View Full Version : Suspension & Brakes
- having problems with my skunk2 pro s v2s help plz
- CoilOvers and Sleeves.
- Raceland Coilovers
- What spring rates should I get on my 92 civic?
- Camber problem/question
- Tomei Coilovers
- Alignment Specs
- GC specifc Koni's, can they be used with different sleeve-overs?
- Who can install my rear disc conversion..?
- Where are the best deals for coilover kits for a 95 del sol?
- Street setup questions....
- Reputable Camber Kits?
- good replacement calipers for rear of prelude?
- ASR support for swaybar
- rear LCA bushings too small energy suspension set
- My car makes a weird noise
- koni yellows w/ Gc ?
- Will coilovers from a 96 civic fit on a 95
- Can't tell if SS Brake Line is leaking
- 95 del sol coilovers/suspension
- Function and form coilover wont come loose.
- Type R rear brake lines on Eg
- Old Gr2 Shocks. They dont rebound. Any good?
- anyone have pictures of wrinkle paint on brake calipers?
- Koni Shocks- Where to buy?
- the suspension problem???
- lowering springs debate
- What`s needed for an EJ1 rear brake conversion?
- Front D Bracket Bolts Snapped Off
- Project Mu ...which kit for a 98 ITR?
- SUSPENSION WAY OFF!
- Integra Coilover and spring rate recommendations for track use...PIC vs. GC/Koni
- Will Ground Control Top Hats work on Function and Form Type 2 suspension?
- 99 EM1 rear sway bar help!
- Weird Tire rubbing
- sway bar question
- i have a rear disc conversion question
- legit question on suspension
- Skunk2 Strut Bar
- 98 civic: Replacing upper ball joints without control arm?
- upgrading brakes on 95 ex
- Drag racing Wilwood brake set up Dynalite Single info
- adjuatment info for strut kit?
- 5 lug conversion axle options?
- Can't figure out what's wrong with my strut
- Koni Yellows an Ground Control Install
- [Info] Big Brakes Civic EK (Ej9/Ek3/Ek4/Ek9.....)
- How to adjust camber?
- Where can I get some ground controls?
- suspension upgrades H brace, worth it?
- did i get ripped off?
- CIvic Street/Strip Pads??
- Brake pedal goes to the floor?! Help!
- koni/gc shock travel setup?
- tein basic vs skunk2 pro s
- Proportioning Valve thread - theory and discussion
- Help please... Suspension...
- rebuilding front calipers
- general consensus on dust covers
- How do I tell what kind of brake conversion I have?
- EM1 RTA w/ Teggy Calipers?
- Noob help! Sway or Strut bar?
- help with tanabe df210's
- Spongy Brake Pedal
- Junkyard find ! tokico/kyb/kyb questions
- lowering springs or coilovers
- have a ek hatch want to upgrade front disc for a bigger ones please help
- Do I need endlinks for a rear sway bar on my EJ1?
- What front LCAS do I have?
- Changing M/C and front calipers with Ebrake on
- Installed ST rear sway bar..issues..??
- DIY: Bleeding your brakes by yourself, it's not as hard as you think!
- 83 civic cvcc! needs lowered!!
- 98 hx asr brace
- Raceland coilovers
- ANYONE KNOW WHAT THIS BOLT IS CALLED AND WHERE I CAN FIND IT???
- Questions on Eg rear lower control arms
- opinions on cutting springs
- Camber wear!
- Autocross build
- Looking at H&R Sport Springs For My 99 Si, Anyone use them?
- 600whp street car brake setup
- 2000 Honda Civic Ex suspension
- brake booster cant suck air
- Koni Yellow stiffness settings?
- Koni/GC Spring rate setups?
- xxr-002 issue
- Where to buy these Akebono Pads
- coilovers ?? humm suggestions,opinions please
- Questions about the ASR or BWR subframe brace.
- New brake Rotors
- bought koni orange and tien s tech: for ek hatch but car didnt get lower
- please help!! function and form suspension on eg and ek the same???
- 98 civic front strut mounts
- suspensions
- best front UCA replacement bushings?
- Suspension noise, need help
- Aftermarket LCA bolts
- Do I need new struts
- Buzzing sound after replacing rotors & pads
- ProgressCs2/PIC APEX/FF2/N+BuddyClub Coilovers?!!
- Suggestions for the track?
- Anyone have the PIC/Suja1 bushing kit?
- Spring rates for daily driving
- em1 suspension
- d series car with a b series swap witch of the 2 shifter bushing kits is it??
- BrakeExpert's Brake Chart Thread - Civic Brake Upgrades for EF, EG, EK and Integras
- Safety of Redrilled (lug pattern) brake rotors
- Brake in procedure - for changing pads and/or rotors
- On a budget need coilovers
- Coilovers: f&f type 1 or type 2.
- Are parts interchangable?
- Foam to use when Filling Chassis?
- Integra Camber kit clearance.
