- Bigger pads?
- Brake upgrade help needed
- accord suspension
- Strut assembly replacement on 2002 Accord. Anything else to replace?
- Rotor and pad recommendation?
- Civic Tien spring on my GSR?
- 294mm jcw mini cooper rotor brake setup. Need help.
- Coilover Recommendations.
- EK suspension question
- In search of budget friendly full coilovers
- Looking for coilovers that I can raise higher then function and form type 1s
- Stock suspension semislick VS aftermarket suspension street tyres
- Worth attempting to fix rusty coilover damping system
- PIC Coilover help
- Interchangable hubs for a rotor-over-hub conversion?
- Increasing track width 99 Civic EK
- What could cause rotors to chronically warp - 2000 Accord?
- 2016 Civic rear suspension
- 1991 EF Sedan UCA hitting shock tower
- Need 282mm caliper to enkei rpf1 7x15 et35
- HELP.... Who to believe now??!!!
- New sway bar bushing doesn't have a split
- ASR/Aftermarket Rear Sway Bar Install Question
- 92-95 EG Civic Comfortable Ride: New Front & Rear Suspension
- Rear control camber adjustable arms
- Brake mystery; HELP needed
- ABS Honda FR-V
- Pads Fit Very Tightly in Bracket
- Should I buy MaXpeedingRods brand coilovers?
- Brake Humming and Possible Excessive Rotor Runout
- 1996 Civic Front Left Engine Mount
- progress cs3 on ep3?
- HELP! Hissing Sound
- Stabilizer link bad - replace both?
- ABS Sensor Harness 2015 Fit
- Dust Seal or Hub replacement?
- AwD EG front brakes???
- Help Needed: Upgrading Suspension on My EK4 Civic!
- Is an alignment necessary in this scenario…
- Carbon Ceramic Brake Kits?
- Tophat bushings not fitting Koni yellows
- ABS module (ecu) repair
- lowing springs and racing springs
- UCA For EG Civic
- NSX brakes on a GD Fit
- Shortest OEM Honda Outer Tie Rod Ends
- My personal parts list for 1995 honda civic lx to integra brake swap and generalcost.
- Coilover rebuilt sugestions
- ABS FWD Collison and LDW comes on intermitten
- A Survey and Sharing of my Fixes for Bleeder Screw Leaks
- Brakes locking up after 10 minutes!
- Tein Flex Z thoughts & experiences
- Fn2 2010 civic shock absorber swap issue
- 01 Acura Integra GS Rear Brake Piston Seized
- 95 Civic SI Budget Rally Suspension Ideas
- 2012 -15 Civic Knuckle Assembly
- Looking to refresh my bushings - Energy Suspension still the go to?
- Civic SI FR and RL brakes wont bleed right.
- Clicking noise coming from caliper while turning
- Integra Suspension Suggestions for $1500?
- Accord / TSX CU2, correcting rear negative camber?
- Coilover compatibility
- 3rd Gen Civic suspension
- Early 2000s MacStrut full travel
- Rear McPherson Strut Suspension
- PS Fluid in Brakes
- Removing Suspension Bushings with press
- Which Springs for my Koni Ground Control Coilovers
- Interesting rear brake setup using motorcycle calipers
- Need advise about Honda civic 1990 dx suspension
- What spindles can run a bigger diameter rotor?
- PCI Front Upper Spherical Camber Arms
- Stabilizer link how much to tighten it
- Camber kit - Megan Racing vs K-Tuned vs Hardrace
- spoon twinblock - removing spacers 4x100
- 2008 Honda CR-V Toe Alignment not adjusting
- Rotor and Brake Pad Wear (How do they look to you)
- Brakes dragging bad when hot
- air bag or coil over suspension for an Accord?
- Replaced master cylinder twice and now no brakes.
- 8th gen HFP suspension question
- brake question
- 5th Gen Prelude Brake Upgrade: TL Brembo vs. SPOON S2000
- CIVIC EK3 SUSPENSION
- Larger Brake Pistons 46mm vs. 38mm/43mm Effects??
- Air In System From Gravity Bleeding Brakes?
- Ball Joint Boots OK ?
- Master Cylinder Channel A&B to Prop Valve Locations
- RTA Bushes that can allow toe arms to be deleted?
- Front sway bar EG DC2
- Fitment Issues With Wilwood Rear Brake Kit
- Best Coilovers for EG
- 1993 Civic EX - ABS Light Code 1-2, Blowing 50A ABS fuse following brake job
- Pic coilovers
- Am I able to run my car with forks rotated 180 degrees?
- Brakes losing vacuum?
- Fastco performance springs
- Spoon rigid collar issues
- SS brake lines compability between 5th and 6th gen
- Fender and Wheel Allignment off?
- Best way to add static caster on EG/DC2 chassis?
- No one can figure out what's causing the suspension popping noise in Honda Fit
- 2010 SI Brake Master Cyl Upgrade
- 92 Eh2 Hatch Rear Disc Conversion Issue
- Weird noise when I slowly take off 95 civic
- Do coilovers need to be at the same height from left to right?
- CD5 Brake Rotors/Kits
- Thoughts on KW V3?
- Front coilovers don’t fit fork
- Suspension gurus: Uhmw bushings. Dc integra
- Do polyurethane trailing arm bushings limit toe adjustment?
- TL Type S Brembo's on the rear of an EK?
- I cant find 85 mm rear control arm bushings for a 90-93 Integra! Please help
- Bolt that attaches soft brake line to shock
- What should I know before I lower my car?
- Pics from where you have replumbed your brake lines?
- what front brakes rotors do we have ?
- Affordable coilovers for a daily?
- Does anyone know what these fit?
