View Full Version : Suspension & Brakes
- alignment
- Can I get a manual rack??
- What are some good rear LCA's to get?
- --Quick Question- EG Hatch, GSR sway bar---
- Pillow ball mounts
- suspension for honda jazz
- problem..need help!
- Corner Balancing
- Please help answer some questions.
- my car pulls to the left...
- Will Rotas bend While Auto xing?
- What is that magnetic wire on rear disc brake?
- spring rate ques.
- blown apexi ws dampner
- Haveing trouble installing camber kit on 99 civic
- Sway Bar Problem?
- first start of GCs & koni yellows???
- not really sure where alse to ask about tire size question
- camber kits....wut the deal
- ????Tokico gas shocks and Eibach coilovers????
- Need Advice On: Dialing in Suspension & Swaybar Selection (Searched)
- tokico HP's with H&R sports
- Koni Sport Kit vs. GC w/ Koni yellows
- Need a good camber kit for my really low 91 hatch
- New front sway bar
- 17's with a 2" drop?
- Steering Ratios
- Can you set rear toe in on a civic?
- Suspension spring question.... need advice
- does anybody have the new skunk2 full coilover
- bilstein's
- What shocks?
- Has anyone tried the Tanabe suspention?
- Caster problem... help!!
- Aftermarket trailing arms for EG Civic?
- any one use one of these before Link/pics
- Anyone Re-valve Teins Yet?
- ground control coilovers good?
- right spring rate?
- del sol lowering problem
- 3rd gen Integra Suspension Alignment Adjustment Points
- Omnipower coilover height problems
- What is the cheapest place on internet to order Eibach Sportline Springs ?
- ebay wheel spacers
- Cusco's, or the OmniPowers... !?
- suspension help
- Need help with suspension
- tire pyrometer?
- ej8 suspension...
- Omnipower Pillowball Mounts Pics
- What tires to run with my 16" rota's?...need opinions
- KYB AGX Question?
- 90 crx suspension work in any other year civic?
- opinions on Koni Yellow and Eibach on Del Sol VTEC?
- Where to purchase hardware for ITR rear swaybar?
- Weapon r pro circuit- sorry BOUNCEAROUND the circuit coilovers!
- help with noises
- How low is too low
- Alignment Question
- Cornerweight, preload and height adjustment: how are they related?
- New to the 15" world. So what tires?
- Tein SS for a EG fit a DC?
- steering swap power to man.
- Inner tie rod boot broke, need advice
- Brake flush?
- Neuspeed Rear Lower Tie Bar Install
- Rear Body Roll issues w/ KYB AGXs????
- BFG Scorcher tire ?Good or Bad
- I'm dropping too low! Neuspeed Race Springs...
- H&R Sports / KYB AGX harsh on smallest bumps?? 5th gen accord.
- Front lower control arms/swaybar??
- coilovers
- Suspension...
- Clunk when First accellerating, and Braking...?
- General Q for Tein Basic Owners
- Suspension Techniques Sway Bars (help)
- Rear coilovers in the front?
- Cost of frame straightening?
- spring rates
- accident and susoension question
- Tokiko illumina and Neuspeed?
- need help removing lug nuts
- GC's for Koni Yellows only?
- Front clunk: detailed description of symptoms... test your knowledge here!
- Does a RSX 5-lug (Brembo) fit a DC2 Integra?
- squeaky suspension
- Tokico illumina coilovers
- GCs w/koni yellows or omni full COs??
- h22 suspension on a eg hatch
- Airbag Suspension
- Cusco Control Arm Brace
- Please help me!!!! ASAP!
- swaybar for my DC
- HELP!!
- Need help putting on 5 lug on my teg.
- Steering Rack Replacement..................help
- Question regarding koni's
- Higher-end coilover choices
- eibach sportlines w/ tokico whites on a 6th gen coupe... Thumping?
- Best upper A arm camber kit?
- will type r shock fit 97 integra?
- Strut Question?
- 22mm+ rear sway bars?
- Omni-power springs, here is what Omni told me:
- your drop
- I am sick of researching MAC DADDY rear sway LCA combos
- tein flex + edfc?
- ARP studs in EH2?
- eg susp help
- has anyone tried the new skunk2 coilovers?
- tokico blues with ground controls?
- Question about Civic front upper control arm??????
- Differences between OE Honda endlinks and Heim endlinks?
- What shocks to get with H&R Sports??
- ITR Suspension help
- Yonaka coilovers
- Camber...
- inverted shock mounting
- Alignment settings
- Did I get everything?
- 94 civic ex – really need some help here - got screwed over
- what is the best suspension not to bounce around in????
- Need some help with my koni yellows
- rattle from right front tire?
- brake question , is that ok?
- rear subframe damage on a crx
- Apollo Coilovers: 12k front,8k rear.......
