PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. h22 EJ floating
  2. Caliper Question
  3. Suspension question, what should I get??
  4. strange noise after drop (more of a clunk)
  5. Question about GC w/ koni or kyb agx...
  6. eg hatch turbo, horrible traction
  7. koni yellow suspension question
  8. Eg Suspension Question
  9. How to eliminate abs from a 90 da integra
  10. BLOWN OMNI POWER COILOVER
  11. where can I buy brake shims
  12. disk brake upgrade on EG
  13. From Skunk2 Pro-S to Koni/GC...WOW
  14. Suspension upgrade help: EH1
  15. Scary: Browser Hack lets other see what porn you watch
  16. spring and shocks from a 91 fit a 96 civic?
  17. OEM shock / Aftermarket spring help 96-00 Civic coupe
  18. Need Some Help Please
  19. How much could I sell for some brand new tokico coilovers??
  20. rear disks onto 97 EX, interchangeability
  21. Progress CSII
  22. Help chosing suspension for BB1
  23. function and form type 1 coilover system reviews
  24. Skunk2 Rear Camber Kit repair kit:916-05-0505, Where to buy?
  25. Apexi Suspension - Anyone Running it? any reviews?
  26. 9CLP14S rear calipers
  27. ASR W/ SUSPENSION TECHNIQUES SWAY BAR...
  28. springs for EM1?
  29. question about extended studs on 4x114.3
  30. what eg suspension parts fit ek?
  31. S2000 Suspension Question
  32. 車高調 HKS HIPERMAXⅡ any opinions
  33. coilovers need opinions
  34. which coilovers help please
  35. does anyone have pics of tein stech with non adjustable shocks on a eg?
  36. HELP!!!! Brake lights and reverse lights and turn signals DONT WORK!!!
  37. ground control stiffness
  38. Loud popping noise from Omni coilovers? Anyone know why?
  39. sway bar question (Picture included)
  40. I need a quick-run down...
  41. H&R race vs Skunk2
  42. Need some springs advice please..
  43. Coilover opinions needed
  44. Looking for a comfortable shock/spring combo
  45. Couple LCA questions
  46. anyone using the D2 coilovers? like em or hate em?
  47. SPRING RATES
  48. CPL EJ8 Civic Suspension Upgrades - Installing Energy Bushing, Ball Joints...[NO-56k]
  49. bushing kit that dosent squeak over time ?.
  50. front lower control arm
  51. upper chamber kit which is the best
  52. dc2 brakes on 1997 civic hx
  53. 92 honda civic
  54. Tein flex question
  55. Suspension options for a 1991 DA integra???
  56. BRAKE LIGHTS DON'T LIGHT UP!!!! ?????
  57. rear disk conversion problem!!!
  58. 1998 Civic + ITR rear sway bar
  59. Eibach Lowering Springs on accord
  60. B-Series Axles
  61. EG Power to Manual Steering (Subframe swap info)
  62. Brake problems with my CRX
  63. using dc suspension in a da?
  64. Camber Kit Help!!!
  65. Which brake pads do you rec.?
  66. Ek Hatch Suspension
  67. What setup would you recommend?
  68. Inner and outter tie rod ???
  69. Are these worth it?
  70. 2006 TL for parents, good replacement shock, Bilstein option?
  71. JDM rhd EG front control arm
  72. Puting rear disc breaks on my 92 civic cx
  73. Help Me with my Kony/GC setup
  74. Shock/struts? Need some input.
  75. tanabe df210 w/ tokico blue struts review
  76. REAR Regular DC2 Calipers + DC2r 260mm rotors + Dc2r Pads = Secret OEM bracket?
  77. Damper & Coil setup advice
  78. rear suspension squeaking
  79. Click noise from tie rod. How to fix it?
  80. Steering wheel play....please help.
  81. In need of fittings ASAP for wire/hose tuck - Brake related
  82. what pads for drilled and slotted rotors?
  83. Tokico Illumina & GC reassembly order
  84. Ohlins PCV adjustable coilover
  85. cant lower my suspension
  86. ef gc sleeves same as ek gc sleeves?
  87. NSX Calipers on 5bolt
  88. How do I lift a 82 Civic sedan?
  89. function 7 control arms
  90. Squeal when tires turn right
  91. EG CIVIC EXTREMELY SOFT BRAKES
  92. Recommend a good rear toe adjuster
  93. Suspension
  94. gsr sway bars on 94 eg hatchback??
  95. Vacuam pump to bleed brakes?
  96. Spoon N1 Dampers front/rear fitment???
  97. Bent Steering knuckle; Need to verify parts
  98. Wanting to pick up SPC Ball joint camber kit to replace upper ball joints--
  99. rear caliper itr???
  100. Modifying ksport coilovers to go lower
  101. drag alignment specs?? any EXPERIENCED RACERS/BUILDERS input please!
  102. Blox Racing Lowering Springs on Stock Shocks
  103. How to identify integra spindles
  104. Installing Energy Suspension HyperFlex Master Kit this weekend, what else should I do
  105. Are these coilovers any good
  106. can someone educate me on where/what the steering rack coupling is??
  107. 97 DC4 w/ H&R Sport
  108. Acura El rear Calipers
  109. how do you press these ball joint boots on?
  110. Corner 8 Coilovers?
  111. Loose steering Wheel?
  112. Tokico Blues with Skunk2's. Hmph.
  113. rear sway bar in 90 civic
  114. What shocks for an 00Si with Skunk2 Coilovers?
  115. Trailing arm compatability
  116. soft brake problem
  117. GC conversion kit
  118. 2 Point VS. 3 Point Front Upper Strut Bar
  119. brake caliper play?
