PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99
  1. groundcontrol coilover problem/question
  2. How low? Zeal B2
  3. 88 crx lower rear control arm vs 89-91 lrca
  4. What type of shocks and spring should i get
  5. 94-01 Teg Neuspeeed springs Fit ek 00 civic???
  6. Question on Caster
  7. Rear Spindle/Hub wieght ratings
  8. ef suspension
  9. Got a question about my springs..
  10. ID these springs
  11. looking for a combo
  12. why is my driver side lower the my pass any info?
  13. coil over help
  14. suspension setup swaybar tiebar combo opinions suggestions EG hatch
  15. Tanabe DF210 Spring
  16. = ride height front to back or ???
  17. da suspension on a 00 civic?
  18. need input Tein S Tech spring users...PLEASE.
  19. need help with my full coilover install please....
  20. gc + kyb agx. please suggest me a springrate for DD.
  21. neuspeed coilovers
  22. nex or omni power coilovers ??????
  23. How much of a drop for an Accord with 18" rims?
  24. Can I use USDM ITR hubs on 96-00 hatch?
  25. Suspension options for 91 ef9 hatch
  26. Are Omni Power Full Coilovers a better set up then Illuminas shocks wiith Tein S Tech springs?
  27. Traction Bar explanation
  28. Does suspension need to be broke-in?
  29. T
  30. Looking for a new setup... suggestions..
  31. Energy Suspension Bushings
  32. CRX/EF Radius arm bushings - I need your advice
  33. ITR Suspension on DA?
  34. high an low question?
  35. Are these any good?
  36. What's a good affordable drop for my Civic?
  37. what could possibly cause my camber to go so BAD w/ my setup
  38. omni street versus sport
  39. Were GC coilovers supposed to come with wrenches to adjust the ride height?
  40. How the hell do I fix this?!? Tacked welded on nut broke off! Involves rear suspension parts...
  41. question with my suspension
  42. Tein RS Dampers
  43. adjusting omni height and spring.
  44. OK... height adjustement problem on the front of my 1995 Si EJ1. Honda guru take a look please :(
  45. Powdercoating Springs?
  46. alternative to ES bushings? Mugen???
  47. koni repair
  48. Omni Power Coilovers any good?
  49. wilwood calipers with aem rotors?
  50. .:: The best combo for street ::. .::Searched many times::.
  51. Zip-tie the brake lines?
  52. coilovers or springs ????!!!!
  53. neuspeed sports, what shocks to get
  54. camber kit installation cost
  55. Question regarding Omni's with no rear sway bar.
  56. Help with Tein part # searched here and tein.com
  57. Comments on my Revalved Koni Dyno Chart
  58. Does ride height affect, ride quality?
  59. Bushing Kit
  60. OMNI LCA Bushings
  61. current suspension + koni question
  62. Looking for performance suspension shop in central Florida
  63. Suspension question.
  64. JDM ITR, USDM ITR and GSR front sway bars all same size??
  65. Owners of EM pillar bar..
  66. spring rate
  67. clunk/pop on acceleration
  68. jurking while on the throttle.
  69. Endless USA Zeal rebuilds
  70. Neuspeed Coilover COMMENTS
  71. 92 bubble w/BRAKE ROTOR/suspension problems. URGENT HELP NEEDED!! please!!
  72. Need help on H&R race springs for 1999 Honda Accord. Please read. Thanks!
  73. integra skunk2 rates + koni reds on a 99 Si
  74. suspension problem
  75. Apexi N1 EXV
  76. Where can i get rear trailing bolts?
  77. KAAZ Lsd going in -> engine mounts? shocks? traction bars?...etc
  78. suspension install cost
  79. omni-power sleeve-overs...where do these black rubber rings go?????
