PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. buying used shock
  2. Pinging in suspension
  3. 97 civic suspension question
  4. Brakes for 95 DX with 15" RPF1.
  5. ### CARBING 4 Point Bolt-In Roll Cage - Suit 94 Civic Hatch ###
  6. Ek Rear Disc Conversion Underway
  7. Pic Performance Still Around?
  8. 92 Accord Coilover install DIY??
  9. 2001-up Civics might need camber kits?
  10. omni lca bushing
  11. 24 mm swaybar ok for daily driving?
  12. Spoon N1 Damper installed - rear is slammed?!?!?! help pls!
  13. cheap rear aftermarket LCA bushing question
  14. got an allignment at les schwab
  15. ef progress rear sway bar
  16. Which End link?
  17. GC extended top hats: the truth is needed.
  18. Full Bushing Replacement Kits
  19. which skunk2 camber kit
  20. Looking into suspension setup
  21. K Sport Coilover Adjustment
  22. ??????????
  23. CTR brakes on Integra
  24. Helms noted bleed sequence
  25. Need help with brakes
  26. How low will Skunk2 springs and Skunk2 shocks sit me?
  27. Fitting Prelude 2.2 Calipers onto Civic EM1
  28. tien ss coilovers
  29. Interchangability of hubs
  30. Coilover question.
  31. Ride height need help!!!
  32. 96 itr to 98 dx knuckle/brake swap
  33. Megan or Progress for an 01 civic coupe
  34. Ef civic supension help!!!!!
  35. Automotive scaling/corner weight?
  36. 98 rs mc with 95 rs bb?
  37. Ball joint?
  38. What shocks?
  39. how to adjust function and form type1
  40. Skunk2 Lowering Springs - Help identify :D
  41. Ground Control "Lifetime Warrenty" and Seized Adjusters...
  42. Braking on the street vs. track
  43. Spongy pedal after start,caliper replaced
  44. Coilover Questions?
  45. Squeaking BRAKES
  46. autozone tie rod ends
  47. Koni spring perch for gc part number
  48. GC Coil over spring rates
  49. looking to lower my civic budget
  50. Car is FINALLY done...ALIGNMENT question....
  51. Will coilovers off a DA fit my 4dr ek???
  52. suspension squeak
  53. Knuckle ???
  54. Rear sway bar
  55. Steering wheel
  56. LCA question
  57. Ground control!!
  58. Installing Spoon calipers
  59. Top hat question
  60. Anyone have experience with Torque Industries coilovers?
  61. advice on spring and shocks
  62. Swapping brake booster out in 4 wheel disk conversion?
  63. proportioning valve
  64. integra type r springs on 98 civic??
  65. Prothane Shock Bushings - top hat inserts? Worth it?
  66. Energy Suspension Install: Need help picking tools!
  67. DC2 Knuckles/S2K calipers/RSX-S rotors: How much to mill?
  68. >>>Tein S tech HELP!!!
  69. EF Subframe brace
  70. Coilover Spanner Wrech Size
  71. Springs for '00 Si
  72. What's ur Max. Capacity?
  73. Still tension in the fr swaybar?
  74. Function and Form Sleeve cracked in half.
  75. Question about Skunk2 Pro-C's
  76. what power steering rack n pinon can i put in a 88 ef hatch?
  77. HKS Hypermax II Adjusting tools
  78. function 7's
  79. EM1 front sway w/ EX lower conrol arms
  80. Which lcas?.. blox, skunk2, f-7s?
  81. Help! 5 Lug Conversion (99 SI)
  82. I hit a Cement wall need help
  83. EIBACH sport line lowering springs, What camber kit??
  84. PIC request for H&R sport spring users that have 17s
  85. Upper Arm Hitting
  86. Pads for a Japanese/Australian Civic
  87. 11.75" Wilwood Brake question
  88. Parking brake light?
  89. blown struts
  90. Rebuildable Coilovers
  91. Possible bent suspension parts?
  92. Just ordered Koni shocks, stock SI springs on a 2000 EX question..
  93. who manufactures hks suspension ?
  94. GC+konis!!
  95. CRX-DC2 Suspension???
  96. switching from koni sport to race install question...
  97. eg civic and ek civic lower control arm the same?
  98. What would you do?
  99. Still getting squeaking sounds after fresh rotor and pad install
  100. EK Front Lower Control Arm Problem
  101. ASR brace installed but forgot a step.. help
  102. Ground control top (hat)mount question?
  103. F2/AMR Bounce on the highway?!!??!?
  104. best "bang for buck" coliovers
  105. in search a proportion valve?
  106. Spring help
  107. Tokico Illumina or Bilstein HD with H&R Race on '93 Accord??
  108. Honda/Acura supension swap guide
  109. Front lower control arms off an ek fit an eg?
  110. semi-braking system upgrade question.
  111. Problems with skunk2 pro c full coilover.
  112. Good indicator i have bad struts?
  113. will 99 oem ex springs fit my 94 ex
  114. HELP! Del Sol bottoming out badly!
  115. Rear-ended, now front end noise.
  116. alignment good but car still pulling?
  117. Which camber kit? Installing soon!
  118. 2008 Accord: Rear brake help needed
  119. opinion needed
  120. How do I lower just the rear of my 99 civic
  121. Proper way to adjust/ measure Coilovers GC
  122. Need Help Skunk2 pro-c suspension understeer
  123. broken bolt :( any ideas on getting it out?
