PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. compatibility with illuminas and progress springs.
  2. can someone identify these buddy club coilovers
  3. Re: New Suspension Setup - Thoughts & Opinions are very welcome
  4. Koni Yellow w/ Part # = What Car?
  5. Rear LCA bushing
  6. I dont know which way to decide...
  7. Omnipower Coilovers, how do you lower/ Raise the car.
  8. noob to EG1 question (old to HT)
  9. 99-00 civic H&R springs on a 88-91 crx???? What will happen??
  10. TEIN SS for EG/EJ, So Cal
  11. Ingalls Camber Kits. Which one?
  12. Can someone explain to me progressive style springs?
  13. KW variant 2 suspension on EK's ???
  14. one side higher then the other side
  15. ingalls camber kit help
  16. is this too low?
  17. Tein SS Question
  18. pillow mounts squeeking?
  19. DRAG springs and struts
  20. accord suspension issues
  21. why does my suspension still fell like chet
  22. This Omni LCA question has never been asked. Need opinion.
  23. Tein S-Tech or H&R sport for AGXs?
  24. want LOwer
  25. noob question (sry)
  26. Where to get a roll cage fabbed for the EG hatchbacks?
  27. question about camber kit for my 02 accord
  28. Just installed type r suspension
  29. best prices on block sleeving?
  30. bushing kit
  31. One Quick Question
  32. Bump stops on KYB & H&R ????
  33. Changing brakes from diagonal split to front\rear split(will this work?)
  34. did some research already on my steering rack but....
  35. koni yellows + gc coilovers in 00 civic
  36. difference in skunk2 pro camber kit?
  37. 15x7 40 offset RUBBING?
  38. Good shock for ground control coilovers?
  39. New wheel studs replacement without removing hub?
  40. Alignment tool DIY..
  41. EK Hatch Swaybar Installation questions
  42. ES Trail arm set poly
  43. few questions.....
  44. Another drop question
  45. NRG engine damper.. installed correctly?
  46. new suspension, noises
  47. Adjustable Shock with Stock Spring
  48. I installed eibach Sportline on my EM-II what are you guys using?
  49. Skunk2,Omni,Function7 LCAs??
  50. Best Suspension: For Daily Driven/Occasional Track Use
  51. Does ASR make a kit for Integras?
  52. alignment issue
  53. skunk2 "race" springs, which one goes where ??? #2
  54. What are the signs/symtoms of a bad axle?
  55. 5 lug conversion on Civic, What suspension?
  56. How do Skunk 2 Lowering Springs look on a EP3???
  57. drums to discs!
  58. Coilover adjustment help: Height vs. Appearance?
  59. itr rear sway on 00 em1 - what parts do i need?
  60. Need help with Integra rotors?
  61. WHAT SHOCKS TO USE WITH ITR REAR LCA INSTALLED IN A DA TEG?
  62. where to buy kyb agx's for cheap? 97 hatch
  63. Need opinions about suspension
  64. English instruction for Apexi N1 suspension
  65. brake pads for 4 by 114.3
  66. I heard that illuminas are bad for lowering your car...
  67. Need Advice please.
  68. what do u think of drop zone struts and DZ lowering spring combo?
  69. Does anyone have TEIN's Super Racing set-up?????
  70. which is better?
  71. bumpstops on coilovers?
  72. koni/GC install help
  73. Ground Control question
  74. Cheapest strut tower bar that will " do the job " ????
  75. WTB///// Tein SS-P package for 2004 Accord Coupe (DSA50-2USS1)
  76. rear passenger side won't lower????
  77. Skunk2 and KYB AGX shocks
  78. EF upper ball joint replacement
  79. 94 integra brakes to 96 civic
  80. Caster HELP??? Can't find a definitive answer...
  81. 2.5 inch drop.
  82. ground control adjustable springs
  83. any good suspension shops in Central Jersey?
