PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. what suspension to run on dd em1?
  2. just bought a ej1
  3. Pillow ball help
  4. Help with Del sol suspension
  5. camber issues.....
  6. Subwoofer having effect on ride height...
  7. ground control height/ preload adjustment
  8. BLOX camber kit installed on EM1 ... Now has grinding issue froms something rotating..
  9. Braking issues
  10. ///To All Spoon Twinblock Owners...///
  11. Tein click assembly install
  12. Please Help!!! Best Coilovers...01 Civic LX Coupe...New to car tuning
  13. HELP! Installed New UCA, Shocks, Ball Joints with same parts...Now UCA hits shock tower!
  14. need suspension
  15. tockico vs skunk2
  16. non honda brake fluid.
  17. OEM Part Number for 23mm D Bushings
  18. DC2R - GC Setup, spring not captive?
  19. How can I keep my Koni Yellows from rusting and corroding? rust corrode corrosion
  20. HELP: EK4 Coupe/EJ8 Rear Sway Bar Hitting Exhaust
  21. integra suspension set up
  22. Ek Hatch 98 ASR Subframe + Swaybar
  23. drop/rim clearance question
  24. how do you adjust strut tower bar preload?
  25. life span for kyb?
  26. Has anyone done business with SPEEDEPOT.com?
  27. what integra parts to put on my hatch??
  28. Just bought some tokico illuminas :(
  29. thumping noise on rear tire
  30. Good suspension?
  31. Is it true?
  32. EK Front Lower Control Arm Problem ... please help
  33. BEST COILOVERS FOR GSR???
  34. no shock travel on koni/gc setup EK?
  35. Ground Control + Koni Yellow or Skunk2 Pro S?
  36. ITR master cylinder
  37. using evo brembo brakes? anyone done this?
  38. CTR Conversion: Would i be able to use EG/EJ Suspension?
  39. SPC upper control arms ... Stripped adjustment nut. HELP
  40. I wanted to buy PIC coilovers...
  41. Need some PIC reviews
  42. K sport kontrol?
  43. question on coilovers??
  44. Press dyes...
  45. skunk2 adjustable coilovers
  46. good cheap suspension
  47. skunk2 shocks
  48. I dont like Skunk 2 w/ Tokiko blues, anyone know about skunk 2?
  49. ground control w/ koni yellow ADVICE QUESTION.
  50. camber kits 92-95 civics?
  51. Looking for DIY suspension install post
  52. Energy Suspension RTA bush install
  53. I REALLY HATE MY GC/ILLUMINA SETUP
  54. extended tophats
  55. Anyone installed polyurethane bushings?
  56. spring rates for racing an eg/b18 hatch
  57. Blox front sway bar anyone done it the 24mm?
  58. ITR rear sway bar on an LS: ITR or LS/GS/GSR endlinks?
  59. Rear sway bar and adjustable end link help
  60. Omnipower sport review.
  61. Need help with my eibach coilovers.....
  62. HELP slamming with ebay coilovers (stock shock trick?)
  63. Is it possible to make..
  64. what size tires
  65. Extended top hats cause drop in ride height?
  66. PIC Apex coilovers for my 4 door integra
  67. Tein Basics..
  68. Please help me diagnose a suspension problem on my gs-r
  69. dc tein superstreet on a eg
  70. 94-01 integra tein superstreet damper on eg
  71. What Next???
  72. need opinion for prelude
  73. Are 96-00 and 92-95 civic dx front knuckles the same?
  74. Dropzone struts/springs...
  75. ***UPGRADED BRAKES**1st gen si rex what fits?
  76. honda oddesy 5 lug
  77. Whats a decent suspension setup for under $600
  78. any way to get more + caster?
  79. 96 spec itr conversion
  80. Looking for help with Koni/GC install
  81. Control Arm Question
  82. progress camber kit
  83. HELP ?????HAVE A QUICK QUESTION
  84. lowering integra ls 98 on stock shocks
  85. Rumor has it...
  86. Tokico Illuminas with what springs.....
  87. brake squeal, but pads are still good?
  88. NEED HELP REAR CONTROL ARM!!!!
  89. would these springs fit my integra?
  90. EM1 Spring/Strut question
  91. caster question
  92. Rear sway bar size help???
  93. 00 ex-H&R sports w/17 rims
  94. tein flexs or jic flt-a1
  95. Set up for street and track any sugestions??
  96. 92-95 hatch and 96-00 coupe stock spring rates compared
  97. Civic 98 Hatch Coilover problem
  98. Weakened rear trailing arm?
  99. omni preload; is it necessary?
  100. ASR subframe plate with Comptech sway/tie kit?
  101. sub frame
  102. getting ready to replace all my bushings, Hardrace or Energy Suspension
  103. 25/22 sway bar set up or 25/19
  104. Drag Racing Suspension Tuning question???
  105. too slammed... axle problems?
  106. Swift sport springs? oppinions?
  107. GAB Coilover
  108. Basic DIY for spring installation?
  109. Comfort Quality ride with Proper lowering Setup
  110. Need help
  111. New suspension set-up.
  112. Civic Spring
  113. From blown cheap suspension to what?
  114. Would it be possible to have stickied or tutorial images stored here?
  115. Can someone help me find a shock or coilover for this revalve project?
  116. got new rotors/pads...situation...
  117. Ball Joint question
  118. hey guys
  119. front suspension problem!