- Recommended spring rates? 95-01 CR-V/96-00 Civic
- good brand recommendation for replacement Control arms and other suspension for EM1
- Da9 suspension problems
- Manual steering rack
- Looking for suspension parts 1994 civic
- Replacement struts and springs
- 95 Civic EX Coupe suspension rebuild
- Upgrading to Willwoods on stock wheels
- What is this scraping sound?
- "Drop" Style Rear LCAs?
- Stuck knuckle on lower control arm
- 2012 Accord V6 Suspension
- RSX weird brake issue - help
- Complementary Strut bar that works in conjunction w OEM Integra Type R Bar
- Best front and rear sway bar size? Running Ohlins DFV Coilovers
- Car is crooked, need help
- Suspension
- Caliper identification and uneven brake disc wear
- What part are needed to replace?
- Help??? Bleeding brakes
- Coil over replacement part?
- Does anyone know the dot/paint colors of OEM EK9 Type R Springs?
- Can the CL1 handbrake spring clip fit on a 99-00 Civic EK ?
- seized outer tie rod end joint
- parking brake not engaging on passenger side
- Finding break specifications for a 1981 CG110
- 2001 Honda Prelude Tires Rubbing
- Replace steering knuckle for ball joints
- Brake Master Cylinder Rebuild Kits
- 2019 Passport... Touring
- Polyurethane Strut Mounts...DIY?
- Proportioning Valve for a JDM Honda crx del sol with B16A Engine
- 1993 DA Integra rear strut id
- EK - K24 w/ JDM ITR 5 Lug conversion
- 96-97 ITR brake rotors
- Car making clanking/clicking metal sound
- Integra bad brakes no abs
- JDM ITR on an EK - worth getting a big brake kit
- Loose/Random Steering
- Brake booster delete kits. Important info
- Need help fixing brakes
- Seeking tips on adjusting parking brakes
- 91 integra rear suspension issue
- What caused (How to avoid) the grooves on brake disc rotors and pads?
- Rear Camber adjustment using washers (how many to use)
- Slotted Rotors be Resurfaced??
- cut springs questions
- Whats your opinion on slipping camber plates?
- Share my rust removal experience from real brake backing plate and hub
- Please help identify mysterious "sliding surface (B)" in parking brake shoe assembly
- TRX300FW Quad query
- Budget EG hatch Coilover & Shock ideas
- Brake hardware questions
- Hardrace Hardened Rubber Bushing Set Opinions
- Please help with a couple of brake caliper questions
- Please help with a few brake assembly questions
- Recommended Replacement Brake Calipers
- 95 accord abs issue!
- Please help me save my lower control arm and ball joint
- Im in need of some help
- Why service manual wants new castle nut on lower ball joint? Is it self-locking?
- Coilover options for EK hatchback
- 96 ITR brakes questions
- Do I need to replace the boot on this tie-rod end ball joint now?
- Issues installing Power Stop Drums
- Brake upgrade on my 93 EX autox/track day car
- New sway bar bushings: grease?
- 2021 Honda Civic Hatchback sport
- Help, need advice on suspension!?
- Honda biz 125 dampers
- What 15 wheels will fit a 6 piston dynapro wilwood bbk?
- Plz help identify
- 40/40 proportioning valve options
- 92 Hatch - Floorboard bent - Driver side Camber issue?
- String Alignment Questions
- 2019 Honda Civic Sedan - Squeaking noises
- Ek civic with prelude booster
- EG strut mount and Insulator
- So I may have fucked up....
- Max height coilover adjustment
- Desperate need for new rear struts
- Is Function7 still around?
- MaXpeedingRods Coilover review on my budget hatch
- -3an to m10x1.0 QUESTION
- HOW CAN I FIGURE OUT WHICH PADS AND ROTORS I HAVE
- CIVIC EG 4040 PROP VALVE QUESTION
- Ground controls coilovers HELP?
- OEM/Comparable Strut shopping for 2Gen Honda CRV
- type r suspension help ?
- Anybody have a picture of a OEM front strut mount for 92-95 civic ???
- can you hack lower front shocks into forks?
- Anybody Using Oem dust covers with Koni Yellows and Ground controls??
- Rear brake disabling
- Hello I’m converting my ek to 4x114.3 all around.
- 2000 EX. Si springs & Shocks work?
- Questions about new coils/shock setup
- Tips You Must Pay Attention To Before Replacing Coilovers
- Coilover Recommendations for Street Use
- Changing spring rates
- DC2 GSR (4x100) Hubs on 96spec ITR (4x114.3) rear trailing arms?
- Brake pad replacement
- Big brake ITR swap...Mushy pedal now
- Chassis Ear for Noise Diagnostics
- spline conversion 26 to 28 on output shaft
- need help getting 1994 wagon straight tires
- integra GS-R Springs + Konis yellow Sports
- squeaking noise from relatively new struts (CR-V)
- 15x8 +32 205/50 on lowered DC2... Camber Kit needed?
- Best spring rates for mostly track driving
- Vibration
- 7.5 inch rims instead of 7 inch
- Upgrade brakes
- ksports kontrol pro coilovers
- Help! How to fix the coilover noise!!
- Front end clunk
- Suspension Settings - Mild Street
- Honda Ballade Brake Pads
- HELP rsx suspension interchangeability
- koni yellow + itr springs (softed adjustment)
- ITR: help for spring lenght.
- Integra Type-R 23t Caliper Brackets same left/right?
- Benen X-Member Lower Brace on Civic EG w/B-Series Swap?
- Bad torque steer with new wide tires
- CRX Brake Bleeder Thread Size
- Noise when I start braking
- Sideswiped (smacked against curb!)
- Integra Master Cylinder Differences
- Camber and pulling issue
- extended top hates on tein basics
- Booster Delete Master Cylinder Size
- Lemforder suspension parts for our Hondas