  84. Integra LCA
  85. CHICAGO - anyone with trail arm bushing tool for loan?
  86. Neuspeed springs sagging??
  87. Koni question
  88. parts needed for eg/dc suspension on da integra
  89. Camber kit inquiry
  90. H&R Springs on ebay coilovers? would it work?
  91. Help new to civics
  92. Noise from wheels?
  93. Sway Bar/Tie Bar Combo Ideas
  94. LS, GSR and Type-R rear trailing arm
  95. ls lca and sway bar 96
  96. quick question
  97. What kind of Buddy Club suspension is this?
  98. Just wanted to share my experience with D2.
  99. suspension noise, need a conclusion.
  100. Got an alignment for the first time. How do my results look??
  101. Skunk II camber kit install
  102. comp arm orientation affect suspension geometry?
  103. Da suspension???
  104. Coilover Question
  105. how do i replace a tie rod???
  106. Bent front knuckle= mad camber???
  107. help new set up problems
  108. Where to buy Carbing?
  109. SHOCKS AND SPRINGS...
  110. sways for my 99 si
  111. questions about suspension
  112. new OEM trailing arm bushing part number? (CRX)
  113. [Question]tokico blue + tein s springs
  114. Picture Request.....
  115. Question about oe springs (searched)
  116. keeping lca with rear DA Sway Bar
  117. ksport feedbacks
  118. koni shocks blown?
  119. Neuspeed sports w/ 17'' rims?
  120. are you lowered?post your specs and tire wear pattern
  121. can delsol tein damper coilover kit fit onto 91 crx?????????
  122. Opinions on OEM rear swaybar replacement
  123. Does every lowered car really need a camer kit?
  124. best camber kit for a 93 H/B
  125. noise from rear after front and rear progress sway bar install
  126. WTF...custom coils+Illuminas vs. Tein SS's for Accord????
  127. Which Coilovers Should I Get?
  128. stupid question. Skunk2 springs. which one goes where?
  129. where to buy alex motorsports parts?
  130. coilover springs
  131. Opnions to make my EJ handle better..
  132. Installing adjustable strut question
  133. tein basic dampers or koni sport dampers for my eg hatch?
  134. rear sway bar: ctr vs itr
  135. Loud creaking noises coming from rear suspension
  136. Spring advice needed:
  137. Issues with 99' GSR Knuckles on 97' EK DX??? Will They cause unwanted camber? HELP!!
  138. Koni Yellows + ???????? Coilover Sleeves = No Cutting/Grinding/Welding?
  139. ground control adjustable perch bolt broke in half
  140. Spring : why is front drop lower than rear
  141. Axle length issues...axles are too long, how to fix?
  142. shock top hat bolt
  143. WHICH AXLES FOR MY AUTOMATIC INTERGA WITH A AUTO B16A?
  144. SPRING COMPRESSOR FOR MY H&R SPRINGS PROBLEM!!!! HELP
  145. JDM ITR REAY SWAY BAR
  146. Tokico blues or KYB GR-2's....too soft?
  147. Function & Form Coilovers....
  148. bouncy
  149. Buddy Club or PIC?
  150. skunk 2 full suspension kit review...
  151. HElP! Coilover Wrenches!
  152. Which wheel bearings to use with circuitworx stage 2?
  153. Missing some parts on a set of Koni's..
  154. need help how to make suspension more stiff.
  155. What suspension set up should i use?
  156. Need to find an oe replacement spring
  157. Lowering! *searched*
  158. SKUNK 2 LOWERING SPRINGS ON STOCK SHOCKS
  159. Looking for opinions of DC2 owners with ksport coilovers (13k/7k rates) on ride quality
  160. eg to sol
  161. lowering problem, help!!!!!
  162. stock eg lca CAN I DRILL A HOLE FOR SWAY BAR???
  163. Toe-Out and Front End Vibration
  164. Swift Spring Build up Thread
  165. lca
  166. tein spring rates
  167. question about koni yellow adjustables...new to struts...
