View Full Version : Suspension & Brakes
- dropzone spring trouble
- DA sway bars on a CRX HF
- Koni question
- Hit the curb - Results inside
- My EK is really heavy, wich sway bar should i get?
- skunk2 coilover question ???
- Flex Question (searched and question on search results)
- Sway Bars on 98 Prelude
- Squeaky Bushings and how to stop them?
- Eibach vs Tein vs Tanabe
- need to know how much of a drop is recomended on 90 civic hatch with 17's
- TEIN SS QUESTION/HELP
- what's the difference from these springs?
- Who runs w/o swaybars but still has semi-built suspension?
- Question about buying shocks with different brand coilovers.
- alignment problem - steering wheel not straight
- Which springs with 17's?
- Can anyone tell me if the Ground Controls are off a Civic?
- rubbing issues and tire size
- What's an ITR rear sway worth $$$ ???
- Strut bar and Pillars bar
- comptech strut tower bar in red discontinued??
- traction bars
- Do you Really Have to Get an Alignment???
- Compensator mount replacement
- Little arm in front of trailing arm...help it broke
- 1998 civic suspention
- gc/koni or .....
- hardest springrate on coilovers???
- Type R Integra Front Sway Bar Versus GSR Sway Bar ??
- crv suspension
- K Sport
- ~~~~~~~bushing for sway bar~~~~~
- Front and Rear Camber Kits
- Life span fo lowering springs?
- VOTE--Cant decide on suspension for DC
- Ground Control Sleeve Color
- Any Experience with Ksport coilovers?
- H&R Limited Edition w/ Illuminas
- nuub suspension help
- Tanabe or Buddy Club N+ good for daily?
- Dynalite 2 Piston or Powerlite 4 Piston?
- a/c + side tranny bracket?
- Anyone in the Vancouver, BC area suggest a place to get corner weighting done?
- axle problems when lowered
- price
- best spring
- form function preload???
- eg?dc teins ss coilovers on a ek will that work?
- Integra 94-01/ civic 96-00????HELP
- Rear Lower control Arms?
- Ground controls and koni yellows
- Rear brakes
- Recent noise makes nightmare of an issue
- bump stop coilover question
- suspension help. 92 hb
- asr subframe and itr sway bar with stock exhaust?
- Reccomended spring rates for DD autox Type-r will run in DSP.
- Spring rates for del Sol VTEC
- Sway bar question
- DA Struts on an ef?
- Will ITR koni yellow w/ ITR GC combo fit on a 97 Del Sol?
- would this handle better?
- Del Sol Suspension Fit Into 94 Civic?
- Vision UCA's: Are they caster adjustable?
- Looking for 2-2.25" drop from a spring...suggestions?
- Stiffer mounts/vibrations = loose bolts/nuts??
- Can i get alignment, then install camber kit?
- 92-95 Civic/88-91 Civic Suspension
- First time buying coilovers and shocks. Need recommendations.
- ground control spring and ebay assembly
- how to correctly set up front and rear strut bars???
- EF Racing bars, are they any good or go with PasswordJDM?
- Why stiff springs instead of stiff shocks?
- ~~~~~~~~~~~~SIMPLE ??? ON SWAY BARS~~~~~~~~~~~
- I wants to be more dumped y0!!!!!
- Function/Form Vs. Progress Comp II's
- Any Experience with this setup on 92-00 Civic: F/10k R/8k or F/8k R/6k ???
- blox LCA's and problems??
- Tein H Springs?
- How-To: lower your car on full coilovers, the right way.
- kyb gr2
- ES trailing arm bushings HELP
- ball joints and poly bushings, what do you know about them????????????
- nobee question
- Best springs to run on stock shocks?
- Brake Setup on EG6 SiR - Please help!!!
- Anyone Have Experience With Energy Suspension Hyper-flex Bushing Kits
- Lowering/Raising a car with coilovers.
- Are the Tokico illuminas a good choice??
- NEED HELP DECIDING ON LOWERING SPRINGS!!!!
- Just rear or rear and front sway bars??
- camber kit or pillow ball?
- where can i learn a bit more about suspension?
- type r suspension
- Skunk2 Camber Kit...Need HELP!
- lowering
- Anyone ever heard of Silkroad
- what parts do i need to install swaybar on 94 dx hatch
- Anyone have experience with Brand X?
- write on how to instal omni power front camber kit
- coilovers for my DC2
- Mugen strut tower bar install.....?
- Stuck Ebay Coil-overs!
- AMR Suspension
- What the F did i do!!! help!
- need help choosing spring rates
- Type R springs Or Coil Overs?
- ITR Endlink Question
- which suspension
- Eg with rsx suspension
- Turn wheel and doesn't get traction, just burns tires
- are honda springs universal??
- skunk full coilover kit or Ksport full coilover kit???
- stock dust covers on koni yellows
- Having a Problem with KYB AGX. Can't change the ride setting!!! Help!
- Buddy Club/Stance coilovers for EG hatch
- backspace qusetions??
- SPRING COMPATABILITY HELP!