- Spring rates
- tein springs
- Question about proportioning valve after 5 lug conversion
- Will camber cause car to track while driving
- 93 civic control arm problem
- M10 x 1.25 x 80MM Class 10.9
- washer trick DIY stumped coolio pics inside help appreciated flame on
- 11.1" Rotors on DX/LX Knuckles Question (23T bracket related)
- WANT INFO:5th gen prelude alignment parts applications
- 11.1" S2000 rear brakes for Civics and Integras
- Camber issue (PLEASE HELP)
- Spring Helper.
- em1 bbk?
- SLOT + DRILLED rotors, bad idea?
- Best 98 civic ex coilover set?
- Alt + axle clearance issue (lowered)
- front brake ?
- BRAKE FLUIDS?
- RARE SUSPENSION TECHNIQUE PRO ARMS INSTALL
- Coil overs / lowering springs and rear disk brakes for 89 accord lx?
- On coilovers and still not low enough... Will extended hats get me where im going?
- camber issues!
- civic brake swap
- Steering out of wack.
- HELP! oem sway bar with F2 LCA;s????
- Function 7 Vs Blox LCA`s
- Excel-G struts any good?
- Rear Disc Conversion Question
- Rear Disc Conversion Questions
- ek hatch suspension upgrade? do you think its worth 80 dollars
- No Caster, need help
- how to take brake hoses off? how to bleed?
- Duralast Brakes
- What brake pads/rotors should I get?
- Springs/struts combo
- Stiffening up the rear end on a 2000 Civic DX hatch?
- Need new brakes for 93 civic - help pls!!! Thx!!! :)
- rear lca question
- Rear UCA and anti-roll endlink question.
- looking to upgrade my front brake system (need info)
- is toe kit needed with negative camber?
- What exactly do i need fr a brake swap?
- Bent Rear Wheel Backing Plate - Pics
- What is a top hat?
- Brand New Skunk2 Pro S II bouncing?
- where to buy parts. good service and resonable prices.
- WHAT FORKS ARE INTERCHANGEABLE?
- 99 si rear disc conversion
- Ground Controls?
- can i machine rear itr hubs to fit on ls
- Will my to tokico blue struts on my 90 integra fit on my 95 civic?
- EG/ EK compatibility question
- Let's talk about suspension
- Megan EZ Street Coilovers
- rear lowering springs eg to ef
- help/ questions about shocks on 95 coupe ex
- Rear toe adjustment rotted
- S2000 coilover choices?
- 10 civic coupe ex?
- Brake Pedal Goes Straight to the Floor
- what all is needed for this brake setup...95 civic dx coupe
- replaced rear hubs on my ef. RUINED EVERYTHING
- You get what you pay for
- What Red Camber Kit Is This?
- Spring rate ride height question
- skunk 2 pro c coilovers
- Blown strut??
- skunk 2 lca?
- Function 7 Billet Rear Lower Control Arms Type-R Style For 96-00 Civic....???
- does this combo fit/work ?
- CRX brake set-up for track car
- 95 ex sedan brakes and suspension
- wilwood six piston calipers
- Ebay front UCA quality?
- Integra (non type r) vs Type R disc brakes: How to ID
- how to adjust 5pc strut bar kit?
- brake fluid change
- QUESTIONS FOR THOSE WITH GROUND CONTROL COILOVERS OR TOKICO ILLUMNIA STRUTS!
- Caster/Camber kits
- HelpPlease.Question
- last thread koni/gc vs tein flex
- balance and weighing chassis???
- k tuned, full race, blox traction
- 5-Lug conversion question .
- Brakes or Suspension
- Just lowered on Koni/GC now axle bind?!?
- prelude steering wobble, new rack and tie rods
- where to buy individual custom rate springs
- Adjustable shocks wear - firm or soft
- Tein s-techs rubbing fenders
- Coilovers (are these ones good or bad)
- Ground Control tophats ?
- coilover sleeves work with quick struts?
- Best suspension set up?
- Recommendations for dc2 integra 99
- 1995 civic dx with del sol vtec brakes
- F&F Type 1 adjust?
- How strong are the Koni nylon perch adapters? Anyone using them?
- Funtion and Form 2
- coilovers ???
- 5 LUG HELP NEEDED
- Proportioning valve question.....
- do i need a rear toe kit??
- Tein Street Advance Coilovers
- 5-Lug Help!!!
- car follows road bad
- Most comfortable way to lower my accord?
- traction bar
- Issue after brake upgrade
- cx racing coilover?
- swappin honda breaks for integra brakes.
- buddy club n+ worth the money?
- NEED HELP Rywire Brake Tuck Kit
- 95 DX front wheel alignment (stock)
- Neuspeed Sport ek
- Need help deciding which springs to go with to lower my 00 civic ex
- parking brake cable install help!!!
- KYB AGX adjustable struts
- Questions about Disc Rotor and Disc Pad replacement?
- still debating
- 97 Type R torque (engine) mounts?
- Tokico?
- which end links are good to use with my rear suspension setup????
- Tein Basic coilover adjustment?
- Rear trailing arm bushing interchangable? 88-00 civic to 94-01 integra.
- How to read tire wear
- Personal Experience from Del Sol Owners
- installing camber kits
- brakes stay engaged
- Breaks lock up (searched)
- Brakes Scraping
- Replace control arm bushing for 1$
- BWR coilover busted? :(
- Bushing questions
- Hard to handle.
