View Full Version : Suspension & Brakes
- Spring Rates
- BEAKS!
- any help is appreciated
- this is a crazy question abot 97 cr-v
- Bouncy teins
- part number for si rear swaybar end links
- adjusting d2 coilovers?
- Kyb with eibachs sportsline springs good combo?
- The truth about traction bars????
- kyb agx shocks
- ITR 22mm sway bar with ASR subframe brace..what endlinks to use?
- LCA question ????
- choosing right springs for konis
- SPOON CALIPERS?
- Coilovers for a DC4
- DC2 Suspension experts
- ek w/itr rear sway bar, si links ????
- Suspension problem
- Buying used shocks?
- Which full coilover setup for my RSX-S?
- Tein civic (EF) springs on my 91 Integra w/oem struts? *searched*
- Anybody know of an Gray Metallic colored H&R Springs???
- best coilovers to dump ride even lower... please help
- bad shock??
- Help with ground control coilover spring rates.....
- Why people install suspension?
- Omni Power non-adjustables
- Need help with air cylinders..
- Best shocks?
- Help me get rid of the bounce and harsh ride!
- need suspension help
- koni yellows and tien coilovers on s2k
- Ek springs on a EG
- where can i buy koni shock
- Skunk2 Coilovers with KYB AGX
- Will I need a camber kit?
- Anyone have experience on Eibach Pro-Alignment front camber & caster kit?
- ASR subframe. The truth, is it really needed?
- Slick sizes..
- stock shocks
- ebay coilovers
- Rear springs???
- cusco comp s installed *pics*
- I hate my lift, time to change
- EG hatch, Tein S-tech and KYB GR2s
- Koni, tokico or AGX?
- Coilovers on Si EP3 ?
- Eibach drag launch springs- Spring rates?
- Big 10 Tires Suspension
- Need Help Need Feed back on Nex Shocks GOOD?
- corner balancing and tire wear
- wanted!! comptech rear tie bar 96-00 civic
- which shocks should i buy for a 94 hatch. kyb agx or tokico blues
- Wanted some feedback about Omni-Power
- Ep traction?
- Tein H or H&R Sport Springs - 95 Integra
- Spring Rates & Sway Bars
- 5 lug convertion
- Has anyone loosen the LCA bolts without breaking heads on old Civic's?
- ***Koni Yellow Liquid/Greasy Substance***
- swayaway/racerunner coilovers?
- 96 hatch gc coilovers and shock question??
- Integra LS suspension vs. Civic EK suspension
- Advice needed: Stiffen rear-end (6gen Civic)
- will this suspension fit?
- Five lug installed on my EK but issues????
- Home Made Traction Bar
- Anyone heard of this coilover before?
- skunk2 full coilovers vs omni full coilovers
- steering ITR vs S2000
- rear lca change the camber?
- does strutbar really works ?
- Will DA Rear Trailing Arm's bolt up to EG? measurements are the same!
- AGX and Eibach Sportline from a 96 Integra will fit civic si 98 (Canadian 127hp)
- rally crx best setup
- Need lowering adjustable coilover help!!!
- front sway bar es bushing
- questions question!
- no bumpstops
- Suspension Opinions/Recommendations
- Is there a specific order in which you remove the bolts from the fork and control arms so you dont m
- machining wheel stud holes
- What are ways to eliminate the loose steering in our Civic's (eks)
- Gsr Rear Dic Coversion??
- Coilovers by Function Form... Opinions Please?
- US honda fit suspension question
- help me out... please..
- RTA bushing part # clarification
- Do I need shock boots on koni yellows?
- quick strut ???
- Please Help.
- For EG suspension Experts...
- [FAQ] Disc swap problem - nut stuck in subframe
- Need some help with spring rates
- eg2 subframe tear out?
- poly bushings for EG front upper control arms?
- GC coilovers off integra fit ek civic?
- 92 Coils on 91 hatch?
- which coilovers/adjustable springs for dd?
- Somethin's bent
- ebay strut bar combo
- Koni Shocks Don't Fit 95 GSR?
- How rough are omnipower sport coilovers?
- Integra LS rear sway bar on 97 civic coupe
- need suspenion advice
- KYB AGX's with Ground Controls?
- D2 Suspension??? Good or Not? Also would like some more info on Function Form suspension
- Adjustable springs with stock shocks?
- Monkeytek coilovers with KYB GR2 shocks.. need help
- My rear is lower than the front *PLEASE READ*
- $40 camber kits still available? The (up to) +1.5 ones?
- RTA bushing? OEM = Mugen?
- Omni FLCA's?
- Drop Zone Coilovers
- how to inspect shocks externally
- Ground Control height adjustability problem!
- 5 Lug......What fits??? What works?? HELP!!
- How low is too low w/ OTS Koni/GC ????
- LCA/Shock Bolt Size?
- 22mm bushing with 21mm bar
- spoon adj. suspension
- 1993 dx sedan suspension?
- CRx dx rear sway bar?
- got an alignment. my results look ok?