- tire size to gas mileage?? 99 em1
- EK Rear Brake / Suspension bolt broke - Anyone been here?
- rear end feels light
- ES Bushings..
- which springs do i need?
- RTA bushings
- Occasional Autox plus street confidence...
- Tein SS Coilover Drop
- JMD Adjustbale Coilovers??? Help pleaze!
- Source for 2.25" ID springs?
- fixing rims
- Car needs alignment bad.. QUESTIONS
- coilover help please
- Front sway bar Question?????
- suggestions for good tire for Si wheels
- how do i replace INNER part of tie rod ('00 ITR)
- anyone in SoCal lower my car?
- quick question?
- problem with alignment what are my options?
- -2.7 camber..how long will tires last?
- Question about the Beaks subframe tie bar
- Ground Control spring rates?
- strut bar adjustment question.
- Intrax
- JDM / USDM DC5 Same Suspension Setup?
- budget suspensin recommendation
- How to raise my car 1/2 inch?
- Bump Steer and Tilted Tie Rods
- What to measure on 98 Accord to check for body/suspension clearance?
- 97 civic A arm swap?
- Help with ST front/rear sway install on 98' civic EX
- Questions about ITR springs
- installed new trailing arm, not car is higher on passenger side...?
- Omni power lca
- Any good tires for the VX rims?
- koni yellow's question so i dont mess them up or void the warranty
- ST adjustable 22mm rear bar mounting methods for 88-91 civic/CRX
- whats the best handling honda ?
- Did any Honda/Acuras have a 5 x 100 or 5 x112 bolt pattern?
- In a gc coiler what is the difference in using a 8inch spring to a 7inch spring
- Little Problem with Koni Yellows
- progress bar safe for your subframe??
- What springrate are 92-95 civic groundcontrols?
- Dual Coilovers?
- Sway bar bushings
- OT- Job opportunity in Koni Service Center
- need setup for bouncy roads.
- 5lug swap question
- Work Lugs Vs. Rays Lugs
- Axle Problems-------????????? Can someone help?
- Rear sway on civic VX, yes i searched!!
- GC springs....semi-progressive??
- Just wonderin'
- Lugnut ?
- stock struts on lowered EJ1?
- Rear Strut Bar Noise
- Question about Ground Control top hats...
- Koni Sport kit, what else?
- question about my tokico blues
- Question about GC coilovers
- question about lug patterns
- Omni or GC/tokico
- Quick strut bar fitment question....?
- Tenzo Big Brake rotor upgrade kits?
- can"t choose
- problem with perch on ground control coilovers
- Accord struts on a prelude?
- best struts for neuspeed race springs on 92 civic hatch??
- Tokico Blue Kit life/problems
- LCA Question?
- Blox rear sway bar?
- Will lowering affect toe?
- Swaybar recomendations(for my spring rates) 92 civic hatch
- What should I do???
- Help/Tips for a Mcpherson strut suspension setup
- what coilovers should i buy?
- Suspension setup?
- Ingall Camber Kit problem!
- Arospeed Coilovers Suck...See Inside...
- Adjustable or Not?
- help me pick out spring rates for my Integra
- rear camber problem!! help please
- I would like to say thanks to CRX Lee!!!
- Mixing springs.
- Tokiko shocks warranty
- Hub Nut size for 92 honda civic
- Choosing spring rates
- Time to replace my springs?
- Koni yellows-what stock parts do i need aside from the cap?
- Nice Rack.
- question to decide the best system for street use
- Corner Weighting -- how many coilover guys do this??
- How To: Asking Suspension Questions
- Difference between EG and EF suspension wise
- Need some suspension advice – 1993 eg coupe – tie rod and other ?s
- help squeaking...blown shocks?
- Omni Power coilover install- Ride Height screwy
- 91 crx hf suspension help
- Some Basic FYI on camber correction
- need advice, which setup.
- Are my Rotora's on the wrong side???
- Coil over adjustment - The install gone to hell?
- Question about ST sway bars for the EK
- Alignment really necessary?
- Lower 19mm bolt is welded in the rear struts
- Keeping my car straight
- Axxas coilovers?
- searched: will "H" or "A" center caps fit rotas? n/m
- Sound from shocks
- Tein S. Tech springs VS skunk2coils+tokico illumina shocks
- EDFC EK compatibility
- GC or Skunk2
- can eg springs and struts fit ek? kyb agx sportline springs
- ball joint/control arm help
- susp. help
- Eibach Anti Roll Bar kit won't fit 2000 Si. Help!
- any difference: ITR/GSR/LS/RS trailing arms?
- Traction bar help
- custom axle length
- Ohlins shocks/struts
- Omni Power camber kits used by SCCA Pro teams?
- Shaking of steering wheel even after balancing.
- gsr suspension on a civic dx
