View Full Version : Suspension & Brakes
- uca
- cheap omni powers
- stud replacement..
- omnipower bottoming out
- Coilover set up for a CRX.
- ground control experts
- Technical Opinions on Autozone Rotors...
- Adjusting Coilovers
- Vespia Goodyear Alignment Center Hamilton NJ
- What should i do
- Full Race ProAM traction bars
- omni LCA bushing question
- skunk2 camber kit????
- 90 accord spindle nut
- full coilovers or spring/strut combo
- *pic request* Nuespeed race springs and Koni yellow's
- re-setting bushings
- Koni
- Good Coilovers for EK
- LCA's for rear of ek?!?!?!
- OEM sway bar don't match up with aftermarket LCAs/ASR Subframe Plate?
- Should i go with the .75" drop or the 1.75" drop with H&R springs?
- some random ?'s
- omni kit quality?
- Sagging Springs
- how much does ride height affect comfort?
- integra camber kit
- is modacar trying to screw me, my ek...please look
- koni yellows - metal collar
- smoothest coilovers?
- ground control numbering system
- need opinions (the threads every1 love)
- suspension problem?
- koni reds on teins s tech
- Suspension or Axle Vibration
- Tein Basic Tire and car GAP Question.
- What front sway bar for EK hatch
- dc2/db8 stock sway bar in a eg2???
- HELP! Ground Control tophat/ front strut bar question
- pic performance coilovers (apex)
- no rebound on koni yellow?
- ground control coil overs on EK, want to go lower in rear.
- question on oem suspension
- h&r sport kyb agx regret?
- Owners of Tein S-Tech springs:
- K-Swapped Coupe Suspension
- For my eg
- What suspension for my DA at an ok price
- Lowering 5th gen prelude... dumb problem(searched)
- Few questions about Ground Control/Koni Install
- what suspension to get?
- home made sway bar reinforcement...
- Fabricate or make end rings for EK endlinks onto ITR sway bar? ASR kit related
- 97 GSR vs 92-95 CiviC ( FRONT Sway Bar) ??
- OMNI POWER QUESTION
- swayaway coilovers need help with setup
- Suspension squeaking over bumps... why?
- trouble removing rear lower shock bolts (on LCA)
- kyb
- questions about 88-91 crx will 92 to 95 eg suspension fit
- tein basic or tein ss for my crx?
- LCA Universal ?
- cheapo sus.
- em racing bars(where 2 buy)
- 06 Civic SI Springs in 06 EX Coupe
- Suspension Torque Specs for a 2000 civic Si? Searched
- Going to look at some TEIN Basics tomorrow, what to look for?!
- drop fork anyone?
- yellow spring help?!?!?!?
- installing tokico illuminas help
- Dropzone. What Sleeveovers will work with........
- confusing susp question
- rebuild kit for progress full coilovers???
- :thumbup: for Tokico's customer service
- Stiffest spring rates for Koni Reds?
- EM1 front subframe Question
- 06 civic coilovers
- 95 civic ex ..... SKUNK2 PRO Series Racing Full Coilover Suspension Kit or TOKICO ILLUMINA SHOCKS &
- How do I adjust my D2 suspension(DA)
- Big Problem
- Changeing load transfer by springs (and swaybars) article Racecar Engineering
- KYB AGX Adjustments
- Eibach Pro Kit or OEM ITR?
- 96 spec brake shims and retainers
- question on koni/neuspeed yellow combo...
- springs or coils...?
- which springs, 91 civic
- adjusting height?
- Tokico HP
- t-world coilover?Rare item i think
- Squeaking noise
- next up?
- Tein S-Tech Which Way?
- Ground control top hat problem
- tein suspension
- ebay coilover
- What's the point of the thing that goes between the two mounting points on the upper wishbone...?
- 25mm rear sway bar on stock '06 Type S suspension?
- rear brakes question.
- Need Coilovers and Camber Kit
- $600 too much?
- shocks prelude 4th gen
- Skunk2 coilovers on 88-91 civic
- rear oem shocks had no bump stops?
- omfg...do i need a new shock?
- Installing a strut bar
- Spot welding extended studs??
- rotor screws
- ASR Help
- Full Coilover vs adjustable shocks and coilover
- 99-00 oem springs
- Increasing camber at same height. Will toe be affected?
- What springs? LMK what you think
- Fluid leak on my front Tokico RAK 502?
- What shok will suit me the best???
- Will integra springs fit an EG?????
- good suspension set-up for h22 in crx
- Aftermarket Front LCA ???
- Can mugens sport suspension support a K20A?
- GOOD SETUP?
- Suspension Solution ?
- bumpstops
- Need help - alignment kits
- Bushings .. what ones
- HELP: Installing Tokico Illumina RAK Coilover tomorrow
- need help on wheel offsets...
- How to remove LCA
- did i install my gc/koni correctly?
- quick ? about my tein flex
- 1988 CRX: rear disc conversion....whole trailing arm or just the hub assy?
- Tein problem
- Ksport?!
- Megan Racing suspension!?
