View Full Version : Suspension & Brakes
- cost effective caliper upgrade??
- Track day on Wednesday, is it too late for new pads?
- Need advice on brand of camber kit and what to tell alignment shop
- sway bar/muffler issue opinions needed
- eg vs ek front fork length?
- URGENT: Tein SS problem
- Benefits of aftermarket camber kits?
- Brakes messed up!
- Suspension for my DD and Tow Rig
- GSR Brake Master Cylinder on EG Brake Booster
- Replacing rubber bushings in suspension - What is needed ?
- H&R 51865R's in 95 Del Sol
- H&R 51865-2 Springs/shocks in del sol
- best coilover for tokico blues?
- How does your pedal feel with a booster delete
- Sand in Break calipers|How to bleed line?
- function 7 ek lca lower control arms and endlinks
- honda partner rear springs
- apexi n1 or ksport?
- Wilwood 11" on EG or forgetaboutit?
- camber kit
- Suspension Setup
- need help choosing a "drag" suspension setup
- Help with suspension?!
- Ksport Kontrol Pro OR Function Form Type 2
- Rear Disc Conversion (e-brake question)
- godspeed rs vs function form type 1
- Need Some Help With My Brake Tuck!!
- EG suspension setup rims.
- power steering rack leak
- loose suspension, please help.
- Lowering and Alignments
- Switching to coilovers. Eg8 dx
- Trailer Arm Toe Bolt
- Information on progress coilovers
- 24mm rear sway bar and adjustable endlinks question....
- Recomendation on suspension
- 99 ex knuckles on a eg.... Castor and Camber issues?
- New member with a brake upgrade/troubleshoot question!
- Can i replace Blox LCA bushings with Hardrace ones?
- How important is the this rubber piece? Coilovers.
- Pic Coilover Spring Preload?
- HELP? rear lower strut bar?
- Does bushing really make a difference?
- Questions regarding coilovers??
- 94 civic cx rear drum to disc swap
- Coilovers for track only eg2
- shocks/sleeves diagram
- Civic EJ9 coilovers- Tein or Weitec?
- UCA's - Interchangable???
- Simple Rear drum to disk swap question?
- Raising Suspension on EG coupe for Rallycross
- skunk 2 worth salvaging?
- Squeaky Noise in coilovers
- I know its not a honda...
- Suspension Gap and Shock Travel problem (Pics)
- Worn shocks vs leaking
- outer tire wearing abnormally Fast
- Beating a dead horse....(coilover content)
- Searched but no luck. Front control arm bushing
- opinion/experiences with "jdmsport" front camber kits
- DA spindles on 94 EG?
- how are blackworks racing camber kits?
- At what point should Koni Yellows be rebuilt on a daily driver?
- spoon progressive springs
- 2 suspension problems, pease help!!
- function and form type 1s vs. progress coilovers vs. Blackworks coilovers
- 03 Accord RF Control Link Replacement
- Coilover Install Experience
- Vibration after installing Tanabe DF210
- Compatability, 99 on 92 shocks
- F&F type 2 spring question
- K Sport coilover trouble
- 98 Civic Coil Overs
- Question about choosing two suspension setups & choosing spring rates.
- 17mm VS 24mm rear sway bar?
- kyb agx/skunk2 coil sleeves wont get low!
- SPC Camber Kits? Any good?
- questions about coilovers fitting on egs?
- wilwood/fastbrakes setup problems
- Used Tein S-techs a good purchase?
- kw 1 variant opinion?
- KYB Struts
- koni/gc too bouncy... Too much negative camber?
- Is Just Tires trying to rip me off? Alignment issues
- 98 civic ex front and rear Tein S. Tech springs question
- Where can I buy a F&F type1 in VA(96-00 civic)
- 9.5" to 10.3" brakes - knuckles/hubs/axles?
- suspenions choices
- CRX CAMBER KIT HELP!!!!!!!!!!
- Vibrations & Tire Cupping - Please help!
- does disk break conversion effect shock fitment?
- spring rates?
- eg suspension
- Better Car Cornering/Handling
- Hardrace or F7 Endlinks?
- Best Drag Suspension For DA Integra
- After 3.5yrs of collecting dust!
- dc subframe swap into ek, wheels don't turn all the way. NEED HELP
- my lower front bushing on my rear knuckle - theyre rusted - automatic replacement?
- Removing stock suspension help
- Question out coilover sleeves
- Coilover sleeves question
- coilovers to springs
- Best shock/spring option for autocross
- Do I need quality rear camber kits? 99 civic Si
- K-sport collar uneven question
- Koni SSP3 Bump stops? Poly or Foam?
- what kind of coilovers are these
- Ground Control spring rates for my car?
- Proper ride height for em1 front?
- raceland full bodies, crx
- Leaking prop valve, weep hole? Help! [pics]
- fa5 rear strut issue
- Koni/GC w/tophats, not going low enough?
- Knocking sound after brake work - PLEASE HELP!
- Integra DA9/DB1 shocks/springs selection.. :(
- what did this come off of? caliper front and rears
- Need help installing front assembly on 02EX
- Bestex / Ohlins Suspension BB6 Prelude
- advise on tracking and corner weights 600bhp drag car
- 97-01 CRV power steering rack into 96-00 Civic
- Where to buy Koni circlip?
- Installed new suspension but wheel gap is uneven?
