148. 90-93 Accord struts will they fit EG's?
  149. Tom Motorsport coilover sleeves...........
  150. Help with Sway Bar (I've searched)
  151. skunk2 full coilover suspension...
  152. Best brake pads for a street car?
  153. i have the worst luck...help needed.
  154. tie rods....? clunking=death
  155. Bushing: OEM or Polyurethane
  156. Ground Control Upper Mount bolts?!?
  157. Spring rates, and its relationship with traction
  158. cheap coil overs install question...
  159. Question about 6th Gen stock alignment
  160. traction bars or lsd?
  161. 1997 Accord LX suspension decision
  162. what from a da suspension ca i use on a eg hatch
  163. Torque Industries
  164. Gold Line Springs
  165. Lowering DC2
  166. Is my alignment result okay?
  167. Is a lower arm bar the same thing as a lower tie bar???
  168. how to tell if suspensions are bad or not
  169. Caster: How much higher than factory specs can you go?
  170. coilover question????
  171. Fender Rolling Tips
  172. I need new front lca's......... sway bar at the same time?????
  173. Coilover problem
  174. will lowering my car drop my 1/4 mi. time??
  175. raising skunk2 coilovers help w/ ride?
  176. eg factory spring rate
  177. Best brake upgrade
  178. greasing sway bar bushings (98 Ek w/progress rear sway bar) QUESTION
  179. Skunk2 Front Control Arms hitting Shock tower, go back to stock?
  180. no snap ring? ball joint
  181. Tein & GC top hats - SHAFT SIZE
  182. sucpension question
  183. AMR Engineering Suspension
  184. Performance upper control arms??????
  185. Traction bars???? How do they affect handling?????
  186. best coilover for drag racing/launching
  187. Q on Sway Bars
  188. Axel Help Please
  189. Anyone riding on blox suspension parts?
  190. Does USDM ITR 5x114.3 suspension bolt to a DA?
  191. strut lengths?
  192. ek rear shock cup
  193. The rear of my std is a bit twitchy
  194. My car handles like a boat....
  195. ground control coilover questions.
  196. TEIN SUPER STREET Damper with Pillowball Uppermounts --------WHAT DO YOU GUYS THINK?--------
  197. Front Strut Bar - 01 Accord
  198. Some Tein Flex questions
  199. End link bushing replacment
  200. Rebuilding Spoon N1 coilovers
  201. Rear disc setup question
  202. what other coilover sleeves fit koni yellows besides gc's????
  203. which front sway bar to get?
  204. NEX COILOVERS: Same quality as TEIN and/or KSPORT/D2?
  205. Help Identify Coilover?
  206. Sway bars
  207. alignment
  208. debate on suspension...
  209. quick question..
  210. My omni's feel bouncy
  211. How does spring length affect ride and or performance of the shock
  212. will these coilovers fit
  213. ground control rate recommendation....and general suspension setup critique!
  214. what causes cupping??
  215. save my tires Best front camber adjustment?
  216. any opinions on suspension techniques rear sway bar and tie bar kit?
  217. Camber Kit installation instructions?
  218. ASR EM1 Brace Need some help!
  219. Tein S-Techs on Stock Struts
  220. alignment w/ full coilovers
  221. Here is some very interesting info
  222. Which race springs should I get to be SLAMMED?
  223. Skunk2 or Omni?
  224. 94-01 integra Neuspeed springs???
  225. would this be a good suspension setup
  226. How do these used coilovers look to you?
  227. Need help fast regarding GC spring rates....
  228. WEIRD PROBLEM. TPS
  229. ITR LCA/Comptech Sway. Problems. Del Sol
  230. I need a straight answer
  231. what exactly is done in an alinment?? (sorry cant spell)
  232. Why do stock shocks blow out if you put lowering springs on?
  233. which year shocks fit?
  234. Need feedback on springs preference for my integ
  235. How to properly set up my coilovers???
  236. Request How to guide to install GC/Koni Yellows on a S2000
  237. Rear Suspension Squeaks and Creeks (EJ6)
  238. zeal function b2 opinions
  239. New omnipower coil-overs
  240. Camber kits on a street car.....are they really worth the money???
  241. Uneven ride height problem Civic!
  242. Trailing arm bushing
  243. Skunk2 vs. Spoon strut bar?
  244. Advice for Coilover and Shocks install
  245. 2000 Civic coupe suspension suggestions...
  246. h&r sports and koni yellows. which height on strut
  247. K-Sport Coilovers OR Omni Power Coilovers?
  248. Height difference between driver and passenger side.
  249. SO i got my shocks and...
  250. Whiteline G4... Help me out guys For sale...