- wall mount spring compressor
- tein or eibach pro
- need konis
- rear camber kit? ('00 civic)
- somewhat of a popping sound?
- Which Bushings SHOULD NOT Be Installed???
- aspec racing reinfor...
- Strut bar!!!!
- GCs on Stock Shocks
- Are the Ebay camber kits any good.
- which suspension set would be the best, i have 3 listed below
- lca help: nut size, brake lines?
- 92 integra springs and strunt help
- are 90-93 integra and 88-91 civic lower ball joints the same?
- struts/spring combination
- Sprint springs/Agx GR2 shocks?
- wtb: adjustable caster and camber upper control arm
- should i have to worry about my subframe???
- Increased Prices
- Stock spring with Bilstein, is it worth it?
- Wanna Lower My car best options
- Where to buy CUSCO?
- brake question 93 civic si hatch
- skunk2 camber question
- Where to put brake lines after installing omni lca's?
- Will 2000 SI springs fit on 92 civic hatch???
- alignment
- Camber kit?
- What size for rear sway bar
- on average, a suspension setup lasts about how long...
- D2 rs coilver system
- Brakes Please Help!!!
- Hey guys is this set up a good set up, theres a link in the post.
- Will Suspension Techniques Rear Sway Bar fit with KYB GR2's on EG
- How would Sprint Springs and Tociko HP's be for a 96 Honda Accord 4cly/4dr?
- Tein Mono Flex?
- I need to change my turning radius - help.
- 93 ls rear swaybar on 95 civic hb???
- koni/ground control help
- camber kit for a 5th gen prelude?
- koni yellow spring perch rings not needed anymore???
- broken rear bake hard line.. whats the best route to go??? eg94 where are you???
- DIY rear tie bar with reinforced sway bar mount
- D2 coilovers did i install it wrong? feels more rough then my old set up
- question on adjusting koni yellows...
- Rtec coil over kit?
- Help! Any RSX owners have D2 coilovers on? Need help with install
- Only one way to take out bump stops?
- which springs go in front and which in rear??????
- How much to ask for gsr rear lca's?
- Help! D2 rear coilovers on an RSX
- My soon to be setup....
- So I solved my own vibration and clunkiness issues. not what i thought but close.
- will this fit?
- energy suspension motor mount inserts...
- Broken bolt - rear shock to LCA
- *For 88-91 CRX's* How does this come apart?- Installing camber kit. help needed!
- help custom tailor my suspension for me!!!
- my car didnt came with sway bars... which one do i need? (97 civic)
- Do 96-00 Tein S-Tech springs fit 92-95 Civics?
- Suspension Techniques
- ground control and tokico
- brake problem..help me
- Do I need to cut my bump stops?
- Suspension and Brakes Rubbing
- Grinding noise in gear, mooing noise in reverse
- front upper strut causing car to lean?
- GC Spring rate conversion?
- who knows what springs has code r-p1a01 stamped on them
- Need Help My cars sitting on jack stands and i got Work Monday :(
- Omni power coilovers (sleeve type) Weird vibration?
- Help installing rear suspension!
- Shock tuning and braking power
- alignment off after gsr brake swap (front)
- Tokico Illumina's?
- 4 choices, which would you choose?
- tokico illumina install help needed
- what kind of wheels these in the front
- korbach frame lock kit ?s
- Skunk2 Proseries vs 1st Gen Camber kit....
- currently have omni coilovers with AGX, looking to upgrade
- ITR rear sway on H/B.....rotates to much
- How do I choose the right shock valving? please help..
- quality upper control arm brands needed
- i need some opinions on tein for my dc
- Why no one like Tien H Tech Springs??
- Camber Adjustment Parts
- enery suspention bushing kit?? searched
- Suspension install
- Will 99 Civic Si Suspension fit on DA Integra's?
- They all look VERY simular: omni, ksport, d2, function, megan etc... Who makes it ?
- Ground Control - Stuck Allen Head bolts on adjustment collar
- Sway bars
- what should i do??? coilover or shock.strut w/ a lowering spring???
- Lower Balljoint Nut Rubbing Brake Disc
- Suspension Coefficient parameters
- Wheel Pushed Back in Wheelwell? Frame? UCA?
- Koni with GC vs Tein Basic
- A successful front camber kit would be...???
- Where to find front LCA ?
- ¥ TEMPLATE HELP ¥
- ride comfort springs
- i've searched. Looking for opinions. trade my tanabe for d2?
- what springs with stock type r struts?
- DS Suspension shifted backwards
- 2001 civic SI front struts who makes them
- Change rear camber on 6th gen Accord without buying expensive kit?
- Removing Spot Welded Nuts for Beaks Kit
- Tein Type Flex + EDFC, worth the cash?
- Lowering 101.
- A FAQ is needed for this forum.
- GC top hat and GSR strut tower bar
- suspension bolts---honda dealer or NAPA/autozone/other
- best full damper kit?
- Koni problems
- good coilover setup
- Suspension/Brake Upgrade: ITR 5 lug conversion, coilovers, NSX calipers
