PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Spring rate question...
  2. Lowering car question
  3. Looking at all new suspension set up
  4. H&R Race Springs
  5. Car bounces ALOT more after installing ST sway bar......
  6. Knocking sound when turning..?
  7. Install of camber kit on 4th Gen Prelude....
  8. Help me out!!
  9. KYB GR-2 anyone?
  10. installing strut bars
  11. how low
  12. 12.19" Rotors behind 16" rims?
  13. koni shocks part numbers
  14. upper front control arm question...
  15. Stock springs from an EG or Ractive Coilovers?
  16. ASR SELLERS ON THE BOARD?
  17. Just need a little advice
  18. using Tein HA's only in the front?
  19. can omni 92-00 drag coilovers work on a crx?
  20. plz help !!!!!!!
  21. is there anything cheaper than a front camber kit but works just as good???????
  22. will i rub with a 2.5" drop?
  23. Am i going to ruin my new KYBs?
  24. I found out today i got a bad bearing
  25. do rotors from a 90 crx dx slotted and drilled fit a 92 teg?
  26. replacing inner tie rod in a 96 civic
  27. Brake pedal freeplay?
  28. tein ss from eg into ek?
  29. What Teins are these?
  30. Rubber thing torn attached to brake.
  31. stock exhaust and rear swaybar
  32. quick master cylinder ?
  33. Alignment results ... fixing caster?
  34. Stance coilovers?
  35. what other brand of coilovers would you recommend besides ground control?
  36. NEED HELP PLEASE!!!!!!!!!
  37. does anyone have any experience with k sport lowering springs?
  38. ???? about lower rear lower contol arm.
  39. Ball joint question.
  40. Bleeding ABS.
  41. Prelude 5 lug on ek?
  42. Theory: Best setup
  43. Brake Pad Shims function
  44. coil over spring rate question
  45. H22A in EG pass. side axle wobbling and shaking!!!???
  46. upper ball joints
  47. Alignment cost when slammed?
  48. Very Important front knucle question!!!
  49. Help with Roll bar!
  50. Stainless Steel Brake line comapnies.
  51. Tein or Buddy club coilovers
  52. trying to find a balance..
  53. Is my tow what's Vibrating?
  54. 88-91 civic traction bar the same as 92-95 civic traction bar?
  55. Starting point for suspension
  56. 99 SI suspension
  57. replaced lower ball joints, need alignment?
  58. BENEN real lower tie bar
  59. anyone replaced rear trailing arm bushings with ball joint tool from autozone/advance auto
  60. Tein Flex height adjustment question
  61. Aragosta Shocks??? Anyone heard of em
  62. Another Ground Control question (spring length/full droop)
  63. 99-00 si springs/shocks on my 99 CX
  64. Bushing for shifter help
  65. which ground-control kit?
  66. Tein coilovers, experiences?
  67. Crossing parts
  68. FS: D2 36-Way Adjustable Coilovers (USED) FOR SALE
  69. would 96-00 civic shocks fit my 93 civic
  70. Brake Pad
  71. SRE Front & Rear Camber Kit Anyone experience with them?
  72. .korbachperformance.com frame locks..
  73. New coilovers or get a limited slip?
  74. lowering spring help
  75. World Sports
  76. keep the old or get some new
  77. TEIN SS and cutting bumpstops
  78. wrx impeza suspension
  79. Are Koni Yellow shocks twin-tube or mono-tube?
  80. Which 19mm rear sway bar do you recommend?
  81. Question regarding the sub frame and asr kit (gsr)
  82. Are these Integra LS sway bars a direct bolt on to a 92-95 Hatch? *Pic*
  83. Help: How-To remove brake clip holding brake lines?? **Pics** 92-95 Civic
  84. 2.25" drop on 94 accord, need camber advice
  85. best suspension for me?
  86. Something still isnt right.
  87. 94-01 and 96-00 civic inner/outter tie rods interchangeable?
  88. Ef to Eg swap
  89. steep driveway and big sway bars..
  90. coilover question
  91. will ST rear sway bar and tie bar combo from a 96 hatch fit a 00 Civic EX?
  92. ak civic question (86 sedan)
  93. help with my suspension for drag..
  94. will eg coilovers fit on an ek?
  95. 96-00 civic owners with 15x6.5 +32 offset.
  96. HUmming...
  97. maker of chassis bar
  98. Help softening up ride
  99. dc suspension setup
  100. Ground Control Top Hat Stem Diameter + Koni
  101. Best DC2 Coil-overs
  102. Spring and Strut/Shock Set-Up
  103. Spring questions
  104. Need Help Identifying my Ground Control Setup
  105. retrofit suspension. compatible?
  106. omnipower adjusting height
  107. Energy Suspension Install?
  108. tein ha ?
  109. rear toe
  110. Camber Kit Info
  111. Ground Control height setting question
  112. Civic VX Sway Bar/ Muffler installation problem. Please Help
  113. Del Sol rear disc brakes on EG hatchback question
  114. What kind of suspension???
  115. What am I missing here?????
  116. Need setup input... 1) Omni FC 2) H&R & Koni Red 4) Sportlines & Koni Red
  117. What are some good shocks for H&R Race springs?
  118. Spring rates
  119. need coilovers
  120. its ok to have...
  121. is it safe?