- KYB GR-2's on 1999 Civic Hatchback
- Alignment results after 5lug conversion.
- Cross Floor Bar
- Omni Drag Coilover's
- CRX sportlines, camber kit
- !Put this suspension puzzle together! ITR strut, CRX LCA, and sway bar?
- 92-95 eg rear ST bar on 96-00 ek???????
- Ebay?
- SUSPENSION SUGESTIONS?
- ground controls
- ITR front swaybar end links
- are da and ef si hubs the same size?
- DC shocks on an Ek hatch??
- need help quick! spring not seated properly?
- Tein Stech springs
- tokico illuminas vs. kyb agxs and the omni full coilovers
- Tein SS Differences??
- question about suspension install
- 1993 honda civic hatchback si, prety much slammed to da ground but touching fenders.
- How To: LSD Traction Bar Install (EF)
- need new struts. dropzone coil overs. which struts?
- Suspension choices
- Have a problem with TEIN SS on a 5th gen. prelude
- Suspension Techniques rear sway install nightmare (DC4)
- Eibach Sportline
- brakes
- are tokico hp's really THAT bad????
- Omni Sleeves + Kyb AGX?
- DA integra (90-93) coilover options.. Advice?
- Strut Bar?
- Re-design of Omnipower Coilovers?
- got car aligned, whadya guys think?
- My Illuminas came in! Time for install....
- cant find D2 LCA
- Eibach ERS Spring Length
- HELP ! BOAT LOOK ?!?!?
- okay. new question - eibach pro-kit + ______?
- question about eibach pro-kit
- Question about arp wheel studs
- pro-kit + tokico blues?
- WTB: 95 GSR FRONT L/R NEW/USED BILSTEIN SHOCKS.. ANYONE KNOW WHERE TO GET IT CHEAP
- Question about compatible springs
- EG6 suspension help?!
- quick coilover question
- Where can i find Ksport instruction on the net
- GC top hats
- installing tein flexes quick ?
- Anyone with a front ball joint camber kit installed? Problems for Accord?
- how much did u pay for GC coilovers
- Anyone have the part # for the rear trailing arm bushing
- will this tool work? bushing install
- which springs
- Suspension Problems!!!!!!!1
- GC Coilovers - Question.
- cusco front tie bar
- car jumps to the side when hitting bumps??
- subframe reinforcement kit<<<<--beaks VS aspecracing--->>>>
- gc's what shocks?
- crx shock compatibility
- skunk2 pro coilovers any good let me know
- JDM ITR Apexi Springs? (not coilovers)
- 98 GSR rear swaybar on a 97 civic EX?
- Going back to stock?
- will i need a camber kit if i drop my car 2''??
- Omni Coilover Review
- Civic rearend upgrades?
- Rear Suspension, Clunk, metal to metal sound, DC4
- Ebay: Tokico shocks
- Question about RSX camber kit?
- omni slip on coilover and koni
- how good are the rsr ti 2000 springs?
- Air cylinder question.
- crx ingalls camber kit 35720 install? help work in progress!!!!!
- 4x114.3 swap?
- crx h-brace?
- experts whats the PROBLEM?
- ek coupe drums to disc conversion questions
- RED ALERT!! : SHOCKS NEEDED IN LANCASTER, CA ASAP
- removing your ebrake cables on your ek?
- Kinda of a dumb question...pillowball mounts & camber kits...
- DA forks on EK
- Question about AGX shocks
- DA teg sways on an EG
- lowerd my car with APC coilovers
- Del Sol eg tuning for abusive driver
- SKUNK2 springs.... are thay suppouse to sit like that?
- gsr sway bar on a eg quetions???
- suspension horror storryyy
- Need new shocks
- Autozone (duralast) replacement ball joint, any comments?
- 94 civic coupe street drag car....lookin for some suggestions
- DRAG RACING AND SCCA!!!! CHECK IT OUT
- SRR LCA's??
- b16 in my eg hatch(what type axles)
- ASR subframe and ITR sway bar. Endlinks
- Dampening Ratings?
- tick :?
- stripped alan bolt for gc coilovers?
- Racing Gear RG N1 Dampers
- Rear toe adjustment question
- Cutting Bumpstops
- Tein Basic Coilovers Question
- would i need a camber kit for these???
- Suspension Shock Travel?
- Have a question about my set up
- Sway Bar fitment question
- Chassis Hardware Shops In/Near Orange County?
- how wide can i go?
- underground racing suspension products.....?
- Confused with Tokico illuminas
- Need some help on Ksport
- Eliminating wheel hop
- 4x114 96 spec R brakes
- Full Coilovers: Form & Function VS. New OMNI POWER Design
- Best suspension package for auto-xing EG
- EG/EK/DC Front Lower Control arms the same?
- H&R Race/Tein/Suspension set up for a Del Sol
- mount question
- Noise Issue and Replacement Question
- Camber question..
- Just got an alignment...FYI
- Please Help on my Suspension
- CTR Rear Sway Bar
- 1993 dx civic
- Any one make silver LCA's???
- omni power vs. tein