  120. Tell me what you think! possible suspension options.
  121. Trying to LIFT my EG.. any ideas?
  122. using beaks bar with ASR
  123. brake flush
  124. i blew my rear struts
  125. corrosion on coilovers
  126. Which Struts to Get!
  127. 1983 Accord brake problem
  128. does this sway bar work with my car?
  129. lowere control arm
  130. godspeed project coilover suspension
  131. Alot of weight
  132. Thinking about pressing your own bushings...
  133. NSX brake swap, a different way
  134. kyb agx shocks and ground control coilovers
  135. k-sport springs on an EM1 ?
  136. Tokico Blues w/ Skunk2 Coilovers
  137. BLOX Front Camber Kits ?
  138. Brake swap questions
  139. ebay ball joints, tie rods and wheels bearing
  140. spring rates for race car..
  141. Need help replacing tie rods on 06 rsx
  142. is bench bleeding necessary?
  143. *******Question about the itr brake booster and master clyinder...*****
  144. ******WHATS THE DIFFERENCE BETWEEN CONCAVE AND FLAT HUBS....?******
  145. Need help adjusting my K Sport coilovers
  146. 99 ek brakes?
  147. rear breaks
  148. full cloil overs
  149. no LBJ circlip
  150. doing a rear brake swap on crx, need advice
  151. blown shocks... what to do next?
  152. rear tire wear and suspenion problem
  153. What strut bar is this?
  154. C-pillar bars
  155. will this swaybar work for my car
  156. 5 Lug Conversion for Integra
  157. Good spring combo for GR2s?
  158. Blox LCA's for a 99 Cx Hatch
  159. Tie Rod Upgrades for EF
  160. 94 Civic Wheel Bearing Replacement?
  161. ITR PIC select coilovers fit CRX?
  162. Will 12.19" Wilwood Big Brakes fit inside 16" Desmond Regamasters? HELP!!!
  163. Cheap 2" drop for a 98 Acura CL?
  164. ASR Sway/ASR Brace/Skunk2 LCA/Beaks Tie Bar
  165. can i remove my front sway bar?
  166. Koni GS minimum drop
  167. what is the size of ground control springs???
  168. ********what's the benefit of Spherical Bearings over regular poly bushings!*******
  169. Function 7 LCA's with Blox rear sway bar?!?!
  170. Integra LS Negative Caster Angle Issue
  171. Oil pan protector shield for slammed cars.
  172. ebc rotors
  173. Rear Toe maxed out on DC trailing arm?
  174. password jdm drilled n slotted rotors
  175. KYB Question
  176. wAnna Ride LoW!!
  177. suspension kit
  178. what do u think about these spring rates...
  179. **** WTF!? stiffer in the front or rear GC/KONI *********
  180. ground control with skunk2 sport shocks
  181. Progress Coilover Systems
  182. CRX spring rate questions
  183. EG6 Racer X
  184. Blackworks Coilovers
  185. brakes sticking.
  186. honda del sol sway bar bushings
  187. Wilwood Caliper bracket nut inserts
  188. B Series EG Spring Rate Question....
  189. Koni GS vs Progress differences
  190. Car pulls left on the highway, new tires/susp recently
  191. 01 CLS rear rotor swap help please
  192. RTA Bush Advice needed after searching for an hour!
  193. del sol subframe...HELP
  194. BRAKE PADS STUCK ON ROTOR?
  195. post your beaks parts
  196. How are the Skunk2 sport struts?
  197. need help my ALB light turned on
  198. adj lower control arms?
  199. springs
  200. Loweing,.
  201. put camber kit on and threw alignment WAY off
  202. how to do this?
  203. ***Roberuta Cups?***
  204. control arms with stars?
  205. Right Rear Drum Lock Up
  206. How to Adjust Brakes on a Drum set-up
  207. how do koni lifetime warranty work?
  208. ek rear lca on del sol...??
  209. Master cylinder question
  210. Tein EDFC experiences
  211. End Link and LCAs...
  212. changing wheel studs?
  213. No brake pressure at all?
  214. 12k Front and 14k rears too stiff for koni yellow shocks???
  215. break me into
  216. Axles in my B16a2 swapped EG
  217. SRR Rear Swaybar brackets
  218. 5 lug for 5th gen accord
  219. Which suspension should i purchase for my 02 RSX Type S?
  220. suspension tuning
  221. Inner tie rod question
  222. Do sleeves go bad?
  223. Which Suspension should i purchase? ej1
  224. Ground Control ots with Skunk2 sport struts DC2
  225. Blox LCA + Stock Sway bar problem
  226. twin spoon caliper clear rim??
  227. Front Lower Tie bar..
  228. 92-95 civc vs s2000
  229. coilover setup
  230. coilover or shock combo tire/ wheel
  231. ST Speedtech rear sway kit for EK, D-bracket question
  232. Kinda embarassing, but I hit a curb
  233. Seat Belt Trick = Better 60fts ??
  234. Shocks or Coilovers?
  235. Help me out with a EK setup...
  236. mugen sway bar bushings
  237. Modified shocks? wut do you guys think?
  238. tie rod stuck, can't get it off, advice??
  239. Koni DA won't adjust
  240. Top Hats Needed?
  241. camber kits
  242. spongy brakes on a 99 accord that I am buying from a dealer
  243. Suspension question
  244. gc from agx to koni?
  245. koni n sportline springs
  246. itr sway bars front and back (endlink)
  247. 94-01 teg suspension in 99 civic??
  248. so im getttin knoi and GC combo. need help
  249. itr handbreak help
  250. brake bleeding problem
