View Full Version : Suspension & Brakes
- Civic full coilover kits?
- 90 EX Accord Alignment
- DA upper control arms
- Replacing front cross member
- installing ksports at home
- Koni/GC H-T kit or buying separately
- stripped adjuster screw on AGX Help!
- How do you install LCA's in a DA??
- Adjuster arm
- Where To Get Aftermarket Sway Bar Links for 98-02 Accord
- camber kits
- Lowering Question
- Any comments on Ractive Tower Bars?
- H&R Sports on EbaY Sleeves???
- will da sway bar fit eg............
- what is the best spring to go wit?????
- Camber Question...
- Can you convert to EK UCA's on EG?
- air cylinder problem....need help
- Need help and info? 98 EK hatch civic
- TEIN COILOVER KIT?
- struts squeaky sound! help!!
- CTR sway bar on EG?
- used shocks
- Two choices
- omni/megan LCA work with ITR rear sways? Also should i add ASR subframe plate
- Tokico Blues with GC
- rear disk brake help asap!!!!
- ground control trouble
- rear disc conversion
- Biggest sway bar on EH?
- Skunk2 Pro-Series for EK
- 1993 DA Integra...Need advice on springs/struts...
- 98 Civic Dx Hatchback UGR Coil Overs any good?
- what exactly are pillow mounts?
- Gsr rear lower control arms on Ek?
- good camber kit for 89 crx
- Eg Coilover Install
- tein ras on eh2????HELP???
- tein ras on eh2???HELP?????
- GSR front disc conversion on a ek?? will everything bolt on??
- tokico blues skunk2 coilovers on my eg hatch?
- Installation on Ksport's for a EK ?
- Want to be 2.5" lowerer. Please advise...
- need help or info on camber kits
- GC Springs w/ KYB Shocks....
- how to replace rear end link bushings?
- Koni yellow fronts stock rear how about that?
- Function and Form coilovers and LCA on ep3
- Koni leakage, cant adjust dampening
- how to get a street car to hook
- can any other civic and integra springs fit ef9s?
- drilling holes in your lcas
- Koni shocks
- EF alignment question
- ef traction bar opinion's
- ITR suspension on Del Sol
- skunk 2 on tokico
- best way to torque down LCAs..
- rear camber corrections for cheap and for all rides.
- 88 Accord suspension advice....
- What lowering springs will fit my MDX?
- Suspension question - ITR springs on EM1 chasis????
- What setup should I use???
- whats a good suspension setup for my EG hatch.
- Where can I get 2.5" PERCHES?
- HELP! MY EF/TYPE R NOW HAS UNPREDICTABLE HANDLING
- Questions about Suspension hardness and height
- Suspension Guru's
- Trying to put on Skunk2 Coil Sleeves on stock shocks
- Camber and tire wear question...
- type r box lca's on DA cuase problem with sway bar?
- Structural Foam Injection
- Questions on what to watch out for when installing F2 Coilovers
- toe arm?
- Help me with this problem, wheel bearing possibly?
- Track Whores Help / Front Sway Bar eK Hatch
- Coilovers!!!!Help ASAP
- how do i find someone to replace my rear trailing arm bushings?
- Rear Trailing Arm bushing remover, for rent?
- ? about Skunk2 Pro Series Full Coilovers
- A-Spec Racing - Website
- spring replacement gone horribly wrong. NEED HELP!!
- Setup questions
- Eg Spring question
- NEED HELP 12mm versus 10mm collar top mount insert
- need advice fast (spring rate related)
- 97 civic hatchback suspension
- 95 EX Speed Wobble
- omnipower vs skunk2
- Something's Loose!!!!
- need help with 92 hatch suspension?
- tein HA q`s??
- Rear shock/spring question
- how do you remove the rear hub dust cap?
- Rear Strut Bar Question
- Help... with height
- Recommend me some cheap shocks & springs for my accord 95 lx
- traction bars
- Suspension Noises
- strange body roll, eg hatch
- Endlinks for rear swaybar on an EG w/GSR control arms...
- h&r race springs 94-01 integ on 98 ek
- Tein Basic Questions.. help!
- Stock Rotors vs. Cross Drilled
- eibach and sprint suspension
- vibrating front end at 50-60 mph
- Thinking about changing from my GC/Illuminas to Koni's/gc's, or maybe tein flex
- c pillar bar ?
- Best ride which lowering springs
- installed springs...uneven drop?
- New wheels on lowered car... help
- dont know what struts my GC's are made for???
- buddy club n+ spec dampers cost prices?
- where did u get your tein ss and how much did u pay?
- Camp1320 Stainless Steel brakes lnes, soft then hard feel, this ain't normal
- cusco sway bushings
- benen rear strut bar
- Issues With Tein Install?
- Rear Disk Conversion On EG?
- what springs/coilovers should i get?
- Suspension noise
- best deal for blues?