  124. blox coilover tuner series part#BXSS-00100
  125. rhd eg6 = rear type R suspension doesnt fit???
  126. DA 5Bolt Conversion Problem??
  127. Prelude fender bender lead to multiple suspension issues
  128. Mugen Showa: Will these fit my EM1?
  129. clunk while coming out of park
  130. FUNCTION 7's Need Help!!
  131. wings japan
  132. rear caliper?
  133. relocating suspension points
  134. Did I install these coilovers properly???
  135. Simple questions?
  136. i've broken 2 axles.
  137. Pads and rotors decision
  138. what are these and what is there purpose??
  139. EM1 5 Lug Conversion Complete....NOW PROBLEMS!
  140. wheel hop in turns, almost wrecked, need solution
  141. what strut to use
  142. functions & form type I question....
  143. will skunk2 upper balljoint fit in a omni power front camber kit?
  144. hardrace bushings or energy suspension or other?
  145. dc sport strut bar and gsr strut bar
  146. rear upper arms - interchangable side to side?
  147. Do these coilovers look in good condition
  148. ITR rear LCA's on an eg?
  149. brake problems??? hard to explain but any helps much appreciated..
  150. tryin to do my own energy suspension bushings
  151. help coilover question
  152. coilover's seized/stuck
  153. Spline Count
  154. 88-91 Ground Control Sleeves fit on 96-00??
  155. Getting speed bleeders, what sizes do i need?
  156. Question about ground control
  157. Brake Questions
  158. Need help reading Eibach springs
  159. save my tires!!
  160. Looking for suspension advice/experience tips
  161. 03-07 accord susp same as 04-07 acura tl?
  162. 2001 Civic Eibach Sportline Question
  163. S2000 rear brake calipers on a DC2?
  164. Good height for my eg
  165. How low will my Koni's go?
  166. Options for going 4x114.3 on EK
  167. Function Form Type 2's
  168. Bad caliper?
  169. Brake Rotors???
  170. need help on performance suspension
  171. PIC Performance suspension
  172. How does coilover spring preload adjusting wk?
  173. 96 itr 4x114.3 rotor ?
  174. Question about Caster
  175. AMR Engineering
  176. usdm itr rotors n jdmctr rotors
  177. Newbie to suspension!
  178. stock struts with springs
  179. Koni Shocks from '97 coupe onto '94 coupe??
  180. h22a & 5 lug ......how to make axles 36mm?????????
  181. Super Blue in ABS Modulator?
  182. Koni Adjustment
  183. suspensions help
  184. problem with KYB AGX not compressing.
  185. Need some advice on suspension for an EM1
  186. camber measurements/adjustments needed.
  187. CUSCO coilovers for 93 EJ1
  188. Please Tell me about these struts
  189. SPC replacement balljoint part #?
  190. HELP PLEASE!!!! EIBACH pro-kit!!
  191. ~Quick questions regarding Legend/ITR/NSX/Accord brakes
  192. Raising suspension
  193. How to remove ABS off my 94 integra?
  194. How much do they weight? STOCK VS Skunk2, Omni power, function7, Tein and more
  195. should i replace both shocks? or just 1?
  196. I've decided on PIC, now what rates? Autox
  197. Prelude vtec calipers have different hub centric than civic....wtf?
  198. Front endlinks for a dx civic
  199. trouble deciding what to go with!! please help!
  200. ek brake setup on eg
  201. Electric power steering
  202. 98 integra suspension help
  203. H&R Sport spring installation
  204. Replacing blown AGXs with different shocks
  205. WTB integra spindles!!!!
  206. Coilover conversion
  207. Quick Ksport camber kit question
  208. H&R race for autox prelude
  209. preloading suspension
  210. Sir brake conversion whoa's
  211. CRX_Lee HELP!
  212. DA rear lower control arm on ef
  213. Koni Sport kit question
  214. what do i need to do
  215. Coilover collars - grease them up?
  216. Question about GC spring rate and Koni Yellow
  217. Will running no bumpstops have the same ride as blown shocks?
  218. prop valve
  219. BC Racing Coilovers: Any1 used them before?
  220. eg front brakes on 91 crx ??
  221. Tein S-Tech (hard) for 01 Prelude
  222. EBC red stuff ceramic pads
  223. d2 coilovers...auto-x.....
  224. Master Cylinder HELP!
  225. H&R race / sport and Tein S tech pic request
  226. gc extended top hats
  227. Will 90-93 DA coilovers fit on 94+ DC shocks?
  228. H&R sport springs lean to one side
  229. Ksport coilover owners post your feedback please
  230. skunk2 pros vs function&form type 1
  231. crx d2 suspension front fork problem
  232. Integra Type R caliper Question
  233. Suspension "knock"...struts? Help needed
  234. EK DC suspension swapability
  235. eg brake conversion
  236. overheating my brakes
  237. Tokico Repair??
  238. Nex full coilovers whats next?
  239. d2 calipers! anyone?
  240. Ball joint boot for S2 UCA
  241. AGX vs. Koni Red for a semi-slammed setup
  242. Help with GC Numbers
  243. Rear Sway Bar Endlinks
  244. caliper paint?
  245. installed new caliper today, soggy pedal
  246. Skunk2 Pro S Coilovers or GC/Koni
  247. Are all civic / integra front LCAs the same length?
  248. Front tire rub...What do you guys do to help?
  249. Adjust Rear Camber Kit?
  250. Bilsteins query