  168. Are the new OMNIpower Gen. 3's done and shipped yet?
  169. extremepowerouters reputation?
  170. 5th gen prelude camber question?
  171. omnipower dealer on the west-coast?
  172. Illuminas or AGX?
  173. O-Rings
  174. Knockoff Password JDM Bars ? ...
  175. Aftermarked Rear LCA's for 88 Style LCA.
  176. ksport coilover reviews wanted
  177. what suspension to buy?
  178. Skunk2 LCA's
  179. d2 or omni
  180. Pic request Dc4 with 1.5 and 2 inch drop.
  181. Ground Control part # for 2000 Civic SI?
  182. delrin offset bushings
  183. How To: Quick/Easy Civic/Integra Trailing arm bushing replacement (also ES Poly Vs. Mugen)
  184. 94-01 Integra DSS Axles_ Pass. Side axles LONGER?
  185. Koni Yellows Came In... Help Please!
  186. D2 36 Way Adjustable vs. TEIN Super Streets
  187. if you're lowered at all... read me
  188. Need help!!!...can i run ABS with 4x114.3 suspension
  189. Footwerks coilovers?? Who are they??
  190. lowering questions
  191. Q: My brakes are constantly grabbing?
  192. bottoming out with new camber kit?? why??
  193. Changed my steering rack today- ps to manual
  194. Rear Lower tie bar. ?
  195. 2000 SiR Suspension question
  196. b16 swap need to swap the 89dx hubs for 91 teg hubs for the axles PLEASE HHHHHEEELLLPPPPP...........
  197. HELP here PLEASE!!
  198. lowered ej7 suspension questions
  199. adjusting D2 coilover dampaing/rebund ??
  200. bumpstops/bushings
  201. EG has GC/Koni and IRT rear sway......still un-happy with handling :(
  202. Broken Ground-Control (Eibach) Spring
  203. Ksport LCA with stock sway bar on a 1991 civic si
  204. removed trailing arms for rear disc swap...
  205. omni coilovers and upper A arm issues
  206. why do i have all these o-rings with my new coilovers?
  207. Air Bag Suspension
  208. INGALLS CAMBER KITS HELP!?
  209. strut options
  210. spring seating period?
  211. changing LCA's on EJ1...should i install brand new bolts???
  212. Tein Basic Coilovers - Now I need a camber kit?
  213. Best front/rear sway bar combo on my EG?
  214. best solution for bouncy rear on civic coupe?
  215. agx installation questions
  216. Confused, please help
  217. EG / EK suspension swap.
  218. Extremely Bad toe out on rear
  219. where is the cheapest place for illuminas?
  220. racing alignment setting book
  221. wut is a good suspension for scca
  222. GC's and Koni's on DA
  223. whats good with agx
  224. Smoothest Riding Suspension???
  225. prostreetonline?
  226. Suspension disassembly problem :(
  227. oem or urethane rear trailing arm bushing?
  228. how is skunkwork coilovers
  229. Puttin 2000 prelude full suspension
  230. **********HELP caster n camber HELP**************!!!!!
  231. Suspension/wheel problem problem
  232. What adjustable parts do I need for an alignment? (96 Civic)
  233. alignment
  234. H&R Coilovers? I'd really appreciate some input.
  235. lowest drop springs
  236. EG Tokicko Shocks on a Ek
  237. changing from crx to civic ?
  238. Weapon R rear Cross bar
  239. Suspension Combo
  240. GROUND CONTROL
  241. Integra suspension to Civic swap
  242. omni street or sport?
  243. Strut Spring Compression Question (Before I shoot someone's eye out)
  244. Ebay rear camber kit! any good?
  245. How to properly adjust coilovers?
  246. potholes suck
  247. Koni: Question about fitment
  248. Is this a good time to replace my front wheel bearings?
  249. itr sway bar
  250. will this shiit settle in??