- Rotor and pads doubts
- Tein ss for 97 accord question
- Adjusting Lower Portion of F2 Coilover
- TEINs EDFC
- how do i install engine strut bar on a 04 si?
- Tein Type HR??
- creaking noise after lowering.
- Good setup for a 96 Civic
- blow shocks
- skunk 2 coilovers on koni yellows?
- Want to lower a 97 acura EL ?
- question on ingalls camber kit
- Suspension Choice.....Really that hard?
- spring rates on 2001 integra GS
- Legit?
- Function7 Endlink & Stock LCAs - any issues?
- H&R race springs for integ on a civic
- good setup for turbo car?
- Personal Experiences with Koni 2812/Penske 8760/Moton Needed
- DC5/EP3 Owners: TEIN FLEX TOO BOUNCY?
- dc2 and ek9
- any comments on intrax springs?
- gsr tein springs on 96 hatch
- Question about Buddy Club N+ Spec Damper
- regular springs on a adjustible sleve?
- Just Got Alignment - Tell me what you think!!!
- Tokico illumina adjustable dial replacement?
- suspension height question
- help tightining nuts for ball joints on steering and control arm
- shocks for my lude?
- stupid question
- tein s techs... do i need struts too?
- type R upper control arm in a 91 crx si???
- Stablizer Links are Grinding Against Shock Body of Coilover
- Tein s tech w/ Tokico blues?
- Adjusting Illumina's, Top or Bottom?
- better eg civic handeling?
- Whats the better combo ? *(Suspension Gurus Unite)*
- AXLE NUT
- Questions about TEIN FLEX
- Camber kit selection
- End Link question
- How do I install GSR Strut Brace on EK9
- sway bars with stock suspension?
- Dampening on shocks/coilovers
- NEED HELP FOR ITR 5 LUG CONVERSION ON EK
- another HELP with choosing my suspension setup question
- omnipower suspension Setup?
- USDM ITR Rear Swaybar on EK9.....
- Need some help...
- Coilovers VS Springs/Shocks...need some help
- EDFC
- H&R race springs and what shocks and struts
- tokico blues on ground control coilovers.
- eibach sprotlines
- Aftermarket bushings....... good or bad?
- Re-occuring Squeak in front suspension--WTF!@#$%
- One side sits lower (lowering springs)
- where do you start when wanting to upgrade suspension?
- itr suspension questions
- k-sport or function?????
- illuminas w/ h&r sports
- optional cusco add in bars?
- DIY engine mount fix...works on trailing arms ?!?
- SPC Upper Control Arms?
- stock sway bar with omni lca
- omni full coilover or tein basics? Also what sway/strut bars would you recremend?
- PIC Performance Coilovers
- Can't raise my front up, Ground Control Help.
- Help needed on Figuring out Spring Rates for performance & daily Driving.
- tokico(5 way adj),kyb adj,eibach pro damper,or bilstein bts sports struts....
- Spring install help which goes in front the longer springs or the shorter springs???
- Question on Spring Rate
- endlinks ?
- civic coupe - how to up the suspension
- Are these H braces from ebay any good?
- Neuspeed Race springs EM1 people
- best EF Suspension?
- Which top mounts for 88-91 crx running skunk2 coilovers?
- best OEM swaybar combo for street in a eg..
- GROUND CONTROL SPRINGS !
- D16y8 motor build help
- omnipower phone #?
- integra suspension
- Bushing replacement Need to confirm some info
- comfortable spring rate for prelude?
- Anyone heard of Function Form Suspension
- Best set-up for a 95 Civic EX
- need help / advice on my suspention build up
- problem with st front sway bar
- noob question about bushings...sorry
- whats the best height drop for an EK?
- how the hell did this happen?
- tokico whites
- civic/integra springs hights
- Civic suspension
- koni yellow/H&R sport 00 Civic
- Spring rate for a 91 CRX Si
- Adjusting Caster
- Kyb agx adjustables with H&R race ?
- Omni Power Camber Kit?
- Function 7 LCA Official weight comparison to stock
- poor man's corner weight setup with bathroom scale?
- ek suspension on eg...will it fit?...
- tokico illumina kit
- need opinion on gc and koni adjustable shocks
- Integra height looking at tein springs
- Function Form on dc2
- how to tighten dampering kit on d2's?
- Clocking bushings
- Lower Tie Bar
- !!!!NEED HELP Installing rear SPC LCA On ma 4dr EF!!!!
- nex coilover?...
- Squeking/Creaking Noise from shock
- Coilover Sleeves :thumbup: :thumbdown:
- Discount on Ground Control site
- ls "top hats" fit itr shocks and springs?
- Stiffer spring rates
- i need coilovers for my 96 EK hatch
- Front Shock - Rubber Mount Missing
- Comptech Swaybar... worth it?
- different length endlinks? how will it effect?........
- Best suspension setup?
- Skunk2 lowerng springs for EK Civic coupe
- Bushings broke...