- wheel bearing race stuck
- Diff Coilover or just Diff Brand?
- I need your suspension expertise...
- 92-95 Civic Tein SS Coilovers installed on 00 GSR
- Anybody have a tough time getting the shock off the fork?
- tokico illuminas
- Best Daily driven street car COILOVER? similar to STOCK ride
- eibach prokit noise? help
- SPOON LOWERING SPRINGS: ARE THEY WORTH IT?
- Wobbly rear wheel
- koni threaded suspension setup
- swaping back to stock springs.
- 96 HB Sway bars
- omni power LCA fitment?
- What cars will 99-00 Civic Si springs fit?
- aftermarket end links and dust cover?
- need help with gsr suspension
- suspension help.
- Tokico HP shock/spring combo
- alot of play in both front wheels
- Suspension problem on my DC
- GAB help?
- Favorite Full Coilover System?
- eg6 suspension set up ideas
- Traction Bars
- EG Sway Bar question
- JIC's on an Ep3?????
- H&R race springs w/ 205/50/15 tires will rub on 99 civic?
- KYB agx struts and boots
- Loud sound coming from the rear? Possibly Strut problems. Need Help!
- tein flex debate
- Cold Weather & Suspension Chatter
- How far can you grind down a caliper?
- Tien Basic on my Integra. (not satisfied Help.)
- Tein Basics or GC/Koni or GC/AGX setup?
- Most comfortable setup for daily driving?
- HUB replacement?
- Creaky back end
- opinion needed
- Adjust caster through radius arm??
- NO bump stops on EG.
- Rear washer question
- Sway Bar
- Koni sports/GC on a DC4
- Buying Used coilovers
- How do I adjust my Omni's?????
- 75mph + steel plate on road = metal on metal squeek sound
- need help with coilovers!
- Coilover choice
- my quick K-Sport review
- Suspension ?
- ok, this is really weired.
- Will Prelude Coilovers Fit On My 02' Base Model RSX
- Suspension setup question
- koni red????
- what dampers to use w/ h&r race springs
- Max rates
- dropped si with a bad rubbing problem, what do yall think??
- tokico illuminas question!?
- recommend me spring rates
- Regassing Konis?
- Full coilovers
- gc with agx is this a good combination?
- Anyone with Skunk2 Upper A arm problems?
- EG handling
- Skunk 2 Pro S Full Coilovers - Opinions?
- super stiff spring rates
- is it possible to be slammed and have correct camber?
- 95 civic ex
- will the integra 5 lug bolt on to 92-95 civic coupe???
- Ksport's installed on 99 Prelude Review.
- KONI 8041 race shocks pic request / info
- Camber kit install problem`
- how to tell if shocks are bad.
- EG SWAY BAR HELP!
- 99 EK rear camber ?
- how r the koni yellows
- H & R Lowering Springs
- Custom Ground Control Spring Rates for RSX
- Which springs do you reccomend? Trying to prevent wheel hop.
- HKS
- Info on Koni Threaded Coil-Over kit (Tire Rack coilovers)
- SUSPENSION VENDER ?
- few questions about suspension set up....
- endlink problem
- KYB-GR2 Struts + Coilover questions
- energy suspension install?
- Best daily driven spring/coilover setup
- need a brake line bleeding order
- crx coil overs
- sway bar
- what to get??? SPRINGS OR COIL OVERS???
- An idea to protect your coilovers from winter road grime.
- Civic suspension
- suspension install in stockton,ca
- SRR's have gone to shit, now what???
- Are 92-00 civic and 94-01 integra shock forks different?
- so my gc top hats came today..
- Omni sleeve coilovers and tokico illuminas.Anyone using this set up?
- Camber correction kits
- tokico shocks 01 prelude
- Skunk2 Vs. Omnipower Adjustable Upper control arms.??
- Purple LCA's??
- Accord rear shocks on EF
- Difference between 21 and 23mm rear sway?
- Same spring, same car , two different weights. What's the effect
- Omni Power suspension
- New Camber kit , had a few questions..............................
- fix camber
- Whiteline 24mm rear bar question
- Question: Skunk2 Pro S Full Coilovers
- Suspension Techniques ST Coilover, Sport Tech Kit, and Speed Tech Kit?
- Rear brake swap from crx to del sol
- Ball Joint Removal
- EF civic hatch ?'s about full coilover setups
- installing omin power coilovers, what bolt & nut should i use for the rear lca?
- GOOD alignment shop in or near TORRANCE
- CRX traction bar question
- Questions on setup.
- ITR sway bar/del sol
- rear disk, SEARCHED
- Car ALIGNMENT, is it really align or they say so ?
- Tokico Illumina Adjustment...
- What kind of grease to lube bushings?
- Looking for "How To" for Driver side mount insert install?
- Energy Suspension graphite (black) bushings
- Monoball mounts needed for DC2
- 1997 Accord Suspension
- slammed alignment
- WHERE? Rigid 3point Front Upper Strut Bar (EG/DC/EK)
- What damper parts to replace on DC???