- 97 civic no abs braking bleeding sequence
- Shocks/Springs for 06 TL Recomendations
- Rear disc swap severe dragging problem need help??
- Eibach with or without anti-roll bars?
- Koni/gc sleeve/ride height/comfort question
- All new Suspension 97 teg
- my review on PCI spherical RTA V2
- 99 Accord Coupe koni/GC installation help
- 7th gen civics: Does the car have to be on the ground when torquing suspension parts?
- Steering rack true center / alignment question
- Koni reds?
- New Brake Rotor help
- Ep3 4 lugs to 5 lugs conversion
- 4x114 type r or Gsr brakes
- 96 hatch swaybar
- Strut bushing defect
- eBay Phase... Suspension. Post all eBay related "?'s" Here.
- Master cylinder question
- Civic 5th Gen, broken bolt in toe arm
- RACELAND COILOVERS
- Ride height question
- would ADJUSTABLE COILOVER LOWERING SPRING be good to lower my 96 civic 1 1/2 - 2 in.?
- Spoon caliper rebuild kits (calling all spoon heads)
- new skunk2 pro c height issue
- BBS RS + brake kits
- Koni yellow dished washer question
- traction bars?
- Need adapter for oversized MC 12mm flare nut!
- Ground Control Spring Rates???
- how to tell what year integra rear disc conversion
- 92 Civic DX brakes!!
- Camber off on only one wheel
- rokkor shocks
- Ground Control question
- Function 7 Rear Brace and ASR 32mm Hollow Bar
- If I let my lines drain/empty. Will bleeding be hard?
- Beaks SRK discontinued?
- Are there after market struts that will lower my civic?
- Removing stock rear lca, bushing tore bolt just spins
- Sway bar size/geometry question
- custom rate ground controls finally in
- What Grease to use on my Poly Bushings?
- Koni Yellow new perch question...
- Integra springs sTiLL Soft
- will da trailing arms work in an eg?
- Alignment Specs Explanation/Decryption
- GC Springs on Skunk2 Pro-C?
- shock travel trick with koni GC 2.5'' drop
- Bump stop tuning...
- Good suspension setup for Drag racing and autox?
- front passenger top of the wheel bent out instead of in.
- Coilover Conversion kit
- EK oem suspension on DA(front sits higher) ??
- COILOVERS..APEXI OR BUDDY CLUB?????
- So I got my AMR's installed....
- Are these Skunk2 LCA's Real or Fake?
- What is the best settings for illumina shocks
- Yonaka coilovers ???
- 90 Civic Rallycross Springs
- Can you clamp the brake line on a 99 Civic?
- Help on this item please...
- Choices choices
- Skunk 2 pro s 2 - questions
- Wanna lower My 98 ek have questions!
- Rebuilding civic calipers, and need some help.
- 94 Honda Civic Koni Collar Shock Absorber Mounting Pin!!??
- Passenger side UCA question/concern
- HardRace Camber Kit Question
- Brakes Still Squishy after Rotor Change
- 00 em1 sway bar end link suggestions, oem?
- Full Coilover VS. Sleeves..
- Clunking noise in rear
- 15/16 master cylinder cap question
- Compatibility of 95 LS Integra brakes onto 93 VX Civic
- Brake pad suggestion
- Question about rear sway bars 98 honda civic EX
- Can anyone identify these coil sleeves?
- Lowering spring nightmare
- Fortune Auto.. Check them out!
- Function and form type 1, need adjusting advice
- LH wheel is off center in well, bent LCA or subframe?
- Help! Suspension Off, Lower Control Arm Holder Bent
- Help with Koni Sport, 99 Accord Coupe
- Help wtf happened to my shock?? pic!
- Ground Control Information Bilstein and Koni adapters
- Couple of ?s
- 99 civic hatch engine swap
- New suspension on 2000 Si?
- Camber kit won't give negative camber...
- Tire thoughts?
- *clicking* Noise coming from driver side front when coming to stop
- spoon calipers components wear and tear
- New brake pads rubbing against rotor
- Cons to super high spring rate?
- Buying 5 Stud Conversion
- 92 integra rear disc swap - wider wheelbase question
- Looking for 96-00 civic rear camber shim DIY
- suggestions on a set of stiff coilovers
- 92 gsr front disc brake on 98 dx hatchback?
- Del Sol Brake Upgrade Parts List – Please Review
- Koni yellow shocks
- KYB AGX Brand New, Never Install since 2004. anygood?
- Would 97 Acura Sedan SUSPENSIONS fit on a 98 Civic Sedan?
- can i mixmatch my front and rear struts??
- skunk2 lower rear tie bar help.
- Best setup
- Truhart USA
- 00 em1 was told they could not do an alignment is this true? help thanks!
- My Progress Technology Praise Thread!
- Question wbout GC coilovers with Koni shocks!
- Can you identify this sound? Suspension noise...
- Brake Help
- Sway bar or strut bar?
- Can u answer this? (pics inside) (suspension)
- question about preload
- Front suspension
- Spring ID question
- Coils for slamming and tucking tire on EG Hatch
- help plz searched no info 6 shims on oem brake pads 2002 civic ex
- Does ITR suspension fit on orginal RHD EF8 Cr-x SiR
- GC sleeve length question
- Koni/GC height raise - longer spring or increase preload?
- Camber question.
- having problems with my skunk2 pro s v2s help plz
- CoilOvers and Sleeves.