  120. Is this a decent set-up?
  121. DA Suspension Poll
  122. Ksport Kontrol Pro Fully Adjustable Coilover...What spring rate?
  123. HALP! My adjustable collars seem to be stuck together... or I'm weak. :(
  124. Shocks/Coilover Sleeves vs Full Coilover
  125. BOLT PROBLEM FROM MY INTEGRA HELP PLZ!!!
  126. Benen rear lower tie bar, need longer bolts?
  127. skunk 2 shocks
  128. looking for a small drop
  129. Wheel spacers?
  130. what suspension to buy?
  131. Tein Type Flex are spongy fronts only
  132. help with struts
  133. suspension opinon
  134. Simple question: Can I adjust Skunk2 Pro S's while car is on ground?
  135. Suspension Help
  136. Skunk 2 Front Camber Ball Joint Issue
  137. B-Pillar bar install(BENEN)
  138. 94 Hatchback semi-track suspension setup help.
  139. Replacing Cv joints
  140. suspension fab?
  141. suspension overhall need part info
  142. Looking to lower, any suggestions?
  143. Rear end getting loose
  144. extended studs question
  145. springs and coilovers
  146. Strut Fork Interchangability Question
  147. Function & Form Preload
  148. Need help....on ground control and koni setup??????
  149. Accord with Integra steering knuckles?
  150. Inner tire bald. Toe was set at zero
  151. Pic request: Skunk2 lowering springs.
  152. have swift springs with spring perches, can i use tokico blues with them?
  153. Eibach Sporline / KYB GR-2 Question.
  154. Tein SSP Pillowball coil over issues.
  155. HSD coilovers review?
  156. will 92-95 civic OE springs work for 96-00 civic
  157. Does this look like a good deal?
  158. homemade tophats????
  159. Will These Fitt???
  160. Shocks and Springs or Coilovers
  161. Feedback on skunk2 full coilovers (pro s, not just the spring kit)
  162. Most comfortable aftermarket susp.
  163. suspension setup question
  164. H&R Race Springs or Megan Racing Coilovers?
  165. Camber kit maxed out and still have bad camber
  166. Rear Suspension Noise on 2003 Honda Accord
  167. Did Blox make different style EK LCA'S
  168. Need some advice on skunk2 springs
  169. UPPER CONTROL ARM PROBLEMS...NEED HELP!!!
  170. What Sway bar will clear a 3Inch exhaust
  171. sway bar question hollow vs solid
  172. Just bought some TEIN S TECH springs and i hate them.Do they fit 99-00??
  173. WILL EF 88-91 CIVIC springs fit EG 92-95 CIVIC ?? HELP
  174. wtf ??Skunk2 Pro S's
  175. Suspension Techniques Front Sway Bar Problems
  176. how do i figure out what kind of coilovers i have??
  177. where can I find skunk2 springs that lower my car 2 inches at most need part #
  178. WARNING: NSX caliper inside!
  179. raised car now it's clunking in the front end
  180. bumpstop ??????
  181. illumnias w/ megan slip overs
  182. gc top hat
  183. Need advice on GC's
  184. How to fix 93 civic dx bushing plus control arm
  185. kyb gr-2 with skunk2 coilovers
  186. SRR suspension
  187. Need help please
  188. URGENT help needed:Suspension Help 00 EX (subframe bolts) Pics
  189. 5 lug conversion rears on front not so much help please
  190. extended top hats install with koni question
  191. Sprint lowering springs
  192. BUDDY CLUB RACING-SPEC DAMPER or TEIN SS COILOVERS!!??
  193. Camber Washer Trick
  194. ITR caliper on civic ex?
  195. axles
  196. Need urgent help with my EK - Function Form Coilovers
  197. Koni Yellow question
  198. DIY COILOVERS ???
  199. tokico illumina question
  200. Suspension Tuning on DC2 with coilovers
  201. extended top hats
  202. piston size????
  203. whats going on?
  204. question on coil overs on my car yeah or nah
  205. Quick Question and Request about suspension
  206. What Tokicos are Red?
  207. skunk 2 ball joints?
  208. ***Trying to figure out suspension***
  209. GC/Koni Question
  210. STEERING PROBLEM!!!
  211. trying to raise car need help
  212. Skunk2 Shocks question
  213. Ej6 front camber kit for 5 lugs. Pics!
  214. coilover preload....
  215. 4 bolt R susp. on EF
  216. 00 Si ASR brace combo question?
  217. air ride suspension
  218. Nex coilovers? how bad are they
  219. 93 CIVIC LX REQUEST FOR BUSHING HELP
  220. Suspension Swap
  221. buddy club n
  222. Need some advise on my suspension
  223. budget setup for 99ex-please input
  224. ******???will shocks blow ???*******
  225. Ef si rear brakes on 93 civic coupe?
  226. How To: Convert power steering to manual
  227. issues with koni struts install
  228. tein basics or gc/koni
  229. sway bar?
  230. Alignment settings
  231. which full coilovers to get?
  232. pic apex
  233. ssr suspension pecies
  234. Help! suspension!
  235. TOKICO HP BLUE AND GC
  236. 95 civic koni yellows GC springs...
  237. spring perches on koni sports????????
  238. D2 and Ksport???
  239. New JDM suspension, check it out
  240. rear camber kit that give less than -2
  241. Popping Sound From Coilover
  242. need help on coilovers
  243. Ground Control on H&R sport cup shocks?
  244. What else to buy to complete installation
  245. skunk2 suspension???
  246. Brembo Brake Caliper Bracket Qs???
  247. dc2 with dc5 brembos?
  248. lowering question
  249. Total noob: Skunk2 pro C help!
  250. Are these Ground Control's for an EG/DC?