  122. Can EK coilovers fit on an Integra?
  123. k-sport installation on an EJ8
  124. Anyone with Skunk2 Springs please post!!!
  125. My tein SS's 16way adjustable go further?
  126. Integra 94-01 spindle direct swap to 96-00 civics???
  127. Question about GC fitting Koni shocks.
  128. JDM ITR SUSPENSION!NEED HELP AND ADVICE!!
  129. General question about springs/shocks
  130. boingy boingy. rear suspenion is bouncy
  131. Competition Engineering Traction Bars (searched)
  132. Suspension Suggestions...
  133. VEGAS ALIGNMENT SHOP
  134. where to buy this x bar
  135. Poll for EK Owners
  136. Caliper bolt Size...
  137. ASR SI endlink adapter install. HELP
  138. my rear is clicking
  139. Wheel alignment
  140. Omnipower rear coilover blown.
  141. Tokico Blues or KYB adjustable
  142. FF or Tanabe
  143. please help with lowering car
  144. DZ kit... good or bad... past experiance...
  145. opinion on buddy club race spec coilovers
  146. 03 card at the track = sloppy!
  147. HONDA CIVIC 2001 coilover problem
  148. why is tein so bad?
  149. What is the purpose of extended top hats?
  150. creaking sound when turning the wheel
  151. Stock CRX shock/strut opinions!!
  152. N+ spec damper; good or bad
  153. Ground Control Spring Rates for a DC? Recommendations please
  154. raising a 2000 civic lx
  155. R1 coilovers
  156. EK HATCH Best full suspension?? need help??
  157. 97 civic EX, broken wheel stud - what's the best option?
  158. Suspension components for a 10 second car
  159. polyeurothane vs. butyl rubber: which is better?
  160. no junky coilovers
  161. TEIN SS for EK9 / EK4
  162. How is the Ksport Kontrol Pro Coilovers?
  163. ball joint Vs. Uper arm camber kits
  164. EF Rear Toe Setting
  165. Will an EK full coilover set fit an ITR GSR
  166. H&R springs sitting over AGX adjustable struts?
  167. Make your own dust boots for coilovers !!..... pics inside..!
  168. How low can I be and still remain daily driven safe....
  169. whats next?
  170. have any body use this set up?
  171. Recommendation to alignment shop in bay area, CA?
  172. need help with integra shocks
  173. Need Help on choosing springs!! LOOK
  174. Blacksmith stile stunk reinforcement(parts from lowes :))
  175. Help with bushing size!
  176. sqweeking problem
  177. Car pulls to the right after alignment
  178. Rear Sway Bar Install Q
  179. CRX vs Civic (EG)
  180. Skunk2 coilovers / shocks / top mounts
  181. Suspension for 99 Integra GS
  182. is this the right suspension?
  183. Picture request , Crx 17" with any stock + springs that are 2" or less, please
  184. INGALLS Question
  185. Hey first post just got a honda, quick question
  186. wilwood fastbrakes?
  187. Tein RA on EG
  188. which are better shocks
  189. will prothane motor mount damage Axle CV boot
  190. tokico illumnas/koni shocks, GC coilover setup?
  191. big prob with Upper arm
  192. Bolt stuck in bushing.
  193. camber kit??
  194. Tein SS adjustment knob?
  195. Help choosing suspension. 98 dx hatch with rear gsr brakes
  196. how is this 1150-5010 koni suspension for my EK4 ?
  197. 94-97 accord with dropzone springs
  198. rear disk brake help please!!!!
  199. koni 8041 race + stock springs
  200. ek struts on eg?
  201. da vibrates
  202. Need new suspension...Any suggestions?
  203. heated or chopped
  204. need help: front lca question
  205. Putting my KYB AGX shock and Tein S-Tech together on my Prelude SH, did i miss anything???
  206. Can subframe braces be used with SWIFT reinforcement bars
  207. 1992 hacthback suspension
  208. Got new shocks/struts , but there is a problem EF WAGON
  209. oem springs identification help
  210. crx autox and road racers
  211. Knocking noise while driving! Help Please!
  212. Which One Do You Pick?
  213. 94 Si Lude suspension...
  214. Question about the need for subframe reinforcement
  215. 1995 Honda Accord LX Antenna
  216. uca hitting the shock towers and bendign and twisting the metal
  217. Popping sound from steering/suspension? (Video Included)
  218. front lower tie bar and 4-1 header clearence?
  219. Five lug Conversion question for eg/dc
  220. tokico coilover kit installed, squeeking noise now?!
  221. which springs are stronger and better skunk2 or eibach
  222. stock axels how strong are they?
  223. solid rear axel pics
  224. Tein Flex - dampening procedure
  225. Camber Wear
  226. What configuratioin for my Koni Yellow's in my 00 Civic?
  227. anyone have a link to a eg civic sway bar that is for civics without oem bars
  228. eibach ground control spring part number (DC)
  229. Tein problem
  230. Skunk2 LCA's
  231. 2002 civic si suspension question
  232. Where to buy individual springs with custom rates for drag?
  233. brake upgrades
  234. Problem w/ rear strunt install.
  235. New to Suspension Forum: D-Spec from Tokico.
  236. K-Sport coilovers compatible with Tein EDFC?
  237. Bad setup???
  238. Koni Yellows w/ GCS = Squeek!
  239. Slipover Coil-over kits other than GC
  240. reliable struts
  241. DSS Stage 3 Axles for H22 EG - what other hubs will fit ?
  242. tein edfc problem need help ASAP
  243. Manual Steering rack bushings?
  244. Subframe tearout...
  245. Which set up....koni's or D2's
  246. Just bought 92 EG
  247. How can you test INNER cv joints?
  248. lowering questions??
  249. car shifts under acceleration
  250. skunk2 race springs