  80. lca
  81. em1 suspension q's, tein ss's
  82. Never ending NOISE
  83. just got new car check out the "custom camber kit"
  84. Sway Bar Woes
  85. please help..tips on making car sit level with coilovers
  86. Koni RSK kit question
  87. Sprint Spings Install.
  88. Looking for someone in NJ with a press
  89. Settling Sway?
  90. omnipower vs. d2 full coilovers.
  91. Tein SS - HKS Hipermax - Omni Power
  92. where to buy springs NY(queens area)
  93. whats better (camber kit wise)
  94. quick and fast answer
  95. suspension help
  96. Bought used Neuspeed Race Springs and it has slight rust on it/paint chipped off.
  97. Dropzone Struts and coilover!?
  98. Apexi- 2005 N1 Exv coilovers ^ or V
  99. Stress on the Rear Subframe during hard driving?
  100. Koni Yellows + Coilovers.....where do you ride?
  101. Will Koni Yellows work with Skunk2 coilovers?
  102. Anyone do at home alignments?
  103. shocks for a 2000 prelude
  104. Rear sway bar blue paint/marking, in relation to car movement
  105. ok, please just tell me (searched)
  106. omni, warranty/spring rates
  107. Are these struts blown or not?
  108. HELP! ES100 in 195/55/15 or 205/50/15?
  109. HKS Hipermax VS Omni Power
  110. accord coilovers on a civic???
  111. WARNING: everybody with the SRR sway/tie bar combo look here!
  112. gsr vs ls suspension
  113. Traction bar help on 96 Civic DX
  114. springs
  115. Eibach ERS Potenza Coilovers
  116. Benefits of going to stiffer spring rates?
  117. Will any of the following suspension compontents from DC4 bolt into EK?
  118. Quick question about wheel stud
  119. stuck lug on rear hub
  120. How you stop wheel hop
  121. What would you pick??
  122. gold line springs
  123. -- Everyone look, I seriously need help.... --
  124. Integra koni yellow on Civic??
  125. Camber Kit Question
  126. Help me narrow down what suspension for an EK
  127. Acura CL extended top hats
  128. Suspension for my GSR
  129. Omni Streets Full coilovers Stiff enough for type r sway w/beaks
  130. Sprint Lowering Springs?
  131. which coilover is best for H22A eg sedan?
  132. Extended wheel studs needed?
  133. WILL IT FIT or no!!!!!!!!! help please
  134. tein basics are bothering me....suggestions on new setup?
  135. Quick Quick Help P/N Please. I have the part numbers, 88 Crx
  136. Should I return this Koni strut?
  137. Alignment Question????!!!!
  138. Problems removing the lower ball joint (Do I need to remove the wheel bearing?)
  139. Si springs on an Integra?
  140. bushing replacements
  141. ....Castle nut socket size for 96-98 civic......
  142. crossbars?
  143. Axle replacement NEED HELP
  144. Newb question, what shocks?
  145. brake setup pricing
  146. Do these sportlines look right?
  147. GC coilovers with KYB GR2...good match???
  148. Stripped subframe bolt hole - Suggestions?
  149. Tien difference
  150. ITR Sway Bar for a DA/EF
  151. Parada Spec 2 or Falken Azeina RT-215??
  152. wheel wobble
  153. know an alignment shop for dumped cars in socal? (714)
  154. What spring rates are good for AGX/22mm Combo?
  155. Koni 8041 OTS RACE shocks!!!
  156. front lca
  157. gc coilover installation
  158. Tein S-tech vs Eibach Prolines?
  159. To Prevent Wheel Hop What Can I Buy
  160. Rear Strut Bars functions??
  161. Zero toe theory???
  162. eg Big rear rotor non-abs
  163. Post suspension mods that aren't street legal
  164. Omnipower Coilovers (sleeve-type)
  165. Purpose for C Pillar bar
  166. Adjusting Koni Reds
  167. A-spec racing ownS!!!!!!!!!!!!!!!!!!!
  168. question about custom spring rates, and why my car wont sit low, possibly because of weight reductio
  169. Tanabe Pro SS, Buddy Club Racing Spec Damper, JIC FLT-A2, or TEIN RA.....What would you recommend???
  170. omnipower coilovers with kyb agxs?
