Suspension & Brakes Theory, alignment, spring rates....
wheel bearings
Old 04-24-2017, 09:49 AM
mrsdymond0713's Avatar
Default wheel bearings
I recently hit a curb with my front passenger tire. it slightly bent the rim. the front passenger tire is shaky and progressively getting worse. Is this just the rim or will i need to replace the bearing as well?
Old 04-25-2017, 10:15 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: wheel bearings
Well....is it just the rim, or did you damage the wheel bearing also?
Old 04-27-2017, 05:44 PM
DaIll1's Avatar
Quick, easy check, swap with the rear. It's probably not wheel bearing but a bent wheel can cause nuts to loosen.
Old 04-30-2017, 03:59 PM
k3ntegra's Avatar
Lower control arm and lower ball joint may be damaged as well if the wheel bearing is damaged, and you may need a camber kit to keep tires properly aligned even after performing these repairs. Take the car for an alignment and have them give you an measurement before and after the task; assuming your LCA and wheel bearing doesn't show physical signs of damage . You can check if the wheel bearing is in sustainable condition by jacking the car up seeing if the tire/wheel wobbles; there are youtube videos on this.
mrsdymond0713
Suspension & Brakes
05-05-2017 05:43 PM
Unphzd
12-17-2010 01:10 PM
rbizzell30
03-19-2008 12:11 PM
RSD
02-17-2006 01:05 PM
Charlie Moua
09-13-2002 04:56 PM
Quick Reply: wheel bearings
