View Full Version : Suspension & Brakes
- "Heavy Duty" Ball Joints for, uh, a Civic. Really.
- Gearhead Challenge - Electronic Brake Proportioning
- Beastly Street DC2 Suspension Setup
- 2003 Acura RSX Base - Suspension issues
- DA vs EG suspension bushing
- Have you bought from AMR recently?
- Rear Struts Popping Sound
- Pilot Rear Suspension Issues
- 5X114 OEM Big Brakes
- Anyone Know the Front-to-Rear Brake Bias Percentage?
- DIY: How to Rebuild Brake Calipers (VIDEO)
- Energy Control Arm Bushings worth?
- Spoon Calipers on 96 Spec ITR
- Help with identifying these coilers
- Caliper piston not moving inside
- Brake fluid brake fade and brake fluid type
- Black stuff in brake fluid flushing 2005 Civic
- 2028 ILX torque mounts?
- b18c Suspension Question for Ek Hatch
- Wilwood Brakes on CRX w/ 13" Lensos
- Do 99 si parking brake cables work on an ej1 with rear disk brake conversion?
- Post CV half shaft installation grinding noise at times
- Stuck right caliper ?
- Help axle won't go in
- Drums or discs ??
- Fork it, it keeps me in suspension
- TEIN lever ratio?
- Hardrace rear lower control arms?
- Coilovers
- Front End Mystery Noise
- Skunk2 sport shocks question
- Brake upgrade, soft pedal once the car starts
- Squeak When Lifting Brake on 05 ES2 Civic
- Coilover Suggestioms For ES2 Civic?
- Energy Suspension install question
- Ebay race ready suspension any good? 1.5 drop
- Kw v3 coils or Cusco Street A coils
- BenseBuilt OEM Brake Rotor Chart
- 6th Gen pedal assembly removal install
- 96 Civic Cx Dual Caliper
- JDM ITR 36MM 5 Lug (axles, wheel bearings)
- Odyssey Brakes
- Can I know eg and ek coilover is same ?
- RSX Caster Correction From Accident..What To Buy?
- Anyone absolutely hate working on suspension?
- Front Suspension Creaking and Popping!!!
- EG6 unibal arms kinematics
- Shaking around 70 MPH and some alignment issues. Need help figuring out the problem!
- Clunking sound Rear Right Wheel
- Rotora Big Brake Kit & Replacement pads
- when to change brake pads?
- Need help deciding which car to buy
- Brake rotor screw Need HELP!!!
- Confirming Mini Cooper & ITR BBK on 92' civic si eg hatch
- AF Shocks/Springs for '02 Insight
- Best suspension upgrade = base model / DX full suspension swap
- Control Arm question
- Wilwood brake kit
- CV Axles
- 96 JDM ITR Brake Calipers
- Noise (buzzing) Civic 2014 Coupe rear tire
- Brake squeal when turning
- Upper Wishbone Bolt Broke Replacing Strut - HELP !!
- Sway Bars or Not?!
- Honda civic VIII hatchback 2008 suspension upgrade
- Should suspension be harder or softer in the rear
- 06 Accord polyurethane bushings
- Strut bars.
- Mini/ITR brake upgrade question
- Question on EK Civic Brake upgrade
- 1999 DB6 Sway Bars/ Brakes Upgrade
- Are 98 civic coupe coil overs compatible with a 91 EF ?
- Did I recieved a bad ball joint? Please help!!
- Koni shocks with OEM springs
- My brakes suck!
- Chinese product or Legit?
- Coilovers for a 1985 accord
- bad alignment w/lowered ride
- Oem hardline mated to russel -3 stainless braided line brake fluid leaks!
- Rear shock fork bolt size integra
- Tokico Illumina rear adjustment dial? Picture or part number?
- EP3 Roadrace Alignment: Twitchy on Straights
- Recommended Parts Brand for Brake Pads and Rotors
- SI suspension vs Sport
- GC Spring Rates for my 1/4 Mile Beast?
- Lowering springs too narrow?
- 98 civic ex factory equipped abs want to delete. Need more info
- Brake Fluid flush issue
- Breaks problem
- Hybrid brake swap
- Will 93 integra suspension parts fit a 98 civic hatch?
- Air Ride on 2008 CRV?
- which brake on my 1994 civic
- Swift Springs on Street Basis Z EP3
- Who makes Honda's rotors?
- Need Help Finding Brake Kit!
- Creaking noise when steering
- Brake Noise ?
- Progress CS-2 spring configuration
- Getting center line of an Acura Integra, for string alignments?
- Asking About Brake System
- Suspension
- Coilover swap
- Figured it out
- Asking about Brake Disc Rotor and adjustable
- Tie Rod Ends Loose in Knuckles (97 EX Coupe)
- Rear Disk Brake Handbrake
- Stoptech big brake kit
- Abs removel .
- Engine Vacuum & Brake Booster
- BB6 Big Brakes-My Experience, Questions and Advice
- New Progress coilovers
- Adjustable Springs - measuring level?
- The correct Koni yellow serial # to match with ground control on del sol
- Brakes Pumping Up/Locking Up, have searched
- Rear disc conversion confusion
- SP Performance Rotors & Pads
- Axle Beam basic info needed (Insight/Fit/CRZ/HRV)
- 1992 Civic VX to 5 lug Type R brakes
- odd weight distribuition Please help
- 2000 Honda Civic Si Pure Stock.
- Leaky ITR brake calipers
- ABS pick up, spec help needed
- Front Hollow Bar
- Willwood brake kit help
- Please HELP ek f20b swap brakes
- caster settings for EF track car
- Custom Strut Top-hats for lifted CR-V
- Stock suspension - rear upper coil spring insulator?