  171. CRV suspension
  172. 96-00 on 92-95?
  173. I already did the spring/shock thing...what else?
  174. Tanabe underbraces and rear strut bar
  175. ATTN: DA's with Tein S.Tech Springs..
  176. Energy Suspension Master Bushing kit Question....
  177. DIY top hats will it work?
  178. Handling Questions....
  179. Lowering spring question
  180. Interesting Suspension Discussion
  181. Drive Shafts on a 92 Civic
  182. KYB GR-2 Gas Shocks. Descent For DD? Quick Opinions
  183. Can an integra ls handle good?
  184. Cheapest Place for KYB AGX for EG?
  185. 90 crx si coilovers on 97 dx coupe
  186. 04 ex rims
  187. APEXi WS DAMPERS VS. NEW OMNIPOWER FULL SUSPENSION
  188. What would happen if you put RWD wheels on a FWD car?
  189. striped strut need advice
  190. Question regarding Tokico shocks for '95 Accord EX
  191. suspension ?
  192. First Drop: need help
  193. top shock mounts bushing on a track car?
  194. 94 civic hb
  195. Omnipower Slips
  196. Wheel nuts for extended studs...
  197. better struts
  198. best coilover sleeves with stock shocks
  199. I am looking for stock integra suspension
  200. any body heard of these coilovers
  201. Does strut bar really help?
  202. cheapest place to buy tociko blues????
  203. 96 EK Hatch, camber and toe settings for street use.
  204. Measuring spring rate?
  205. Need some advice on my 92 Civic Si Hatch suspension
  206. DIY? X Bar
  207. Tein S-Techs and 2004 Accord Coupe
  208. Preloading ?
  209. Noisy Upper Ball Joint...safe?
  210. aftermarket suspension 4 89 prelude?
  211. tie rod/ball joint help
  212. Welding sway bar to endlink?
  213. tein s tech springs on EG civic...???
  214. 90 CRX lower control arm.. help
  215. itr swaybar and beaks kit but what susp??
  216. Gab revostroke question
  217. I need to STIFFEN my rear springs!
  218. Shock hat extension, how much before I hit the hood?
  219. First impression: all polyurethane bushings and 22mm sway bar!
  220. Bumpstop question
  221. Ground Control Question
  222. putting on camber kit and have question
  223. tear out problem
  224. Hi all! Need Suspension Advice.
  225. Please try to answer this question for me
  226. Need advice on Koni Yellows and ebay "Ground Control" coilovers
  227. DIY top hats...where's the thread?
  228. Caster Discussion
  229. Suspension Technique sway bar kit ( front+rear ) please read
  230. 94 si vs 94 gsr susp Need help
  231. diagram: WTF is up with my coil over springs?
  232. Aluminum Rear Lower Control Arm
  233. jsut bought front and rear disc convertion from passwordjdm.com
  234. Arospeed Coilovers or tein s-tech
  235. Switched spring rates, worth it if i can?
  236. Tohatsu SWIFT springs: anyone use them or had used them?
  237. help: omnipower full coilover manual
  238. Where to get lock rings for Mugen/Showa N1 coilovers
  239. Where to find H&R Cup Kit for cheap?!
  240. BEAKS KIT??????????
  241. Stockton, CA- ** where to have wheel hub pressed ?? **
  242. KW Coilovers, anyone using them?
  243. coilover vs progressive spring
  244. BEAKS kit safe?
  245. strut bar q...
  246. Clunkiness in suspension-Help plz
  247. recommended 215/45/r17 tires
  248. My suspension delima -coilovers/combos/etc.....thoughts?
  249. AXAS COILOVERS DAMPERS
  250. reinstall sway bar w/ omni full coilover problems....