- Fake integra type R function 7 rear lca usable if i replace bushings?
- 5-swap on weird swap, EXPERT HELP NEEDED brain hurts.
- hard race front camber arms on stock suspension dc2
- Accord Rear Brakes
- Insane Shafts Axles
- Replacement rotors on a brembo big brake kit...
- EG6 Fender Braces
- Rotor upgrade 10.3" to 11.1" (262 to 282mm) on EG Civic
- hrv shocks
- 96-00 front brake trim differences
- EG short knuckles
- EM1 Fromt Swaybar Overkill?
- Camber question
- 4 wheel brake tuck kits - opinions
- tapping threads for ABS for rear JDM 5 lug?
- Suspension experts, I need some serious help with an issue in the rear
- DA Integra and DC Integra steering and suspension compatibility
- 1998 CRV
- Will spherical bearings last on a street car?
- High pitched noise when stepping on brake
- Will Prelude rotors fit on an ITR?
- Brake tuck advice on front routing
- Is it possible to install a set of 1999 Accord calipers on an ek4 w/ 282mm disks?
- MR2 EHPS in EF Civic, what P/S line can I cap?
- Yet another proportioning valve thread..
- BRAKE PEDAL DOES NOT RETURN ON 94 ACCORD???
- Em1 Break / Fuel lines
- Skunk2 lowering spring question
- Braking issues 1994 civic hatch
- Where to find rebuild parts for jdm itr 1" master cylinder
- GC Coilovers
- Replaced Leakey prop valve, brakes still do not work.
- Late 2005 Honda Pilot Brake Line Bleeding Problem
- suspension for an ef hatch rally-x build?
- car vibration during take off
- 07 Civic Si 4D Lowering help
- Lowered EK Noise Question
- Is this washer needed?
- 36mm Jdm ITR 5 lug with your D Series
- PROFORGED Swaybar endlinks for Accord/TSX
- Eibach springs not level at the top = top hats lopsided!
- Popping when Braking - Timed with wheel rotation
- Brake tuck kit using compression fittings
- da integra with 5 lug setup
- 2001 Honda accord brake line size type of flare and type of fittings
- flipping tie rods
- Top Hats when lowered more than 1 inch?
- Rear Sway Bar & Tie Bar
- Bilstein Shocks for 99 Civic Si
- civic 2001 brake abutment shim
- Best Balanced Set-Up?
- Performance Brake ROtors
- What Setup Are You Riding on?
- Pros and Cons to Lowering Springs, Coilover Sleeves, and Full Coilover Systems
- Uneven pad contact/rotor wear? TL brembo.
- TL Brembo Torque specs.
- k tuned spherical tie rod (BUMP STEER)
- SUSPENSION INFO
- 1992 Accord long brake pedal...need help/advice
- 2000 Si Civic Coilover Question Measurements Brands etc
- Hard Brake Pedal
- Traction bars, whats good?
- 93 si HB soft brakes
- Brembo brakes on ep3
- Did i ruin my ABS pulse ring(Wheel bearing) 08 TL-S (PIC)
- Progress Coilovers
- 1991 Hatch Suspension Upgrade
- re-man rear calipers - parking brake sticks [w/ video!]
- Acura Integra 1989 Suspension
- Brake Rotors difference
- Pic request/input. TL-S brembo vs RL Advics on CL9
- Most comfortable suspension? 1997 Honda Civic Hatchback dx
- 03 lowering springs on a 2000?
- Soft brake pedal on my 08 Honda Civic?
- TEIN STREET BASIS or Kyb agx with Tein S. Tech
- Secret To Remove Those Pesky Brake Rotor Screws
- eibach pro kits on type r with bilsteins b8
- 2000 honda odyssey brakes
- Replacement Spherical Bearings for stock toe arms
- Honda Logo GA3. *HELP NEEDED*
- Delrin front shock bushing in LCA 1996 Civic
- 2006 Honda Accord EX ABS Not Working, No Fault Light
- Adjustable endlinks beneficial for lowered car?
- Brake proportioning issues
- Full degree difference in FL & FR Camber... What?
- Shock Body and Spring Length Koni/Tokico/OEM
- 13/16 master cylinder on integra brakes safe?
- Silly question...can a car be too light to compress springs???
- Best Coilovers for my DA Integra?
- Spring rate setup opinion (square vs front biased)
- 5 lug setup confusion EG/DC2
- Self Brake Replacement for Civic & Accord
- Car pulls right even after alignment
- AMR ENGINEERING GONE? SHIPPED COILOVER FOR WARRANTY NOW MIA.. WTF
- Rotor not centered in caliper
- I am planning to lift my 95 Civic Coupe, any suggestions?
- Front brake upgrade for 1992 Si hatch
- Koni custom coilover.
- Replacement suspension parts
- EJ/EK Suspension Differences
- Master Cylinder bleed? Help
- Is Amr engineering still in business??
- Prop Valve Help
- Need sway bar mounting info. Please help.
- CRX insight brake swap
- Can anyone ID these rims? I am having no luck in searching the net.
- rotor shield redundant?
- 4x114.3 trailing arms
- brake hissing sound
- Coilover issues
- Wilwood 12.19 Forged Dynalite Wheel Fitment
- caliper powder coat question
- Need help removing completely stripped brake line to replace it
- Prelude coils on dc5
- Question for those with Blox Drag pro coilovers.
- does the 2015 civic ex sedan have a double wishbone suspension
- Ground Control Sleeves Dimensions 92-00 Civic
- Twin S tech springs on Tein Street Basis Adjustable coilovers
- Which suspension to go with for 97 Del Sol?
- brake lines 05 TL
